- saph 4x4 poor starting
- 3 way valve
- electric woes- heated window button illuminates
- calipers
- front bushes
- L8 ECU in a 3d
- replacing dump valve
- Turbo rebuild?
- size of the socket/star key to remove headbolts from my 4x4?
- saph speedo not working
- Not my day
- will a 4x4 turbo fit a rwd??
- Cossie suddenly got very tappety
- 2wd 4 pots reconditioning
- Power steering question
- DATA CHECK 200
- Group A coswoth coil loom ?
- starting problems
- Hot Coil Pack
- Vent blanking plates
- handbrake mechanism
- REAR DIFF OIL
- Valve Guides ???
- how hard to do a hedgasket on my 4x4!!,think mine has gone!!
- Whats this? (pic inside)
- 3 DOOR REAR RED/TINTED LIGHTS
- 4x4 speedo drive gear.
- Proalloy oil Breather Tank Pics..........
- 3dr cooling fan
- Number Plate A Bad Omen?
- ignition barrel stuck..
- diagrams
- 4x4 sapphire with escort wheels what tyres??
- whats needed for 2wd solid, too vented disk conversion
- how many rs cosworth was produced with out sunroof??
- has he given me the wrong part
- saphy 2wd cooling fan.
- Escort Cossy Rims
- non ford standard colours
- Need more power
- Cosworth high reving
- no power to fuel pump saph cos
- Missing at high revs?? help please
- Part needed (washer bottle)
- overheatin cossie+the fans aint cuttin in??UPDATE!
- Carbon fibre 3 door dash anyone
- where too buy a 6paddle from?
- Cosworth owners, I'd like some help ABS wise please.
- Wiring diagram
- Anyone know where there is .................................
- 2wd sapphire rear bumper still available?
- saph cosworth engine advice
- 10 x 18 on a 3 Door?
- 4x4 speed sensor, can you open it?
- SECS Monitor
- 2wd heat shield on a 4x4
- Ultimate handling fast road/occasional track day saff 4x4
- headbolts
- Boost Problem, somebody please help me!!!!
- adding a/c to 4wd engine
- Engine Flooding
- 315 mm. front disc on 2wd Sapphire
- Got a electrics problem. [windscreen washer fluid warning]
- Stiff throttle pedal...
- Whats are these pipes for ?
- quick question
- Escort intercooler in a saph 4x4?
- Rimmed!
- Steering Coupling 4x4
- Preferred cosworth tuner!!
- saph headlining
- Crank Bolt
- Little spring on clutch fork
- Cosworth misfire
- 3dr mudflaps
- A few questions
- Does anyone drive their cossie hard?
- Wire ringing on a cosworth
- ****HELP HELP HELP****
- wheel Focus RS
- Injector colour
- misfire advice needed please
- electrics... what do all these have in common?
- engine management
- CV joints
- CHANGING HYDRAULICS
- Throttle & Clutch cable removal and refitting
- extra power
- difference L6 Ecu and standart ecu quick please
- door cards repairs and advise please
- BD 10 Camshafts
- Turbodamper nut gone?
- Spax coilovers.....
- Autometer oil temp gauge fitting?
- opinions on my cylinder head, with pics
- Saff 4x4 - where does oil pressure gauge connect to?
- Picture of bush please
- fitting an intercooler
- fitting a 4x4 cooler to a 2wd, and a q about the 500 cooler
- gearbox and diff oil
- Rough running saff
- What Oil Temperature Are People Running?
- 4x4 service questions, quick ones
- Tappety cossie
- Sierra 4x4 hatchback
- Steering wheel retrim
- Has anyone...
- lots of oil smoke is comming out my exhaust!!
- new record !!!!!!
- 2wd ecu prob help?
- My little 3 door story :)
- diff noise
- best RS500 spec intercooler
- does a saph cossie diff fit a normal sierra?
- rocker cover 3 door
- Sapphire Cosworth Door Mouldings
- Turbo suddenly started whining louder
- slight missfire - updated
- Tyre sizes?
- where can i get a pair of new wings for my 3door cosworth???
- banjo on fuel filter leeking
- cossie fuel
- wheel ofset??
