- t34 turbo suppliers
- Exciting times!
- How much head work is needed for 500BHP?
- poly rear beam bushes
- Front diff strengthening plate??
- Knock sensor tech data needed
- oil for diff and g/box
- 4x4 Saph FORD Badges??
- rear bumper
- polishing standard cosworth rods ???
- Steering racks 3dr & sapph
- 2wd brake upgrade
- changing inner TCA bushes, any tips?
- Almost run in/
- cosworth diff oil level plug
- 3 door arch and sideskirt fitment
- 3 door spoiler blanking plugs
- cosworth fan wiring loom
- what max disc size with 17 mo`s
- feul pump wiring diagram
- finally got engine running and now oil leak!
- Aeroquip/goodridge hoses
- Cabon air-ducts wanted
- 3 DR drive shafts
- What colour are foglight surrounds on a saph?
- Up and down movement on my steering wheel (saph)
- Exhaust blow?!
- Brake fluid?
- brake sensor cable.
- sapphire side trim's....
- rattling on 2wd saff
- 7.5 diff cwp ,same as??
- vibration on 4x4 saff
- sapphire side skirt rivet's.
- Making a 2WD Big Wing Sump?
- noise on the overrun
- Saff 4x4 Diff change
- gauge holder 3x 52mm late spec dash
- Irratic rev counter
- amber lens part number
- Lamba sensor
- 3dr alloys
- plug gap
- Sapphire Rear Panel
- What power you running through your standard 4wd transmission?
- 2wd cosworth wheel bearings
- My turn - abs light stuck on!!
- 2wd or 4wd?
- How to get doorsill trims of??
- ext.gated t34?
- pinto tappets
- Head Gasket
- cosworth 4x4 and xr4x4??????
- Torque setings
- timing marks
- Smoking on boost...
- alloy flywheel for rallying??
- Cam gasket, half moons and cam seals
- What are the biggest disc you can fit under 18" Comp MO's?
- 2wd x 4wd clutches Help please
- XR 3.9 diffs into 4x4 cosworth?
- ISCV Cosworth?
- 4x4 sump questions (threaded hole and leak)
- 235/40 17 R888 on Fronts ??
- track rod ends - same on all sierras?
- 2wd sapphire interior
- YB 3DR Head problems - Advice Needed PLZ
- Identify make of s/s exhaust
- Solid rear beam bushes
- bumpers
- 4x4 problems
- 4500rpm mis-fire fixed
- Spoiler Screws/Bolts
- Ap/Helix/Alcon
- running problem (HELP!)
- Spark plugs 'Help' pic
- Roll cage and Harness wanted!
- Any difference between 2wd and 4wd hydraulic lifters???
- how do you dissconnect fuel pipe?
- what's the difference?
- Full Geometry Set-ups
- Best glue for bumpers?
- brake light and abs light on
- HID Kits on a saff.
- Ht leads
- Trolley jacking points
- sorry.....
- Anyone have Focus/Fiat brembos on a 4x4???
- 18s on a saph
- 3door bumpers
- number plate fitting kit?
- Turbo Builders?
- Front hub nut torque on 4x4 saph???
- 4x4 fuel pressure regulator
- Silkolene oil grade?? Help!
- USA Xr4ti racer build
- Sapphire bumper sagging
- 4X4 more power
- steering rack
- bumper trim fitting
- How much (aprox) for a turbo rebuild?
- Sapphire carpet/underlay?
- Query on a turbo heat shield for a 2wd cosworth.
- 4X4 brake upgrade
- anybody own E690 MWP black 3dr?
- clutch cable conversion
- Rear hub wheel studs & bolts !!
- Very slight hesitation on throttle
- Clutch differences 2wd Vrs 4x4
- ABS light?
- co2 on 2wd saff
- roll cage?
- rear parcel shelf speaker size
- Fuel pipe
- Won't start
- Pulling the plug on ABS, Literally!
- replica RS500 front spoiler?
- 3drs with Focus RS wheels?
- ABS sensor 4x4
- ECU technical trivia question - Which chip to get for my ECU (pict. incl)
- 2wd Engine loom
- 2wd pump terminal connectors ?
- Jubilee clip size for thermostat housing and radiator on 4x4???
- 3dr rear disc upgrade?
- how do you remove hand brake cable?
- cast flywheel advice
- 2wd sapphire cosworth plastic header tank.
