- Strange knocking noise
- What pitch are propshaft retaining bolt threads?
- Fitting a rollcage in a sapphire
- cosworth breathers..?
- cossie cam followers
- T170 Gearbox for Sierra Cosworth?
- What wheels do you think?
- Cosworth sunroof help
- More headbolt questions !!!
- Central Locking
- 2wd lightened flywheel weight
- Anyone know what springs they have on their 3 door?
- Fitting gear stick to cossie gearbox.
- yb oil filt cross over part #s
- sapphire rear window trim
- Cossie T5
- 2wd exhaust manifold
- Water Leak
- Hart Manifold Question
- replacement arch
- Koni adjustables for DOHC sapphire
- rear brakes binding..
- 2wd sump / oil pump ?
- 2wd Saph issue - any ideas?
- help please rewiring fans
- iscv fault??
- this manifold?
- wiring fault on my 3dr
- car cover??
- does anyone know this car
- FAO Tabetha
- More info about (this) N/A 3dr Sierra.
- 45 50 and 60mm core intercoolers
- 3 door cosworth wheels ??
- cosworth front 4wd brakes fit 2wd???
- torque setings for 6 nut an stud kit?
- MSD chip with ALS ?
- 2wd/4x4 exhaust manifold question
- Cosworth gearbox oil seal
- How important is the length of the map sensor pipe?
- ggr dump valve
- whats needed for 380bhp saph cos
- amal valve wrongly fitted
- fuel rail question
- Help please!
- thanks enhanced performance
- Bootlid spoiler grommets.
- Frofix Racing exhaust manifold
- bloody misfire
- fuel pipe i.d
- RS COSWORTH 3 door t4 Turbo ???
- Which head gasket
- Cosworth Fuel Filter Thread Size?
- saff vs 3dr dimensions
- Sierra diff mount?
- Mongoose Exhaust Fitting - Sapphire
- Help! Gearbox mount bolts
- Diff Oil
- this turbo any good
- Really bad vibration on my 2wd saff?
- how much power ?
- YB flooding...
- swedish plenum
- what diff to go for
- Inlet pleunum spacers?
- Power steering pump pulley question ?
- e640jlt anyone know of this crystal saph?
- whats its worth
- engine parts ?
- gt35 at 15-20 psi...
- Group a ignition coil
- Help ... New Design for my Sapphire Rallyecar
- Sierra Saphire RS Steerin Hub
- Sapphire Wrap!!!!
- Clutch, Exhaust, Sticker questions????
- bigger intercooler?
- Isle of man tour..may 2011 final price's
- £dr fuel tank level sender unit
- dizzy cap
- sapphire cosworth 2wd help!
- Bosch 044
- Oil pump testing
- 5th gears for T5 gearbox
- what colour for my wheels
- Let down by ford,anybody know where I can get these from?
- My 3 Door before goes away for winter
- Saff with 8" and ET32
- bayjoo springs,where from
- color nr red cam cover
- cosworth shell
- Denso iridium IK27
- sapphire cosworth front bumper
- How much BHP?
- Rear light gaskets?
- Rear beam and standard sierra floor pan
- T5 gearbox rear oil seal
- sunroof panel
- RWD engine Prices
- ecu pulses per mile??
- What gearbox fits Sierra Cossie?
- 3 Door Sound Deadening etc
- Where to get pistons pocketed and head mildly ported?
- white saph's on comps
- Where can I get hold of a .55 housing from, for a T34 Turbo??
- Opinions please guys
- Fuel gauge
- sierra cosworth rad over heating problem
- Anyone know what this is??
- Ford sapphire 2wd cosworth heat shield.
- Mt75 gear lever cradle bushes, solid alloy or poly?
- idle dropping
- Rocker cover gasket
- Whats a 4x4 beam and trailing arms worth ?
- sieera running bad when warmed up
- ABS Power supply
- 4x4 gear oil
- 24v injectors
- cossie coilovers
- Copper brake pipe size
- L8 Weber babyboard
- clutch cable
- Abs pump
- Sapph steering column flexible rubber joint?
- 3 door head lining
- 4x4 Sapphire fuel pump priming
- diff viscous fluid?
- what is a brand new 4x4 engine worth
- L8 ECU ?
