- EEciv plsnum with TB and idle speed control valve on 2wd
- headlamp wipers
- poor head lamps/3 door
- What size comps for saff?
- t34 compressor housing
- cos wanted
- rocker cover painting
- xr4x4 shaft problem
- Sapphires on 17" rondells pics
- cosworth Compression??
- front bumper bracket pop rivets for a saff
- throttle cable clip
- How to lower a sierra p100
- 2wd diff oil
- abs semsors
- Lost keys - don't live in the UK
- 2wd /4x4 antiroll bar
- clear tails
- Swirl pots
- monte wheels!!!
- Cosworth late head bolts
- wheel and disc size help
- Power Engineering Stage 1 - change fuel pressure?
- L trim on a 88 sapphire?
- Whats my Saff worth realistically? NOT a for sale post
- cosworth cams
- Headlights
- Cossie Cam Followers
- Exactly what needs to be done to fit a 2wd beam and arms to a 3dr
- 3dr 4x4 anti roll bar?
- 3 door battery
- cosworth rear arms?
- Price
- 3dr fuel rail help
- Are 2wd and 4x4 door mouldings the same?
- C Pillar trims - how do they come off?
- finally bought me a Sapph
- Auxiliary and cam belt kit.
- Sapp water pump advice needed.
- carbon bits for a saph
- 3 door coz best actuator+air filter to buy?? help!!
- Sapphire Suspension???
- fuel reg
- Show us your saff/3dr engine bays
- jenspeed modded plenum elbow
- saph radiator fan
- Headlight wipers
- 2wd sapp makes a good track car?
- Recommended fuel or remap??
- rear brake issues
- 4 x 4 fuel rail
- Sloid rear beam mounts - where from?
- intercooler and rad for 2wd saff
- what would you do.......
- 3 Door wiring
- Laguna splitter - help?!
- my old saff has come home
- Oil Light Flickering
- aeroquip GT30 oil drain pipe
- Sapp 4x4 engine into 3door, what's required?
- What tyres for a 4x4 saph?
- Bailey breather set-up help
- Sierra (sapphire) cosworth 4x4 transmition questions
- Another Revs/Idle Problem
- no 2-4-reverse gear
- New Oil line with filter?
- K650 MEJ silver saph whereabouts?
- Saff cossie 4x4 reving up
- Cossies and running rich
- 2wd throttle position sensor voltage testing.
- who makes a good front arb?
- front arb captive nuts
- Ex Rally car details
- Idle speed control valve
- sapphire seam welding with coil overs
- 2WD Saff Cossie Rebuild
- sierra fuel gauge/sender
- 1992 World Rally Championship - Focus on works group A Sierras (GREECE UPDATE !)
- 3 Door Comp CXN's
- Amal valve pipes
- 3 door rims
- Greek Monster!!!@@ LOOK!!!
- sliding sunroof blind
- 3 DOOR
- rouse (sp)
- incar bleed valve
- Door Rub Strips
- Engine rebuilt ???
- warning display panel..??
- 2WD Probs
- will it deliver ?
- 4x4 saph cossie feels like kangaroo petrol!
- Second fan not working
- iscv
- strange stutter just before boost
- oil stain at tail pipe
- looking for rear wishbone
- INA Genuine lifter (anyone brought matt lewis one's)
- head mods for bd15 and bd16
- are back boxes interchangable between brands?
- front wheel bearings
- turbo damper 3dr
- difference rear calibers between 4x4 an 2wd
- Garrett air adaptor
- Cosworth Sump Plug Oil Return Fitting???
- 2wd sump removal & crank shaft seals
- Sourcing race springs
- Simulated narrow band signal to the L8 ECU
- brake fluid sapph 4x4
- D255 YAP
- Diff breather
- Authentic Ford indicators
- clear tails?
- alloy header tank for standard plastic (3dr)
- Set up's
- 2wd oil breather whats best
- saphy speakers..
- saphy speakers..
- cossie cam caps
- Alloy bushes for inner track control arm mount?
- cossie smoking intermittent
- saff cossier iterior clock
- head gasket?????
