- doh! (twin 45's)
- Sierra Mk2 rear lights, Saph and Hatch different?
- Sapphire Door Strips
- 3Dr side exit exhaust fabrication
- Wiring questions
- sierra sapp cosworth
- Head rest removal
- Cosworth 4x4 rainbow cloth?
- 2wd saph running issues
- Boost and idle promlem one for a cossie god
- Bonnet pins / Aerocatches
- t5 4th gear problem
- Dimensions of a Saph cossie front foglight?
- My p100 tell me what you think
- Pics upload small
- swirl pot mounting 3dr
- Lambda sensor thread on cossie?
- 4wd plenum
- saff bumper brackets
- gaz gold set up ??
- ABS wiring loom grommit
- doors on 3door help
- New Fuel System Goodies
- brake upgrade
- Sierra 2.8 metering head and injectors
- Wasted spark
- Bleeding brake valve on sapphire 2wd
- What clutch for 400bhp?
- 4x4 side repeaters?
- Sun roof on a 3 dr
- Mountune YB-cams
- cosworth tie rod ends
- saph heater matrix
- On a saph, what do you call the black metal part nearest the bulkhead?
- Sapphire Cosworth idle problems, tickover lumpy. HELP!!!
- valve spring qestion?
- Sierra estate suspension
- billit fuel rails with retaining clips
- What actuator for gt30?
- Air In The Cooling System
- 2WD vs 4WD Front Wheel Hubs
- Recaro seats swop
- Fiberglass 3 door kit suppliers?
- T5 shifter
- AGPR 902P or denso irridium IK27
- P100 2.9 v6
- Cylinder head testing
- Bara gearbox rebuilds
- Aux water hose kit - oil modine
- lowering compression
- Pro alloy breather/mirror image
- Granada front hubs same as 3dr cossie ones
- Rocker cover gasket, whats best?
- ABS sensor/Brake wear sensor front suspension strut clip?
- Searching piston & longer rod packet (YB)
- 2wd petrol flap gasket
- Cosworth YB 2WD – Coolant system
- Front hubs
- general engine loom questions
- 3dr ignition switch cable
- 4x4 saph front springs
- ECU indentification
- Gearbox mount thread
- can a cosworth water pump be rebuilt
- GT30 water feed piping advice
- cosworth v's xr4i front shocks
- Standard Rev counter in 2WD Saph
- 2.0 dhoc turbo???
- saff cossie 4x4.T3 turbo
- Alternator Issue ?? I'm puzzled
- Flushing the full system on a 4x4
- Airtec intercooler
- Fuel Pipe leakage
- skirt rivets
- differential
- 2wd ecu on 4wd car
- Waterhose size
- Where is this wire/connector for in my Cosworth??
- Dead Turbo...
- Cosworth exhaust manifold to elbow gasket
- saff cossie door mirrors
- prefrences on cone or performane panel filter??
- Sapphire battery clamp
- Hex prop donut
- A17 AHF white saff, upto2001???
- air filter housing diffrence
- 2wd rear caliper thread size
- Saff Cossy ?? Dead or alive
- Sticky caliper
- struggling to start??
- Coilpack location ideas?
- help! need wiring loom grommet...
- Which fuse for central locking??
- What disks and pads????
- 2wd saph diff
- difficult gear change 4x4
- rev counter and fuel guage problem
- sapphire indicator lense
- 4x4 Suspension
- Turbo Damber - Fitting Problem
- Can someone that actually knows clear this up for me?(front diff removal)
- 4 pot calipers
- Rebuilding rear calipers
- 3 Dr bumper question
- saff headlight wash wipe
- Gear gaiter
- What's the deal with Cosworth ABS Sensors?
- diff mount ?
- where to get used rims
- Heater Matrix on a sapph?
- Bad vibrations
- Rebuilt Kit for MT75
- 6 Degree Rear Beams
- 2 x Screws for the rear of a 3 Door roof lining?
- moonstone 3 door, registration D36NWL
- Red inner wing clip
- RS500 T4 or Escort T34
- 3dr fitting kit
- How to replace original Sapphire Cosworth 4x4 stereos for aftermarket model?
- New here and driving an Sierra 4x4 Cosworth and A Escort RS Turbo in The Netherlands
- Wheels???
- Crap voltage, help?
- sunroof
- 2.o zetec in a mk1 sierra
- Map Sensor, Wiring help ?!?!?!?
