- frst map sensor and edis module
- FRST hunting on idle
- What tyres on 16's?
- Standard Suspension
- RS1800 running ST170 6-speed
- wont boost like it did a month ago?????
- Turbo to radiator hose needed
- croydon fords
- lowered rs turbo fiesta
- act sensor
- rs turbo probs
- Fiesta Carbon Fibre
- whats everyone got against the rs1800?
- brake kit wanted
- what do you think of this?
- RS1800 dipped beam problems
- Fiesta rs1800 2.0l engine conversion.
- Threads asking for Car Stereo codes are not allowed.
- How much
- New to Fords
- driveshaft belt?wtf
- 165 chip, what do i need to change
- msd 225 chip question
- Mk3 Fiesta rear disc conversion (RS2000)
- driveshaft query
- mahle pistons
- please help rs turbo missfire and kangarooing !!SORTED!!
- fiesta rs 1800 electric windows probs
- Very quick question!
- Somthings not right!!!
- Compression Test Results?
- boost presure
- help with calipers brembo
- well all help wud be great on this t3 turbo kits
- injector help????
- Ofab Engine loom wiring HELP !!!
- Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hh help me lads
- well all
- what mods 4 240ish bhp?
- forge actuator
- ofac ofac difference?
- hello, ive just bought a frst.. 1800 zvh H875NVX and started work already..
- Fiesta Turbo Conversion Trouble !!!
- fiesta rs turbo bodywork
- RS1800 - running problems, help appreciated
- New to the Fords
- RS1800, anyone got one chipped/remapped?
- frst wont idle wen at running temp
- fiesta turbo ecu
- Ofac/ofab superchip?
- rs1800 won't idle! help apprieciated
- Fiesta rs turbo ecu anyone!
- rs1800 4-2-1 manifold more problems!
- Fitting 4-2-1 manifold RS1800 problems
- Where can i get Inner Sills for my RS1800
- Fiesta MK3.5 hub and CV problem...need help?
- Side skirt removal on rs1800
- h226 cdx
- How To Adjust Actuator? (Pre-load)
- fitting a new cambelt trouble.
- rs1800 injectors, need help!
- Engine cuts out when i turn the lights on!!!!! HELP!!
- RS1800 idle problem and flat spot, need help!
- Rewiring rev gauge??
- My 1985 Ford Escort GT Turbo...Looking For This Part
- my car wont boost past 0 psi????
- Carbon Bonnet vents
- OMP Roll Cage
- Which tyres to use on standard fiesta rs turbo alloys
- Fiesta t3 conversion help
- Wots the most psi a standard t2 actuator run..
- Fiesta rs turbo tuning help!!!
- Hi, and a few RS1800 Questions.. Sorry!
- EFI Vacuum pipes
- Adjustable rose jointed lower arms
- fiesta rs1800 low down tuning.
- anti roll bar issues
- Help needed t2/t25 gurus please
- FRST Parts (A Few Needed) also some advice.
- mk2 fiesta xr2 5speed: which driveshaft URGENT
- In tank uprated fuel pump...
- water pump 1.2 zetec engine remove & Replace
- mk3 fez
- 1999 Fiesta 1.4 rear brake pipe
- Ford Fiesta Mk6 tail light upgrade
- 2007 3dr Fiesta Zetec Passenger Window Not Working
- MK2 Fiesta RARE part required - can you help?
- 1.25 Zetec power loss.
- fuel rail connector removal
- Drive belt routing
- RS1800 engine into a xr2i-loom help?
- mk3 fiesta sill plate
- Newbie with radio question
- Mk4 Fiesta cl help
- Fuel Surge / Starvation?
- frst
- max power 2.0 zetec bottom end ( turbo with decomp)
- RS1800 with mk5Rs2000 discs on rear
- frst engine loom needed quick
- fiesta rs turbo
- rs1800 misfiring. please help
- newbie needing help
- Is it simple to install a 1.6 zetec engine into a 1.1 fiesta lx?
- FRST Air leak testing
- Electric headlight adjustment problem
- My Fiesta RS1800
- RS 1800 engine issue.
- heater matrix by-pass
- Fiesta MK3.5 1.1 to 1.3 engine conversion, sounds silly but its the run about car
- ECU Pins 3, 23 & 24
- fiesta parts catalogue
- please help me lads!!!!!!!!!!!ahhhhhhhh......
- help me lads!!!!!!
- Fiesta boot won't open.
- Ford fiesta mk4 1.8 zetec
- Fiesta mk4 1.8 Zetec
- Which engine for frst restoration project?
- Fiesta MK7 Colours
- looking for info
- What intercooler? 2.1L ZT Mk5 fiesta conversion
- what you think of this rot then?? and mot man?
