PDA
View Full Version : Ford Focus RS
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15
  1. Focus II 2.0 Duratec flywheel
  2. ST170 Plugs & Engine oil for sale
  3. Help/Advice needed!!!
  4. Eco-Tec Valve CB-26P
  5. Changing front grill
  6. ST170 Clutch & Flywheel advice
  7. rear spliter
  8. mondeo st24 hubs the same as st170 hubs?
  9. Ford Focus TDi heater blower problem
  10. Ford Focus MK2 Woes
  11. Car/wheel ramps???????
  12. Shock absorbers, Focus RS MK1
  13. Focus RS Master brake cylinder
  14. fitting mk1 focus rs engine into escort mk4 rs turbo s2
  15. ST 170 tyre issue
  16. Hub Nut Size On A Focus Mk1
  17. loads of focus parts for sale
  18. st170 manifold heat shield
  19. manifold and lambda trouble
  20. goodridge brake line kit - 4 or 6 pieces
  21. Can you fit a 2.0 litre zetec focus engine in a 1.6 focus zetec
  22. Heater only works on setting 4???
  23. aftermarket headunit help
  24. Engines To Go In FRS mk1...
  25. Manual Bosst Controller
  26. Focus RS Engine Wiring diagram
  27. Headlamp Replacement
  28. blueflame
  29. just tried fitting dump valve
  30. ST170 Tyre Pressures?
  31. focus coilovers
  32. big problem need help
  33. ST170 Aftermarket Manifold + Cat advice.
  34. St170 instrument cluster fault
  35. Focus RS running gear
  36. ABS or No ABS?
  37. Location Of Footwell Lights On 2003 Focus
  38. Knockin Noise???
  39. EBC or Black Diamond? - ST170
  40. Strange Sound Coming From Front Of Car
  41. scorpion pipe anyone got one ?
  42. Problem opening electric rear window
  43. ford focus with a 35mm drop
  44. Plz Plz Plz help badly need a water pump
  45. 2005 Focus Mileage and Radio Lights
  46. which dump valve??
  47. MK1 RS Brembo set up
  48. American FoCos?
  49. Focus BTCC Bits !!
  50. talk about the un-thinkable
  51. Just bought a FRS and after some advice please.....
  52. mk2 Ford Focus 1.6 Sport
  53. Changing head light bulbs dip in focus tdci 04 help..
  54. Frs #0910 - pf52 h#u.......
  55. ST170 Back Box Upgrade
  56. New RS focus
  57. focus rs mk1 driveshafts
  58. Does a 2.0 head fit a 1.8?
  59. radiators
  60. ST170 Discs: EBC Ultimax, Turbogroove or something else
  61. Rear wiper not owrking, fuse? or motor??
  62. focus powersteering rack
  63. airbox compatability
  64. Focus mk1 debadged grille, do they work?
  65. ST170 Thermostat Plug Leak
  66. St170 instrument cluster "earth"
  67. Focus tdci headlight bulbs and sidelights, which h7??
  68. st170 OIL TEMP/PRESSURE GAUGES INTO NON ST....
  69. Rear seats question
  70. focus leather seats
  71. manifold?
  72. Question About ESP on Mk1 Focus TDCI Ghia?
  73. WRC bonnet vents?
  74. How To Improve MPG on ST170
  75. ST170 Advice!
  76. ST170 De-badge Grille
  77. ST170 Brake Discs & Pads
  78. Xenon Problem
  79. Slight Rust Around Ghia Tailgate Chrome Trim, How To Prevent Getting Worse?
  80. whats it worth
  81. Focus TDCI decat
  82. St170 leather repair
  83. Ford Focus MK2 PAS High Pressure Line
  84. urgent help please
  85. Mk1 Focus RS engine
  86. focus cl remote locking help
  87. FRS Starting / Idle problem
  88. FRS Breaking problem
  89. Focus 1.8 tdci error P0257
  90. focus 1999 2.0 ghia Mileage trip issue
  91. st170 chips/remaps
  92. Spotted : mk2 Focus RS green with carbon bonnet?
  93. droning noise from rear sounds like bearings - NOT
  94. Thermostat - pattern part problems
  95. Focus tdci 04 to chip or not to chip??
  96. 1998 focus engine change
  97. ABS llight
  98. st170 steering rack on 1.8 focus zetec
  99. part number for
  100. Sticky Throttle
  101. Focus rs mk1 rear slam panel
  102. ford focus
  103. st170 ehaust????
  104. ST170 won't rev above 5000rpm under load now fixed
  105. Focus RS mk2
  106. St170 wheel centre removal
  107. St170 cluster removal
  108. what can the problem be with my focus diesel 1.8
  109. Help with 2.0 Tdci
  110. can any 1 help
  111. What Would You Do With My Car?
  112. Focus ST3 Towbar
  113. Water in passenger footwell of my FRS
  114. st170 induction
  115. Bigger ST170 flexi???
  116. focus diesel non starter
  117. O/S Rears Door central locking problem?
  118. Focus MK1 rear window sunblind
  119. mk1 focus rs tuning options
  120. problem with blown/leaking intercooler mk1 rs
  121. What is the best remap?
  122. Can anybody give me step by step instructions fitting coilovers to a mk1?
  123. Solid flywheel conversion issues!
  124. 04 ST170 - sidelight bulbs
  125. Service quest
  126. Focus RS Mk1 - Brake problem.... sort of?
  127. Engine stutters when accelerating
  128. Mk 2 Focus RS key fob
  129. How do you fit TURBO TIMER to FRS?
  130. 2.0 zetec turbo conversion
  131. focus rs;what to look for when buying.