- help needed rear drive shafts
- ISCV question? High idle.
- 3dr Missfire Still not solved HELP!!
- Solid steering rack bushes
- Genuine RS500 intercooler on sapphire?
- Standard 3 door wheel refurb
- adjustable bottom arms clicking - normal???
- 4x4 Calipers on mt FRST
- fuel pump rewire wire size
- Best Oil for diff 2wd cossie
- Best oil/atf for a 2wd t5 gearbox
- SPAX stickers
- New wheels now fitted
- Diff size
- Oil circulation problem?
- Need for readjustng the actuator for Manual boost controller?
- Intermittent problem
- 2wd Springs - what ones?
- steering rack leaking oil,prop uj where from?
- Front wing removal
- Battery dead
- Alloys
- 3 Door ABS ECU
- head parts
- Steady boost ?
- gave her a clean up
- 92mm 8.0:1 Wössner pistons and 136 mm rods
- 2wd Steering Rack
- Missfire On My 3dr
- ABS Light Staying on on a Sapphire Cosworth
- What Spark plug?
- Temp Gauge gone limp!!
- servo pump seized?
- Spring platform height
- Whats the best Brakes setup I can buy for my 3dr for around £500-£600 ish
- compression test
- Air condition (R12) service ports 4x4 saff
- IK31 iridioum denso or Qc57 champion
- starting problems 4x4
- breather return
- Oil pump driveshaft?
- cosworth 2wd inlet
- Sapphire Fogs/Surrounds....
- 2 Cossie's Same Carpark
- Fuel starvation problem
- newbie buying adv
- 3dr abs problem.
- Cosworth none start
- Co. up & down
- Where can i find chassis dynamics springs SRH???
- torque settings on 6 long stud block?
- 2wd pick up pipe
- cosworth rear uv joint drive flanges
- Enhanced performance
- Front drive shaft angle
- Where can I get this
- Fan cut in temp ??????????
- Turbo pre filter
- Most Expensive Cossie's I've Ever Seen!!!!!!
- can Valve to piston contact damage be removed by pocketing?
- who else uses 15w50 engine oil
- comp ratio question
- Cosworth ht leads -reistance
- Water injection. What kit??
- 2wd Header Tank
- Manual steering rack on 3dr? Opinions please.
- New greek cosworth forum !!! Check please
- What is this??? Late spec 4x4 Saph
- another addition to the ford family.
- Fuel pressure
- What do they break for?
- water leak cossie 4x4
- Setting up Cosworth cams
- Cosworth battery
- Strange distributor oil leak ?
- Interal block pic's request (:
- Oil press gauge sonection on 4x4 sierra coswarth
- Repairing 3dr turrets..
- How much power is put to each prop? MT75 4x4
- Saff Splitter
- Damn thing won't start!! **Now works as of 04/10/10**
- different turbo stages t3
- quick question
- SQS Sequential Dog-Box
- Kill Switch Behind Bumper **Now with Photos**
- Wasted spark, coilpack bracket
- Back to standard alloys
- what size In and output the best for new radiator and RS500 kooler
- Toe-In
- Vernier Cam Pulleys
- comp question
- VIN number
- How easy zetec into p100?
- What chip for T34 & greens
- saph cossie is kangarooing
- small turbo plenum cover ????????????????????
- rear arms
- rewired fuel pump
- Saph Front Wings
- 205 short motor value??
- 3 Door 4x4 Tickford
- Which fuel pressure regulator?
- Head gasket
- Minimum hight 4wd Cylinderhead
- Annoying problem with sapph 4x4
- Troubble with Sapph 4x4
- Best way to keep a cossie cool on track?
- AVO coilovers?
- Is there any rare colours?
- cosworth oils
- RS5oo inlet vacuum pipe size????
- RS 500 Thermostat ?
- Cosworth & pinto crank differance
- ideas on fitting braided fuel hose to saff
- Cosworth Breaking Prices
- 4x4 Rear Koni's
- help canister
- why convert a 4x4 saph to 2wd ?
- What parts do i need?? If i need them?
- Engine oil gallery etc cleaning brushes
- bolt kits for the underside of my saph
- Sierra sapp 4wd fuel rail & fuel pressure regulator
