PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. wheel and tyre size?
  2. gt30 question
  3. crank help.....
  4. White sapphire cosworth (A9 COS)
  5. Chrome rocker cover for 1.8 CVH engine
  6. ABS sensors
  7. 3dr/sapph mirror casing..
  8. cozy air cone prob
  9. how to abjust fuel pressure
  10. Wanted front-rear seats from 3dr
  11. Cam cover gasket
  12. Fitting 2wd 4 pots, advice required please....
  13. Exhaust heatshield?
  14. Greys / siemens
  15. problem with iddle
  16. piston rings
  17. saff cossie bumper mount.
  18. New AS heat shield
  19. Help escort small turbo inlet and throttle body on to 2wd saph?
  20. Brakes
  21. CO level sierra cosworth 4x4
  22. omex ecu
  23. manual boost controller and original actuator
  24. RS 3 spoke steering wheel for 3 dr cossie. Which boss?
  25. arch liner & fixings
  26. need advice with my 4x4
  27. strut braces
  28. 3dr smoked rear lights?
  29. sierra trackday top mounts
  30. Rs 500 plenum
  31. WANTED crown wheel and pinion 3.36-1
  32. Wanted! June/July 2010
  33. Reversing Lights not working 3dr Sierra
  34. bit of a rush!!engine problem.!
  35. rs500 replica bumper fitting indicators
  36. 2wd clutches
  37. ABS Questions
  38. gearbox
  39. j978roc
  40. lowering springs
  41. 3dr bonnet vents!
  42. who does a chip for 400's,t34/48,standard engine,l8
  43. Best place to get stage 2 rear beam set up in midlands?
  44. braking problem
  45. RS500 Moonstone in Australia
  46. how to up the boost from 18 to 25psi
  47. how much is it worth
  48. front LHS drive shaft outer CV joint belows split
  49. COSSIE CAM/ROCKER COVER :protect
  50. custom or new brake/fuel lines
  51. i need a pinto 5 speed type 9 flywheel in essex anyone?
  52. Where to get prop rubber and driveshasft bolt for my sapph?
  53. Question about ABS
  54. best engine?
  55. Where to get standard clutch for 2wd saph
  56. heater broken? water in drivers side front and rear footwell?
  57. decals
  58. 4x4 MT75 Viscous Coupling?
  59. ABS swap
  60. Fuel Pump Rewire - Relay Location?
  61. Lumpy running Cosworth??
  62. just been offered a 2000e
  63. sierra hid lights
  64. New Wires
  65. Cosworth help??
  66. nufink but problems
  67. Saph cos hoses
  68. Clutch help
  69. Cosworth Lambda sensor question
  70. REVOLUTION RFX 15" wheels
  71. lowered saffs i need some pictures.
  72. wheel
  73. Want to change a few things on the 3 door
  74. 2wd cosworth gearbox problems
  75. t34 is tha same as t35???
  76. misfire at 5500rpm
  77. Interior clips/plugs required...HELP!
  78. Rubber fuel pump mountings
  79. underside clean up
  80. Motec ECU
  81. Seirra RS Cosworth Replica (Sorry!) anyone seen it ?
  82. Wanted Please
  83. Buying advice please
  84. Stage 1 MSD chip what actuator?
  85. 3DR Parcel Tray Straps/Stays?
  86. sierra cosworth standard wheels dont fit?
  87. Thread size?
  88. re-fitting gearbox to 3dr cossie
  89. anyone no this saph k121xfc nouveau
  90. Battery relocation
  91. Mis firing 4x4
  92. Wasted spark driver bolts
  93. 3dr chassis stamps
  94. Cosworth tappets
  95. 10.9 head bolts
  96. Timing up a WRC Cam Trigger? **New Problem 10/07/10**
  97. springs std height
  98. injector probs
  99. braided brake lines
  100. MERKUR XR4ti
  101. DOHC turbo conversion. yes or no
  102. sierra DOHC question!!!!!(help)
  103. Maybe changing 3 Door to Escos
  104. Engine loom
  105. cosworth running prob
  106. a few sierra sapphire parts for sale
  107. 14mm inlet spacer where from??
  108. Help required please.. **cosworth clips**
  109. Fitting Gt40 turbo
  110. pics of white Sapphs with Morrete's please
  111. 2wd propshaft
  112. Bajoo springs & Konis
  113. clutch wanted help 1.8 cvh
  114. T38 or T4
  115. strut brace ????
  116. 1992 Sapphire 4x4 Alloys - offset and pcd query ?
  117. Block..200 v 205
  118. Where to buy a L8 ECU?
  119. NOT a nice christmas
  120. what wheels on your saff?
  121. comp mo wheels on a 4x4 saff.
