- turbo???????????
- 3 bar map
- focus rs calipers on a 3dr
- what sort of BHP for the following...
- 3 door Shell
- 18" alloys-et40 or et35
- autometer gauges
- Brake Caliper Help?
- A pillar pod?
- more than likely allready seen
- Witch pods,gauges you think!!
- saff running problems
- Sapphire high revs
- Spec to GRA Mountune
- Rwd cosworth misfire/running rich????
- Cosworth insurance in dreaded manchester postcode?
- need my std FORD alarm removed
- need help!!!
- Boost setting for stage 3?
- wanted power steering pipe for 4x4 cossie
- Vernier Pulleys
- sapphie side skirt fitting kit
- 4x4 head bolts v 2wd head bolt torque?
- Aston Martin Caliper Info
- P8
- cpr
- power steering pipe
- 3DR Speedo cable
- secs monitor wanted
- ABS light stuck on!
- Gearbox Rebuild!
- FIRE
- spark motorsport REF: 0904884
- turbo T31/T04 RS500
- RS 500 engine numbers
- RS24 cosworth sapphire More info needed
- 3 door ecu
- XR4X4 Rear Brakes
- Unstable Saff
- air filter
- Tarox G88 Discs
- Which turbo?
- Hi and loads of saph cossie questions :)
- saff 4x4 and escos radiators are they the same??
- Lowered saff sitting high at front - any solutions?
- Turbo shaft play?
- Sierra Sapphire Cosworth 300 bhp setup, which is the best?
- F**KING MISFIRE
- Phase sensor
- do sierra cosworths have pas?
- tescos petrol !!!!!!!!!!!!!! ahhhhhhh!!!!!!!
- Speedo Dials
- Bottom end rebuild
- fuel pump
- Twin plate clutch on a saff cos ?
- standard injectors
- Is a blown engine worth anything?
- rev counter???
- 3 door chassis number check
- My Andy Fisher rebuild
- Help with some part numbers and what anti freeze? please....
- 3dr non standard colour - looking for opinions
- Draging rear brakes on 3dr?
- possible abs problem - 4x4 sapphire
- 2wd saff idling problems
- sapphire cosworth 4x4 problem
- eggenbergger group A block?
- Rouse Splitter
- Can anybody help me find these parts anywhere??
- STANDARD CAMS
- 4x4 cv boot keeps twisting???
- Grease For Propshaft
- Diamond Cut RS 7's with 215/40/17 tyres
- Insuring a 3door on classic, any good companies?
- ECU questions?
- RS500 Wheels
- T 38
- Jap vs Cossie
- cosworth rocker cover
- 2wd to 4x4 manifold change over
- saph problem
- H966 CMT WHITE 4X4 COSSY- ANY BODY KNOW IT?
- Heat shields
- Valve stem oil seals
- Sapphire info.
- 4X4 Cosworth Driveshafts.
- 2wd engine mounts??
- smoking cosworth
- Saph Missfire
- 2wd Rear anti roll bar links
- Finis Code for water temp sender for dash gauge
- Apexi AVC-R EBC anyone??
- removing abs system
- RS500 Splitter
- compression test results. your opinions?
- WHATS THE DIFFRANCE????? whats better????
- oil???
- spark plug gap
- saph cos idle and low rev probs. please help!
- my new car
- a little question for ECU
- DOES ANYBODY KNOW THIS CAR ??
- help!!!!just replaced headgasket,now sludge in header tank!!
- Battery relocation
- pleas please HELP!!!
- Dipstick
- with or without anti roll bar
- chassie no
- Saph problems
- Bilstein grA coil over on Sapphire 2 wd ?
- National Day 3dr Stand Anyone ?
- ALS on L8
- Original clutch Sierra 4X4 Cosworth with T34 and 1.2 bar
- Finis code for Saph 4x4 water pump
- fao koni owners
- Bottom end
- LEVEL 8 INTO 3DR.
- How much power for 7" rear diff?
- Pic's of 3dr's wanted
- New T3
- ABS Fault on 2wd Sapphire
- Smoking
- brake options for saph 4x4?
- Rough idle?
