- Part numbers
- 4x4 number plate surround
- 500 style splitter
- ap calipers 6 pots
- Rocker cover paint
- cosorth wont start
- can you get adjustable rear beams
- Fitting 8x18" wheels on a 3dr
- Cosworth 3Dr door strips and speedo clock wanted
- what size tyres for a 3dr
- Starter motor
- *** Euan*** AVA swedish plenum
- Brake pipe problem
- Brake bleedin problem
- H.I.D. Headlamp conversion..... pics :)
- Disconnecting iscv
- cossie using loads of fuel
- Breaking
- saff with 3dr front bumper
- Saff side trims
- Down on boost?
- Bumper strips
- 2wd oil pump
- Bladed front antiroll bar !
- gt28 turbos
- 2WD stainless steel manifold
- Access to the oil breather box
- Front Cossie 4x4 splitter
- what oil for runing in 2wd
- Stripping 2wd differential
- Fuel Tank Fixing Bolts
- wanted sierra sapphire 2wd or 4wd
- Urgent help needed!! Saph 4x4
- Where to find 12 pt turbo/exhaust nuts
- Lattice wheels
- Restoring a cam cover...?
- rousekit with sapphire cosworth in magenta
- cosworth t5 gearbox grinding
- fuel tank capacity
- Tyre sizes
- sapph crossmember?
- Saff brake pipes
- what oil?
- cosworth strut brace
- Saph boot badges
- Anyone recognize this disc - 310mm??
- ABS Front sensor - stuck in!!
- STARTER MOTOR
- 2wd saff problems
- 3dr Sierra arches on BTCC/Race varients?
- 909 Shell
- Cylinder head oilway question?
- picture request gold MOs on black sapphire
- cossie panels
- cossy crash
- 3 door cosworth - aerial on wrong side??????
- sapphire front bumper removal
- First Cossie need help
- leaking door seal- sapphire cossie
- 3 door front bumper inserts.. where??
- can anyone tell me where this bracket goes?? under c/console
- Cossie/performance ford specialist in Essex?
- why do we bother?
- 3 DR HELP NEEDED
- Sapphire/Sierra - standard speaker cable - upgrade or not?
- lack of boost
- Stereo amplifier, where is it?
- wheels
- Fuel Pump
- Induction kit
- engine wiring help
- Saff underside restoration
- P100 brake upgrade
- going to buy a saphy- what shall i look for
- coil packs,closed loop, which ecu/inj? help decide please.
- 2wd exhaust + 4wd exhaust
- closed loop lamda
- Swedish Plenum Throttle Cable Bracket?
- RS500 Thermostat
- Bumper Mouldings
- quickshift grinding on a t5 box
- coilovers
- Breaking
- Viscous Coupling in transmission
- mondeo wheels-will they fit a saph
- Magenta Paint Code
- tilton triple and twin plate clutch kits
- Anyone running a 7 1/2" diff in a 4x4
- Front Bumper Fitting
- My car seems to EAT starter motors...
- Radiator fan switch
- ECT sensors
- Getting wires/pipes through the firewall to the dashboard
- 2.0
- 82 or 88 degree thermostat for 4x4 sapphire
- Anyone know of this car
- Outdoors Cover Needed for 3 door
- Is a Dunlop D4 an original cosworth tyre?
- breakers
- ALS
- Turbo/Exhaust seal
- Which type of liners to use?
- cossie insurance
- gaz coilovers grinding
- cossie exhaust downpipe diameter?
- Ebay 18" Compomotives, Revolutions (real deal or not???
- Driveshaft with bits missing
- double valve springs
- Sideskirt Clips & Rivets
- Radient red Cosworths
- g'box removal/refitting 4x4 saph
- Fog-lights 3door. Hard to find?
- Black plugs...???
- Dunlop D40,s
- Cylinder head questions...???
- residue on my front wheels
- Turbo strip down....
- 500 intercooler fitting problem
- turbonetics turbos
- looking for a new turbo
- NEW DOOR SEALS ??
- spark problem on my saff!
- are 2wd and 4x4 cosworth front shocks the same diameter
- rusty sunroof
- 3 Door ID
- rs 500 front splitters
- Any one know this car???
- Rear bumper removal
- unequal lenght shafts
- Valve guides...?