  122. Do i sell, or do i rip out the heart of my sierra cosworth?
  123. Prop shaft donut
  124. Combat Bodykit Arches...
  125. pressure for 225/35R17
  126. Saph headlight dimensions and more
  127. bd14 inlet
  128. To all cossie owners
  129. Bucket seat with side mounts fixing in Sierra
  130. broken down... no spark
  131. best oil 4 my 500 bhp 3dr
  132. just bought my dream car and the probs have already started
  133. Rear Arm Brake lines - Braided vs Rigid
  134. dashs
  135. removing front towing eye on saff...
  136. Is nearly xmas,the scumbags are out and about!
  137. 360bhp yb
  138. chatter!!!!!!!!
  139. Best mount for 909 bar?
  140. Rs 7 spokes.
  141. 3dr cams???????????
  142. door trims
  143. Looking for my old car
  144. Fuel pump
  145. YB conrod installation
  146. Multi-plate clutch for 2wd
  147. 3dr leather interior
  148. Strange sound from the rear of the car
  149. 3dr sierra hubs?
  150. 2WD Idle screw
  151. cossie taxes ??
  152. Please delete
  153. Fighting body flex
  154. Inlet? spacer? questions
  155. ford car fone wanted
  156. 2WD Sapphire Raven Leather Seat Repairs
  157. CV Joint washers (which way round?)
  158. Burst CV Joint boot
  159. does any1 know this saff |J7 ydl magenta
  160. ford part number?
  161. Cosworth rear diff upgrade anyone had a gripper diff???
  162. what cams
  163. Custom Loom
  164. Alternator belt squeek
  165. Help needed with my saph
  166. for free ford 2006 rds
  167. Head Bolts
  168. Looking for this part,where?
  169. Mods delete, wrong section
  170. cossy tb
  171. sapphire cosworth kit on to estate?
  172. Coilovers..... AVO or Gaz???
  173. A question about swirl pot
  174. 2wd brakes
  175. Poly diff mount
  176. white saff G544 XXX round harrogate friday n satday
  177. 044 fuel pump priming,how long?
  178. 3 door sierra shell
  179. Diagnose connector
  180. NEED advice
  181. 18 inch Comp MO's on a Saff
  182. Cosworth Gaskets & stuff
  183. saff cos loom advice????
  184. Saff headlights
  185. bd 10 cam
  186. sierra 2wd diff can you rebuild or adjust the tightness of them
  187. 3dr rev counter fitting to sapph?
  188. 9 inch rear diff
  189. Sierra wing mirrors, same???
  190. Rouse sideskirts
  191. sierra sapphire cosworth conversion
  192. 3dr arch adhesive/double sided tape?
  193. Saff Rear Spoiler
  194. Sparkplug gap with grpA coil?
  195. sierra
  196. Power through standard equipment. Also abs help.
  197. ARP Long Stud & Nut kit
  198. Power steering banjo bolt??
  199. really stiff steering
  200. Friction plate springs
  201. Cosworth Rocker Cover
  202. 205 block on a 4x4
  203. Power steering pump - rebuild?
  204. 2wd & 4wd oil pumps?
  205. Koni shocks & springs for 2wd sapphire cosworth.
  206. cosworth wiring gurus in here...
  207. What is between the A/C pump and the block
  208. Project Double Ton- WHATS ?
  209. Front brake rotors
  210. Good place to get Lexan Windows?
  211. Saff boot wires (I'm lazy)
  212. pace 500 coolers
  213. 4x4 Fan Belt Tensioner
  214. 3DR head lining
  215. Sapphire rear bumper
  216. My new rs 500build no 456
  217. My brakes are doing my head in Help please.
  218. please help
  219. Difference between a 2wd & 4wd heatshield
  220. saph tickover
  221. clock / gauge holder
  222. FAO rev counter changers
  223. cossie battery
  224. Minimum Head Thickness?
  225. Header tank differences
  226. ECU SWAP
  227. What’s the best value for money head gasket to buy?
  228. steering problem
  229. Belts
  230. 2wd Spark Plug Recommendation
  231. Chassis rail/beam pad thickness
  232. Cossy crackup
  233. mapping question
  234. adjustable tca's?
  235. Noisey tappet??
  236. bulkhead parts
  237. water injection
  238. 2wd/4wd diffs etc
  239. cossie exhaust
  240. Moonstone 3Dr
  241. Couple of running issues?
  242. dohc 8v inlet
  243. 3door lowerarmes
  244. where was my car built
  245. bulkhead lining
  246. 3dr column bush
  247. Fao s.e.c.s monitor owners
  248. ...4x4 rail with 2wd fuel feed ??...
  249. Cosworth Servicing
  250. 3 Dr Cosworth Hibernating for 9 Years
