PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71
  1. ABS warning light on - help please!
  2. help Size of a head, unskimmed or full fat?????
  3. Where to get damaged RS500 front bumper
  4. escort cossie rims on a sierra, tyre size?
  5. RS500 top wing
  6. Front drive shaft problem! With BIG pics, please help.
  7. Attn Saff 4x4 / Escort Cossie owners
  8. uprated cam in standard head
  9. could someone help
  10. Do you know how powerful your car is???
  11. Difference between 2wd and 4wd pistons ??
  12. Snapping noise....no clutch..
  13. Sparks on 1 and no Sparks on other cilinders?
  14. Saff Cos
  15. Oil in inlet?
  16. sapphire dash in a 3 door
  17. what fits a sierra estate
  18. Brake judder at slow speed
  19. rs500's build number?
  20. Saph had Misfire and now won't start
  21. HOW MANY.............................
  22. 2litre XR4X4?
  23. how do i tell if its a 4x4 head
  24. H26 AFG SAFF COSWORTH
  25. Last few parts wanted, can you help
  26. 3dr parcel shelf
  27. brake upgrade under standard rims?
  28. CARWISE UK ????????/
  29. RS500 boost hoses
  30. fuel pump what bhp
  31. How to replace the lower arms ?
  32. What turbo 2wd sapp
  33. best rods to use???????/
  34. 450bhp TURBO INJECTORS, PISTON+CAM SUGGESTIONS!
  35. smoking....
  36. 3dr spring heights
  37. 18" wheels on 3 door..
  38. any1 fitted a blueflame exhaust on a 4x4 saff
  39. Mayo in bailey breather
  40. body kit clips for a saff???
  41. post your 3 door pics
  42. pistons???
  43. 2wd and 4x4 conrods the same
  44. got my sierra sapphire cosworth Pics now added
  45. t34 from 2wd to 4wd???
  46. engine rattle
  47. t34 wot next ?
  48. Does anyone know? how many Mercury saphs?
  49. Body shop
  50. Obscure Sapph cossie question...
  51. just died help please
  52. Definitive list of what may turn the warning light on?
  53. rs500 splitter
  54. rs500 alloy intercooler difference
  55. Very Big Problems
  56. gearbox oil
  57. diff hanger?
  58. coilovers
  59. RS500 no.4 fuel pump problems
  60. Cosworth 4x4 brakes on XR4x4 - help!!!!!
  61. wehey just got off the rollers!!!
  62. 2wd saph engine probs!
  63. Engine Bay Stickers location
  64. Rocker Cover
  65. Going To make a saph cosworth my next car needs some pointer
  66. Whos Does: Grp A Wheels to Standard Stud Nuts?
  67. BIG Problems whit my Sierra 4x4 Cossy
  68. sagging bumpers - saph cos
  69. cosworth stereo
  70. PROBLEMS!
  71. Ratios for manual Sierra steering racks?
  72. 3 door suspension
  73. flow rate
  74. Cossie Blocks
  75. Idle speeds
  76. 2wd sump gaskets
  77. pics of your saffs with mudflaps
  78. Dump valve..
  79. door/lights display
  80. Sierra Cosworth TPS
  81. rouse bits or rs 500
  82. fuel pump Bosch
  83. -=Help=-
  84. cossie ticking over problem
  85. Help!!! 3dr centre cap key needed desperately
  86. A1 Rally Website????
  87. I think I know
  88. Need to contact a guy who lives in Qld Australia and owns a.
  89. Moddin on a budget
  90. Rous splitter on theyr way too Norway
  91. fwhy does some thign always go wrong?
  92. Help needed!
  93. warm runnings......
  94. private plate for sale
  95. Funny running?
  96. Buying a cosworth
  97. cosworth rear brake presure control valve
  98. Which Spoiler for an Sapphire
  99. Head gasket on a 3dr
  100. Driving to work today....
  101. Diamond white indeed!!!
  102. 3dr bumper strips/mouldings...
  103. door trim
  104. rear diff oil
  105. Compression Strut Group Buy
  106. PIC,S OF HEAT SHIELDS WANTED
  107. Adjustable TCA Group Buy ? ** LAST WEEK **
  108. 3 Door Side Window Seals ???????????
  109. Saff cossie 4x4 plugs
  110. cossie hot start problem
  111. 18's on a saph
  112. does anyone have a spare secs monitor that they want rid of
  113. 3door headlight help!!!!1
  114. Cometic headgasket torquing procedure question
  115. where is
  116. shapp 4x4 cutting out after 25 miles
  117. Apology from Fiat Coupe owners
  118. 2wd abs help
  119. crystal blue saphy how many left ??????
  120. tappety things
  121. fuel rail welding???
  122. with regards to my last post
  123. Coolant temp. sensor......volts?
  124. ************LOOK************************
  125. Hydraulic lifter / follower question
  126. Dual Master Pedal Boxes
  127. fuel pressure???
