- Sapphire 2WD Diff & Gearbox Oil,
- >>> which oil for gearbox/diff
- Front Hubs... 4x4 Sapph vs Escos
- Removing Rear Number Plate Panel
- Standard reproduction 2wd exhaust.
- Info on 3 door sierra cosworth
- Ford Scorpio Diferential Doubts
- sapphire glove box handle
- Seen this in RSOC forum looks good
- Original engine block colour
- can you still get 3 dr cossie windscreen from ford?
- few issues with my sapphire
- Brake problems
- 4x4 saph suspension questions
- RS500 front bumper gap.
- Rear diff bolts and locking plates.
- 3 door spoiler screw caps
- Sierra Cosworth front brake pipe pics info/pics plZ???
- door moulding & seals for a saph
- AP's for sale
- GT3076.63 vs GT3076.82
- Cosworth L8 ECU or Aftermarket?
- best place for front drive shafts
- cosworth stage 3 advice needed
- electric power steering or 4X4 pump for YB 2wd
- Sapphire Cosworth 4x4 Rear Hub/Disk/Backing Plate
- Valuation please Sapphire
- Best place for HT leads
- Cosworth crank
- 3 bar map sensor
- Magenta sapphire
- Cossie alternator voltage
- Abs help going insane!
- Cosworth idle problem
- Anyone used a MSD fuel pump loom?
- Searching: MK1 lower rear boot spoiler
- Siemens 55lb injectors
- 200 block with 2wd internals
- Number 4 plug getting wet ?
- Line boring in Hertfordshire?
- ISCV operation HELP !!!!!!!!!!!!!
- looking for f193ryn
- 2wd & 4x4 rebuild parts
- Fuel consumption increase lately...
- What clutch to replace paddle?
- Actuator Nut Thread Type
- fuel pressure regulator leak
- Passed MOT again!
- Injectors-turbo help
- Brake pipes for AP's
- my ebony 4x4 saph finish or break???
- setting up TPS PF01
- Saphire V8 conversion
- Quick cossie pulley question
- Rs500 original exhuast manifold
- Lamps/lenses/lights E marked or not E marked?
- Fuel gauge intermittently dropping off, then works OK again.
- ABS light turns on when indicating right???
- cosworth front seat inserts
- best spec for 450bhp
- 3dr window rubbers
- 2wd front discs
- What's it worth
- 2wd to 4wd front end chassis conversion and welding
- Brand new ISCV, is it correct?
- Cosworth wheel studs
- wanted cosworth pf01 tps
- Help please
- H522ebv stolen Id please help
- Can anyone help me with a wiring diagram please?
- Lining a cosworth block or not
- Missfire when revving from cold
- Front anti rollbar options...?
- Fitting rear beam with Powerflex bushes
- 3 door header tank
- HELP...low boost and fuel smell
- Standard air box fouling boost hose
- gaz golds question
- buying a car with no keys.
- 3dr cosworth starter motor
- How to remove a dodgy wheel nut
- Sierra Automatic problems
- What tyres
- Quickest road legal rwd Cosworth quarter mile?
- 3 Door values
- 2wd calipers
- Dark purple Sapphire springs?
- complete cosworth engine whats it worth
- Widest 17'' wheels that fit Sapphire Cosworth 4x4?
- 3dr new fuel lines
- Reverse gear saff cos
- Wanted door cards
- Traction mods for big hp....
- 3 door cos brake compensator
- RS fuel line clips
- T5 Synchro Kit
- cossie sapphire question
- Ford Sierra azura
- Help Required - YB not start due to injectors not firing
- Anyone local to southampton I could try my ecu in your car?
- Reverse lights come on when braking?
- 3 door Cosworth TCA's source for new ones or refurb ?
- Indicator/Hazard Light Probs -Help!!
- What's it worth
- Suspension recommendations 4x4
- Cosworth 3dr standard wheel colour ?
- master brake cylinder
- Sierra 2.0i dohc throttle position sensor
- Cam cover leak question
- DTA pro s60 ecu on a cossie,anyone?
- 2wd front hubs
- saff cosworth door strips £?
- Oil drain pipe to sump
- Type 9 bellhousing Swap
- et20 17x8
- Mcrae 3 door
- WANTED 3 door header tank, rs500 boot struts, turbo water pipe
- Fitted new brakes
- GT35 Turbo brace
- 2WD Sierra Cosworth propshaft
- secs monitor
- Turbo bolt options?
- Individual coils/ coil on plugs
- Rear speakers
- Dove gray floor paint code
- 2wd Oil cap (genuine) WANTED.
