- BCS exhaust mk1
- focus rs coilover knocks help??
- focus rs track width
- Kiwi obd and iPhone app
- Focus RS Mk1 Alternator Belt
- help!
- Focus mk1 rs mats
- Door Ajar Light
- Want an rs mk1 I think
- Map Sensor Vacuum Hose
- MK1 RS Brake light?!?!?!
- Mk1 focus rs valves problem. HELP!
- focus rs conrods?
- Focus RS2 AP brakes
- Mk1 power figures
- lightened flywheel
- Brembo dust seal fitting
- Headlight Bulbs
- Does anyone know where to get these hood vents?
- FRS Tuning & Bluefin/Dreamscience Discuss
- Few picks of mine RS.
- door mirrors
- tumbleweeds
- WN53YHU
- Mk1 FRS Injector Flow Rate?
- Focus RS Chassis number
- Threads asking for Car Stereo codes are not allowed.
- Wheel Centre Cap Dimensions
- Focus RS Mk2 tyres
- Carbon front panel trim
- Focus RS Brembo's
- unlocking the digital dash to display tempratur
- RS MK1 Steering shaft
- Best Dump Valve For FRS
- RS Replica Build - Xenon Headlight Help Please
- Comp Test on FRS
- usb stick
- mk1 frs - uprated fuel pump?
- Your running costs...mk1
- clunking when being pout in to gear
- focus rs parts
- MK1 FRS phase 1 and 2
- Needed- Part number for Turbo-cat clamp
- Pic Request: Std DV set on FRS
- Some help/understanding regarding Chargecooler / FMIC
- MK1 RS Gearbox/Clutch ??? Weird Problems
- zsw zs1 wheels, do they fit????
- Rough list of parts needed for 4wd cosworth conversion ??
- Oil Slick!!
- new forge dump valve
- Wing mirror dilema
- Looking for spoiler mk1 focus
- Focus RS Mk1 buying advice
- clutch kits and lightened and balanced flywheels for mk1 focus rs
- Headlight/HID fitting questions
- car throwing up this code
- RS mk1 decat
- focus rs ecu's and mapping
- Revo Knuckle on a Mk1 Focus
- Frs mk2 itg or mountune airbox?Spec r or airtec cooler?
- Blu fin question
- MK1 FRS induction hose for turbo?
- mk1 focus rs= are both fans supposed to come on?
- mk1 focus RS production question
- mk 1 Focus rs engine bay
- mk 1 Focus Rs YC03 YNY
- mk1 frs on pectel t2
- jamsport mk2 focus rs 400hp kit are they any good
- MK2 FRS air boxe/filter change
- mk2 FRS dump valves
- roose hoses where they go
- mk1 rs front bumper width
- Oil feed restrictor
- frs wing mirrors
- mk2 rs clutch issue whilst driving hard
- 3rd rear seat install in rs mk2
- How much boost are you guys running on your standard frs engine+turbo?
- Focus RS 1827
- ecu diffrence's ?
- transit connect rs HELP!!!
- anyone know where i can get........
- mk2 forcus rs are they worth it
- Big Brakes Upgrade Help
- vacuum lines focus rs mk1
- st170 big brake conversion?
- Headlamp Washer Covers
- R5 RST - St Helens
- Are all focus MK1 wish bones the same through the model range.
- Focus RS mk1 cutting out now and then. Any ideas?
- Sorted the aircon today.
- mk1 RS rear discs
- Changing the Thermostat and Thermostat housing frs mk1
- #1479
- Air Con MK2 RS
- Air con diagram Focus Mk 1
- ST170 coilovers on an FRS mk1
- RSOC
- What tyres are the weapon of choice for RS owners.
- De-tango'd my head lights today.
- Sprayed my FMIC and Chrome Grill Satin Black.
- Bought my first every Ford. First ever Focus RS
- oil choice for zetec turbo engine
- FRS mk1 suspension
- How to Open Focus 51 Front and Rear Bumper
- What flywheel for zetec and Focus Rs box?
- focus rs mk1 straight cut gearbox/set
- Will a stnd focus dash fit a focus rs
- Low miles focus rs mk1....
- Ooo another noise?
- Living with a Mk 1 Focus RS?
- Focus rs mk1 oil,what do you guys use?
- MK2 Focus RS's, tuning potential?
- Focus rs throttle body mk1
- Mk1 FRS centre cap diameter??
- Mk2 focus rs clutch
- Focus Auto Gearbox Solenoid "A" Part Number ??
- fRS suspension
- kangarooing
- Wiring id
- Bluetooth
- Rear wheel bearing noises...??
- Custom Single-Din Fascia
- AUX belt tensioner
- I'm sold.