  128. Ford Badge?
  129. my new sapph 4x4
  130. RECARO MATERIAL - anyone know where to get?
  131. what next??
  132. anyone want a pair of sapphire cosworth headlamp protectors?
  133. How do you get focus RS calipers on a saph
  134. STEERING WHEEL JUDDER
  135. Sierra Cosworth Story
  136. just looking back at some pics...
  137. sapphire cossie replica
  138. 4x4 Differential Trivia
  139. group a k&n where from?
  140. Anyone tried orginal amp.& coil with Autronic or corresp
  141. can your ford turbo beat a coupe 20v turbo?
  142. Head gasket gone!!
  143. On the look out for my cossies sister 3dr...D673 FFL....???
  144. where can get saph door strips????
  145. Help Needed (call out )
  146. Where to get 3dr/RS500 rear quarter window rubber seals ?
  147. crystal saphy
  148. Correct decals/ stickers for RS Cosworth and RS500
  149. Re Cossy Wheel Issues!
  150. Where to get an engine re build
  151. best suspension set up for road on a sapp
  152. Fooked again !!!!
  153. Stripping down and repairing RECARO's
  154. brand new 3dr motorsport shell
  155. Correct decals for RS500
  156. Paging wrc007rally (Ebay Name)
  157. 2wd and 4wd cranks
  158. OPINIONS ON CLUTHES
  159. Some dimensions please
  160. Saff 4x4 pulling to the right under hard acceleration
  161. low temp thermostats?????
  162. It was running fine and then it wasn't
  163. RS500 SLITTERS
  164. 2wd hot start prob
  165. 2wd Cossie clutch question...
  166. 2wd front calipers, overhaul! info required please
  167. 4X4 intercooler
  168. whats my 3dr worth?
  169. pinto question
  170. Are the 2wd cossies, RWD or FWD?
  171. What could cause this ?? :( :(
  172. Anyone know a decent bodyshop in southeast?
  173. 2 stage boost
  174. j reg 3dr? found in autotrader website
  175. how much power??
  176. help needed with fuses
  177. Smoke on full boost...
  178. 3 door chipping advice
  179. combat2 bodykit
  180. Few Photo's of my car...
  181. Any buying tips or advice........
  182. chip 400bhp+ of the ahmed beyjoo
  183. Cosworth boot stickers?
  184. Wire diagram for morettes
  185. stage 3 settings
  186. my new toy
  187. t5 speedo drive
  188. info please
  189. 3 door mats
  190. what is this part called ??
  191. outa the pan and into the fire!!
  192. Spring rates .... coil over for road use AVO-GAZ ???
  193. cossie clutch?
  194. brake bleeding???
  195. overboost??
  196. Which one 2wd or 4wd
  197. can anybody help i need one of these,
  198. had me car on rollers today
  199. 2wd and 4x4 rear brakes?
  200. Carbon hood
  201. my cars 1/4 mile times.
  202. saff install??
  203. Side mouldings
  204. Can you run two maps on a l8 ecu??
  205. saff coil overs
  206. help needed please
  207. P-reg Mitsi Evo - owned and humiliated :-)
  208. Breathers
  209. sky 1
  210. Refitting the return fuel pipe to the fuel rail
  211. my bird just came out with this joke any1 find it funny
  212. Rev Limiter
  213. 3door Cosworth
  214. check this saff
  215. RS500 race car
  216. power question??
  217. price for a orginal top wing RS500
  218. for my xr4i DOHC
  219. coilovers on 3 door??
  220. 3 door arial
  221. Will The Sun Roof Fit ????
  222. Bailey Oil Separator
  223. INCLUDING SIDE EFFECTS AND DRUG INTERACTIONS
  224. tuning
  225. Bathurst 1000, 1991 Video (Features RS500s vs GTRs etc)
  226. 2wd intercooler measurement
  227. 1 F***ING DAY :mad:
  228. Fuel Rail
  229. Welcome Bonus 777$ !
  230. Welcome Bonus 777$ !
  231. decisions decisions......please help
  232. ARE THESE COSSIE CALLIPERS
  233. Bad Idle with 071's
  234. 1990 (g) wire diagram
  235. Anyone using a TurboSmart Dual Boost Controller, Help Needed
  236. sapphire starter relay
  237. Oil Light Flickering!!
  238. just how rare is aL plate saff
  239. first saff 4x4 service
  240. steering wheel height adjuster
  241. rear hub nut torque???
  242. 2wd inlet, and favour needed please
  243. advice on coilovers
  244. High clutch pedal
  245. Exploded drawing of 4x4 steering rack. pls
  246. Compression on 4+4
  247. front drive shaft
  248. 4x4 clutch adjustment
  249. gearbox specialists for T5
  250. HELP for bolts to my 9 inc. rear axel.