- Need help on L8 ecu + baby board
- Sapphire Cosworth Database
- ABS issue
- best rims for sapphire
- Removing the wastegate from a T3. Tips?
- 3 door carbon vents
- What is the width a a standard cossie wheel
- Pic request: moonstone 3 door with carbon bonnet vents...
- big discs for standard calipers
- what springs for a saph?
- dooge's new 3 door
- 4x4 & 2WD crankshaft Differences
- wanted pictures of saffhire cosworth with focus rs wheels
- Picture Request - Flint Grey Saph's on mo's
- Sierra T3.48 vs. T34.48
- Starter motor - 2WD vs 4x4
- Morette headlights
- which turbo GT30, 35R ...
- warning module
- leaking water !!!
- RL7's
- Boot lock jamming!!
- New wheel for the Sierra folk...
- boost gauge
- lots of smoke at idle, what is the cause
- rear shafts on the front?
- has anyone got any 3door centre caps and locks for sale ???
- Whats needed to fit an electric sunroof?
- turbo exhaust housing size?
- Alloy Fan Bracket/Holder (Desperate)
- Are 2wd & 4wd diffs the same
- Rouse splitter Saph
- Car Polishing
- coil lead
- Sierra dashboard - tips for dismantling
- Few little jobs - with pics
- rear springs
- im back
- First clean of 2008 (2)
- where to get a t34.63 turbo for 2wd saph?
- How many AMPS required for cable to fuel pump?
- What's This????
- Power coating costs
- 4x4 gearbox
- converting 4x4 to 2wd
- turbo on pinto?
- Wheel Studs On 4x4
- Saff 4x4 & 2WD wheel offset... are they the same???
- gearbox vibate/ rough
- xr4x4, & escos front driveshafts?
- Front strut removal
- Going through the gears to qiuck
- cant find the mud flaps!!!!!!
- tappet noisy
- 2WD Cosworth Aftermarket Turbo Manifold!!!
- L8 ecu in 2wd cossie?
- cosworth 4x4 boost problem
- Going to look at 3 door at weekend what to look for ??
- 4wd saff transmission
- boost/driving problem
- focus rs brembo's
- Should I fit a turbo damper?
- where to buy rouse kit parts
- best looking saff and 3dr on here
- fuel pressure?
- Vibratechnics mounts?
- genuine ford pannels
- Does the Rs500 Suppose to have the plaque near gear stick
- Cosworth bumper brackets for sale
- comp brake adj TCA's
- Camshaft "tapping"
- advice on 8x18 on 3dr
- 3door rs500 alloy wheel centre caps and locks,help!!!
- strutbrace
- Been away and coming back - advice needed.
- Ford racing temp gauge fitting
- powerflex v flo flex
- spark plug question
- SEVERE WHEEL WOBBLE
- Whats it worth?
- Sapphire rear speakers - 5" or 5 1/4" ??
- HEADLIGHT WIPER BLADES
- how much do you like cossies?
- defi gauges in london or essex or in surroundin area
- BEWARE E BAY COSWORTH HISTORY FOLDER SOLD!!
- TURBO ???
- fit a skyline box to a saphire help!
- short shifters...whats the best out there **urgernt**
- AP racing or Comp Brake?
- temp gauge on 3/4
- Tuning companies.
- Buying a Saff...
- oil pumps
- Apexi AVC-R Help
- Saph 4x4 gearbox & diff oil??
- INFO ON SAPH'S
- OZ Mags 18 x 8.5 Centre Locks
- Did you know
- Port sizes
- 2wd / 4wd pistons
- Dump valve sound, or lack of !
- Replacing studs, discs and pads. Thanks and pics.
- What Camshaft's?
- YB Cosworth Thermal Inlet Gasket with double o-rings
- Saff offset
- where to get 3 door bits?
- Saph shell on rollover spit.
- Saff rear lights
- heater matrix on a 3dr?
- Removing gear knob...
- 3 door boot stickers?
- clutch ratchet
- 3 Door restoration help
- Will ap100 center console fit a regular Sierra ?
- turbo garrett 2wd & 4x4 sierra cosworth info?
- how to screw in back calipers
- tremec t56 6 speed box
- 4x4 front shafts
- Upgrade stages
- RADIANT RED SAFF !!!!
