- 400bhp clutch
- springs
- Windscreen removal and doors off a Sapph?
- Sierra heater matrix wanted asap!!
- pipe size
- compbrake adj tca's worn out in months!
- Burtons Hydraulic Clutch
- Sierra RS Cosworth adjustable rear axle
- V6 2.9 sierra, wont start
- iscv
- Comon reasons the indicator fuse keeps blowing?
- Injectors
- Ambers or clears....
- rev counter issues
- 2WD Cosworth flywheel
- Brands Hatch Pace Car XR4i A405 MHK
- exhaut
- 3dr or rs500 splitter
- sapph abs issues
- Unknown YB Head
- 3 Door out for the sunshine
- Sapphire Cossie clutch change-2 tops bolts
- item help please
- Thread size for inlet manifold vacuum take off?
- Brakes help
- injector flow checking
- front arb bushes
- Engine knock
- saph problems still steering or something
- what clutch do i get ???
- Speedo Cable Assistance Required
- MSD poly diff mount help
- Wheel bearings
- Which bolts do you not replace with...
- opions regarding price
- sierra cosworth late model alternator
- Cosworth cams
- changing the timing belt
- Average prize for original 3dr Cossie rims in good shape?
- What's the Differance between a 2WD and 4x4 Clutch?
- Bleeding Cosworth ABS system
- re setting co on l6
- Rear beam bushes/how to remove??
- Indicator relay
- spotted at turbosystems
- What no dump valve!!!!
- engine rebuild how much?
- T5 Gearbox Input Shaft Tube / Mount
- Replacing Rear Outrigger
- bd10 intlet cam vs standard cam
- OIL LEAK
- 4x4 gerabox?????
- under pressure
- 3dr cosworth horn wirring
- engine mount bushes? help
- Wrc headgasket help
- Sierra RS Cosworth - Automatic gearbox?
- 300bhp 22psi on standard injectors????????
- RS500 style front splitter for a 3dr cossie- Which is the best one??
- YB multi layer head gasket questions
- 2wd fuel rail
- 3dr and saff hubs
- Clutch setting advice
- Rear beam bushes (flo-flex)?
- Alternator issues? issue now found ish
- Ford Sapphire 3.0 GLX
- Clutch self adjuster problems
- broken clutch arm
- saph cosworth vent bolts where from ?
- RS500 genuine lower spoiler.????
- Best oil for 400bhp saff
- rear cv joints
- Finally its on lol (Rouse boot spoiler)
- Is my car chipped?
- clutch. anyone used these???
- Mk2 Sierra wings still available ?
- flywheel puller
- Con Rods
- Which Phase Sensor for Cam Trigger?
- cosworth idle trouble..HELP!!
- Electric Window Loom
- little bit of play in rear diff????
- What spark plugs?
- Wiring Diagram - Sapphire Body Loom
- AB07 Cam
- fireing order on 2wd sapphire
- WTF?what water pipes are near the bulk head on a sapph?
- gearbox for 450+bhp 4x4
- Where to get 200block lined
- rear beam bushes
- boost pressure in different gears
- Saff cossie 4x4 thermostat
- Parts prices opinon(FAO KSA-cossie?)
- Hydraulic clutch parts
- RS500 spoiler Lip on ebay. Any good?
- Dry Sump Installation advice
- changing front diff & steering rack on 4x4
- Front brakes pipes issue?
- Vibrating noise out of exhaust comes from turbo
- Mk2 ambers vs Mk3 smoked
- 408bhp Sapphire Cosworth
- rs 500 thermostat housing?
- Best breather system for 380bhp-400bhp
- sapphire cosworth side skirt clips
- T34.63 From 2wd to 4wd
- Speedo cable bracket for a 3dr
- New member on a mission for a low mileage saph. (Northern ireland)
- stem seals
- Clutch rattle
- Advice on RS500 intercoolers off ebay
- Quaife diff'..
- screamer pipe
- T5 bolt size
- Track newbie (advice please)
- parts???
- boost pressure drops in high rpm
- Line lock for Sierra Cosworth?
- Sapphire - 22 mm Rear Anti Roll Bar
- Removing Sapphire interior door trims and cards
- Pic Request: chassis leg wiring clips
- SINGLE 52mm gauge holder/pod :protect
- 3dr windscreen replacement(prices inside)
- sanity check
- converting 4x4 to 2wd.
