- Correct flywheel for Mt 75 with 2l Zetec
- sapphire cosworth
- Sierra cosworth 3 door compomotives
- saphh 4x4 heater blower not working-aircon model
- Green cam cover
- What wheels?
- Main/big end bearings?
- Cossie running problems
- P8 ecu
- Sierra Engine???
- Cosworth 2wd turbo upgrade
- Auxilary shaft pulley
- Copper slip or thread lock on driveshaft bolts ?
- Cosworth swap...
- RS Cosworth GR N
- Saph rear to low
- 909 uprights and 909 bilstein coilovers
- Koni suspension kit
- Where does this plug in to? (2WD Saph)
- New ecu wiring harness - sierra cosworth
- Alternator
- Moonstone 3 door
- What dry sump kit
- interior seat repair
- diff oil
- MSD Fan Loom - Instructions
- Wheel Bearings
- Magnex exhaust best for 2wd saff?
- Underseal
- Ford parts Wiltshire area
- Sierra Rs Cosworth Bumper Sliding Bracket dims
- Wastegate Actuator
- 17x8.5 wheels to rs500
- Clutch for RWD 350-ish bhp?
- electric sunroof cover problem
- 4X4 Header tank plumbing and tank type.
- cosworth intercooler which one
- cosworth fuel pressure regulator
- Rough running cossie
- T3 turbo question
- Electronic boost control suggestions
- STOLEN Silver Saph Cosworth, J757GRG, Shifnal, Shropshire 19/07/17 STOLEN
- sierra saph interior door handles
- Replacement Crankshaft
- stolen 3 drs
- cosworth 4x4 rear splash gaurds
- Max power on standard 4x4 intercooler
- Which COMPS?
- Cosworth 2WD ECU Repair
- Rear Diff
- 2wd cam belt cover bolts
- Saff inner rear arches info needed.
- 2WD Saff 6 degree beam geometry settings needed...
- Overhaul - Sierra Cosworth 4 Pot Caliper
- powdercoating question
- Instrument bulbs
- Abs brake pressure switch
- Xr4i 2.8 engine noise after rebuild
- Ahmed spec Leda springs
- What colour are your door cards and where to get them recovered?
- Fixing a 4x4 steering rack oil leak
- Mt75 4x4 gearbox
- Hydraulic clutch
- 2wd saff cossie chip advice.
- Whats this port connect to.
- Sapphire interior trim help
- 3dr owner
- Sapphire Cosworth 4x4 boot badge position
- airtec radiator
- 3dr window glass
- Rear beam mounting bolts, what type are they?
- Stage 3 intermitant missfire
- 3dr Cossy/Sierra front door differences
- Sierra steering bush conversion
- T5 gearbox rear viton seal size?
- Cosworth boa coolant hoses problem
- Cosworth 4x4 rear diff ratio
- Are these Cossie Arch guards?
- Where did you install your MAP sensor?
- Sierra ABS Self-test Problem
- Hydraulic Clutch Conversion Pictures.
- ABS ECU Self-test fail
- Fuel pipe size
- Wanted: BOA engine or full Granada Cosworth
- 2.0 DOHC 8V Idle Problem ( HELP )
- Under Headlight Trim Panel - Sierra Sapphire
- ECU multiplug wires on 3 door - Missing 12V battery
- Sierra zetec
- 2WD Saff tyre size + type on 8X18 mo6s ET35.
- front suspension turret dimensions
- Strange wiring issue on my sapph
- What throttle body upgrades are there for cossies using level 8 500bhp+?
- Help with original radio and amplifier
- Problem with turbo
- Spark plugs
- 7.5 inch diff upgrade recommendations
- 1UZ Swapped Sierra need sticker measurements
- Heavy smoke on boost
- Stopping seat reclining
- Cambelt renewing guide
- crank pulley thread on yb crank
- Tyre size on front of saff
- Front door glass
- Sierra 3 door bracket rotted away
- closed loop chips
- Power upgrade
- Explosion in intercooler
- Sierra Cosworth tuning advice needed
- Amal valve tuning
- BOB conversion
- Wanted Cosworth Steering+DS Headlight Wiper
- Looking for a particular LHD 3dr Cosworth in the UK
- Interior trim
- Wanted: Sierra Sapphire Cosworth bits
- My Saff ready for Simply Ford
- Need to separate 2wd exhaust manifold - Scared!
- Need to crank over engine. How?
