View Full Version : Ford Sierra / Sapphire / RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. stronger gearbox/diff etc.
  2. looking for info on Sierra CVH roller lifters
  3. rs500 inlet
  4. 2WD turbo heatshied ? Ally ones ?
  5. gauges
  6. wheel help
  7. ruud racing saph kit?
  8. 2wd saph gearbox rebuild. help please
  9. Dump valve's
  10. Does anybody out there know my new three door?
  11. wot oil??
  12. cosworth rocker cover
  13. Cosworth Mud Flaps
  14. How do you remove the exterior qtr trims from a 3 door ?
  15. Engine hesitating and backfiring when coming on boost
  16. Cam Belt Change
  17. miss fire
  18. Suspension shims
  19. What should i do
  20. DOES ANYONE KNOW MY CAR? G57 AOO
  21. Wheel offset
  22. Oil leak at front of cam cover 4x4 Saff
  23. Heater blower motor
  24. how much boost do you advise??
  25. Quick Question
  26. Did sierra cossys come with 4pots standard?? newby soz
  27. front number plates- what sizes do you have?
  28. Water Temp Sender
  29. Will an XR4x4 front cross member fit my 2wd sapphire
  30. garage warranty
  31. Compomotive CXN WHEELS for 3DR
  32. rs turbo engine in a sierra will it fit ?
  33. Saff cos 1993 standard alloys ££ value??
  34. Are these intercoolers any good
  35. whats the difference between a 2wd and 4wd engine loom?
  36. Oil Seperator?
  37. Compomotive wheels
  38. Idle control valve
  39. what is your top speed in your stage 1 saff???
  40. What spark plugs can you reccomend
  41. Rear Diff Mount
  42. Distributor cap and rotor arm..........
  43. Help needed ASAP please!
  44. I need help, what chip, injector should I run ???
  45. Hiding wires
  46. Philloy Products need pics
  47. Steering rack questions
  48. 4x4 cossie rear wheel bearings
  49. STAGE 1 OR MORE POWER?
  50. 4x4 bonnet carbon air vents
  51. Cossie clocks / white dials
  52. oil breather / oil seperator
  53. saff interior
  54. saphy throttle pot
  55. centra wheels
  56. New Cossie advice
  57. 4wd conversion
  58. Running and boost problems
  59. Saff 4x4 rear strutbraces
  60. How much bar load pressure with 300 BHP?
  61. Turbocharger number of revolutions with 1,5bar
  62. level 8 ecu
  63. help
  64. running MSD coil pack with autometer rev counter
  65. Original 3 Door Wing, Bonnet, Grille
  66. saff scorpion exhaust
  67. Photo of morretes
  68. cosworth Starting problem
  69. spark plugs
  70. cossie pistons
  71. pro alloy intercooler fitting ?
  72. Urgent Help Needed, ABS Wiring Diagram
  73. Saff Roof Liner
  74. interior trouble
  75. Exhaust manifold to turbo gasket?
  76. 2wd/4wd engine loom
  77. 4x4 saff gearbox
  78. Knackered wheel bearing cause discs to warp?
  79. Which is better 2wd or 4x4 exhaust manifold
  80. nearside front driveshaft
  81. 2wd Saph Tyre Sizes
  82. Saff bottom end rebuild advice please.
  83. Thinkin about Cossie ownership...
  84. mis-firing RS500!
  85. Piston ID
  86. lets see your cam covers
  87. new engine
  88. A good Brake Set-up for a Sapphire with standard 15"
  89. Crank Pulley
  90. 3 door steering question/help
  91. 4x4 rear wishbones
  92. Inlet Length on Sweedish Inlets
  93. how do you no
  94. parts.....
  95. Only 385 bhp.....!
  96. Escort anti roll bar
  97. what is this actuator
  98. where is the best place to get a 2wd gearbox rebuild?
  99. backlit saph dials- colour options?
  100. Pics of cossie's with mudflaps on
  101. Are there any internal / mechanical differnces between a ...
  102. Is the L8 ecu in a 1990 H plate 4x4 Sapphire ?
  103. fuel pumps
  104. just bought my first long awaited saff does anybody know it?
  105. standard airbox of group a filter
  106. rear wishbone bush`s
  107. length of cossie?
  108. Wheels & tyres for 3dr.
  109. Aqua-mist water injetion/intercooler spray
  110. Oil cooler recomendations???
  111. does anyone have a good 2wdsaph gearbox 4 sale?
  112. Grp A 3door rims
  113. taken the head off, what a relief
  114. size of rear driveshaft nut on cossie?
  115. Random wires
  116. Slight misfire
  117. FUSE BOX
  118. need some info,
  119. Which springs
  120. engine rebuild.........
  121. help/ photo required
  122. Setting up a -31 actuator, help please
  123. cossie clocks
  124. Mike Rainbird is ACE
  125. How Reliable Has ur Cossie Been??? (please contribute)
  126. help needed
  127. Suspension mods to 2wd
  128. earliest registered 4x4 saffs
  129. Amal valves
  130. Special tool
  131. Buying a Cosworth
  132. saff diff
  133. saph 2wd missfiring badly! help!
