- gearbox specialists for T5
- HELP for bolts to my 9 inc. rear axel.
- finally
- Test for sig
- we need you cossie boys to come to this
- Shocking dizzy cap
- More electrical dramas..
- know a good upholsterer near Bracknell?
- whats it worth
- nearly there.. but :cry:
- Jack point Cover
- Lifter rattle on first start up
- abs sensors
- sound of an induction kit?
- Cosworth Sierra Exhaust Flames A Policemans Thoughts Please!
- What things to look for when buying a saff coss
- speaker size in sapphire (4x4)
- Offset for 3 Door
- rouse splitter
- idle speed
- TYERS WHAT SIZE....
- what boost??
- bloody thing will not start
- colour change on saff cos
- Impreza 2.0GT vs Saph Stage 1?
- 3 Bar SECS error message, help needed
- oil pressure when cranking over ???
- thermostat seal?
- Ever heard of/had little end trouble on YB
- turbotechnics
- 2wd head on 200 block ???
- Diff.....
- Saph cossie door mirror glass
- saph 4x4 compression pressures
- turbo damper on a 2wd saff
- How quickly can a set of blue motorsport leads fail?
- just booked the car in at NMS
- What fuel pump??
- Need the trim strip on on a Sapphire bumper
- Sapphire Washer Bottle Level Sensor
- Sapphire Cosworths wiring diagrams
- 4x4 not ideing right
- Fuse panel thingy
- rear disk back plates???
- what are the ancillary hoses
- Stage two set up for saph
- what v6 do i have?
- Amal valve restrictors
- fuel press gauge
- 3dr Cosworth Rear Spoiler Brackets
- Refurbed cam cover
- Who sells 3 gauge holders that replace the centre air vents?
- What should I do with my engine?
- 1ST COSSIE LOADS OF PROBS IDLING @2200RPM??????
- NOS on cossie?
- What rims for a 3dr and a sapph 4x4?
- what wheels?
- What Turbo
- what size discs on standard rim?
- rite got cash need a side exit exhaust for a 2wd saph
- please help brembos
- Post your saffs!
- Polly bushed rear beam.
- Wanted drawings for a big winged cosworth sump.
- Sapphire cosworth boot/bonnet carpets
- Got this little lot back today :)
- How much is my saph worth ?
- Stu at MSD urgent help required now please
- saph wont start .....
- Fuelpump periodic cut out problem??
- Where can you get smoked rear lights for a 3 door?
- Heated windscreen relays
- IS THIS TRUE??
- ignition coil positions?
- Cossie polybushing question??? (in general...link inside)
- nearly got the cossie running but need futher help......
- Any pictures of the engine?
- cossie wheel bearing help
- saphire bodykit
- What oil in a T5 box
- WOLF Sierra cosworth dash
- Help needed!
- diff oil 2wd ???
- was that you?
- Are all sapphire cosworth clocks the same?
- Suspension set-up for 3door cossie?
- F900 EBA (Saph Cossie)
- D33 SFV (3door cosworth)
- Vernier slipped!
- SAPH SKIRT CLIPS
- what offset??
- pics wanted
- fault
- body shells
- petrol leak
- How much are D40 tyres worth
- Silly drunk question
- was that you
- jaycos
- alternator info wanted 2wd & 4wd
- insurance???
- Where can I find the computer???
- COSSIE STILL WONT RUN NO SPARK
- Rear windows electric motor
- Chrysler Crossfire - Boom! Bitch went down!
- 4x4 throttle position sensor
- running a saff everyday???
- Best and most reputable tuner (closest to manchester)
- Which cars have a Level 8 ECU as standard
- D309 KUE Where r u?? With PIC!
- 2 tricky ones for ya!!!
- HELP NEEDED!!!
- clutch cables
- lowered 3 door
- PS fluid
- D92 ENV
- does any one know
- Mud flaps on a 4x4 Sapphire
- 2wd Cossy Engine Life
- 3dr owners I need some help
- cossy leather rear bench needed
- Wont Rev over 3.5k
- T5 gearbox
- Sapphy amplifierblanking plate???
