- Oil in cooling system on long studded engine
- Retro fitting an escort cosworth rear ARB to a 3dr
- Opinions on rolling front arches?
- Desperate to find a spare part
- Owens GBT turbos
- Engine machining
- Gearbox oil draining and oils
- Instrument dial removal
- Sierra
- 1984 Mk1 parts wanted
- Warm start issue
- Ford Sierra Cosworth 4wd Cloth Trim
- Cosworth splitter help
- Diff breather
- Is this timed up right? (New belt and tensioner)
- YB engine number
- Power steer rack refurbishment
- Charge cooler updated cooling
- Steering rack
- Sierra cosworth oil consumption
- Turbo to down pipe leak
- Brake Bias Valve
- Looking for help.
- Guess the bolt location (no prize for winner)
- Hi Spec poor customer service
- Rear shelf speakers/tweeters
- Hazard lights switch
- 2wd boot badge position?
- Hub splines very tight
- Cosworth 4wd springs option, ahmed bayjoo no good
- Suspension recommendations for 2wd saph please
- Cosworth 2WD cv plunge joint
- Rear hub question
- Powerflex black series rear beam bushes fitted.
- Vibratechnics gearbox mount. Loud!
- Cosworth driveshaft gaitors
- 2WD drive shafts
- Camshaft answer
- Wheel bearings
- Brake pipe location
- Fuel flap lock mechanism
- Turbo Heat Shield Repair ??
- Cosworth speedo clocks
- water pump options/upgrades?
- Rs500 splitter pics?
- Cosworth 2wd steering wheel ford badge
- Sierra (and Granada) ABS Expert Wanted
- Water temp sensor
- Fired up after 4 years dead
- Oil/water stain dash cluster
- Rear axle bearing housing torque plus seal deep
- Sapphire "ford" badge dark blue - paint code
- Engine bay decals
- Cosworth over fuel misfire when cold
- Seirra 8v DOHC efi
- Race Yb Vernier pullys ?
- Air box clips, are they unique ?
- Timing belt cover bolts
- Battery terminals, multiple cables?
- Amal valve relocation
- Water seals T34
- Finis Code
- PF09 TPS suppliers?
- Coolant system refill
- Wiring woes, what are these plugs for? (2WD saph)
- Gasket needed between block and PAS bracket?
- Sierra RS500 Coilover
- Garrett t4 marum shaft
- Best literature to follow for Sapph Build
- Cosworth 2WD rear brake splash guards
- Sapphire drop link fixing
- First proper drive this year.
- 4x4 cam cover "wAnted"
- fuel gauge issues
- Hi Spec handbrake calipers
- Thundersaloon build Progress
- Supra diff oil
- T34.48 held boost pressure
- brake master cyl actuator
- Part numbers & diagrams
- Sierra pinto exhaust/4 branch
- cosworth salling
- Original 4×4 sapphire back box
- Rear shelf speaker covers wanted
- Sierra MK2 sunroof wanted
- Sapphire rear brake splash guards
- Droning noise from engine - Appears when warming up (with video)
- 4x4 Sapphire for sale, only £70k!!!
- Koni setup
- Sapphire Carbon Firbe Roof
- What size Disklok?
- Loctite 518???
- Supra diff weir kits
- New boots
- Koni suspension question
- 3 door petrol cap
- modine oil seals 4x4 sapphire
- Cosworth strut dust covers
- Looking for some 4x4 sapphire rear brakes
- Driveshaft half moon washers
- Side skirt clips
- Roof aerial
- Length of standard springs 3door Cassie
- AB07 cam
- WANTED sapphire Cosworth headlights
- ABS Sensors
- Yb aux shaft pulley issue
- front seat belts wanted
- what engine oil to run in a 400bhp cossie
- replacement seat belts
- What brand immobilizer is this?
- Saph wipers won't park
- Another 6 degree rear beam question....
- Fuel fail to Regulator hose
- Master Cylinder pump
- 3Dr with Compomotive Th's
- Wanting to buy 3 door sun roof seal
- Wanted ...sapphire cosworth rear brakes
- Rad fans
- wheel nuts
- Mk2 front arch liners in a 3 door cossie
- Fuel rail adapters
- 3 door coosie loom
- Anembo vs Quaife Peg type pulley?
- Cosworth rear Stub Axle failure
- Rear camber shims.
- Mk4 Mondeo 2.0 tdci fault
- Delete - duplicate post
- Boot equipment
- Gearbox oil
- Anembo cam pulleys?
- Turbosport.net clutch/ flywheel?
