PDA
View Full Version : Ford Focus RS
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15
  1. Focus c-max engine coolant sensor
  2. Restrictor valve in coolant hose
  3. Ford Newbie
  4. Engine swap??
  5. 1.8 s reg focus- advice please
  6. Focus Rs need new turbo
  7. 2.0 Block/bottom end
  8. Zetec S/Se compatability
  9. Ford timing tool
  10. fuel additive
  11. Engine Management Light
  12. mk1 focus help???? PLEASE
  13. FRS charge cooler mounts
  14. focus rs rolling shell wanted
  15. delete
  16. focus 1.4 zetec help
  17. ford focus shock absorber gaiter
  18. any spare ford fair stand passes?
  19. ST170 Accelerater stuck open !
  20. FRS. Front bumper removal... Mk1
  21. MK 1 Focus Ghia - Rear Window Mechanism
  22. St170 Power Steering pipe...
  23. side bump strips
  24. ST170 cat bracket *
  25. Mk1 Focus RS Hybrid
  26. Exhaust Heat Shield
  27. ST170 Accelerator Cable Problem
  28. Swaps if any ones knows mk1 focus
  29. st170 wheel bearings
  30. Whats next??
  31. Rough Idling??
  32. FRS gearbox strength
  33. clutch
  34. Ford Focus 1.8i 2000 pulls to the left
  35. fault code on st170
  36. brake pipes
  37. Pads for Focus RS MK1
  38. 1.8 51 plate Focus Zetec....
  39. To buy or not to buy 2010 Ford Focus for $16,242?
  40. Getting the bumper off a Mk1.5 focus
  41. Focus RS Gearbox?
  42. EGR Valve on a Focus Mk1 Petrol??
  43. Focus werx spoiler fitted
  44. what do you think, or what would you do
  45. Wideband Lambda location FRS
  46. unsure what exhaust to go for advise?
  47. My ST170 trip to Vercors - France
  48. focus 2.0 esp pics date:17/7/10 + mods list
  49. child locks
  50. Time for abit more power
  51. 2.0 Blacktop questions
  52. Loss of power
  53. Ported and polished 1.8 blacktop zetec head
  54. Fitting 2.0 engine
  55. newbie on this forum but a newbie to some people
  56. mk2 speaker sizes please
  57. Focus RS mk1 Drive Shafts
  58. Newbie saying hello!!!
  59. auto dim rear view mirror
  60. electric windows
  61. Tuning Boxes for Focus TDCI 1.8 115bhp
  62. Smelly upon starting
  63. can you get a...
  64. anyone had this code
  65. ford focus estate breaking
  66. Turbo Mk1 Focus
  67. more info on this please
  68. mk1 focus buying advice wanted
  69. Focus rs brakes
  70. wheel bearing
  71. recommended st170 performance mods
  72. tuning mk1 rs
  73. ratttlee
  74. Focus ST spare wheel?
  75. My Focus Project....(06.07.10)
  76. A big hello from a newbie who needs some HELP or advise with his Focus.
  77. Replacing 6006E 6 CD Player Focus Questions?
  78. odd problem focus auto
  79. Focus werx boot spoiler
  80. Picture request: focus mk1 on coilovers
  81. focus lambda question
  82. FK Coilovers
  83. Best Plugs and Leads - 1.8 Zetec
  84. Steering Problem
  85. FRS Sparco Seats.
  86. best oil for mk1, different to standard spec.
  87. Tdci tuning box mondeo/focus
  88. new rs mk2
  89. Ford Focus MK1 Engine Swap
  90. Exhaust help pleasse???
  91. Focus RS mk1 Gearbox oil
  92. FMIC v Uprated Pre-Rad
  93. FRS mk1 gearbox?
  94. 1.8 2002 4 Dr Saloon Wiper Bottle
  95. Anyone got FFOC membership?
  96. Focus TDCI starting problems !!
  97. 52 reg focus 1.6 engine swap no fuel
  98. ecu query
  99. ST170 rubbing noise intermittent?
  100. mk1 rs, burst water pipe.
  101. ST 170 Springs, advice needed please
  102. Multi-Spoke Wheels..??
  103. Side skirts
  104. power stering rack
  105. Rs owner! Again
  106. anybody got shop manuals for the foci?
  107. K&N Induction kit.... with Cold air feed...HELP??
  108. Ford focus 1.6 Zetec SE..... what can i do?? HEHE
  109. MK2 RS Fuel Consumption
  110. Mk1 Focus Water Leak?
  111. removing mirror covers on mk1
  112. focus with cvh turbo engine??
  113. focus st170 vvt problem
  114. 1998 focus 1.8 zetec Help Me Please
  115. Removing a/c, any help?
  116. st170 oil cooler leaking...?
  117. mk1 wheel bearing
  118. 1.8TDCI 2002. Thrust bearing.
