- saff cossie 4x4 steering
- S.E.C.S Monitor differences
- cossy 4x4 missfire
- Crank shells
- 8x18 on saff, minimum offset, what do you run ?
- 3door cosworth rear lights *swop* mint
- Wheels
- Confused? Breather
- Best injectors for the job.
- cosworth wheels
- Looking for an inner gear gaitor...
- dizzy caps
- Cosworth crank shells
- Is it easy to take a fuel tank out?
- cosworth temperature (cooling issue)
- Saph Cossie Sunroof Wooes
- somebody tell me which hoses these are
- fuel tanks..
- boreing out a yb engine block
- question re Saph braking systems
- EVO 9 brembo calipers on cossie 4wd
- Saff coming on boost late
- 044 pump need the non return valve off it
- Water temp sender - YB engine
- Fuel pump hose
- secs monitor readings
- Gear oil grade
- fitting gauges
- Fuel Lines??
- Sierra 4x4 Cossie Fuel rail & Regulator
- A Little Something, FAO Saph Cossie Owners
- 3dr Trailing arms ply bushes or rose jointed Ford items??
- Fuel pump non return valve & Banjo End Bolt
- 3dr and 2wd sapp fuel tanks-same or not?
- Pro5.0 shifter?
- Will bits from a hatchback fit a sapphire?
- help needed
- 4x4 cosworth overfueling ?
- where to buy and parts needed?
- Borbet A 17`s for 3dr Where/who from????.....
- best place to buy braided hose for breather
- 2wd rear caliper howling
- cosworth wont rev out when hot
- 1.8 cvh to 2litre zetec conversion
- My New Sierra Sapphire.....
- Anyone got this switch?
- L8 remapping?
- Steering wheel question?
- long studding
- rebuilding cosworth for 500bhp
- what size braided fuel hose for fuel rail and fuel pressure reg
- Hard to start
- new chip or is 334bhp all im gona get
- 3 Door flywheel
- YB NA on a budget
- will the engine fit
- Needed
- What color this 3dr sierra? - Norway
- Wires from solenoid on starter motor
- Help please...cold start problem
- Piston size help
- rs500 spoiler
- ISCV
- What size spare tyre for 3dr? 9"x17"R 8"x17"F
- Help Required
- 3 Door Crank
- Cosworth Cam bearings and Cam cover gasket!!!!
- 3dr central locking problem
- Sapph suspension.
- Cam choice, hmm...
- Clutch Options- circa 380bhp
- quick question abs light!
- best choice exhaust housing on t34?
- Magenta Sapphire
- Rose joint size
- Uprated Fan switch and standard rad?
- changin to braided/aeroquip fuel lines
- Coilover problems
- sierra cosworth abs
- Has anybody bought one of those Auto specialist group A filters
- Rebuild
- Rear Hub Nut
- sierra bits
- lambda sensor wanted
- Strut Brace - Front
- New fuel pump loom.
- Cosworth starting problems
- Andy Rouse RS500
- Bonnet raisers on a 3dr???
- Noob needs help, kinda a buyers guide.
- T5 Gearbox / 5th gears
- fuel pump
- Setting CO and idle
- laggy turbo
- Coilover's for Sapphire 4x4
- Cosworth Radiator
- Coolant/water light
- Thanks to Jon at work
- saph front bumper help!
- gt35 with 63 exhaust house
- Top mount bush problem
- 3DR Turbo Actuator Bracket/Mount
- Rear diff ratio for 1/4 mile?
- Where to route bonnet release cable on 3dr?
- diff change, how?
- crystal blue saph info plz
- Saphire cossy idle problems
- steering problem
- what type and how many litres of oil 2wd?
- Where to route ABS loom on 3dr?
- Which Cams for Sierra RS Cosworth 2WD?
- Maxxis tyres
- alternator volts output?
- Building up a 200 block
- Good advices for more power to my Cossie?
- 2wd gearbox
- E 858 SNF COSWORTH info
- Powerflex Top mount bushes
- fuel pump wiring
- 9x18s on a saff
- New sapphire cosworth amber indicators!!
- What brake disc's and pad's for a 3 dr cossie ?
- Brake warning light stuck on - help pls?