  132. Focus mk1 coilovers
  133. easy cheep but effective focus 1.8 tdci mods
  134. Buying a Focus!
  135. focus 1.6 sports cat and manifold
  136. problem with idle on focus rs.
  137. ford focus mk1 trip computer ouside temp sensor where is it ?
  138. jet help
  139. Failed power sterring pump
  140. bluefin help
  141. seats
  142. Water Pump
  143. FRS Mk1 Wheels
  144. focus 1.6 16v blowing bateries
  145. focus 1.8 problem,.. coolant temp sensor.....
  146. Brake light fuse on '02 focus TD???
  147. torque setting on hub nut?
  148. Billet Alternator Belt Tensioner Pulley/underdrive pulley
  149. Mk1 Focus Audio - Advice needed on basic upgrade please
  150. Aftermarket ECU on N/A?!
  151. Frs normal water temp
  152. Long Lost Car
  153. Focus USA rear lights help!
  154. Heater Resistor Pack
  155. FRS K&N Gen 2
  156. Too many car modles
  157. Changing the radio
  158. DSI IMRC P1518 Photos
  159. Focus Mk1 Door Mouldings/ Rubbing Strips..
  160. ASBO
  161. good mods that can be done to the 1.8 zetec?
  162. mk1.5 tdci sport.....help!
  163. Do these coilovers adjust on the rear?
  164. zetec 1600 se injectors
  165. can sum1 tell me if this is the correct
  166. Focus 1.8 tdi ghia
  167. error code help
  168. New lad
  169. ST170 injectors
  170. Focus Door Card
  171. strange noise
  172. hi newbie here!!
  173. 07 st footwell light bulbs
  174. ST170 Sits 0.5" lower one side....
  175. RS Spoiler
  176. St170 Cat help needed
  177. I need help with my sick frs
  178. rs focus mk 1 pads?
  179. Decat pipe
  180. Focus ST2
  181. Cat Back 2 1/2" Cat back Vortex exhaust system
  182. Problem with ESP FORD FOCUS
  183. Inlet manifold/Throttle body on a 1.8
  184. 1.8 to 2.0 conversion?
  185. Sony
  186. does ne1 no focus RS tyre size?
  187. Buying guide on 02 focus RS
  188. heater blower resistor
  189. focus -Heater Stopped
  190. st170 fuel pump replacement?
  191. 2004 Ford Focus ST 170 in Silver. (3 dr)
  192. focus rs replica??
  193. Xenon Bulbs
  194. Focus Central Locking issue
  195. T reg Focus 1.8 - heater failure
  196. focus help
  197. Coilpack and leads.
  198. Fuse keeps blowing! No. 32
  199. bWANTED, 1800 airbox
  200. focus rs clutch
  201. ive just been to ford :(
  202. Temperature sensor
  203. 2005 st170 loss of power
  204. would i be better off
  205. Thinking about putting my focus up for sale
  206. Focus Wheel Bearing
  207. How to fit new side indicator light
  208. Engine codes
  209. St170 Problems!! PLEASE HELP :(
  210. MkII Focus RS Big tyre
  211. 1.8 VS st 170
  212. high mileage rs ?
  213. Suspension and vehicle set up some specialised advice required.
  214. 2007 Focus Angel Eye / Halo Rings
  215. NEED HELP!
  216. Best RR and place for Remaps
  217. IS the previous owner of Focus RS mk1 no 3339 reg ND03 YKS on here?
  218. Focus TDCi - lowering
  219. non starter
  220. 2.0 esp performance mods..
  221. 2000 Zetec going for scrappage
  222. throttle body upgrade
  223. focus rs seat covers
  224. focus componants size?
  225. oil in 1600 se ans pollen filter
  226. 2l esp being a guttsy mofo
  227. Number Plate T400 FRS
  228. focus rs mk1 rear hubs needed urgently!!!!!!!!!
  229. Does Any 1 Have a Coloured Cam Cover??
  230. Fuel Issue...Adulterated Gasoline
  231. oil temp and pessure gauge
  232. Serpentine Belt/Steering Rack Question
  233. ST170 Leather recaro seats into TDCi Sport....
  234. ST170- New Discs, pads and fluid (front and rear), Opinions please.
  235. WRC rear boot spoiler - Help needed
  236. 5 stud conversion
  237. Battery warning light - Heated front window problem
  238. 1.8 tdi turbo change......
  239. focus & mondeo (Silvertop & Blacktop) conrod pics
  240. Lambda sensor quest
  241. Pulley options!!
  242. Heat Wrap - ST170
  243. Rear footwell wet on MK2 hatch 5door
  244. Newbie
  245. Blaupunkt satnav cd
  246. Instrument Panel - Information Display / Cluster
  247. Introduction and whinge
  248. 1.4 for 1.6
  249. ahhhh, tips needed for rear brake hose!
  250. RooseMotorsport Hoses
