PDA
View Full Version : Ford Focus RS
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15
  1. would 17"alloys...
  2. central locking not working......
  3. Intermittent wheel wobble???
  4. Buying Advice on a Focus 1.8 zetec (1999)
  5. Mondeo 18's
  6. MK2 Door card removal
  7. Steering Wheel Removal
  8. camber kit
  9. Cams advice
  10. just bought this
  11. rs 7 wheels
  12. focus rs question
  13. RS Focus Front Bumper
  14. Carbon parts
  15. Forge Actuator
  16. MTX-75??
  17. Fiesta st alloys on focus st170????
  18. TIG ART manifold + turbo package
  19. intermediate driveshaft bearing
  20. Are ST170 Calipers the same as Normal Focus Calipers?
  21. front brake shims help please
  22. Focus rear disc conversion.
  23. Diognostic code help
  24. 5dr central locking
  25. BEARING this in mind
  26. st170 internals
  27. question about focus engine
  28. FRS has sprang an oil leek!!
  29. Strut braces for Ford Focus 2.0 TDCI year 2005
  30. Rs focus front splitter
  31. Oil & temp pod!
  32. Focus RS Windscreen, Heated?!
  33. ST170 Shafted
  34. colour code
  35. focus rs radiator fan question??
  36. mk1 focus 1.6 decat?
  37. de cat
  38. st170 mongoose pipe on rs
  39. Drilling Holes in the airbox
  40. I'm Planning to buy a Sub
  41. Air/fuel ratio gauge
  42. AE or AF map
  43. Scangauge for FRS
  44. water and oil gauge for Ford Focus RS
  45. ford focus mk1 having a 2.5 ST engine convertion
  46. Where to get MIL Iliminator?
  47. focus turbo conversion
  48. MK2 bodypanels WRC Anywhere??
  49. imperial blue
  50. Anyone know focus st sf56 ruv
  51. US spec rear lights
  52. 5dr focus
  53. Where to get carbon goodies for FRS?
  54. ST170 Headlamps!!
  55. lowering a focus
  56. How do i remove the st170 fog light bezels?
  57. Zetec 1.8 bhp mod' s
  58. Focus cutting out.
  59. FRS chips?
  60. Focus ST Xenon Headlights
  61. Tuned Focus RS... A13 23rd Jan
  62. Intermitently faulty intermitent wipers
  63. Weight difference in standard/rs doors/bonnet?
  64. Best Stainless steel system for FRS?
  65. help service required.
  66. Focus Tdci
  67. Knocking sound from front and real suspension.
  68. Advice when buying a FRS
  69. wheels offset from FFRS???
  70. Focus RS vented bonnet
  71. leecy mirrors
  72. Help please !
  73. ST170 TB
  74. My frs-a write off
  75. rear brake conversion
  76. 2.0 zetec ITB's
  77. How do i repair the fuel guage on a 99 focus please?
  78. Focus headlights
  79. Rs Focus front knuckle
  80. RS grille badges?
  81. Focus TDCi
  82. fast rack forfocus rs?
  83. Ford focus rs reprogram remote
  84. Problems with FRS front suspension!!
  85. What are FRS rods and pistons good for power wise?
  86. 2003 FRS - wiring for heated front screen standard?
  87. front lower strut brace?
  88. focus 1.6 zetec s under fueling and bad idle
  89. Alright people, Wonder if there is life here??
  90. how to make a focus look nice
  91. focus gear linkages
  92. changed fuel filter now wont start
  93. focus 1.6 zetec
  94. Focus RS Sprang a Leak
  95. conversion from 1.6 se to st170 ?
  96. puma 1.7 tb on 1.6se??
  97. focus Hubs
  98. Pics or Focus lower arms wanted
  99. 1.6 zetec se engine
  100. focus rs brembos, will the fit under 16" wheels
  101. turbo with throttle bodies
  102. what is it worth
  103. Zetec turbo - What is definately needed?
  104. Forge Actuator
  105. Anyone removed FRS ecu module?!
  106. CryO2 from USA for FRS & Cossies
  107. Focus rs tuning
  108. focus 1.6 s engine probs !!!!
  109. focus rs chrome goodies
  110. Very random Q - how does it perform in an accident?
  111. Focus Gear Linkage/Lever Spring?
  112. manifold/decat
  113. cosworth management?
  114. 1.8 zetec speed sensor problem
  115. St170 squealling noise..any ideas?
  116. FRS Custom MAP Vs Bluefin/Dreamscience
  117. cold morning starting problems
  118. whats the best suspension?
