- best cams for 400+ gt30.
- T5 Rebuild
- -17psi off throtel and only 14psi on. HELP
- Saff 2wd Engine Mounts ... what to go for?
- boost problem.
- ABS Warning Light Deactivate...
- spec me a turbo
- turbo spec help
- Brake advice
- Koni adjustment..
- Plenum gasket 3dr cosworth
- Another missfire, and other problems...
- Which tyres on 3 Door / RS500
- Single valve springs
- Peugeot brembos and discs on a saph?
- who will big wing my sump
- aerial cable
- rear bean bush question
- 3dr rear lights, anyone heard of these?
- bumper gap on 3dr
- My new RS500 T4 Turbo - What changes needed to fit from my current spec?
- sapphire 4x4 temp sender
- AP brakes under Sharktooth wheels
- Engine spec?
- F478 THK saph cos anyone know it
- Tuner in south east
- Couple of things.......
- Pump+wiring
- Sierra GT DOHC brakes upgrade?
- New webshop section!
- Running Without an Amal Valve, Question?
- misfire on 1990 saph cos 4x4
- COSWORTH-WRC-CYLINDER-HEAD-BOLTS-what do think?
- Whats it worth?
- 4x4 starter motor
- Looking to put cossie engine in my sierra HELP
- what is a sierra mk1 crossmember worth
- Are there differences between the left hand and right hand engine mounts on a 3dr?
- What to Expect from my first Cossie
- 3dr cossie drive flange and Stub Axle specs
- 2wd cosworth diff
- Sump oil return - big wing
- Cam timing - what do you do?
- l6 ecu
- 4x4 cosworth clutch cable routing
- new chip & ecu
- ABS sensor resistance?
- 2wd T5 gearbox rebuild
- Arghh, transmission fluid?!?!
- FRS alloys on saff???
- help with my sierra needed asap
- OAP Pete
- 2wd cosworth diff question
- boost problem
- engine and gearbox oil.......again!
- T3 oil feed
- new springs and exhaust
- intercooler advice
- 2wd complete head standard unskimmed whats it worth? and block
- Sierra zetec
- Oil feed. T4 onto 4x4 head help!
- 2wd manifold gt3076R spacer thickness
- anybody run a msd evo stage 3 chip?
- Not holding boost
- 300mm rear brakes
- Sierra 2.0i DOHC temperature gauge
- Cant beleve my luck
- rear trailing arms-differences
- Sierra 3dr Carbon Parts
- 4 Paddle clutch
- Sierra 205 block
- base primer
- alternator
- Breather question
- sierra p100 speedo
- Focus RS Brembo Bracket.
- Long Shot!
- What size allen key needed to remove clamp on battery tray.
- New Wheels
- what bhp/torque will a type 9-mt75 take?
- headlamp washer
- help reqd identifying chip E006 !
- MK Motorsport 4inj inlet
- where from?
- exhaust options?
- Best turbo for stage 3 chip?(pinto)
- cossie 4x4 water pump gasket
- 4x4 steering problem
- 2wd coil wiring
- 4x4/2wd mahle pistons and rods in 205 pinto?
- driveshafts
- abs sensors!!
- quickest way to remove trailing arm on sapphire....
- saph cos 4x4 trans probs
- 2wd Rear Drive shaft length
- blue sapphire cosworth recovered from tibshelf.
- 3dr droplinks
- 4x4 sapphire spring poundage advice...
- rear drive shaft removal
- T4 turbo
- my old 24v drift car
- Cossie rich off boost
- another sierra
- cosworth smoking, help please
- OAP Pete...Pic of my 3Door
- cosworth loom
- what do you think its worth??
- Ahmed track spec springs....
- No voltage at CPS..........
- 3 door bonnet ?
- ford sierra rear abs sensors
- Temperature gauge
- AMAL Valve wiring
- My new cam goes very tight
- gearbox
- Door hinge pins
- Help needed - Turbo oil feed & filter
- Cams
- what size 18" tyre for a saph??
- Best pistons
- PF01 throttle position sensor
- wasted spark loom
- 4x4 Water Pump..........
- 2wd rear anti roll bar
- saff cossie 4x4 water pump pics.
