- Warped block??
- the Cossie's shit itself AGAIN
- What power?
- 3.4 litres that all a 2wd takes?!?
- fitting 3dr exterior trims...
- Replacing rear brake calipers
- Coil leads for 2wd saph
- Cossie Cams?
- Engine Loom fitting...
- Hiya whats a 205 block worth with 1mm over size pistons, freshly built
- shouldnt fuel filters be supplied with new copper washers?!?!
- Marelli 3 bar map sensor part number
- dump valve question
- Please be wary - Dundee rs500 engine on ebay
- Anybody used....
- Will a grinded crank be any good?
- suspension/diff carrier
- siemen 72lb / 83lb
- L6 to L8...
- Alloy Products!
- which big brake kit under std 15" wheels
- Where can i buy 5.1cwp for a 7.5" cosworth diff??
- What's it worth?
- Brake servo removal
- 2wd 7.5" diff
- can you clean / fix Idle control valve?
- 2wd fan re-wire
- 3dr Cossie power steering very light
- Miss firing!!
- Rouse 304-r magazine feature pictures
- 2wd turbo/manifold removal...absolute twat
- Pillar pods - same on all sierra?
- Knock sensor
- BD 14 15 or 16
- lights on cosworth computer
- solid rear beam mounts
- 3 Door Cosworth Engine Height
- Bracket beneath master cylinder
- saph leather gear knob??
- Cosworth diff
- T5 Gearbox Oil
- 4x4 gear box. tell difference ?
- Koni suspension.
- 2wd axle beam
- cosworth alloy rad's
- Cossie ht leads
- Sierra RS Cosworth rear window seals
- Dodgy rev counter and missfiring?
- Advice needed
- ABS sensors
- S.e.c.s monitor wiring
- help wanted heatschild
- Boost Controller
- L6 ECU...mines broken..litteraly.
- Re sealing abs master cylinder 4x4?
- et 32 8j 17"
- Oil feed hose & filter (GT Series)
- Price of 4x4 ecu help
- secs monitor
- finis code
- Poly bushes
- Rs500 intercooler
- Breather system (5 port)
- head temp sensor pics?
- what paint for alloy
- not enough power from dark greens
- Need to borrow a turbo
- fuel systems
- cossie heat issues!
- Tapping 2wd cossie sump
- Voltage opinions?
- YB cambelt renewal..
- Which cylinder head bolts for 3door?
- Cosworth ecu l8 connecting with closed loop lounch,anti lag,wasted spark driver??
- cossie's a bit poorly
- a little help please lads
- secs monitor plug?
- Timing marks
- What wires?
- help wanted , new sierra owner
- Saff Cossie front jack points... Pics please
- Sierra RS Cosworth 3 door / 18inch wheels
- Saff cossie ecu,s and wiring looms
- HELP My 2wd saphire cos is running on 2 cyliders
- My 3 Door Cossies
- Steering bush
- sun roof
- sierra cosworth vac pipe inlet mainfold
- sierra 3 door rollcage specialist????
- T4 sized cone filter and hose?
- searching a spec-r breather system
- 2WD Cosworth Steering Rack.
- Cosworth standard cylinder head thickness
- Mobil 1 15/50 motorsport not being made anymore...
- bailey breather
- Clock wiring/plug on 2wd sapphire
- what's involved in having a chip 'set up'?
- Sierra cosworth wheel size
- 3dr steering rack
- power steering racks...leakage.
- T5 speedo sensor
- Door Mouldings
- Is it a seller's market at the mo??
- water pump
- Connector under the steering wheel
- Standard 2wd Motorcraft clutch
- t34.48
- Cosworth propshaft lengh ?
- RS 4 Spoke steering wheel fit saph??
- tremec xr3r gearbox fit yb? difference from T5?
- wheel offsets..?
- 4x4 stage 1 back to standard
- can you remove saph pedal box in one piece?
- Help Saph new Battery
- Hiding ht leads
- window rubbers/weather strips...
- Gaz coilovers
- Winter cheer myself up thread
- what do i need?
- what lb rate for coilovers
- Swedish plenums
- Vernier Cam Pulleys
- Breather tank and pipework pics required
- OAP Pete
- amber rears - genuine or not?