- 'Clunking' Noise When Braking - Help!!
- Newbie question sorry .. . . broken key . . . not found a relevant answer yet
- RS head lights. Had they orange in them.
- fuel tank removal
- Are there any quality aftermarket oil and water pumps for a Foc RS mk1?
- Thinking of buying a 2003 Focus RS mk 1 any help please.
- What exhaust. Mk2 focus RS
- Goodridge Braided Hoses
- GT25R turbo issue! (defo turbo only :D)
- adjustable strut top mounts
- Loosing coolant from the thermostat housing
- S/S exaust cat back - but not too loud??
- 4 small but annoying problems
- Focus RS500
- Pictures of your stereos please
- MK1 FRS Roll bar kits
- Ford Focus MK1 Interior Change
- Dream Science SCT plug and play
- mk1.5 Fuse Box Diagram
- Focus TDCi turbo hissing
- Focus RS did well in this hot hatch shoot out
- Mk2 frs's
- 1999 Focus MK1 Horn Problem
- Mk1 Focus Engine Missing / Loss of Power [1.8 Zetec]
- EGR Valve location 2007 focus 1.8 tdci
- Focus speed governor???....
- ford focus rs mk2 steering wheel hub
- Mk2 ford focus
- 2002 ford Focus
- help!!
- focus mk2
- dus mk1 RS have
- Advice needed with seating in a 51 focus
- the good old noisey cat heat sheild problem!
- Spray Focus MK1 Fascia
- how hard is it to change a cambelt on 1.8 tdci
- Carbon splitter
- Best ever Focus for sale ad!
- help possible clutch problem? Focus RS mk1
- Double Din Depth?
- bang, now lacks power until 60-70 mph
- Rear Wheel Arches Starting To Rust, Repair Or Leave?
- Idle Problem?
- Using focus Rs thermostat housing for turbo water feed
- where can i get this mk2 splitter/skirt
- mk2 tail lights
- Davidhi
- Fitting front fogs to a Focus without them
- Back Wheel Bearing Frs mk1
- Central Locking help 1999 Focus
- New engine or tune what I have?
- rear beam removal
- New to here so Hello :)
- Bluefin FRS mk1
- New Alloys
- 3 button key fob
- 1.6 Zetec to Replace Sigma?
- Removing bumper from focus RS mk1
- alloy wheel nuts
- Tuning a Mk 1 focus RS
- focus interior
- Think it's time to get a rs focus
- Leccy window issue on Mk1.5
- MK1 1.8 Zetec Running Issues
- some pics of my new pride and joy
- 130mm Brembo mounting bracket
- Focus 1.6 2001 issue (fuel related) urgent help please.
- Focus MK 1.5 Wiring Behind Dash
- Please help with my 1.8tdci
- what mpg do most get from 1.8 zetec?
- Thermostat housing.. ??
- Temp gauge not working
- Pro Sport Coilovers....
- 2008+ front and rear bumpers on 2006?
- 2011
- Mk1 focus on comps pics please
- wheels
- Water pump for Focus rs mk1
- 02 wiring
- mk1 focus 1.8 zetec 3 dr
- Tubular manifold...
- Help whats this hose?
- wilwood calipers on focus mk2
- removing dash trim
- Wiring auto-dim mirror into a Mk1
- dreamscience to turn decat light off
- American spec Mk1 rear lights
- Mk1 Focus Brakes
- mk1 focus rs+creative carbon stuff
- wiring diagram
- Focus Hydraulic Tappets
- Upgrading front brakes and rear drums
- Focus rs parts for sale
- loom help
- Exhaust for RS2
- Focus lowering springs
- Ford Focus 1.8 Tuning Ideas Needed!
- Zetec turbo owners.....
- lowering a 2005 ford focus 1.8TDCI 3dr
- possible problems?
- focus mk2 towbar wiring
- 1.6 se tuning
- which of these do i need?
- Focus tdci mk1.5 2004 Gearbox Problem
- Buying Focus RS Engine
- Focus mk2 TDCI instrument upgrade?
- Focus 1.6 engine
- Another weird noise, with video! Aux belt?
- Lights help
- High Emmisions
- Internal blower fan not working
- MK1 Focus RS
- Strange Exhaust Noise Mk1 Focus
- focus ? 4x4
- More Mk1 focus problems!
- Remote Locking Fault
- focus RS MK1 Electrical Fault
- mk1 RS brake pads
- MK1 Focus gauge pods
- Knock heard when reversing
- Focus Projector & HID Help!!
- high powered clutch setups
- focus rs mk1 map
- Focus wheel offset
- Mk1 Focus centre rear seat belt replacement ? ?
- Front disks and pads(Focus RS)