- sierrasrus Bumper brackets
- Fusebox ( relay & fuse ) identification
- Electric sunroof problem help needed
- 4x4 Cosworth Clutch cable
- Cosworth 4x4 driveshafts
- Police spec Cosworth interior ?
- Custom 2wd exhaust system
- SABTVRO
- RS500 Turbine Housing Clamp Dimensions
- What Front Windscreen for my Saph??
- Sierra Cosworth 3 door Header tank woes....
- ABS Refurbishment Help
- Cosworth fibreglass bumpers....
- Sierra Cosworth Info Request
- anyone got the part number for 3dr splitter
- Dipstick
- Refitting saph front and rear screens, need advice
- 2wd sappy fues box removal??
- 4x4 droning noise
- Rubbing when fitting cambelt cover
- Anyone know this 3dr Cosworth?
- Boa conversion glsi sierra
- rear window regulators
- battery drain - saff cos
- Sapphire door speakers
- Sapphire wet boot carpet
- 2WD Cosworths clutch cover question
- Help. Cozy crank needed
- removing dash
- Xr4i vs 2wd cosworth hubs
- Stunning RS500 Replica For Sale!!!!!
- 2wd cosworth genuine oil pump stockist
- Spark plugs
- saphh front bumper
- Dashboard modification
- brands hatch centre push clutch
- Best sump gasket and method
- Back to Back camshaft test
- Oil leak on my Dax Rush Cosworth
- Twin 40 carbs
- Car ID help
- best oil for t5 rebuild
- Rear beam bushings
- hub nut torque
- Can you still get the under bonnet rubber bits
- Offset on a 4x4 saph
- WRC breather problem
- Anyone know where these bits go ?
- saff boost issue
- Won't change down gear (type 9)
- turbo screech
- Cosworth Blow through turbo
- Any one know anything about this?
- Petrol flap opening mechanism
- Saph Cossie 4x4 heated windscreen washer
- Sierra 3 door 2.3 turbo
- How much it's worth
- Lock set swap
- Alloy Wheel Centre Cap Locks Sierra Cosworth what is a fair price for a set?
- 205 block alternative
- 2wd cosworth cylinder head follower port size/oversize follower supplier
- Stereo interference
- 2WD Cosworth brake pipe and ABS wire routing help !
- Cosworth rear bump stops still available ?
- Top feed injectors rail in 2.0 16v engine
- Rs500 grills (fog light)
- rear bumper
- Heater blower in A/C sierra
- Before and after..
- Sierra wagon rear seat belts
- White Saff E273 MSC
- Rear lamps mk1
- 4x4 Cosworth steering wheel leather
- Expansion tank.
- Gear knob identification
- Sierra steering wheel
- Seats
- The smallest of light bulbs required..
- 2.0 OHC (Pinto) MAF sensor difference ('91 N4B low MPG issue)
- Gauge holders
- Cosworth engine oil
- 3 door cosworth steering uj complete
- Brake bias valve
- 3 door
- Cam cover opinions
- 3 door spare parts
- 1987 wagon
- 2wd Sapp CO setting?
- Sapphire Cosworth Wont Idle
- Cosworth over fuelling
- Morette inner light blanking inserts, where from?
- MT-75 Box Problems
- Sierra springs
- Sierra chrono clock
- Removing driver seat slider.
- auto box to cosworth YB
- Bigger intercooler benefits?
- 3dr headlamp mainbeam
- Cosworth YB cambelt tensioner locking plate
- Sapphire Cosworth seat height adjustment
- What's it worth?
- Ford S(ierra)-Type
- Saph Cosworths with the RS badge
- Clutch recommendations
- Level sensors wiring
- Sapphire headlining replacement
- YB Dipstick Stuck
- Sapph Rear bumper mounts
- Raid / mountney snap off steering wheel
- 1987 estate a/c
- Airbox pipework 2wd 3dr
- Sierra Cosworth front lower ball joint
- Cosworth fuel tank
- 2WD Cosworth belt change
- Correct Gear knob
- RAID snap off steering wheel kit
- Meaty tires
- 3 door
- A treat for Xmas
- Where would I track down a lamp pod for a Saph?
- Sapphire cosworth ecoboost??
- gear oil smell
- Attaching a Sapp front Spoiler?
- Sapp cossie belts? (89 2wd)
- cosworth clutch pedal
- Oil sitting on the head under cam cover (Sapp)
- Need advice please with rear brake caliper piston and brake cable..
- front bumper backets.
- Moonstone Blue code
- Uprating light bulbs?
- How anal are you with cleaning you car?
- Dump valve fitting question
- Dash light bulb upgrade