- Exhaust Clamp
- Slam Panel
- Question
- anybody wana swap a late rocker cover for an early bayonet type?
- cosworth stage 3 engine info
- t3 t4 turbo conversion - oil screw threads
- removing rear dust guards
- Fuel flap
- engine help
- wht coilovers?
- clutch
- She wont start, help?! WIRING ISSUES?! Post 29!
- solid gearbox mounts
- Electric sunroof woe
- sorry for the usual question....service items?!?!
- Sunroof drainage pipes
- air injectors
- Saph 4x4 strange noise
- .63 housing question??????
- co level with closed loop
- Converting L8 Throttle to EECIV ST ESCOS
- ST Escos throttle body
- Whats the best diff oil for a 4x4 diffs
- saff headlight protectors
- cosworth running badly, with video HELP?
- Can you have to much oil flow ?
- which fuelpressure regulator to use when going aeroquip?
- wheres the best place for 3dr panels
- Help fusebox problem not solved
- rolled arches...can you rectify this?
- TPS folt. any 1 stock a TPS for a 4x4 cosworth?
- Sapphire 2wd fuel tank
- tps readings ok???
- Any Idea's on this.
- whats the best way to change my cosworth suspension over
- Bad brake judder
- 2wd sapphire with 4x4 header tank
- Escort cambelt cover
- headed front screen on a 2wd saph...
- Sump gasket kit question.
- 2wd lead order
- Rolling Roads & Boost??
- Water Injection
- 87 xr4x4 gearbox
- 400bhp on a t34???
- Breather Set-up Question
- T3 / T4 turbo conversion - i need some help please
- Help me please!!!!!!!!!!!!!
- Should a rebuilt engine puff a little blue smoke on cold start up?
- t5 oil
- Finis codes for underside clips
- diff size?
- This inlet
- irish cosworths
- white saph pic request
- Helicoil on head?
- flat spot
- boost spike
- Saff cossie 4x4 abs
- wheels offset help
- Why are maps with big boostspikes so common
- sorry, help again...seem to recognise this black saph...
- 3dr rear lights
- ecu wolf
- Q. Upgrading internals.?
- aeroquipping fuel lines
- putting car back together
- rebuild parts off ebay, cheaper but reliable?
- 2wd cosworth/not cosworth steering rack
- Sierra sideskirt bits - help!
- Ecu resistor wattage
- reasonable price for a strengthened Diff
- saph rims?
- Bolt & Nut size?
- 3 bar map sensor question
- Name that part
- few questions, oils and pressure
- Advice needed please
- Ford rs 500 shell
- long stud kit
- Cosworth rear Reyland brake info, what size wheels?
- Gearbox reconditioners ?
- 3dr heater fan
- alloy mounts
- a-pilar molding
- 2wd cosworth Fuel Pressure Regulator?
- 4WD to 2WD
- Cosworth clutch upgrade advice please.
- 2wd saff stereo wires
- clutch quadrant help plz
- spacer or plenum
- t38 poll
- Weber Cosworth FPR
- How many of you guys run 400+ bhp on std. MT75 box?
- Anybody know this big power saph?
- airbox question
- side mouldings for 3 door
- Saph 4wd brake upgrade options
- differant t38's
- cosworth poly bush set fit standard sierra?
- What's your opinion about this setup on sapphire 4x4
- t38 turbo's
- stage two saphire with std exhaust will it work
- cossie idling too high, any ideas??
- Fuel Pressure Regulator
- diy intercooler water spray? worth it?
- Lookin for a bumper
- Front crankshaft seal?
- morrette sapp cos question
- Duratec into a Sierra?
- two question about fusebox.
- turbo identification?
- iacv question
- engine specs
- sierra cosworth 4x4 gearbox differances,early,late spec
- ABS Sensor
- Inlet differences
- Head porting.Where too,how much?
- Thinking of buying a 3 dr Sierra Cosworth ,advice needed
- breather system options...
- cos 2wd engine mounts
- creaky steering wheel
- 3DR/RS500 bumper insert
- Cosworth Brake help needed!!
- sierra no brakes and air sound from pedal?