- saph suffer from electric probs? having a few probs
- saph horn not working
- Cossie Pics
- Moonstone 3 door, 11.200 miles. - Should I buy it?
- recon back calipers
- Please help me identify this
- 4x4 rear coilovers?
- Quick Question - With regards to Injectors and Fuel Pumps.
- filling up the t5-box
- confirm my ISCV is shafted?
- Sapphire cosworth colours??
- Brake question?
- t4 turbo
- 4x4 saff cossie brakes
- 4x4 Cossie idle screw
- Group a coil/plenum spacer questions
- Body panels?
- green injectors
- STEERING WHELL COWELINGS
- what exhuast you got on your saph?
- cold start crap and idle speed controlvalve
- wastegate leek
- new member
- Rear diff
- any one see a prob
- show me your 18"/19" wheels on your 3drs and Saf p
- ebays gone mad!
- fuel return pipe
- engine bay loom
- Rolling road and fault finding masters
- Is my 3 door the last produced?
- I WILL BE BK PLEAS HELP
- 18inch tyre-ARCH WORK???
- T38 outlet size????
- ECU CHIP and Mapping 430bhp
- 2wd cooling fault
- anyone had chassis rot ?
- 2wd manifold?
- Engine mounts saff 2wd yb or dohc?
- Rear strut braces
- What ECU?
- A few questions
- Help please stage 3 saff
- anyone know this car?
- Vacum Tubing
- 4x4 bonnet
- transmission fluids
- Itemno for coolantwater container? 3 door.
- group A fuel pump conecters
- Sapphire door rub strips
- Ht leads to the dizzy
- skyline box in a saph 4x4 cossie
- 3 Door Cossy Grill Mesh
- BEST TYRES?
- santa pod launching probs
- Anyone got some pics of the inlet plenum of a 4x4 Sapphire
- RS 500 No 341 on Ebay
- Escort cosworth engine a good choice to use in my saph???
- 3DR Finis Code Please
- ABS Help needed
- 18's on a 4x4
- Help Fitting 4x4 intercooler........
- Rear caliper needed
- Change of Colour
- Sierra Cosworth 4WD
- Engine build for 400-450 bhp
- sierra cosworth front bumper sagging
- saph 4x4 poor starting
- 3 way valve
- electric woes- heated window button illuminates
- calipers
- front bushes
- L8 ECU in a 3d
- replacing dump valve
- Turbo rebuild?
- size of the socket/star key to remove headbolts from my 4x4?
- saph speedo not working
- Not my day
- will a 4x4 turbo fit a rwd??
- Cossie suddenly got very tappety
- 2wd 4 pots reconditioning
- Power steering question
- DATA CHECK 200
- Group A coswoth coil loom ?
- starting problems
- Hot Coil Pack
- Vent blanking plates
- handbrake mechanism
- REAR DIFF OIL
- Valve Guides ???
- how hard to do a hedgasket on my 4x4!!,think mine has gone!!
- Whats this? (pic inside)
- 3 DOOR REAR RED/TINTED LIGHTS
- 4x4 speedo drive gear.
- Proalloy oil Breather Tank Pics..........
- 3dr cooling fan
- Number Plate A Bad Omen?
- ignition barrel stuck..
- diagrams
- 4x4 sapphire with escort wheels what tyres??
- whats needed for 2wd solid, too vented disk conversion
- how many rs cosworth was produced with out sunroof??
- has he given me the wrong part
- saphy 2wd cooling fan.
- Escort Cossy Rims
- non ford standard colours
- Need more power
- Cosworth high reving
- no power to fuel pump saph cos
- Missing at high revs?? help please
- Part needed (washer bottle)
- overheatin cossie+the fans aint cuttin in??UPDATE!
- Carbon fibre 3 door dash anyone
- where too buy a 6paddle from?
- Cosworth owners, I'd like some help ABS wise please.
- Wiring diagram
- Anyone know where there is .................................
- 2wd sapphire rear bumper still available?
- saph cosworth engine advice
- 10 x 18 on a 3 Door?
- 4x4 speed sensor, can you open it?
- SECS Monitor
- 2wd heat shield on a 4x4
- Ultimate handling fast road/occasional track day saff 4x4
- headbolts
