- focus coilovers
- focus rs external wastegate and sceamer pipe
- Any 1 Done This??
- cd player please help
- new seats
- Focus RS 300bhp
- factory sunroof upgrade
- DIY work on FRS
- St170 Brakes Question
- what calipers fit the st170 hubs?
- focus rs con rod bolt part numbers please :)
- focus fog lights.
- st170 audio help
- Focus RS Electronics
- Difference between Focus RS and Focus Zetec box?
- TomEbbs Progress Thread
- ID help
- Focus RS Turbo/exh manifold questions..
- ST170 vs 1.6 Focus Engine
- 02 RS
- Key Code???
- wots the best bodtkit for the focus
- focus rs bumper inserts needed
- DPF problems on Focus
- st170 fog lamps
- Ford Focus zetec wheels in grey?
- Rear drum-disc conversion
- Good afternoon ;)
- Help please focus st170
- focus headlights
- Ford Focus 1.4 FXDA Water Temp. Sensor
- Megasquirt ECU or similar ECU
- Puma engine in mk1 focus??
- Steering wheel out of line
- can i adjust turbo on my 1.8 tdi focus
- Focus 4 Dr Saloon Rear Heater
- quick question baout FRS boost and power
- what is
- Focus Zetec 1.6 cold start problems
- 18x9 on a focus RS rep.
- focus wheel arch rust need help
- Focus 56 plate door card removal
- focus rear trailing arm bush
- Ford focus 1.4 low power misfire
- Ford Focus 02 1.6 Zetec Limited Edition
- Clutch bleeding...
- New Boy here
- ST170 Headlights in a mk1 focus?
- can somebody tell me how the radio housing come's off?
- Focus 2005 Help plz
- St170 gear selector problems!!
- 19" S-Max wheels
- 2.0 TDCI Bad mpg?
- New Focus Diesel Glowplug symbol
- Window Tint
- ford focus 1600 se injectors
- interior light issue LED
- Focus gear lever
- the cost of tuning a frs?
- cam options
- Cam Quest
- heated rear screen
- Focus MAF
- Focus RS spark plugs
- its jontys focus ink
- st170 brake upgrade..
- st170 wheel offset..
- Focus Central Locking
- best focus manifold option
- Newbie question
- My new intercooler!
- Focus Help
- how low can you go before problems
- st170 tyre sizes
- focus driveshafts
- post deleted?
- 2003 ST170 Lighting Problem
- Focus RS turbo wanted *Please*
- Very fast help needed
- Fast help needed please relpy
- anyone got some vents for they bonnet?
- require torque setting
- Mk2 ST snowflake alloys..
- Focus RS Mk1
- few questions
- 2litre throttle body
- k and n induction
- Labeled Illustrations of Fiesta Components.
- st170 brake upgrade (bearings gone??)
- Focus mk1 1.8 fuel surge problems???
- decating the focus
- bonnet struts on focus
- newbee advice
- Focus 05 - Headlight Bulb replacement
- Stolen - Focus RS Seats
- brake upgrade
- wanted - original Ford Rims
- 2003 Focus ABS
- seat cover, rims for Focus MK2
- Central Locking Help
- Focus ST170, *PROBLEM SORTED*
- electric mirrors
- clutch spring
- Few problems
- where do you buy all your "shiny bits" from
- 2.0 focus fueling problem??????????
- 03 shape RS or st170
- ST170 Engine Management Light No DTC
- engine swap
- may seem like a silly question but
- mk1 Focus RS flex pipe, in brand new condition.
- Lights/bulbs
- help needed
- focus rs oil return?????
- bluefin what is it?
- does any1 no my car?
- Custom Remap Focus ST225
- ST170 price....
- Which K & N induction kit?
- Focus RS mk2 wheels on Focus ST?
- Focus Gear Stick
- best place to get wires from engine bay to inside
- Set up??
- will this work as an itb set up?
- just bought a focus "silver" help please
- mk1 focus 1.6 poor idle
- 02 plate focus wing removal
- FRS Induction Kit Any Good???
- whos got the most power out of a 1.8?
- frs alloys
- New spain and question!
- whos car is this? and whats the rear bumper?
