- tie rod end thread ?
- Injectors
- 1987 Sierra xr4x4 help....
- Fitting 100mm flanges into a 2WD 7.5" LSD
- saff cooling fan loom + relay
- iscv mod
- 3dr electrical problems
- Sapphire cosworth brake warning problem
- Anyone know this car
- Looking for this or idea's on how to make
- Any Cossie guru in suffolk want to take a look?
- Tuned needed for Motec M800 in Kent
- How do i know its a t34??
- Clutch combo confirmation please lads.
- t34 compressor size ?
- Cosworth 3 door ABS and Relay locations.
- Hydraulic clutch conversions?
- Supra diff help plZ??
- Bailey turbo damper don't fit
- what oil
- Wheel size for 4x4 coissie?
- Fuel flap sticking out ??
- Sapphire best way to drain fuel
- sierra 3 door
- Sierra from Singapore to UK
- 3 Door wiring Diagrams
- my sierra cosworth 2wd!!!
- Cosworth Racing forged piston clearance?
- 3dr abs relays and fuses
- 2wd sump removal
- Helix Paddle 6/Helix Cover
- wireing diagrams for efi twincam
- Best Fitting Exhaust
- Modine vs oil rad
- Brakes for 4x4 saph
- Black 3dr in Fife on Gumtree, anyone on here?
- COSWORTH exhaust centre box
- Sapphire Side Skirt Jacking Point Covers:
- Saff seat bolts/ fixings
- fault changed, see post 10, what controls revcounter?
- Excessive play at TCA bushes
- Welcome J932 BVW help wanted.
- Clutch
- Help and advised on the 3 door
- Please help on rumble.
- Sunny day for the cars to emerge
- mogul 400
- Steering collom bolts
- Some bastard!!
- Fitting Compstruts
- Cylinder head 4x4 YBJ
- could somebody check for me please
- T34 water feed/return aeroquip?
- MT75 4x4 Shortshift & Cradle Bushes
- Newbie - 4x4 propshaft hex rubber
- Advice on what to look for on a Saph?
- 3 door sierra abs light on
- ford sierra xr4i
- 1984 Sierra - problems with windscreen wiper system
- Tank strap
- Rare old stock cosworth recaro dark grey cloth material
- 4x4 front hubs, lower steering uj
- power steering problem
- Sapphire seatbelt question?
- Tidying the loom up in a saph
- Sapphire Air ducts where from?
- Sapphire Cluster
- Newbee Intro & Questions
- clutch recommendations
- T-5 Output spline count
- door moldings saph, whats it worth?
- 4x4 saph misfire
- standard ride height coil springs
- grey injectors 0280 150 403
- 3dr cosworth tca Help fast
- camshaft
- T5 speedo drive
- injector fitting kit
- Anyone know this saph, H773OHK
- Gaz coilovers for Sierra
- 6766 turbo
- Hydraulic clutch
- Insurance help
- fan problems
- Cosworth power steering problems
- The dreaded YB missfire - I'm out of options!
- fuel pump voltage
- I need to find a new shaft any ideas where
- RS500 ABS Cluster Lights
- Replacement rev counter Saph Cosworth
- Rhd loom in a Lhd car?
- AP clutch pressure plate...
- OIL pressure switches
- Pf09 tps
- 2wd sierra cosworth noise issue
- cosworth headlight problem
- running lean cosworth?
- Sierra P100 Hose Kit...
- Rear shocks?!
- Tps voltage help
- wilwood master cylinder
- Hunting!
- Bore sizing and reliability
- 3dr brake servo stopped working.
- crankshaft pulleys
- 300 rear disc conversion help
- Australian Saph
- 6 degree beam
- Cosworth YB Standard engine max BHP
- amal valve problems...
- idle speed control valve problem
- Cosworth breathers
- Cosworth 4x4 door cards question
- Fan problems
- Any advise on Sapph rear lights issues 😞 (rainbow effect)
- 3 door sierra brakes
- Max BHP on a 60mm I/C
- Rear beam bushes
- oil squirt jets
- Koni suspension legs
- Which clutch should I fit?
- Mocal Sandwich Plate
- 4x4 and 2wd engine mount differences
- abs pump plug
- Fuel pressure regulator
- strange saph starting problem
- Nuts
- Bleeding brakes
- wanted ,sapph 4x4 ,engine core plug and manifold gaskets
- Petrol tank
- 403 greys fitting kit
- Toad ai606
- Gearbox oil leak MT75 4wd
- Steering rack leaking
- Anyone know this saph?