- Paint Job
- Average price
- 3 door coz blown turbo.....head off??? (spindle nut fell off)help please
- New clutch time
- MT75 mainshaft
- Boost Controllers..
- Any Ideas?
- Used 9 inch differential reliability
- 3 door dash
- L8 REPAIR?
- rs500 plenum with 4x1000cc ?
- Sapph brakes - whats their limit?
- 2wd sump removal
- 3dr front hubs help
- Brake and fuel line clips
- yb head numbers???
- Grille Mesh
- the car shivers when drives backward...
- Garrett turbo .t3.57trim comp wheel+housing upgrade set
- Next job - beam dropped, any idea on offset bushes?
- any ideas whats wrong now?
- Interior light problem
- T34 hybrid turbo?????
- Turbo compressor wheel T3-T35-T4?
- Lowering?
- KnN cone filter for cossie
- Polybushes in front TCAs
- Shocks and springs for a 2wd sapphire cosworth.
- Front ARB problem...
- who's the owner of f47sfh moonstone saph?
- Who's car got the most interesting history ?
- valve cut outs in standard pistons?
- new lights
- Any 1 know this 3 door
- 2wd or 4x4
- 3dr 17' wheels as the original!!@@@look..
- NGK-DENSO equivalences ??
- hydraulic clutch kit help
- Lowering a 4x4
- Gaz Gold coilovers on Sapph?
- Smokey saph
- Is this a 3 door hub?
- Sapphire Amplifier slot
- Standard Cossie Breather System
- 2wd/4wd inlet manifold difference
- T38 spec discussion/advice
- my engine - what would you do?
- Cosworth Turbo garrett T35 Vs T3 ?
- bargain.....
- which thermostat?
- Setting TPS help please
- Sump removal and refit
- anyone uses this plenum?
- rear axle mdoifications on 2wd beamd and arms
- Rear bumper clips on saph
- Rear badges on saph cossie show me pics
- The wheel question...
- replacing oe intercooler for rs500type
- abs problem
- 200block+2wd head??
- saph pic's thread. can't find it??
- Battery draining on saph?
- saff cossie 4x4 oil filter
- Spec-R header tanks
- Alloy Wheels
- Oh no ! Cracked block.
- Removing the ignition cylinder (key)
- side body thingys
- cosworth electric? problem
- smoked front indicators on a saph
- Oil catch tank into side of block?
- Cossi on e85
- Front anti-roll bar mount bolts. Where?
- WRC Escort Cosworth engines
- ecu breaking down
- This familiar to anyone..??
- Saph Brakes
- Parts shop
- 2wd engine on l8 & 4x4 loom
- "R&D" gearbox
- voltage drops during max boost
- bigger front discs
- Bonnet release Question
- Bolt Thread Size for 2WD 4 Pots?
- aeroquip fuel lines
- which battery
- pics of a lowered 3dr, please..
- Brake wobble ???
- adjustable rear beam and compression struts
- replacing a lame horn
- saph boot install ideas
- Saph idling proob
- magnex exhaust catching speedbumps
- Where is the "problem" ?
- TH Lines Wheels For 3dr
- Best air filter for stage 2 saff cossie 4x4
- changing rear windows from manual to electric???
- Boost pressure control valve
- where'd my half moon thread go?
- carbon roofskin
- Great Cosworth News
- Quick question
- Free flowing air filter
- Cossie 4x4 revs
- RS Number Plate
- Saph 4x4 Discs
- ATB
- Piston Scoring problem
- sapphire vs focus st vs 325ti
- spring size bilstein grp A
- Half Moon Seal Problem
- cossie losing water
- Making up a hydraulic clutch
- sierra 1.8 cvh
- Removing sunroof on a saph
- NOS.....
- workshop manual
- Spark plug choice
- 2wd/4x4 power steering pump?
- rusty sunroof
- Fuel regulator question
- fit 10.5" jaguar diff
- Turbo timer.
- manifold on 4x4 engine.
- Steering ball joint
- 17" tyres on a 4x4 saph??
- Cossie's That Cant Be Driven UPDATE
