- 3 door original wheels
- idle problem
- squeaky front bushes?
- replacing front diff,how tricky?
- N7A (Escort rs2000) in a Ford Sierra?
- fitting cosworth spoiler
- 4WD running problems
- 3 Door Wiring Diagrams
- T3 hose for RS500 airbox
- ok, well it's not quite a sierra anymore
- What tyres are you running on your cars ?
- saffs on coilovers
- Is this a Cossie diff?
- what power? spec inside
- missfire
- disconnecting fuel pipe, special tool?
- 3 door sierra with headlamp fault. help please?
- Bit of help
- Larger uprated diff for a 3dr cossie???
- 4WD boost pressure set and problem
- plug gaps
- cossie 1/4 times
- Best springs for a 4x4 Saff.
- wanted 4x4 front hubs
- Temperature
- ACT sensor thread size
- AFR gauge and kit?Where from and prices?
- strut top movement is this right?
- torque settings
- Stiffer the better for launching?
- mk1 xr4i boa conversion (help needed)
- front wing
- Turbo heatshield
- saff cossie 4x4 front drive shafts.
- Fuel pump wirring route
- What plugs on msd 380
- frount pully bolt
- Sierra uprated gearbox mount help
- 3 door sierra cosworth rear window surrounds needed
- What jag diff for 2wd cossie?
- best aftermarket engine mount daily car
- Convoy to wellinborough for pod..
- Saff 4x4 Cossie Heat Sheild
- Can 380+BHP really be acheived on a standard 2wd cosworth?
- service history
- P100 rear ARB on a 2wd saff?
- Best suspension setup for 2wd saph
- newbie
- gripper/cv joint/shaft problems
- Problem with my sapph
- Wiring fuel sender Sierra ? Anyone have a Ford wiring diagram ?
- which spark plugs are best ?
- 2wd saph cos running hot
- L8 ECU with babyboard needed
- cant dis-arm immobiliser!!!HELP
- Next Q - inlet manifold damper
- 2wd Oil pump base - how does it work?
- diff mounting
- Nitrogen filled tyres..
- help terrible handling
- Best oil for T5 gearbox?
- clutch or diff
- dipstick length?
- sapph headlining
- standard tca's..what camber?where from?
- 3dr cossie ABS sensor..anyone???
- Breakers near London?
- What Seam Sealer?????
- escos steering rack?
- Ford Night Ace Cafe London 6th April
- yb 202 block
- Are cosworth and fiat turbos the same
- What rear diff for 1/4 mile?
- Convert Sierra to 5 stud hubs??
- comp mo wot size
- Best diff for a 2wd saff???
- wot a f**king ball ache
- what make tyres you using 8x18
- Changing ECU from L6 to L8
- Thinking of fitting front and rear strut brace on my 3DR - Yes or No? ?
- New oil pump - use old cover?
- Rs500 inlet/throttle body maybe eeciv tb?
- Cold running problem
- garrett T35 info!!
- speedo gear drive
- mk1 3 door heated rear screen and washer jet not working
- Pectel t6 descpro profiles
- vacuum pipe size ?????????????
- Escort cossie wheels on saff
- how 2 start a cosworth
- 3 door rear side windows removing
- Fuel pressure regulators??? 2.9 XR4X4
- Is cosworth suspension a straight fit onto a normal sierra?
- 3dr/rs500 center caps
- Fuel filler neck seal where from?
- ISCV problem
- help needed please (Well info really)
- sapp started over heating
- Correct Offset
- engine oil in 2wd
- more pics from the swedish cossy cemetary
- Adjusting konis
- Tinted headlights?
- Wiring Volt gauge
- wanted coilovers
- "update"wheel geometry-handling-tramlining-tyre wear
- cosworth running issues
- pec pistons??
- 3DR Scuttle Panel Differences
- Are these still available???????????
- saff wheel arch grommits any chance they are still avaiable
- 18 revolutions
- Sorry more mirrors
- crank regrind
- manifold vacum fittings..?
- New to Passion Ford
- looking for pic an opinion
- G439 AOO any info anyone? Special edition ?
- Wing mirror backing plate
- Stage 1 fuel economy
- Lower RS500 Clips, Where From?