  134. Oil ???????????????????????????????????????
  135. Coil pack conversion
  136. fuel pump and vibrating
  137. Fitting polybushes 2wd saff
  138. Temp gauge fitting?
  139. YB/pinto bearings?
  140. rs500 intercooler and alloy rad measurements
  141. need a few inputs
  142. rs500 intercooler
  143. Oil Separator / Breather
  144. Fast Idling Probs
  145. "Cosworth Eater" Laugh, I Nearly Dropped My Kebab!
  146. P100 body
  147. good fast road engine spec???
  148. Head gasket thickness
  149. Not boosting Properly and Stutter.
  150. 3dr 8J & 9J tyre sizes
  151. higher or unchanged compression.
  152. Some cylinder head questions?
  153. flipping abs
  154. running on 3, clock flickering
  155. Where I can buy Sierra RS Cosworth bumpers & wing?
  156. bd10 cams and vernier pulleys
  157. BD10 Inlet - BD14 Exhaust ??????
  158. Alternative suspension pivot point
  159. Smoking Probs. Expert Advice Needed.
  160. 2nd Fuel Pump Relay In the Boot??
  161. Help ! starting prob
  162. DTM Mirrors for Sapphire
  163. Toyo 888's!! Track day guys
  164. xr4i
  165. Help with inside front Hubs on 2wd sapph PLEASE
  166. Help: Cossie fuelling hint??
  167. Air injectors
  168. Exhaust Valve - Where From
  169. Heated Front Screen Not Working?
  170. front mud flaps
  171. Fuel pressure
  172. SIERRA COSWORTH L6-L8 ECU
  173. 2 wheel drive compresion
  174. This is a new one!! Help needed!!
  175. blown head gasket, how hard to change it
  176. Any one running Super leggras on their Saff?
  177. Stock wheel and tyre Escort on rear Sapphire
  178. Bumper brackets.
  179. 4x4 Cosworth Buying guide???
  180. 6 speed gearbox options
  181. Cam kit for xr4i 2.8 v6 colonge
  182. carpet
  183. Standard lamps vs Morettes: your opinions thankyouplease
  184. Is It Common For Rad Fans To Be ON When RS500 Cooler Fitted?
  185. 3 door , skooshers prob
  186. power conversion to my westfield costs??
  187. 18' rondells
  188. Do they make 18" Rondell/Engells for 4x4 Saff
  189. I have a simple question, help please.
  190. Hydraulic Handbrake
  191. IS THIS A GENUINE 4X4 WATER PUMP???
  192. H reg 2wd Sapphire cosworths
  193. Pistonheads legendary cossies
  194. 2wd and 4x4 head differences and costs
  195. Electric to Manual windows, HELP !
  196. please help my saph is dead
  197. Cossie Problem
  198. Pic request, Mercury Grey Saphs
  199. mot ? will i fail if
  200. RS STEERING WHEEL BOSS
  201. front shafts on 4x4
  202. 2wd and 4x4 Master Cylinder the same?
  203. Broken Wastegate Penny
  204. 2wd manifold
  205. Koni Damper Settings
  206. rear beam bush
  207. 3dr Motorsport mirrors?
  208. coolant system
  209. What's wrong with my window?
  210. poly bush`s
  211. Any experts with abs pumps/wiring ?
  212. boost????
  213. COSSIE PLENUM
  214. Where can I found RS500 AIR BOX lid ? (tittle rewritten)
  215. saph elecmirror switches? are they the same in any other car
  216. 2wd cos abs vibrating pedal
  217. Bearing Greese
  218. Sparco Rollcage
  219. headlight wiper arm needed
  220. Anybody running RS7's with 215/40/17's/Koni's/35mm lowered?
  221. Pictures wanted
  222. XR4x4 front driveshafts for saff 4x4
  223. Saph 4x4 Cosworth Transmission Noise?
  224. water pump
  225. 2wd misfire
  226. does any bodey remeber this car ??
  227. stupid earth faults!!!!
  228. Can you still get the side door mouldings for a 2WD Saph?
  229. which stage 3 chip?
  230. FUEL PUMP RELAYS????
  231. RS 500 Plenum
  232. What Will +0.5mm Pistons Bring My cc Up By/To?
  233. Valuation Please - Ebony 1991 J Sierra Sapphire Cosworth 4x4
  234. Copper Ring Round Cylinder Bores. What is it and why?
  235. Alloy Wheels for Saffy 4x4
  236. Has anyone managed to fit 245/35/18's on a Sapphire?
  237. disappointing results
  238. How do i change the foglight bulb
  239. Cosworth Management L6
  240. Slight Problem With Cossie
  241. best bet for removing T5 gearbox
  242. What clutch should i use in my 2WD cossie??
  243. Esc Cossie alloys
  244. REMOVING THE ENGINE IN A 3 DOOR
  245. ABS Intermiten lights 4x4 cos
  246. cosworth , rocker cover gasket prob
  247. Escort Cosworth suspension springs fit in a 4x4 Sierra?
  248. Cometic head gaskets
  249. Parts stolen, can you help me out
  250. Tips on running in my engine rebuild??