  119. focus reving itself
  120. Anyone used RS Tunings remote remap
  121. whats the max power/torque can a std rs head gasket take
  122. wooornig
  123. I want 300bhp
  124. rs focus clutch anyone got any pic's !!!!!
  125. focus 2.0
  126. 4-2-1 manifolds
  127. lowering focus diesel
  128. what power you running in your rs??
  129. MK3 TDCI electric power steering pump
  130. Dump valve
  131. Is this just Ford taking the mick - what would you do?
  132. WANTED N/S hub
  133. What sizw wheels on a frs
  134. tdci engine stopped a few times in rain why??
  135. would this fit?
  136. RS cooling fan?
  137. where can i buy ITB's in europe?
  138. Intermittant wiper upgrade
  139. front mount intercooler help
  140. st 170 piper ultimate road cam?
  141. how to put turbo on 1.8 zetec?
  142. focus rs pistons?
  143. Injectors
  144. Fuel pump for zetec turbo
  145. Escort/FRS off set
  146. conversion from 1.4 to 2.0
  147. Suspected bad petrol causing problems
  148. Warning for the uninitiated!
  149. focus rs parts?
  150. ST170 Brakes..
  151. experience with bluefins?
  152. Focus stereo
  153. Wheel Question.
  154. Focus doors??
  155. Need a clutch and flywheel
  156. comparison with st170 and focus rs head
  157. 1/4 Mile times
  158. Rs Wheels On St170??????
  159. Which Focus?
  160. HELP - headunit fuse - ford focus - mk1
  161. ECT Sensor 01 Focus
  162. focus estate Seal / chassis
  163. Focus RS Track Cars?
  164. focus rs bhp?
  165. Rs Brembo's
  166. Does the Focus RS have different rear fog/reverse lights...
  167. Zetec+st170
  168. new lights
  169. cosworth escort drive train in a focus?
  170. Focus ST engine into early focus
  171. focus rs cambelt change
  172. Running Costs of FRS
  173. zetec se
  174. FRS, problem
  175. St170 B&M shifter?
  176. water leak
  177. Bonnet Raisers
  178. bluefin troubles
  179. Focus HID self levelling?
  180. Focus Front Grille
  181. RS Headlights onto Mk1
  182. frs rear quater
  183. focus rs
  184. .U.S. focus rear lights (hatchback)
  185. bbs crew ??
  186. ecu diagnostics
  187. Focus RS Engine Mods?
  188. head gasket
  189. tank problem!!
  190. rs parts wanted
  191. focus speedo
  192. Mk1 focus st170 tax band
  193. focus springs
  194. FRS Sparco pedal sets?
  195. Focus Rs strut brace!!!!
  196. Gearbox limit
  197. sideskirts wrc replica
  198. Focus RS turbo brakes, discs, will they fit a KA?
  199. Help!! Anyone fitted .U.S. rear lights!!
  200. Focus rs Cd player
  201. rs2009 for london motorshow
  202. Carbon Bonet Ford Focus
  203. K&N filter
  204. focus bonnet raisers
  205. knocking comingfrom boot
  206. Setting TDC on the vp30 fuel injection pump
  207. Changeing A Cv Boot On A Focus
  208. How do you change the front sidelights?
  209. New Car
  210. Remapping
  211. ST Springs
  212. frs help..major problem
  213. Brake Pads
  214. frs newbie
  215. Focus ST auxillary Pod
  216. what cam? blacktop turbo...
  217. Knock, Knock. Who's There??
  218. wheel size's for a focus st170
  219. focus ABS
  220. *** Dr. Colorchip Group Buy ***
  221. engine swop
  222. Chipped UK/ Paramount Performance / Angel Tuning - REMAPS
  223. Focus RS power
  224. RS tuning!
  225. would a st170 head fit my silver top zetec?
  226. water temp to high !!! no boost
  227. changing hubs
  228. De-Cat & Eng Management Light
  229. Why should i spend £6000 on a ford
  230. FRS wheels
  231. Wheel question
  232. New Focus RS Forum
  233. My sig
  234. this forum
  235. Thread size
  236. focus rs superchip
  237. New Focus Rs Spy Vid
  238. Focus RS wheels on an ST170.... Do they fit?
  239. rsoc still down then....
  240. FFS
  241. what's happened to the rsoc??
  242. Boo
  243. Turbo water feed.. Focus Turbo
  244. just sold my evo and bought a focus RS#684
  245. RS Carbon Fins?
  246. FRS Keyrings
  247. my graph for you to see
  248. My 2003 FRS
  249. St170 manifold
  250. FRS Boost problem.