- Steering Rack Extensions
- Air injectors ?
- Electric windows, sunroof and heated screen
- Sierra spoilers
- torque settings
- Matt Lewis
- throttle position sensor
- Rear diff and driveshaft..
- vibrating braking
- BGA hydraulic tappet
- funny noise
- T5 gearbox 2wd
- Anyone else experienced this?????????
- Cossie running REALLY rich
- pics of your 3dr please lowered
- whats better? saff 2wd or 4x4?
- Antilag on a gt3076R-wg Good or Bad and best place for setup for 3door?
- Engine management light on
- 3dr ignition amp bracket and speedo bracket
- Escort cosworth fuel rail on saph inlet ???
- calipers
- RS500 chassis rails.
- l600 ecu ?
- smoke on over run.
- Anyone want to do my engine bay wiring? (Paid of course)
- boost gauge T piece
- Stereo head Unit
- saph problems
- plenum spacer
- Crap intercooler...my options?
- Pic request: Hyd clutch fitting
- Best glue to stick down leather doorcards ?
- Sierra Doors Question
- Moonstone blue saph possibly not seen for years found (BETTER PICS) UPDATE
- Which rear springs for RWD saff?
- what ferodo pads for a 4x4 cos
- Brake discs & pads upgrade or not ?
- Camshaft Knocking noise
- co help
- 4x4 intercooler on a 2wd
- Decals
- Saph cossie headlight wiper
- Tail lights
- what block i have here??
- i,s,c,v? plug gaps? cosworth cutting out on start up!!!
- Help, hesitating?
- RS Cosworth Sierra 3 door - advice on values
- cosworth diff ratios..
- Oil temp
- new quaife diff,,HAS IT GOT TO BE TORQUED
- ABS Loom
- Cosworth issues
- needed for my car
- brake warning issue
- 4x4 missing on 3-4
- silly question. air filter/4x4 bonnet.
- Cossie 4x4 'Strange' Head gasket leak...
- Standard 4x4 sapphire boast pressure
- 200 /205 blocks
- 4x4 problems
- morretti saphire headlamps wanted
- cosworth crank-rod bearings&liners ??
- Poor starting and idling?
- Wasted Spark ?
- t38 turbo
- Diff mount, ARB suppliers?
- xr3i brakes into sierra
- RS500 turbo spec?
- Live mapping ?
- gaz gold coilovers- how do i set them?
- saph 4x4 steering rack same as escos?
- 2WD quickshift. How to mount?
- sierra mk1 smoked/red rear lights
- low boost
- ahmed bayjoo
- anti roll bar question 3dr
- f***ing b****d cossy im going to break it soon....
- CO adjustment 2wd
- Tyres size on a 3door
- TPS
- Rough power for my spec ?
- Nitrous for Cosworth engine?
- suspension advice 2wd cossie
- fuel pressure take off
- Centre Console Vents - Sapphire
- Center caps compomotive wheels
- Many questions about the L8 ECU's
- cossie oil
- rev counter probs
- Torque settings wrc gasket
- missfire as boosting
- 4x4 saph black gearstick surrounds,what they worth ?
- Saff revving high on idle
- turbo swap
- Burnt Engine Harness...HELP!
- 2WD quaife diff..best place to buy.?
- std ride height springs
- roller bearing t38
- amber side repeaters
- Mapping In The South East
- What's the difference between Escort Cossie and 4x4 Saph steering racks?
- Are 4x4 Steering Racks the same as 2WD ones?
- OEM Replacement Discs
- tyres
- Cosworth stem oil seal
- Clutch Fork
- cosworth problems
- 2wd or 4wd head
- abs ecu
- strange running problem
- 2wd clutch cable help
- 3 door wheel center cap with lock needed
- fuel pump rewire
- cosworth battery
- rock hard brake pedal
- oil pressure
- Flow chart to diagnose misfires
- changing discs and pads 2wd Saff
- Why should this happen?
- 2.9 v6 conversion
- how to uprate the standard cossie 2wd diff
- pic of ecu?
- 3drs coilover
- What size of bolt holds on front calipers??
- fuel tank sender unit