- 2wd tighten head info
- Fuel Lines (HELP!!)
- 3dr cossie Intercooler/Radiator/Cooling Fans upgrade advice please
- 044 Set-Up
- YB conrods options
- Cosworth Fans
- H/G & Engine bearings
- Stage 2 MSD bar - psi ?
- gt30 compared to t34 .55
- saph handling
- Rear Arch Rebuild At Last. PICS UPLOADED.
- Wtf saph cossie automatic on the bay
- 3dr indicator lens - n/s... anyone?
- Front diff? How to..
- Standard Fuel pump connectors
- cossie head help?
- Sapphire Cosworth RSOC Registrar?
- What pistons
- 2wd std cams technical characteristically
- New turbo?? advice needed
- lookin for my old saff
- Engine mount advice - Saph Cos 4x4
- Which head would you choose
- loosing boost ? MAP
- what engine
- this part from where??
- 4x4 Violent shaking over about 10mph
- Photo of timed up dizzy needed please
- YB head bolts torque
- 3dr engine loom
- boost problem
- 2wd plug gaps
- Cossie Breaking Prices?
- Setting Idle CO
- Fuel tank/sender needed
- Anyone from Malta on here?
- ECU problems
- MF2 wiring .. Faulty Controller?
- valve stem oil seals
- Bonnet Spacers Fitted and a Clean.
- Cosworth 4x4 front driveshafts
- Sun Roof
- 2wd saff speedo and stereo stopped working???
- 2wd vs 4wd manifold?
- morettie twin headlight help
- cosworth engine`s
- original engine mount sierra 4WD
- Moonstone blue paint
- wheels spacers
- Who's moved up from a .48 housing on a T34 to a .63 and??
- what clutch 500nm / 370lb/ft
- 2wd rear badge position
- What do you think of this guys, New Mounting Pics Build 09/07/2010
- Looking for my old saff G626 DWC
- Headgasket Question
- Rear Anti Roll Bar links
- inlet manifold
- Kinked hoses?
- Oil Leak Hasgasket
- Bumper help
- head gasket going?cracked block:(
- WRC Head Gasket??
- fuses in 1989 2wd Sapphire
- Cosworth Plumbing questions
- Garrett GT30 or 35???
- stage 3 advice please?
- Suspension recomendations please guys
- Limp mode
- headgasket
- fao EMERALD K3 users
- FREE clutch pedal pawl bits
- Rear beam mount's
- Fuel pump to filter banjoo pipe.
- Front driveshaft removal..
- Pictures
- How to rewire my fans and feulpump?
- Cosworth Pistons Dudes
- Decision on rebuilding a RS
- Just Purchased 4x4 sapphire 1992, basic pointers Needed
- saff playing up again......
- sierra cosworth - problem with car ???
- painting intercoolers?
- Cosworth Sump Gasket
- smoking
- Cosworth rear arm bushes
- 71/2 inch plated gripper diff
- Saff cossie 4x4 coolent pipe.
- l6 loom on p8 ecu
- arp nut and stud kit
- 3door 'door' ?
- track rod end lock nuts,where from?
- front / rear diff rebuilt
- oppliger tubular manifold. Is it good quality???
- Brake compenstor valve
- Gear linkage/Gear stick removal MT75?? Help!
- Power Steering Cooler
- Help! Head gasket for Pinto...
- after a plate for my 3dr
- sapphire headlights
- 3 door cosworth oil
- sapph airboxes that are modedd
- What Boost controller?
- Advice on gear shift vs boost?
- saff cos amber rears, finis number !
- Power steering prob
- ford badge, 2wd 88
- Sierra Diesel
- cossie brakes
- Re fitting side trims
- What front diff??
- White RS500 on Ebay dry stored for 20 years
- cossie using water
- 4x4 saph brakes
- buying a saph cos 4x4
- Refitting front arb
- Single piece prop
- foot well repair..
- Sapphire fylwheel bolts-unusual size ?
- 4x4 springs on a 2wd
- No ignition lights sierra Sapphire
- Rear Wishbone Bush
- Sapphire Front bumper removal
- Sierra cvh to pinto
- L8 CO Problem MSD chip
- alloy(solid)boost pipes
- t5 gearbox
- How to..
