- Stuck lifter? What would it sound like & how to prove it
- Cosworth Timing Help Needed Please
- fuel pump on a 2wd sapph
- Engine mounts
- L8 - MSD - THROTTLE SENSOR
- 9x17 ET 20
- What is needed for 19-20PSI Boost
- 4x4 saff knock sensor
- K1 racing HT leads any good??
- what shocks are best for 2wd sapp
- saph 4x4 buying guide
- 2wd sapp oil in spark plugs
- sierra cosworth lamda sensor + closed loop chip
- circlips for bronze guides
- what boost....
- Best Adjustable Coil Over kit?
- Help please.............
- whats the pros an cons????
- Injector question
- Minimum head thickness (Help needed urgent)
- Ideas?
- 3dr cosworth car cover where from ???????
- anyone interested 16" ecos /mondeo alloys mint swap ???
- ideas
- nurburgring
- big brakes
- Shim kit for rear
- front and rear bumpers
- Bottom pulley needed
- 2wd & 4x4 cosworth head!
- stage 3 - what next??
- Alternator belt
- Where does a 3 door rust?
- what bhp should i get
- rs 7 spokes what size tyres? 205 or 215?
- stg 3 chip wanted
- Help! Tachometer not working!
- GT30 turbo
- OMP roll cage in a 3 door
- How much boost with Stage 1 T34 .63 and original injectors
- what are my hocks worth
- L8 ecu chip / board fitting
- Spring rates 2wd
- Which route to 400bhp?
- remote oil cooler
- OIL PRESSURE
- Just gave the old dog a polish...
- Cossie 4x4 gear stick
- front suspension
- Wheel fitment ? 3dr
- 200 block and head thickness
- rear wheel bearings (2wd)
- well im happy...
- my old cossie
- cts sensor on a 2wd sapph
- 2wd caliper rebuild
- Oil in the Water
- tubular manifold prob - any ideas please?
- exhaust manifold 2wd sapph
- Was it you? Dark grey saph with white wheels in Kirkhamgate?
- Cosworth headgasket
- 2.0dohc oil
- 2WD HEADER TANK ON 4X4
- what comp ratio to use
- Solid lifters / double valve springs
- 2wd engine in 4wd car?
- Heater stopped working, what can be wrong?
- Handbrake/abs light
- Wheel bearing?
- mt75 gearbox query
- 'Ford Motorsport' chip with pectel for L8
- Opot sandwich plate
- Throttle body?
- Cam options
- Hidden leads??
- How to adjust my koni's
- Stage 1 vs standard
- engine problem!
- ABS LIGHT
- misfiring 3dr
- Is the amp slot DIN size for gauges?
- front splitter
- Strange ABS problem on Sapph
- Rod bolts
- spark plugs
- split rims on a 3dr
- Air in heater?
- Gauge holder
- saph missfires
- Cosworth cam belt change
- What colour are these Sierra's?
- Engine loom wires, which is which?
- HELP..........Suspension dilemma
- Crazy Russian guys))))
- Honda turbo kit? WTF?
- Sapphire front bumper
- Removed the spoiler from the Saph
- actuator problem
- Is fuel causing probs???
- smoking cossy please help!
- sapphire missfire please help!!!
- Exsesive tyre wear!!!!!!!!!!
- 2007 shows!
- 4x4 engine into 3dr cossie
- Whats the differance: standard and GrpA gasket
- Recommend a supplier of Cosworth performance/race parts
- 3 Door abs sensors
- battery draining due to central locking?
- Brakes
- clutch release bearing for a 2wd sapphy
- sapphire fuel pumps
- Which coilovers?
- workshop manual
- advice needed!!!! rs500's, what they worth???
- pully covers
- head gasket
- expert help please people
- help needed still got problem but now different
- sierra wiring diagrams
- Reuse Mountune wrc headgasket.
- SPEC-R header tank ?
- Does the DOHC 4X4 share any running gear with the Cossie?
- help with mixture (north east)
- Big disc kits? (budget)
- LSD
- 3dr Build Pics.
- What Are Best Pistons For Rebuild?