- Saph Floormats LHD
- bit of help needed
- 3 Door cosworth dash
- what colour works well on smokestone?
- who sells steering column bush??
- What shims to improve rear camber.
- Which TCA for a 2wd cossie?
- new wheels
- cometic headgasket
- Cheap wheels on the bathroom scales
- bypass valve leaking?
- chassis numbers
- Thinking of fitting an oil breather. What bits do I need?
- Where to buy these items?
- picture needed please ( battery clamp )
- fuel pressure gauge
- Difference between cossie and normal sierra headlight glass???
- Cossies left to rot.
- NEWBIE Sapphy.....
- Anti roll bar upgrade
- What Dump Valve?
- Plenums / Throttle body
- brakes and info
- cosworth 3 door hubs
- striping K197 EEV the morrow, what should i take note off?
- fueling problem
- tyre pressure 215/35/18
- Radiator Fans
- tyres
- 3dr door mouldings?
- Can MSD Launch Control be fitted to your existing chip?
- engines engines engines ?????????
- manual windows for a saff
- TKO600 crossmember
- 3 bar map sensor
- 6 Degree rear beam-fitted and set up!
- Please help me identifying wiring loom
- 2wd cosworth saff front disc's
- Cosworth wont start help needed
- Head gasket failure?
- Best ways to tune a 2litre pinto for maximum performance
- LHD Speedo Cable
- mint sapphire 4x4 rolling shell
- Best engine to tune for maximum performance
- 3 dr cosworth parts value
- 3dr Engine mount problem
- ooh ooh how cool would this look.....
- rs turbo alloys on my 4x4 cosworth
- Headgasket
- Info Required ****fuel tank*****
- has anyone owned my car b4
- Ford Sierra Sapphire Cosworth Carbon Parts. Where?
- 2wd ex manifold on 4x4
- Cosworth parts coming soon
- plugs and plug gaps
- Sierra RS500 Radio / console details
- brake calipers??
- rear anti-roll jumping out of clamps
- CO setting on chipped cossie
- Plug identification
- best induction kit
- Malfunction indicator light not working.
- another three door comes out too play !
- cosworth 2wd oil pump
- lambda/HEGO sensor on MSD closed loop on late cossie 4x4
- Koni Shocks
- Single wiper conversion
- Sierra Center Prop donut problem
- speedo cable help!!
- sierra part name?
- rear beam bushes removal!....help
- RS500 8 injector loom.
- Help please
- Proalloy VS airtek intercooler ???
- Nice gear lever?
- amal R port jetting
- Bosch fuel pump
- Saff cosworth headlights
- cam identification - no markings
- sierra scrappage shame
- setup
- Saff cossie head lining cloth.
- My 3 Door Cosworth out of the garage
- T5 Borg Warner gaskets???
- 3dr sunroof
- brake/fuel pipes
- Valve stem seals
- Looking for a 2wd throttle body
- Headlamp issue. Familiar to anyone??????
- GP A saphhire
- oppliger big tooth kit
- Won't start, coilpack making a noise
- Anyone have a step by step guide on changing the rear diff mount
- angled distributor
- front splitter
- How to - Spot 'Gen' RS
- Alternator Drop Link
- standard 2wd saff made 222bhp ;-)
- anybody have a upgrade or replacement doughnut??
- t34 or t38
- Fuel Line Clips
- track control arms
- Cossie rear prop, staked or circlipped Universal Joint?
- dash display problem sapphire cosworth
- lowering springs wanted!!
- Tabetha new gauges
- Airbox or Cone filter, interesting!!!!!!!!
- First time project--1990Sierra V6
- Saff Cos/Esc Cos tca's difference
- Nsf drive shaft sapph 4x4
- Fuses
- Radiator
- Sapphire wheel on a mk2 Sierra
- What size...........
- does any1 know J7YDL magenta saph
- standard stereo
- Two questions about G reg '89 2.9 xr4x4
- Cosworth 4x4 spark plugs
- About GPA coils
- Both ABS lights come on when braking
- Sapphire advise
- Paint code
- closed loop
- ECU main live?
- main cap's
- do you think this is the same as a t5 realease bearing arm
- wat turbo replacement
- Rolling road
- Sway Bar - Rear