- Best rear camber setting for 2wd
- Where can I get rwd cossie CV boots?
- High idle speed?
- Are rolled front arches needed for 18's?
- 2wd 3dr alternator 70amp or 90amp?
- 2wd Cosworth Front Anti Roll Bar options.
- Sapphire 4x4 overboost problems, standard bhp
- Saff 2WD fogs fuse wiring conFUSEion!
- Axle tramp???
- Wiring Diagram Request 4x4 Saph Cossie
- Fuel regulator
- Map sensor question
- Front prop
- A pillar weather strip!
- Possible missfire? Please help.
- Help! My sunroof is broken!
- 2wd cosworth
- Revolution Millennium Wheel Nuts
- 3dr loom advice
- coolant hose
- Stage 1 Cowsorth remap simple?
- looking to buy sierra cosworth 10k
- Lifters
- 3 door floor colours
- 2 Door wing lip repairs
- 4x4 front diff leaking from one bolt, any body had this?
- 3 door sierra turbo
- Diff backlash ?
- Suspension top mounts
- Fuel Regulator Bottom Hose.
- fuel line help please.
- 3 door cosworth
- Sierra Sapphire 4x4 Cosworth brake upgrade
- 2010 Ka Steering Wheel Custom Retro Fit
- Cosworth Misfire
- YB 2wd running on 3 cylinders. Need help
- Fuel system for 500/550 bhp what's needed
- adrenaline beam rose joints
- Amal valve wires?
- ABS brake servo and distribution block service
- swan neck for cosworth
- ZF clutch type Differential
- Saff front bumper
- Problem
- Various niggles
- Rota RM200 vs Compomotive TH
- Sierra
- 3dr rev counter mod for wasted spark
- yb cossie engine removal
- What crank pully?? 2ad sump onto 4wd engine?
- Saph 4x4 idle control valve issues
- 3dr owner, free stand pass for Ford Fair
- New sapphire floor mats
- 1988 2WD Sapphire Cosworth Ride Height
- Injectors
- C0 level closed loop ?
- Brakes opinions please...
- Heavy power steering
- T5 Sierra Cosworth Gearbox parts
- Sapphire group A Roof Vents, where from?
- Coolant temperature sender replacement
- Fuel gauge doesn't work
- Fuel pressure test
- What diff and box oils for 4x4 cos
- Back to standard ride hight
- Need help loosing will to live
- Polyurethane Steering coupler for 2wd Sapphire.
- Saph bonnets
- Hesitation under light throttle
- 2 oil spray jets per every bore
- 4wd to 2wd?
- Offside front driveshaft
- Abs pump
- does anyone makes spacer for the sump for the oil ?
- what stroke you use for yb 2200 or 2400 ?
- Can I run a 4x4 front end with a 2wd gearbox?
- sierra 1.8td cylinder head
- Strange noise when slowing down
- T5 big tooth box
- New 4x4 front drive shafts. Seem a bit cheap!!
- Does anyone know this 3dr?
- What t5 oil
- eBay Sapphire Rear Lights?
- coilover clunking
- Any other Crystal blue owners??
- Handling upgrades for 4x4 saph
- Saff jacking point covers
- Saff waterproof cover
- 2wd front wheel bearings
- How do I get Ford UK to verify my car
- Expansion/header tank for 2wd sapphire
- 205 block
- Compression strut kit
- Cam Cover paint and machine??
- Saff bumper mouldings
- 2wd Cosworth rear driveshafts
- Who does the non abs loom mod plZ???
- anodised pulleys
- 235 wide tyres on sapphire??
- max hp on collins baby board
- Cosworth Coilover options??
- 4x4 pf09 tps setting up help
- AS breather
- Piston and bore clearance
- Eaton diff for 2wd cossie from USA!
- T5 advice
- 6 degree exhaust mod
- 2.8 Clutch fan removal tips
- What clutch? 4x4 saff
- WRC head bolts
- What is this plug for
- Ford Fair 30th Anniversary display (3dr Sierra Cosworth)
- two strange kind of noises from cosworth engines
- Fitting 18" wheels on a 3door
- Anyone fitted a Piper BP270 cam to their 4i? Got a tappy 2.8 here....
- An-6 fitting into standard fuel rail
- Shudder when braking
- Sapphire Interior Colours?
- RS500 Bumper
- 3dr front hub grease caps
- Sapphire buzzing from fuse box & indicator problem
- tie rod end thread ?
- Injectors