- Noisy tappet(s) at mid temp - Quiet when cold and warm / 3dr Cosworth
- injector problem and Doubts
- 4x4 plenum
- Saph cosworth 4x4 clutch cable
- Fuel lines and fittings
- carb issues
- WANTED Sierra Cosworth bonnet stay and engine bay tag
- Undertray
- Replica RS500 front bumper
- Sapphire o/s/f (drivers) moulding part number
- Driver Seat
- Roof Rail fitment info needed
- 7.5” Diff
- 2wd & 4wd front fog lights
- Cam cover differences
- Seatbelt Adjuster mod.
- Sapphire Door Card Leather / Vinyl.
- Sierra Cosworth 2WD front anti roll bar H13
- Free 10 bhp upgrade!
- Couple of 4x4 questions (fuel pump & ISCV)
- Standard airbox & 500 style intercooler issues
- Bumper ford sierra cosworth rs 3 doors
- Original airbox fitment
- 2WD custom breather setup
- Supra diff
- Piston oil jets
- P/S Pump bracket to block?
- New coolant tank
- Difference between normal Sierra front hubs and cosworth ones?
- What’s this and how’s it work
- Bulkhead sound deadening material, what to use?
- 6 degree beam question
- Sound proofing / Sound Deadening / Sound Dampening a Sapph
- Live engine monitoring options
- Rear beam bolts just spinning, anyone had to fix?
- Side skirt rivit head colour
- Fuel lines
- Any idea what this is
- Sapphire Cosworth performance rear brakes
- Fitting the Cosworth auxilary belt pulley
- Insurance - During Restoration
- Gearbox cradle help
- Chassis Rail - Internal Diameter
- Diff gasket
- t34 or gt3071
- Ahmed Bayjoo springs
- Poly bush or standard
- Cosworth 2WD mounting
- Rear anti roll bar
- Sapphire 2WD suspension
- Amal Valve and TPS Setup
- Fuel pump feed??
- Getting my 1st Sierra & Introduction
- Petrol Filler Neck
- Fuel pump correct behavior
- Amal Valve issue (Found chasing high idle)
- YB cam tensioner nut sizes
- wire grille for 3 dr
- 3 door Cosworth chassis Vin plate source
- Need a boot lock gasket for a saph, is this the same???
- best cam followers
- Original radio unit request
- Parts wanted to replace stolen ones
- Sapphire 4x4 dails/cluster differences
- Sierra search begins...
- Looking Rear wheel left arch liner , front bumper mouldings and brackets
- Sapphire gauges
- Sierra Cosworth handbrake cables
- Sierra brochure
- Big wheels on race car
- Is a saph cossie boot lock the same as mk4 escort/mk2 Orion?
- 1986 sierra 5door 1.3
- Sapphire Cosworth Rear Wheel Archs
- Ford Chassis Plate Data
- Mk 2 Sierra / Sapphire Build plate Data
- MK 1 Sierra build Plate Data
- This post about the difficult life of Ford in Russia...))
- RS from France
- 3 Door Sierra Cosworth Vin/Coloured info plate
- Anyone know where to get carbon exhaust surround?
- group a engine mount kit...
- 3door cosworth project sell or build
- compression mounts question??
- Mouse in my cossie help??
- 3dr fibreglass arches and skirts
- 6 degree beam questions ?
- T5 gear knob
- Yb cosworth oil leak question
- shop to buy a new T3 .63 exhaust housing
- Cosworth 3 door
- Yb engine advice.
- Cosworth 2wd - 4x4 oil pump
- RS500 Cosworth Alloy wheel paint codes
- XR4x4 after minor repairs,wheels refurbed,polishing,waxing and sealing.
- P100 manifold/turbo
- 3 door sierra bodykit
- Baby Seat Suggestions for Sapphire Cosworth
- Any difference, Ford DOHC (I4) heads.
- Cossie Headlights
- Sierra Cosworth wont go over 3krpm
- Help / new sunroof window seal
- Unknown Cosworth Wiring Plug
- Ford spare parts
- Coilovers on a Sierra
- Comp MO6 on 3 door – 18”x8”
- Sapphire standard headlights or twin
- 2WD head work before / after
- Compomotive alloys
- Good base model Sierra website
- Oil Breather Connection access
- Sierra Cosworth 3door Turbo T3 360 bearing new
- What's this part from
- Sierra ABS brake pump into Capri
- Looking at buying a 3dr, seeking advice. Thanks
- advice on forged pistons
- Correct flywheel for Mt 75 with 2l Zetec
- sapphire cosworth
