PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. ECU baby board question
  2. FINIS/availability 3 dr engine bay hose clip ? ...
  3. cosworth running prob
  4. What oil do you run in your cos
  5. new alternator!
  6. 2wd cam timing
  7. Help Fitting EECIV Throttle Body Please ?
  8. ecu help
  9. cossie 4x4 oil
  10. crank sensor
  11. how much sierra cosworth ?
  12. Advice needed
  13. Cylinder Head Porting - Software modification
  14. GGR fast road rear beam kit?
  15. 2WD TPS Adjustment
  16. how to do rear brakes?
  17. getting a 4x4 to 400bhp
  18. Radiator??
  19. Motec ecu?
  20. 2wd Head
  21. Over revving on idle
  22. New sapphire panels
  23. Pic of your dash
  24. Hi
  25. Advice on Seat belts and Recaros
  26. 400bhp.
  27. crank sensor bracket not lining up
  28. coilovers
  29. hydraulic clutch actuation
  30. 2wd cossie steering
  31. fitting new phase sensor
  32. bang
  33. still in box, 200 block (how much is it worth?)
  34. Ford Focus RS Brakes and Discs On Sierra Cossie 2Wd
  35. Saff cossie 4x4 front driveshafts
  36. TCAs
  37. Cossie paint
  38. removing anti roll bar + or -
  39. Need ya help again 4x4 cossy still broken
  40. rumbling/vibration noise under gear stick
  41. distributioncap replacement
  42. map sensor
  43. Sierra Cosworth 2WD 4 Pot Caliper
  44. colour code
  45. What's my 2wd Sierra Cossie worth? opinions please!
  46. RS500 wheels
  47. bonnet help
  48. Front Anti-Roll Bar Mount Nuts
  49. 2wd alternator pulley
  50. Hesitation whiste driving
  51. NGK 9 plugs?
  52. ECT testing
  53. Are there any american Cosworth owners on this forum
  54. Cosworth Fuel light
  55. cosworth colour
  56. ACT sensor
  57. putting head back on lol
  58. Would 225/35/17 Tyres Cause Rubbing Issues?
  59. Info on Cossy ECT sensor
  60. Fuel tank strap
  61. Sapphire dizzyless/coilpack
  62. cosworth diff oil
  63. .55 Garrett exhaust housing - really rare?
  64. GpA coil resistance
  65. cossy 4x4 still poorly
  66. what brakes are people using on their saphs??
  67. engine and gearbox removal
  68. engine and gearbox removal
  69. saff boot light switch?
  70. Fuse box
  71. BRKAE SIZE NEEDED V QUICKLY
  72. Wastegate leak
  73. ROCKER COVER PAINT
  74. plugs
  75. some trouble in full boost
  76. MAP Sensor mounting ...
  77. Another Q RE; what fuel do you use ?
  78. injector fitting kit
  79. 2wd engine removal
  80. noise from camshafts!
  81. Another smoking cossy - any advice welcomed
  82. heater wrap recommendation
  83. higher revs when engine start
  84. Brake pipes
  85. 15ins/16ins/17ins
  86. Saph 4x4 strange rattle
  87. Spark Plug Question.
  88. colour?
  89. Quaife, Gripper or ? rear diff?
  90. sapphire cosworth exhaust
  91. What oil for a 2WD cos
  92. t34 - spec ?
  93. Strange brake problem!
  94. Burdsport stage 3 chip??
  95. Are there any differences between 2wd+4wd saff boot badges?
  96. track control arms
  97. Degreeing specs std exhaust cam
  98. cams Q
  99. downpipe anyone
  100. smoky cossie.....advice please
  101. Tuners in North East Scotland?
  102. RATTLE ON MY 4X4
  103. Thermostat
  104. Upgrading from L6 to L8
  105. Head bolt Trq settings?
  106. spring question
  107. Location of ECT and water temp sensors?
  108. what is the best suspensions
  109. is G341 OHL still out there
  110. sapphire rolling road
  111. help with 4-pot 2wd calipers please?
  112. 3dr Front Bumper
  113. saph with wheel arches?
  114. Are Cosworth Inlet and Exhaust Cams Interchangeable?
  115. Three door fuse box
  116. MK2 RS 2000 COSWORTH
  117. 2wd cosworth-Water spraying from exhaust
  118. 3dr caliper seals...
  119. front pipe gasket
  120. What oil for T5 2wd cosworth gearbox?
  121. Saff is just not bloody running right !!!!
  122. sierra rs aluminum flywheel
  123. help mounting bailey separator
  124. rs500 inlet or swedish plenum?