- saph , cossie fuel
- Intercooler Upgrades
- no power to fuel pump. :(
- rouge wires- anyone know where they go?
- How much front camber ?
- Compression??!!
- fan switches
- 4x4 props
- Oil pressure
- ABS Problems
- fuel pressure
- Carbon fibre
- help needed boosting probs!!!!
- 2wd cossie speedo cable
- diffrens betwen 2wd engine with 204hp and 4x4 with 220hp
- OVER HEATING HELP NEEDED PLAESE
- Tyre rubbing on Koni shock??
- cossie misfiring at 25 psi ?
- what about B363 AOO 4i cosie conversion still around ?
- Cosworth help needed!
- Boost problems!!
- lowering springs
- Cossie 3Door / sapphire car loom differences if any
- cosworth?
- MY OLD CAR, ANYONE ????
- cossie over heating please help!!!!!!SOS
- steering problem will my bodge be ok ???????????????????????
- Best way to 350+ ft/lb?
- is my old 3 dr and saff still alive ?
- 2wd with low power help
- 4x4 cosworth project
- is my old 3 dr still around
- steering joint collapsed please help
- Standard saff cossy bits wanted
- Dashboard question
- Cosworth Rear Suspension
- SAFF WONT START
- water pipes to heater matrix
- problems with my sierra
- Where can i get a rs500 style splitter for my saph cosworth
- 3 door help
- Electronic boost gauge question?
- 2wd saph loosing boost help
- Spark plugs
- sapphire floors
- steering wheel
- Weber-Marelli ignition module
- locker diff
- Exhaust
- lowering a saff
- standard fuel line`s..............where?
- Is my old car still around?
- 4WD or 3dr, who's driven both
- broke down
- t35 or t34
- 4x4 cos rear brakes on a 3 door
- Waxoyl - Good or Bad????
- Are 3 door hubs better than sapphire hubs ? Do TCA's differ
- cosworth problem
- How hot does ex manifold, turbo and downpipe get
- 2wd or 4x4 Turbo
- Autronics engine management???
- 4wd???
- Air Hose between T34 and standard air box filter
- set up for stage 3
- fuel pressure settings
- Timing Belt - What tension?
- tick over
- headlight wipers
- 2wd saf coz rear wheel bearings??
- over fuelling problem??
- sierra sapphire 4x4 ghia spring and shock question
- Rolling Road Set Up In Scotland?
- RS500 Intercooler Dimensions
- Loose breather flame trap
- t38 with greys, t34 with greys???????
- T3 Turbo Rebuild Question
- FedEx lost my parts ! Need part #'s
- Windscreen Wipers
- cossie vs scooby
- Radiator fan relay.
- 3 door grills
- RS500 intercooler/Air conditioning
- What type of spark plugs for cossie on green injectors??
- Converting XR4x4 to RWD
- engine oil?
- Engine out?
- Water pumps
- FAO: European Cossie owners - Exhaust
- oil cooler yes or not
- Engine/Gearbox info please!
- A few wiring questions
- plastic sideskirt clips needed
- "ELE" LEATHER INTERIOR
- 4x4 cosw vs. xr4x4 lowering springs?
- getting it back
- 2wd oil breather fitting help
- escos wheels
- wrc headgasket
- smokestone blue pics?
- ABS light come on
- anti-roll bar re-fitting (sapphire 4x4)
- 3 door wheel studs???
- what fuel pressure are you guys runnin?
- pectel bored
- fuel problem?? 2wd saff
- Cossie on greens...
- 4wd and 2wd turbos the same??
- O.e bushes.
- Amal valve
- Head light wipers?
- Tuning help needed....cmon guys lend a hand
- Different compression between cilinders
- L1 & L6 ecu
- head bolts????????????
- car is squeaking like a mouse is stuck help!!
- crank regrind
- ABS 3 door, saphire 4X4 and XR4 what is the difference if an
- Colour code for RS500 black
- Cosworthshell = non Cosworthshell ????
- Aftermarket air-con for a Sapphire Cosworth.
- Coil pack conversion
- ABS Diagnostics Port
- a few bits for my shonk i just got
- Sierra 4x4 Cosworth front right driveshaft problem
- 2wd Saph suspension on a three door?
- 2wd Ignition Module part number