  119. Instrument cluster gone mad
  120. focus engine cover
  121. 1.8 Performance
  122. usa spec rear lights
  123. anyone got any pics of their mk1 focus rs on non-standard wheels??
  124. what you think of these alloys
  125. what kind OBD connection does tdci focus has?
  126. 2008 focus 1.6 zetec towing electrics indicator problem
  127. Focus MK1.5 EGR Bodykit
  128. tdci cutting out
  129. mk1 focus RS.. Problems??
  130. Changing ST170 xenon bulbs?
  131. focus tdci sport
  132. Clutch upgrade on mk1 1.8
  133. mk1 FRS TURBO HEAT SHIELD BROKEN
  134. 12mm Bolts for Mondeo Calipers
  135. ST170 Back On The Road *Verdict*
  136. WRC bonnet mk2
  137. Rough idle, reving between gears, Help!
  138. lsd for focus 2.0
  139. st170 warning lights
  140. remote central lockling
  141. focus rs transplant help
  142. clonk or knock when plling away
  143. fault code P0001
  144. Towbar confusion
  145. Ford Focus Car Mats..
  146. drive shaft
  147. Mk2.5 offset?
  148. Lowering the focus
  149. Focus RS throttle cable
  150. Help on adding a little more power
  151. Focus ST - Fitting an Auto Dim Mirror
  152. can i use a 1.6 gearbox in my 1.8 mk1
  153. Speedo, clock and radio backlight
  154. front calliper's..
  155. focus st 2 problem
  156. ST170 Fog light bulb
  157. focus st 2 rear side window covers ??????
  158. St170..knocking under drivers side
  159. Problems Replacing Front Lower Arms
  160. Focus rs mk2 seat covers.
  161. Help on my wheel offset please
  162. Focus RS MK1 Misfire
  163. New Here, Need Advice & Plans
  164. Cataltyic Problem
  165. Focus Diesel
  166. lightened flywheel
  167. immobilser pats,
  168. question on st170??
  169. Mk II Focus flat blade wipers
  170. Oil for MK1 Focus RS engine?
  171. anyone know what this is?
  172. immobiliser stuck on!
  173. just after sum advice really
  174. PD Ceramic White Mani & GT25 Hybrid Ebay
  175. focus rs2 1 week old losing boost pressure
  176. Temprature issues.
  177. Radio/cd and dash display fault linked?
  178. Flat Diesel Focus Sport
  179. turboing a focus
  180. st 220 engine and gearbox
  181. Exhaust heat wrap tape
  182. ST170 suspension on 2.0 ESP
  183. focus 2l clutch upgrade help
  184. 5 stud ford alloys 17"
  185. focus on cold start
  186. Mk1 focus RS turbo
  187. Thermostat Housing
  188. plz help me
  189. Flat Focus TDCI Sport
  190. Stuff on Ebay
  191. miltek
  192. focus mk1 loose noisy doorcards.
  193. Focus RS Denso Plug Type???
  194. prepare for holidays?
  195. how do i change the rear brake pads on focus 18tdci
  196. push button start conversion
  197. Toyo T1R -or- Hankook Ventus V12
  198. Focus ST spoiler brake light
  199. St 170 tuning........
  200. FOCUS ST performance upgrades
  201. face lift st defuser
  202. engine management light...
  203. Difference between manifolds
  204. focus 2002 1.8tdci running problem
  205. 2 Faults on a Focus RS
  206. Help...?
  207. Focus RS500 from RS500.com
  208. Pic or photoshop request please !!!!!
  209. focus wheels+suspension
  210. Need part no. of Focus RS MK1 Turbo Garrett GT2560
  211. sport's cat
  212. LCR splitter
  213. Ford radio navi dvd
  214. 50mm2 in a st170
  215. Rear electric window For focus Ghia
  216. St170 manifold and system onto a 1.8
  217. ebc rears
  218. RS focus sump...........same as a st170??
  219. LPG for under £500?
  220. Whos got a mk1 focus st170
  221. can somebody help please
  222. 65mm throttle body on 2.0 ghia
  223. Ford Focus ST 19" alloys
  224. When to change timing belt/chain
  225. 2006 mk2 1.6
  226. plug problems with my focus rs.........what do you guys use/suggest?
  227. Focus ST - intercooler
  228. Focus engine change???
  229. Focus genuine parts
  230. fuel filler pipe change..
  231. focus rs
  232. cd changer question
  233. Wiring Loom
  234. 2.0 ghia vs 2.0 st170
  235. Focus Steering Help Needed
  236. Interior change
  237. Some pics of my RS @ the pod
  238. st170 front brakes help
  239. Some direction needed...
  240. ford focus help
  241. Colour coding
  242. Car Vibrates when doing over 70mph
  243. ST170 Fuel Filter
  244. Standard head unit problems, new head unit questions.
  245. Distance between strut tops
  246. focus st170 upgrade, ABS SENSOR
  247. Newbie
  248. Ford Focus ST170
  249. gauge sweep
  250. focus rs interior wear