- Standard Sony 6 disk HU + Sub?
- Jamsport Mk2 FRS website
- focus rs offset
- Focus 1.8 zetec turbo conversion
- help on the zetec turbo conversion
- Injectors
- Heater Fan Speed not working FRS
- focus tail lights and dash lights not working
- focus poly bushes for wishbones
- focus underneth exshaust heatsheild removal
- Conrod specs for Focus RS and Zetec.. please
- does anyone know this car? 400hp 26k
- Engine management light
- heated front screen st170?
- Boost Problems RS Focus MK1..Help Please!
- focus rs mk1
- 06 2.0 TDCi oil leak?
- A how to thread?
- Will a Focus CC front bumper fit a Mk2?
- BLACK(!) MK2 RS in this month's Fast Ford
- Electrics
- focus rs ap clutch.... help!!!
- AMD Technik
- Focus HID's
- Focus climate control
- Trip computer issue
- What turbo did the mk1 Focus RS come with and how much power is it good for?
- The Joys Of Water
- ex police ford focus
- focus engine will it start
- Focus trip meter panel still lit when cars turned off/locked
- engine upgrade in 1.6 focus
- maf
- FOCUS 1.8 TDCI Smart charge system help!
- 2006 Ford Focus 1.6 idle
- Focus Fusebox
- rear stabilizer bush
- Standard FRS actuator
- What are these wheels?
- focus sound system wiring info needed
- rear bumper lower section
- to sell or not to sell
- focus suspension kit and wheels
- camber on focus
- alloy intercooler pipes
- Airbox
- How can I identify 1.6 engine?
- Few focus questions
- will a 1.6 exhaust fit onto my 1.8
- high compression zetec engine build info needed
- [MK1] 4-1 or 4-2-1 manifold @ Ebay ?
- gearbox
- focus rs turbo time!!!
- George David Engine problem...cutout
- trim
- changing focus front fog lights
- Ford Focus (europe) 2.0i ESP (2000) TCS light after brake/disk replacement
- mk2 focus towbar electrics ??
- 2000 Focus overheating while driving but ok when Idle or stuck in traffic
- Focus - almost cuts out. ***FIXED***
- Search is on
- focus rs clock help!!
- Anyone running Compomotive Mo Alloys?
- help modifying 1.8 tdci 115....what can i do other than re-map???
- focus 1.6 coilovers
- Focus RS service manual
- ecu
- focus link arm bushes
- how strong is it?
- water junction box?
- Focus ST170 Acceleration Problem
- focus rs manifold??
- GEM wont go into learning mode.
- gear stick linkage adjusting
- upgrade site for st170
- Remote Central Locking
- Whitter Tow Bar on mk2 focus
- stupid question!!!!!
- zetec e in focus mk1
- Ultimate Green paintwork
- Looking for RS Focus NSF Door in Ultimate Green
- Buying a 2nd hand Focus
- rs brakes on a 1.6 focus
- Decent Dyno in SouthWest
- focus wheels
- rs turbo engine focus
- ST170 Gearbox in the RS!
- passenger airbag
- Focus 1.8
- ac filter
- need help pls
- Mantainence to a fous
- steering follows every groove in the road
- noise from focus 1.6
- ST170 suspension
- ST170 Miss-fire
- Ford Focus 1.8 Zetec power loss/stuttering issue
- Fault Code P0047
- another problem!
- Footwell Lights
- ford focus st170 timing
- where to get st 5cyl pistons from
- focus 1.6 zetek?
- ESP light ON in Focus ST225
- st170 rear suspension
- NEW Focus Breaking !
- Rattling sound???
- Focus RS parts for sale on ebay have a look
- Blown inlet RS Focus MK2
- 2.0 blacktop cams
- ST170 Turbo - Engine Bearings Issue
- Pro's and con's of Bluefin vs Dream science chip/re-maps
- ST170 Intermitently hesitant under acceleration
- Focus 1.8 and 2.0 info
- 1999 Focus ABS Control Unit which output for OS and NS rear brakes
- Charge cooler or swap to FMIC????
- Lumpy idle
- ARP Bolts for the Mk2 Focus RS or ST225
