- dry sump for a 4x4 cosworth
- 3dr steering rack
- Noob
- Carbon Parts For 3dr?
- Front Hub
- free to anyone
- Hello, I'm new...
- Winter Gremlins !!!
- Buying a 3dr sierra cossie
- 2wd head
- sierra bumpers
- Anyone got anti-lag?
- Torco gear oil full synthetic75/90w or ATF for T-5?
- pleas - estimate price ????
- Pic request please
- breather kits
- Cam cover
- 3.0i Rs saphire
- 4x4 cossie's with NMS gunship chip
- Engine loom problems
- My first FORD!
- saff gauges voltage regulator?
- Whick Exhaust system is best for a 2wd sapp cosworth
- 3 door cosworth alloys for sale
- Which mustang had T5 gearbox like sierra cossie?
- Which Fuel Pump
- Brakes on 3 door
- 7.56:1 conpression ratio good 4 a cosworth
- needed asap!!!!
- how do i measure my 4x4 head
- sierra 4x4
- Help needed on battery going flat
- Strut Brace choice??
- What is 526nm of torque in real terms equate to?
- cosworth engine wont idle
- converting L6 to L8 ecu
- Sapphire stage 1 chip
- 7x17's with 38 off set fit a saffy
- One for the bufty/resto peeps
- Fitting 4wd camshaft on 2wd head
- question?
- Whats this in my ECU?
- This is sick. Brand new 3 door for sale. (driven 6 miles)
- RS500 Replica Splitters To Fit Sapphire Cosworth
- Help needed Headlight problem
- Who fixes seats ?
- green injectors
- need some parts
- 1st post, Value Question
- Turbo question?
- Buying a 2wd, problems and rust area's to look for?
- Who is running over 400 bhp on a T34-55 ( T35) ?
- coolant / antifreeze question
- abs prob.. 2wd saff????
- Is there any way to have no dump valve noise between gears?
- 3 door offset
- 8x18 saff offset
- Recomendations?
- exhaust gaskets
- REV COUNTER READING HALF AFTER COILPACK CONVERSION
- parts help please
- parts sites?......
- Oil...
- radiators
- fuel pressure regulators
- 2wd gearbox question?
- 4x4 FMIC
- How do you change Throttle Body Bearings?
- What to look for on a Sierra 3dr??
- Closed Loop and Coil Pack Conversion
- saff power steering problems
- rally pic
- air fuel ratio
- idle speed
- air fuel ratio
- fuel pressure gauge
- Whos best for .....
- 2wd missfire HELP!
- Anyone got a Pic of a 2WD Bottom Water Hose ???
- 4x4 saff front diff
- Stage 1 two wheel drive setup
- Another problem lol , brakes this time
- Starting question ??? cosworth , help
- What size are threads on Inlet Plenum for vacuum lines (PIC)
- Req: Owners Handbook 3 door (PDF)
- Group A Coil - Wiring
- F**ked up wiring
- Lattice wheel paint code?
- REV COUNTER READING HALF[ENGINE REVS]
- What the hells offset !!!
- turbo and injectors
- Wide rims
- chatter-trouble!
- Piston rings melted in to the piston!!
- how to fit arp head studs?/ how do i recognize a -31 actuato
- Crank pulley question.
- my sapph
- gear box oil??
- Cosworth, more like bloody Christine!
- What about spark plugs?
- Rocker cover , Sort of black but ....
- removing engine from 4x4 HELP (updated)
- Best choice for Brake Discs 2wd Saph.
- Fuel pressure
- Advice Sought - Difficult Rear Fender Rolling
- Looking at my first cossie, what do I need to know?
- 2WD Diff Upgrade
- COSWORTH COILPACK PROBLEM PLEASE HELP
- Rear Diff and Gearbox oil
- will these wheels/tyres fit 4x4?
- Strange boost gauge readings???
- Saph Electric windows not working
- Saph Carbon Fiber??
- saph stearing rack
- Best rims for a 3 door , need some help guys
- Cossie clocks!!
- is it worth any thing
- where can you get those pillars with the gauge mounts in?
- Sierra Saphire Cos Gearbox
- How did it feel for you?
- 3dr fuel pump
- Timing cosworth engine
- 9 months work have resulted in .........