- Radio Comms in the WRC cars of the 80's
- what colour is this car
- Strange overheating issues
- Ebay ISCV
- Saph 4x4 CV Joint Save??????
- New Airtec Product Offer!
- Diesel sierra rev counter?
- Cam cover refurbs, who does these at a good rate?
- uneven afr
- Anyone know the clutch plate bolt size and length? Better still, has anyone got any?
- cossie gearbox question
- 2wd saff cosworth fuel pump
- cosworth head gasket
- Cosworth Pistons / Head rebuilt
- mk1 sierra pinto anti theft
- Tap Tap Tappy noise
- cosworth sump plug size
- No boost
- Feeding oil pressure pipe through bulkhead where?
- Sierra (bolt-on) driveshafts positioning
- Looking for 18 inch comps
- skyline front diff
- Xenon Kit
- central locking relay 3dr position / + or - steered ?
- cosworth suspention bolts
- Removing 3dr rear windows
- cossie rear beam system,where?
- Cosworth Turbo's and water cooling??
- Dump Valves
- Pectel T2 ECU and wavering Tacho
- Where to buy these?
- 4x4 throttle position sensor
- billet swedish plenum
- Shows for 2012 - 3 Door displays
- Spotted today
- 2wd Sierra Engine mounts
- Adjustable strut tops - anyone seen these before
- Anyone know this saph 4x4 ??
- misfire@1500revs when cold
- Door strips
- Glovebox clips?
- AP or alcon clutch?
- Fitting alarm to Sierra
- P100 - Electrics HELP PLEASE
- 6 degree beam reversing problems!!!!
- Group A coil wiring up ???
- 2WD wiring loom connections ??
- Wire where does this go 2wd loom ????
- Ford press car H527 KOO
- Clutch release arm
- Pectel management, Anyone good with it in the south west??
- What to do
- Electrical Gremlin...
- breather on stg3 car?
- Larger Intercooler.
- A piller boost pod
- T38 r/b owners
- Exhaust manifold
- Sapphire Cosworth Steering Wheel + Electric window problem + CD player...??????
- 3 door seat belt
- Running Closed loop: Little bit of hunting at idle?
- MK1 Sierra Body Panels
- 4x4 cosworth exhaust manifold
- after some advise
- new here and 1st cosworth rep build :)
- Petrol Tank (Race type) Wanted
- non sodium ex valves and .48 ex housing ?
- P100 YB Cosworth
- Conrods?
- welded diff pics please
- Oil
- Gasket between turbo and manifold, who uses one?
- Billet main caps on 200-block
- Performance air filter myths.
- front driveshafts
- T34 "hybrid" Turbocharger Querys
- If you're after a new Fuel Tank look no further
- 2wd drive gearbox no speedo drive
- any pics of saphs on rl7's
- 2WD sapphire alternator - which make
- whats the best saph off sets
- New Wheels for my 3 Door
- 6 degree rear beam with Magnex exhaust
- Massive thanks to Paul at RS Spares.
- who is the cossie owner with billet blue cam cover?
- refurbished rocker cover
- Multipoint Saff rollcage...
- Engine loom recon
- Headgasket Thickness
- 2wd will not start
- fuel filter outlet thread? size?
- Brakes....
- Favorite sierra cosworth. Sapphire/3dr/RS500
- which springs for 4x4 saph
- 450+- bhp headgasket Cosworth
- What would the wife say!!!
- What discs are best
- 4x4 Cosworth against 2WD Cosworth (comparison)
- 2wd hydraulic clutch how/what/ where from
- removing fuel pump connectors
- saff cossie rear sub frame/axle.
- cosworth rattle/ticking/knocking
- Gas gold spring rates ?
- cosworth 2wd
- crank case vacuum !?
- Are 3 Door Sunroofs the same as Sapphires?
- Saff rear tyre sizes on 18"?
- Sapphire wheels
- Steering column bush
- 2wd saph loom are they same as 3door loom??????
- Questions! Jummie ones i guess.
- lattice or shark tooth
- A few pics of my car!
- where's best value to buy sodium filled ex valves , valve springs and head set
- 2wd to 4wd plenum
- Heater resistor...
- Metal Water pipe issue with GT30
- broken CV joint?
- Cylinder head port volumes and lengths
- head gasket help!!!
- replacing water on a 3dr were is the air screw ??
- 8x18 et32 on a saph?
- 4x4 gearbox?
- Merkur XR4Ti aka US 3 door Suspension help
- Couple of problems