- cosworth RS 500 cooler and alloy rads
- Sapphire sagging front bumper....
- ARP torque settings
- rev counter v6 cosworth conversion
- interia lights won't work
- Driveshafts and Flanges
- 2wd diff oil
- Can't read fault codes
- ABS and Master Cylinder Kits
- Sapphire emerges from the garage
- Spark plug recommendations please.
- 3 door tyre size
- Plenum Breather Valve
- anyone help me with this please?
- Do rotor arms burn out
- Door glass removal
- what to do with my 4i??
- sapphire 4x4 green top lambda test strange
- sierra sapphire abs fault
- small issue
- pic's of your oil breathers
- Escos turbo heat shield on saff cos 4x4
- Breather separator
- Parts compatability
- group a coil part no. and wiring
- Wheel help
- Heavy/notchy power steering on 4x4
- Fitting coilovers
- 3dr rear bumper - ends sticking out??
- Quiz for you boys - pics (strutbrace)
- baily breather
- L8 ecu difference
- 4x4 rear brake back plates
- cossie t5 gearbox
- Sharktooth Alloys Colour
- Help to identify ECU & Oil Modine needed please.
- Torque graph/diagram for YB?
- fuses and relay layout
- To any Cossie owners in Western Canada
- ISCV problem
- floorpan/gearbox tunnel
- L6 ecu to L8
- cosworth mainfold
- 2wd fly wheel into 4x4 cos
- Rear Diffs
- Camshaft Timing belt problem
- saph cos advice
- Cambelt question
- suspension swap
- rear caliper brackets
- Clutch Fork Pivot Bracket-Lightened flywheel
- saph cosworth ABS problem
- re map in the south east
- sun roof
- rs 500 touring cars
- Another stupid question.
- Does anyone knows this product?
- How thick are a standard YB head gasket?
- are 2wd and 4x4 inner tca bushes the same?
- Cleaning header/power steering tanks..
- als + launch control instructions
- Wiper Mechanism
- Wont start from cold!
- Anyone know what the ford part Number is???
- 2wd brake problem
- Gabriel (Raven) Recaro Seats for a Sapphire
- turbo position
- fitting air to air
- Oil filter/modine on 2wd sapphire
- Light steel flywheel
- Modified sump baffle
- Best way to get things looking emaculate
- Sierra cosworth Idle control valve
- Oil modine bolt
- arp maincap torque and oilpump question
- Loom cable size?
- any one know f30rpx
- What rear beam bushes to get?
- 2wd front wheel bearings
- bailey breather fittings sizes
- cosworth running problems help needed
- White Sapphire 4x4 - G787 WAS
- Scorpio 2wd driveshafts
- Sierra steering rack
- MSD L8 Chip question
- J879mfd white sapphire cosworth 4x4
- Saff- making passenger seat a drivers???
- Saff cossie 4x4 abs wiring diagram
- Will Escos struts and rear dampers fit a 4x4 Saff?
- which 2wd HP oil pump?
- rear panel
- Differences between a Sierra 2WD shell and ordinary Sierra shell
- Saff 4x4/Focus RS brakes
- Big wing sumps (2wd)
- Wheels and big breaks
- Cosworth and RS logo?
- Electric Windows
- Coil
- Front diff rebuild
- Please help! Identification and advice needed
- 4x4 fuel & boot release
- bumper repair/mishaped where to get fixed?
- Creating new cossie engine loom
- Tensioning
- cosworth re map?
- How 2 - power steering seals.
- electric window problem on sapphire
- Saph Cossi Engine bay loom
- 2wd calipers
- can you repear a 6 long studded block as 1 of the studs came away from block?????
- 3 door breaking
- (2000) Ford FX 3000 CD Player In A Sierra 1989
- cosworth coil GP.A part number??
- 3 Door Cosworth Fuse Box
- Breather drain pipe
- A bottom end?
- can cosworth 4x4 gear linkage be adjusted??????
- Cos Misfire.... Burning out rotor arms?
- ht leads
- cossy not boosting?
- Cossie 4 pots
- Stainless bolts for my re-build
- 2wd gearbox mount
- Is it worth fitting vernier pulleys on a standard engine?
- 044 bosch fuel pump