- OFAC - Amal Valve
- mk3 fiesta parts...
- FRST + L6 cossie ecu
- FREE Mk3 Fiesta wing mirror & indicators
- Did some work to the Fez today
- FordFiesta 1,1 i 1995 Cold start problem
- Some pics of the Fiesta
- RS1800 rear brake cylinder different to XR2i?
- escort gti wheels
- sun roof leaking, specific questions to answer please
- fiesta st seats
- Fiesta Mk6 clutch
- neeeeeeeed help
- 90 spec recaros into mk5 fiesta
- RS1800 running badly
- fiesta rst steering
- Where can i purchase charge carrier grommets
- HELP PLS Fiesta rs turbo brake load sensor valve
- John colley studios pf magazine feature pics :)
- Zetec s tdci
- cheap low boost zetec turbo?
- Fiesta brake problems
- Fiesta MK6 heater noise
- Fiesta Heater problem
- FRST Fuel Pump
- Will frst rear seats fit a mk2 xr2?
- tripods on fiestas? (posted first in tech forum...)
- Underbonnet padding
- fiesta st hunting help
- Fiesta RS Turbo Beige Injectors
- mk6 fiesta bad vibrations above 50mph
- heated front screen
- Grey trim pieces
- "Sloppy" gearbox - '98 1.3 Fiesta
- mk6 fiesta flame - which engine conversion?
- Mk3 Fiesta Rear quater glasses
- Handbrake adjustment problem
- in need of some help :-(
- Need a rs1800 under bonnet sticker!
- Boot Latch Panel
- H283 GTJ fiesta turbo
- need help fiesta rs 1800
- Engine loom
- fiesta pinking and smoking help
- fezzi mk2
- Retro fitting a Mk6 Fiesta trip computer
- 13x7 wheels: mk3 fiesta
- Rs turbo topmounts??
- MFI to EFI ?
- Proplem with rst mounts into mk1 fiesta
- Temperature gauge not working
- frst inlet air tem sensor req asap
- fiesta rs1800 steering wheel swap
- fiesta rs running lumpy ??? help needed please
- Help to a new member, "ford fiesta 2005 tdci"
- Zvh 1.8 conversion. What bits do I need?
- Mk2 Fiesta side exhaust !! is it legal ??
- rs1800 rebuild
- Rear Wheel Bearing
- which flywheel
- removing rear windows
- starter motor trouble
- HELP
- Other gearbox 1.8 xr2i
- fiesta 1996 speedo
- Fuel line ?
- Mk1 Fiesta rebuild (rs turbo engine)
- Ford Fiesta Mk3 XRV?
- Escort mk5 shocks to Fiesta mk3?
- frst oil breather vac pipe set up
- Favour please
- Anyone Turbo'd an XR2?
- ZVH in a Zetec S??
- Suitable car cover for outside?
- Can someone help with no oil pressure
- Ford accessory tinted rear lights
- Rear disk conversion, which hoses ???
- pic request - fiesta turbo oil breather system
- overheating problem
- ZVH Breather Return
- Fiesta MK7
- XR2i 8v EFI Gearbox???
- over heating problem
- temp question..
- SO i got my Fiesta RST yesterday at last! ONE QUESTION THO
- i only get stickys?
- Omex 600/Ofac wiring scematic
- Fiesta RS Turbo Project (need some help please)
- fiesta van 1.8d
- Fiesta 1.4 zetec
- IGN fuse keeps blowing on MkV (2004) Fiesta
- Wirring sound near aux drive belt on 04 zetec fiesta
- N/S rear 1/4 panel
- Frst backbox
- fiesta turbo ACT sensor
- does anyone re manufacture the FRST green side strips?
- New member
- mk4 fiesta, twitchy backend ??
- Fiesta courier derv running issues
- Broken tilt wires
- Fiesta/Focus ST170
- Air filter for a T3
- Max BHP and PSI
- Racetech gauges
- Fiesta RS1800
- Not a good day at the workshop!
- Losing water!!!
- mk3 fiesta doors HEP!!!!!
- gearbox differences
- mk4 lsd gearboxes
- RS1800 airbox
- ECU and Fuel Pump Problem...
- LSD gearbox on rs2000 block in my FRST
- newbie help
- door cards
- Ashley Exhausts
- swap 1.6 to 1.8/2.0
- mk 1 fiesta wheel fitment?
- Ride Height And Wheels...
- rs1800
- more power
- T3 downpipe
- Fiesta MK3 Lights...
- RS Turbo owners, Fan Switch news!
- do i track my rst or make back to orginal form?
- fiesta mk5 2.0.
- Any body know this rs turbo?
- Convert my Fiesta Mk3...