- D502 JHW 3DR COSSIE HAVE U SEEN
- Is this a Cosworth Group A Coil? + Other bits
- LHD 4x4 Steering rack
- saph oil problem
- New User from BasqueCountry(Spain.Steering wheel leftside!)
- problem with ecu
- Suspension coil springs
- Can anyone tell me if my car was an RS500
- HELP..COSWORTH STANDARD MAP SENSOR PIPE WANTED
- Jaguar XK8
- Any body had this problem before.
- blue sensor ?
- bottom end on 3dr cossie
- Missfire...
- 1988 Sapphire Front Spoiler Sagging - Advice needed.
- 2wd cosworth stage 3 . what psi are you running ?
- Differences between 2WD and 4x4 Engine mounts
- 3door with sapphire front anti-rollbar?
- spec r breather and catch tank????
- Acuator question?
- Recondition a head for 4x4, anyone on here???
- re-shellin a saph
- 3 dorr front bumper removal
- trackday weaknesses
- 4x4 head
- Thinking of buying a 3 door (help)
- whats the metal block connected in the???
- Lexan Windsheild
- HELP wot clutch
- Cosworth Specialist in the North East
- Crunching Gears
- What sparkplug for a Stage 1 2wd?
- Advice on exhaust wrapp
- 4wd block question
- Whats a 3dr worth??
- Morette/quad lights, pics please
- Fusable Links
- under reading rev counter
- Engine breather
- Battery always going flat, have no idea why!!!
- Early 2wd, january 1988
- A VERRY SAD DAY IN MY LIFE
- Anyone seen my old 3 door?
- rolling road
- T34 Boost....
- Heated front screen
- 2WD Cosworth Sapphire shock absorbers
- new turbos or uprated
- Newbie question
- 4x4 brakes
- COSSIE STILL WONT RUN..AAAARRRRRRRRRRRR
- o/s/f hub carrier 4x4 saff please??
- car alarms
- sparkplug choice
- oil breather fitting help please
- Short rear axle ratio for Sapphire 2wd
- 8 injection manifold
- ABS pump
- Which headgasket?
- Black plastic trims on back windows
- IS A COSWORTH THE RIGHT MOVE!!!
- dip stick
- does anyone use a b&m short shift??
- OIL IN AIR BOX
- Is this the right psi of boost?
- wheel arch rust
- stage 1
- 18's on a 2wd?!...
- Maximum Turbo Boost??
- battery light saf cos
- Suspension
- this is a gearbox mount for a 4wd cosworth????????????????
- Reverse Light Switch
- no brakes!!
- New Cosworth owner??
- map sensor identification
- WANTED RS HORN PUSH
- brake hoses
- DUMP VALVE PROBLEM
- my cossie
- nearside driveshaft
- removing dump valve. turbo damage
- 3 door rear fin screw caps...
- Which distributor Cap?
- can anyone help
- ANYONE GOT REAR CALIPER SLIDERS X2 FROM 4WD SAFF FOR SALE
- Advice Please
- Picture request. Sierra roll cage turret mounted.
- cam belt
- Clutch difference's between 2wd and 4x4???
- HOW SAFE IS???
- by-pass switch for radiator
- acid dipping
- Saph 4x4 valuation
- 2wd and 4x4 cossie calipers.....
- Turbo rebuild
- worth selling up?
- coil pack on saff cos
- ecu help
- What is??
- saph cos advice
- my cossie
- Best place to get a Sapphire wing?
- Approx bhp with this engine spec
- WHAT DO I NEED TO PUT 4WD REAR BRAKES ON 2WD..PLEASE HELP
- checks before buying sapphire cosworth (4x4)
- EBC greenstuf
- What Are These?
- What is this?
- what oil
- my new toy
- f22 dew
- Wombwell
- My accident damage!
- phase sensor fitting
- CARBON FIBRE TAKES AGES TO MAKE pmsl
- why wont
- whats wrong...
- Cossie problem
- Heat Sheilds
- 3door strips
- have you seen
- compatible?
- Pic request 18's on sapphire cos please
- Header Tank to rad hose
- rocker cover colours