- Race seats in a cossie
- denso plugs
- turbo housing size???
- Fitting an RS500 Intercooler at 4x4 Saph
- anybody know gasants of here!!!
- Carbon fibre door trims
- Engine Tips
- Roof??
- SAFF 2WD OFFSET
- heater gauges
- Sierra Handbrake problems
- Seems I need a new radiator
- What do you think about this configuration?
- Polyurethane Exhaust Hangers
- Saph: Inner light on Morrettes, air ducts
- Sapphire Koni Adjustables keys....
- aeroquip hose size for fuel supply/return
- petrol tank
- central locking / electric windows saff 2wd
- Saff cossie 4x4 heaters
- if any one is board.....
- front mount???
- CATCAMS camshafts for 2wd cossie.
- Saff speaker options
- Stage 1 on T34
- flow rates
- Essex Cossie advice
- Am I turning into Graham Norton?
- XR4i what are they worth????????
- Where to get arches rolled ?
- after insuring my saph on a classic policy,whos the best??
- bleeding the front brakes
- camshafts for cosworth 2wd
- chassis plate!!
- my new baby,opinions please
- Air box pipe size
- Rattle hydraulic or bearing
- Rear number plate holder
- need help buying my first cosworth
- 4x4 Power hike................
- boost.....
- best chassis set-up 4wd
- wide band lamba kit
- a man i norway need help
- Lowering using standard cosworth springs
- wheel wobble still. 4x4 saff
- Help needed light problem
- help with inlet manifold
- 3dr side strips & rear window seal
- 2wd engine into a 4wd saph cosworth
- aftermarket fuelfiller-cap 3door cossie..
- removing top vents in saph - how?!
- help needed running problem
- Scorpion exhaust will not fit on saph!!
- Mongoose exhausts
- Technical information for cosworth 2wd original camshafts
- Engine mounts high?
- 3dr ecu???
- steering coloum
- WRC Headgasket 3 or 4 layers?
- body panels sierra
- How difficult to change engine mounts
- throtlle RS500
- Gear box oil
- What to look for when buyin a 3dr sierra cos
- mondeo rims on a sapphire..
- Turbo oil return - for breather too maybe?
- LOST ALL POWER
- what atb/ lsd
- short block question
- overbore limit
- Quick fuel filter question
- plenum for sierra cosworth 2 rm for moore 400bhp
- Looking on the Autotrader and Pistonheads...
- Headwork needed/advised for stage 3?
- Recirc D/V help (pic)
- Buying a 3 dr sierra cosworth (wats it worth)
- P100 conversion Q's
- Any EASY way of removing the front struts on a Saph?
- Cometic head gaskets!!
- pics of a hydrolic clutch conv for 4x4 please?
- 4 paddle clutch
- Junc 28 E plate Saphire cosworth
- indicators problem
- Pic of rouse front splitter please??
- plug gaps on coil pack con
- Rouse front splitter
- diff and gear box oil 2wd
- Cosworth throttle diameters? pics inside
- SPARK PLUGS
- NO BRAKES and then BRAKES?
- What oil should I use in a 50k engine?
- Sapphire 4x4 weight?
- 3door interiors and bay's
- Noisey cossie tappets
- Emissions too high
- After 15 reliable months its started!!!
- 3dr wanted for wedding
- FITTING 17" RIMS TO A SAFF
- help!!!!!
- group a coil / motorsport leads ?
- saph cossie breather pics
- 3dr inner wing question
- Saff 4x4 and 2wd brakes
- Little end pricing???????
- Is this high even for standard Saph, back end??
- White Sapph 2wd Cos, Valuation pics
- K Plate Saffs
- Fitted the K&N, some pics with liner out!
- cam pulleys...
- Tyre choice
- Saff rear hub nut size
- Removing the air box from Saph
- Got the Saph back and got nabbed by speed camera!! Arrgh!
- lowering a saph
- Can you buy a Haynes Manual for a 4x4 Saph?
- What thread sizes
- best offset with 17s
- Experience from R&D 6-speed
- 3 BAR MAP SENSOR
- RS 500 INTERCOOLER
- Sierra hub
