- Cosworth cylinder Head rebuild help!!!!
- fao hard users on IK plugs
- what places to check for rust
- help alarm wire for the 4WD late version
- roll cage
- best chip stage 3
- Need 3 door rear sway bar pics
- spring weight/length?
- putting a 2 litre zetec into a sierra
- Saff petrol flap gasket, tibbe key, filler neck
- 3 Door rear lights
- sapphire surround rubber trim what's it worth?
- What should be standart gasoline pressure
- What's up with my Wide Band AFR Gauge?
- Air/Fuel gauages
- How long is life of 4x4 engine
- Andy Rouse RS500 BTCC Car
- this cosworth
- offest for 3 door with coilovers??
- hybrid 8v
- offset for comps on a sapph?
- T3 glowing after 10 minutes on track.
- Removing Saph boot spoiler
- 3dr cossie bodykit
- Fan motor cover
- 2wd Thermostat clip!!! help
- External Wastegate
- spark plug coulouring..?
- modding Saff crossmember for roll center
- How to make your SECS gauge work with a Coil Pack Conversion
- 3 Door Brakes
- saph cos 4x4
- 18" alloys on a sierra
- Rouse splitter
- 3/8" bleed nipple thread?
- fuel pump rewire
- 2wd cosworth diff tighten??
- Trans-question...
- best 6 paddle clutch
- 5th gear for T5 gearbox
- Green injectors
- 3dr ARB size ???
- 1991 j plate sapphire 4x4 - whats it worth ?
- ecu plug what colour?
- Best place to buy a RS500 replica front splitter
- best 2wd discs?
- 3 door a pillar
- rear brake caliper carriers
- 3dr 9x17 Rear Wheel Offset
- fixed rose jointed top mounts
- 550bhp saph
- 4x4 revs high
- Larger inlet/plenium & throttle housing
- cossy probs
- Engine bay decals (3 questions)
- T5 Gearbox Speedo Circlip
- rear beam and crosmenber Sapphire Cosworth 4x4
- outer window seals for sapphire
- T5 Gear Kit............
- 3dr brake pedal goes solid
- Repairing 1 front caliper 4x4 Cos
- Pic request on seats, thanks!
- After market speed sensor kit?
- Converting idle control valve to Anti Lag?
- wheel size
- cooling fans
- Saphire 2 wheel drive cosworth
- sierra run around(non cosworth)
- amal valve jets
- Where can I get a Pectel Baby Board Plug from? **Found New Socket**
- Are 2WD & 4x4 rear pads the same?
- Whats the difference between 2wd and 4wd camshafts
- disk difference??
- power limit of standard 2wd engine mounts
- A 2.0 RS X private plate
- where to get single standard middle ring
- MSD stage 4 question
- 2wd plenum
- side exit exhaust
- what bushes everyone using ?
- electrical display fault. 3DR
- Sierra Cosworth Motorsport Shell
- AP Brake shims
- sierra sapphire replacement panels.
- Big thank you!!
- 400hp from a t34.63?
- 3 door electrical gremlin
- Daft Throttle Body Question
- Headwork??
- Sierra RS Turbo?
- damage when piston melted? reuse 2nd hand piston?
- ecu holder
- 18s or 17s alloys for my saff need help
- Saggy headlining
- Help needed fitting lower boot spoiler on 3dr cossie
- Is a early 4wd bottom pulley the same as a 2wd?
- what do think its worth
- quickie - need some torque wrench settings please
- 4x4 Cossie calipers Escort different to Sierra?
- what do you think of this 4x4?
- Do all 3 doors have the rs logo on dash
- intercooler advise
- Exhaust opinions
- .....Alloy pulleys any special kind?......
- removin 4x4 engine 1st time:(
- Should a SECS gauge read 1/2 RPM on waste spark conversion?
- need help building a 380+bhp yb.. help with parts!
- 2wd gear box mount
- Is this a mongoose?
- How allign the cilinderhead when mounting
- 4x4 YB Timing belt change
- Injector fully open all the time??? **Problem Solved**
- spark plug gap
- Where to get a new V-Belt Tensioner (4x4)
- 2wd quaife atb diff
- 205, standard bottom end, max power?
- DECAL
- 2wd thermostat housings..?
- 2wd cos front brake pipe help
- Rouse rear spoiler
- Who uses theirs everyday then?....