- Propshaft centre bearing
- what engine Oil grade do you guys use?
- Sierra cosworth 2wd rear drive shaft cv joint
- Make a Sapp to chase R32 GTR...
- Any 1 got a front pair 4x4 cosworth hub flanges.....
- Flat shift software for l8
- Speedo cable
- Brands Hatch Performance on ebay? Reliable?
- Anybody got a good 4x4 head
- Another year another starting issue
- WTB Ecu and loom
- Car can't Boost With Motec M800
- ABS / brake loom questions
- what exhaust to go for??????
- Found my ecu on the speaker
- Losing fuel pressure after turning engine off
- Weird Cossie overfuelling problem on cylinder 3: Solved
- Tremec TKO 600 mods required?
- Finally, that time of year has arrived
- pics required plz?? mo5s an white 3dr??
- Best place for prop recon?!
- T5 Speedo Blank
- wtb 2wd Stub axels
- Fitting Bigger Valves in a YB
- Saph Foglight bulbs
- 3 door brakes
- Fuel pump relay wiring
- Need help, what Turbo is that?
- Interior floor reseal?
- L8 ECU
- Sierra saph pedal boxes all the same?
- AN and thread sizes for breather fittings on each side of the block ?
- Afr readings ?
- L8 ecu with lc+ALS closed loop and wasted spark Is it worth selling i
- brake to pedal connection on 3 door
- multi connector for headlight
- What's the best mod you have
- Rear wheel sticking out of arch 15mm??
- Can you get a speed sensor for a t5
- 3 door Cosworth misfire?
- What engine bearings for YB Cosworth?
- K'in ell! Just found my cossie documents!
- Carbon false floor where from?
- Ecu problem
- Sapph carcoon
- 4x4 stub hub
- Airtec plenum hose help
- Supra diff,where?
- Horn relay location on sapphire?
- Breaking my 3 Door - worth it? LOADS of PICS added 29/4/15
- timing belt tensioner tightening torque
- Fuel pump cradle
- master cylinder upgrade
- Cosworth ISCV
- 3 door suspension? Where from
- Pectel monitor pinouts please
- Battery wiring - connecting block HELP?
- t34 to the 2wd saphire
- Help fitting alternator
- 2WD Sapph Brake Master Cyl overhaul
- Borg warner t5 heavy duty slip yoke
- Genuine rear bumper??
- T35 flow rate
- 3dr Coolant plumbing
- Fuel pump mount rubbers???
- Rs500 fuel pressure reg wanted, cash waiting
- 4wd header tank hose
- Sierra Mk2 - Brake & Suspension
- Poly bushed rear arms :(
- whinning from rear.
- Have your used this AP twin plate
- First drive after the engine rebuild.
- Cam timing
- Chip Id help
- Saff cossie 4x4 rear wheel bearings
- Any knowledge on Gp n Gp A fr Bilsteins?
- Where on floor do these go
- heatproof silver stuff where from how much do I need?
- Stripping engine
- Maram 247 shafted T34/0.63 where can I buy one?
- max thickness radiator and intercooler for 3 door
- Trailing arm bushes
- hall effect for yb
- tilton pedal box
- Sapphire bumper bolts
- Stack st200 tachometer wiring in Sierra.
- Help Wanted !!
- Rs500 airbox lid
- AP's under Comp 18's
- Front End Oil Leak Help!!!
- Airtec RS 500 rad/Intercooler
- Can anyone tell me what chip this is
- 2wd downpipe/exhaust on 4wd manifold - 3dr cosworth
- Sierra boot locks
- Cossie 2WD dip stick tube length
- Cosworth 4wd oe copy exhaust with cat.Does it exist
- 1989 XR4x4 2.9 not starting.
- Block Engravings
- Manifold YB, different injector/trumpet section
- Engine block number tracing
- Saff cossie door warning light
- bootlid lock
- Cosworth fuel pump cradle bushes
- refit of spots and indicators
- 3dr tailgate wiring
- Ford Racing Boost and oil Gauges new
- New stroker kits
- 4x4 front caliper carrier to hub bolts
- cosworth not running
- Bbs rs reps
- Got my head back from being skimmed
- Bailey oil breather pipe kit
- Sapphire Morette wiring loom?
- what boost do your yaris coils support
- Looking for a Wiper Arm for Sapphire