  125. Timing, Advise please.
  126. throttle body
  127. What are these injectors?
  128. Saph starts then dies
  129. Standard cosworth intercoolers... comparison
  130. recon t34
  131. prices for cosworths
  132. Saph rear Chassis Legs.....
  133. sierra sapph
  134. Fuel pressure?
  135. Co adjustment Sierra 4*4
  136. 18 inch on a saph 4x4
  137. Front door removal on a Sapph
  138. sierra sapphire 4x4 cosworth power steering tank/cap finis?
  139. Reprod. of coolant water bottle for 3 door. Who's interested
  140. sapp. Grp N or Poly bushes?
  141. sticky revs ?
  142. best chip for my spec???
  143. disconnecting the battery
  144. running rich?
  145. surely hes p*ssed?
  146. whats difference between 909 shell and normal 3dr cosi shell
  147. Paint code??
  148. exhaust wrap........coloured!!!!
  149. rooflining stay or go???
  150. 2wd only spinning on 1 wheel????
  151. caliper brackets for 2wd cossie
  152. Exhaust housing on my turbo
  153. mt75 vs t5 transmission?
  154. floor pan
  155. 2wd cosworth discs road/track
  156. sapphire 2wd.. which actuator ?
  157. Idle problems
  158. MY NEW SAPH 4X4
  159. Saff cossie 4x4 front driveshaft
  160. 2wd cos exhaust heat wrap amount
  161. sapph headlight wiper blades
  162. bloody cosworths
  163. MY NEW COSSIE
  164. quick injector question.
  165. cosworth question?? Costs of things??
  166. my old saff
  167. My 4th Cosworth.....:)
  168. Rear Antiroll Bar Drop Link Bushes
  169. 2wd engine mounts........
  170. XR4x4 front driveshafts for saff 4x4
  171. Turbo elbow/downpipe
  172. L PLATED SAPH 4X4
  173. Stage 3 Conversion 2wd Sapph
  174. 3 Door Window trims & loom
  175. More cracks inside turbo exhaust housing
  176. COOSSIE NOT RUNNIN RIGHT
  177. 4x4 thermostate housing on 2wd
  178. Possible T34 Failure? making noise on idle
  179. cooling fan relay
  180. Rear Hub Nut Thread Direction
  181. What is the ofset??
  182. Crazy Revcounter
  183. to buy or not to buy?
  184. A/F ratio and EGT questions
  185. engine mounts
  186. Crack in turbo wastegate seat
  187. cossie ecu on ebay
  188. 3dr 4x4 how hard
  189. fitting rs 7 spoke dimond cut and soflines
  190. viberation on saff
  191. Boost/running problem
  192. J20 Cos 4x4 sapph
  193. wiring gauges
  194. Need a Trusted Cossie engine builder?
  195. Help lambada sensor and closed loop msd
  196. sierra Coilovers
  197. Looking for 2 doors
  198. Problem with my water pump 4x4??
  199. TCA's ?
  200. Focus RS alloys
  201. P8 ecu
  202. first time cossie owner advice
  203. Sapph, No ignition lights? **Sorted (kind of)**
  204. Low mileage Saff 4x4 value
  205. blown fuse
  206. help please
  207. PAS pump bracket 3 dr ...
  208. 225/45/17 tyres on a 3dr?
  209. 2wd cooler
  210. cossy callipers
  211. 245/40/17 on 3dr
  212. DODGY BRAND NEW MAP SENSOR ?
  213. head bolts
  214. Charging Problem
  215. broken axles on 2wd?
  216. Idle Problem!!
  217. radiator problems.........
  218. What oils in gearbox, axle etc
  219. 16'wheels with tyres
  220. Sapph rear roll bar fitting
  221. AVO coilover leaking? Refurb??
  222. intermitent problem
  223. t38???
  224. 4x4 saff abs
  225. p8 ecu
  226. Best offset for 8x18's
  227. What Order To Bleed Sapphire 4x4 Brakes In?
  228. cossie 4x4/xr 4x4
  229. 2wd steering rack
  230. sierra pics from nat day,1st lot.(edit,few more pics)
  231. Fan wont work
  232. 2wd saff wheel offset
  233. powder coating/paint heat
  234. sluggish off boost
  235. Monte/Escort wheels on the Sierra
  236. Poor running saff 4x4
  237. sapphire bushes
  238. Croft 2007 3 door display
  239. Turbo recomendations???
  240. FAO: people with 17'' on saffs, tyre size help please
  241. advise please people
  242. T5 GEARBOX OIL AND DIFF OIL
  243. Brake problom on my 4x4 saff
  244. Help 3Door RS Cosworth
  245. 3dr insurance
  246. Sierra RS Cosworth 3dr
  247. diff size
  248. 4x4 water pump
  249. can I use universal zirconium Bosch lamda sensor for my
  250. Gear oil advice please