- HELP please!!! cosworth 4x4 rear beam bushes
- Wanter ,,cosworth prop yoke
- Benefits of a 4x4 cooling system over a 2wd set up????
- 2wd gearbox noise
- i need help finding something
- Head gasket differences
- best breather?
- wiring diagrams for a group A coil
- Weight of a 2wd diff?
- Rear caliper differences
- help thread in head for the water sensor dashboard
- 2wd Turbo heatshield on a 4x4?
- 15" latice wheels
- sapphire cosworth exhaust for sale??
- sierra cosworth exhaust heat shlied
- P100 lower arms same as 3 door?
- front windscreen rubber !
- leaking abs unit, again
- Turbo Chatter......
- rear brake dust sheilds and 300mm discs?
- 2wd head on 200 block
- Big wing sump
- Converting 3dr to 4wd - Only a few bits to get....Advice Please
- Speakers in my 3dr,what to to replace orriginal
- throttle cable for saff
- My Ford Sierra RS 2.0 OHC Turbo Project 3xx HP!
- 1989 2.9 xr4x4 ht leads diagram
- Wheel Bearings!
- ...RS500 £6500 @ Nat Day?
- any 1 running uprated clutch with standard cover
- 1.6 carb wiring
- Grove Garage Stage 3 . What ECU?
- oil leak new engine
- 7.5" scorpio diff?
- sunroof visor
- Sparkplug gap 071c
- drop links
- Failed MOT Brakes binding!
- Looking for an 'old friend', D705SVW
- Slotting inner arms crossmember
- Newbies 1st cosworth, the story & help needed
- ......Plenumn gaskets sealant??......
- fans inop 2wd saff
- Steeringrack problems..
- Maximum power for a t3?
- 2wd cosworth pinion gears - scorpio ??help
- ABS problem - rear wheels locking up
- Rev counter 4x4 saff
- Who sells solid lifters for Cosworth heads?
- No brakes on 3dr cosworth
- bare head - valve options
- 1/8 conical plug where can I buy it
- Rolling road result
- 2wd strut brace
- Suspension
- Whats it worth
- I'm start to build Cosworth MK1
- sapph advice needed, buying?
- 4x4 propshaft center bearing - Where to buy?
- Winter rebuild need some advice!!!
- brake calipers
- Blowing Header tank cap!
- new member, new cossie
- Heated Windscreen...
- roof rails
- Cosworth cam (which ones?)
- carbon fibre plenumn spacer
- cossie heaters
- Steering cuppling for the Sapphire cos 89'reg
- Fao Carbon people....
- Gearbox bearing replacement
- Sierra/Sapphire Cosworth Data for certification
- stripping t5 gearbox help ?
- 4x4 crossmember as a jacking point?
- Testing for a bad ABS sensor?
- Sump off - breather options?
- RP Lab users
- Stud length
- injecters
- cracked block - bin it or sleeve it?
- dose any1 have any sierra cosworths parts for sale
- took the cossy for a little blast tonight
- Floor Sound deadening
- cosworth exhaust who's??
- 3 door cosworth wheels on a sapphire cosworth.
- gear box change need help
- saph 2wd heat shield
- 4wd caliper help please
- 2wd cosworth diff rebuild??help..
- sapphire 2wd ecu needed ???
- Yellow ABS light stays on
- High CO and erratic lambda with MSD closed loop - Now fixed and info within
- Cambelt tensioner - OEM part quality?
- Mysterious switch in red-top 4x4 Cossie
- wheel bearing
- what oil
- missfiring problem
- my first cossie
- turbo not spinning..??
- duff diff..??
- brake resovoirs on saffs..?
- escos in harrogate N735 XXB
- Block
- Roll cage for 3doors Sierra?
- Cosworth Managment
- Weirdest thing you've found in your Cossie
- ECU CO2
- concourse 500
- Boost hose info????
- Fuses
- painting the cam cover
- what rack is this?
- Cosworth rear brakes
- Need standard chip for 2wd cozzy ??
- rich oil smell when givin large 2wd sapphire
- Effect of a dead ACT sensor?
- T5 gearbox strip.
- Rear arch liners
- 3dr engine wiring loom colours
- turbo pic request
- what pistons make YB non-interference?
- 4x4 burn engine oil
- turbo blown need to get home
- How much is a Tremec T56 Gearbox worth?
- Raven Leather Seat Repair
- rear panel
- 2wd cos problem no spark
- 4x4 hestiation on low revs
- Oil pressure 4x4