- Whats the going rate for a 3 door interior?
- Thread Size on block for breather
- annoying knock from pass side front is back .
- RS500 v 4x4 Saph Thermostat housing
- Sapphire cosworth "rs 500" splitter
- Cosworth ABS on/off switch
- What sort of power do you think my car is? and top speed?
- 4x4 Dirveshaft
- 4x4 fuel rail to 3dr fittings?
- Leaking fuel regulator
- Fitting coilovers to a 2wd - help please
- New Engine....
- boost and oil pressure gauges fitting?
- oil temp/pressure gauge help
- 2wd cosworth rear anti roll bar drop links!
- Externall wastegate on my 4x4 saff
- Fire Extinguisher for a 2wd sapphire cosworth.
- 4x4 vs eeciv plenum
- Diff or gearbox
- plugs soaking with fuel+wont start unless dried
- Rs Ecu cover Genuine or not ??
- driveshaft question...
- beam removal where to support car??
- Speedo problems
- coilover opinion saphire 4wd "HELP"
- broken exhaust cam
- Sapphire clutch rachet
- feul pump problems :(
- stranded cossie with a leaky radiator
- Cosworth fuel tank... help!!!
- f***in b****rd car....
- crank sensors for cossies?
- Sapphire rear bumper moulding in black wanted!
- Thermostat housing 3 door cossie
- 2wd cosworth manifold
- Cruising speed problem?!
- HT leads? ford ones or 909 leads?????
- Removal and replacement of fuel pump
- ecu issues!!!!!! help please
- Saph cosworth front splitter
- 4x4 motorsport loom >>> 3dr car loom
- fuel tank fixings
- et38 offset will they fit my saph???
- top speed for 4.44 on 18" rim
- l8 ECU
- 2wd hub nut size?
- steering rack question
- has everyone seen this?
- Sierra 2.0 Ghia 1985
- Saff suspension/springs?
- tempreture gauge
- Here we go again!!
- Rear quarter for a Sapphire
- Possible Water Pump Gasket Gone.
- Trik Motosport Problem!!!
- Saff cossie head lining
- changing rear splash shields
- are arp stud/nut kits re-useable?
- failed mot today,welding needed
- thermostat housing O ring
- Grp A coil partnumber
- Car won't rev over 4.5k under load
- rear beam bushes (HELP!!)
- Brake pipe adaptor thread size
- front amber indicators for my f plate saph??
- Best clutch for 400BHP 2WD Saff
- Im Building my car, but need help to specify the engine bits
- mot time!!!!
- Torque settings required
- stilauto,s
- Electric problem in my sapphire
- Fuel lines
- hunting on idle?
- Making adjustable track control arm out of std items
- 2wd suspension problem - out of ideas!!
- Sierra/sapphire mirrors...
- tyre pressures
- 4x4 rear pads
- PTS Chip
- Pistons change or not ?
- Focus rs brakes on a 2wd sapphire
- Still Looking for a center console with no arm rest
- Where to get a Cosworth Turbo Housing
- 3dr windscreen scuttle trim thread lost?
- swedish inlet
- ABS brains - somewhat universal?
- focus rs front rotor on a 4WD
- Closed loop lamber sensor
- FPR 2WD
- Water feed through turbo advice
- Sierra P100 1.8td diesel books
- Cossie Rear Beam
- 500 lower rear spoiler
- Are 2WD and 4x4 turbo heatshields the same?
- Fuel Tank Cosworth (help)
- 2wd REAR DIFF
- sapphire rear beam's..
- Module location for dash board warning indicator
- Poly strut top mounts?
- squeak - could it be rear arb bushes?
- Widest wheel on a saff?
- 4x4 driveshaft
- 3dr tank guard?
- 2wd Sapphire plug leads
- Fuel filter, fuel pump & wiring question
- Saph Cos tailgate badges??????
- Which panel filter for a Sapphire 2wd???
- trying to find the previous owner's of my moonstone blue 3 door cosworth
- is this a standard t5 box??
- Loosening hub nut
- solid rear beam mounts
- Intercooler from Volvo - good for Cosworth Sierra?
- Fitting RVS doorsill protectors
- 3dr rear beam mount??
- what injectors has my car got?
- different t34 turbos?
- t-56 on 2wd.is it posible?
- Cost of fitting new suspension
- Track use
- tightening torques for studded blocks
- Saph 2wd boost cut???