- best plugs
- Oil Capacity
- BK FROM PAINTIN
- 3 door coilover spring rates??
- V6 MT75 rwd vs 4x4, same bell?
- Bloody ace quote
- any tips???
- help what level ecu is this ??
- ANY ONE HAVE COILPACKS FITTED TO THEIR COSWORTH .QUESTION
- insurence
- Boost guage fitting?
- sapphire Backing plates
- gearbox (sierra RWD vs Mustang)
- Interior carpet set
- solenoid control valve
- differences between a T3, T34, T35 and T3/T4 hybrid
- cosworth wiring loom
- aquamist water injection and SECS ecu monitor
- Multi-point roll cage for 3 door - pics request
- fitting oil breather/seperator
- help me please on what i should expect to pay info pls ???
- Pistons say 91.275 What over bore have i got ??
- Electronic Boost Controller
- nice track toy
- Need help - coolant leak!
- Bolts to studs?
- Locking fuel cap
- inlet manifold spacers???
- T38 with external wastegate
- can you???
- HELP
- Cosworth piston rings?
- running in
- wrc inlet manifold
- headgaskets
- stage 3
- escort cossie rims on a saph
- 3dr carbon bonnet with vents ????
- in 24 hours...............
- engine mounts, which are the best ones?
- how much is my cossie worth? will be selling ***UPDATE***
- unusual abs question
- gt30r turbo
- My Dutch Sierra Cosworth
- 3dr Gearbox mount??
- help, what would you call this ?
- Jack point Covers
- Blue Injectors
- Please help - 2wd Sapp Cossy not functioning right
- diff
- using a 4x4 sump pick up on 2wd sump
- Job lot of 2WD parts
- does anyone have sapphire cosworth F140MSR ??
- SILENCER PACKING
- cage....
- stupid question - ashamed to post it (pics)
- Saff jacking points?
- Exhaust query?
- Saff panels and parts???
- Limited Edition?
- What colour wheels on a white 3dr?
- cosworth ecu
- anybody know where i can get....
- what do you think about this chip ?
- 3dr ECU plugout diagram
- what the..............
- Finally back to rwd, new saff.update pg2. 21/1/08
- cosworth problems
- rear window quarters
- RS500 Cooler???
- question for head bolts
- buying a 3 door
- saph 4x4 track control arms
- problem whit sierra coss
- Cossie 4x4: Temp gauge is showing hotter than used to be..
- My New 3 Door. Setup Advise
- changing the timing belt
- new engine in saffie,now wont start!!!!help urgent please!!
- RS500 Lower rear spoiler
- setting up adjustable TCA's
- cossie cutting out
- 3 door carbon bonnet
- Adjustable boost?
- 3 DOOR RIMS
- RS500 intercooler question
- Heatwrapping downpipe on 4x4 saph cossie
- 3dr alloys refurb were???
- is this
- Righ, come on, whos going to own up to this
- difference in splitters
- What brake horse is ur Cosworth? Please contribute.
- swedish inlet manifold
- Can anyone help with these items please??
- Lots of non-cossie saph questions....
- Help please from Swedish Cosworth drivers
- help me ID these knuckles please
- coughin and splutterin on mates saff 4x4 what could it be?
- Show us some pics of your stripped interiors.
- what plugs and gap??
- Standard 3dr wheel offset??
- what colour?????
- 'O' ring-ing
- Headgasket
- What Measures Have U Tuk Securitey.
- WHAT TO SET C.O AT.PLEASE HELP
- Question on 4x4 Suspension
- does anyone know this car ??(G463 bvx??)
- Creative Carbon Heat Shield.
- 3 Door reving
- rev counter gone mad!!!
- somebody have the racelogic traction control?
- How exactly to do do a compression test??? Poss h/g gone
- Clutch requirments
- Throttle position sensor (TPS)
- where does your temp gauge sit
- 2.0 SAPH GLSi
- wot 2 look for
- PU Poly Bushes
- Deflex PU Bushes
- draper fault reader. ??
- speaker upgrade for the saph?
- Roll over jig
- RS500 Plenum/elbow/throttle body
- Rev limit
- A/R .63 Turbine Housing (External Wastegate)
- AFR 2WD Cozz
- ecu pics
