- Zorst still Fookin Scrapping, Standard springs the answer?
- help t34 hoses !!!
- Alarm to control central locking
- new hub bearing's really stiff
- Fan loom help
- Gear stick
- 3 door bodywork
- Andy Rouse's first 304R Sapphire for sell on EBay !
- Has anyone built up thier own turbo ?
- 12.6 sec @ 128 mph at Stratford Raceway today **Terminals Question**
- advice on turbo please!
- ROUSE SPORT database
- Automatic Sapphire cosworth
- Does anyone know K55 COS?
- Is this valve a 2WD Cosworth part ?
- cat cams in uk for cossie valve springs ???
- 3dr cosworth front brake upgrade advice please.
- Cosworth top speed
- front splitter
- 6 Degree Beam - info needed
- Thinking about buying an rs 500
- abs problem 2wd saff cosworth
- 3DR Standard Ride Height
- Cosworth which 1?????
- Turbo blow
- fuel.pressure
- any saph pics with team dynamic wheels
- what oil for 4x4 cosworth
- turbo advice please.
- saph cosworth rare colours? what are they?
- Constructing a 6 Degree Rear Beam
- Best place to buy 3 Door Sills?
- Oil cap rubber
- turbo housings
- 18's on saff
- 1989 Sierra RS Cosworth??? What is it worth.
- Help with ecu set-up
- Off set on wheels ?
- P100 help please!!
- GT3076R Spec for my 4x4
- Oil pump
- steering rack differences?
- Alarm systems
- Car covers for a 3 dr RS
- Runs and stops????
- Valve Springs on Rebuild YBB
- What oil pump???
- Sapphire 4x4 new engine loom suppliers??
- SECS Monitor max boost reading
- Diff identification
- wing mounting panel
- can i get a t34 wastegate repaired or changed
- siemens 55lb code?
- T3/T4 turbo sapphire cosworth
- does anyone know F868 RSF ?
- Sunroof Seal
- Turbo exhaust housing turning help/advice required
- Checking what head gasket is in
- Shaking front end
- Modine oil seal
- saphire cossie 4x4 front drive shafts
- Big brakes for sapphire????
- 3m carbon effect vinyl
- 4x4 aux belt tensioner
- What colour is this sapphire?
- crapi with cosi stud pattern
- Whicch wheels for sapphire cosworth??
- Cosworth front subframe
- South African Cossie
- Buying a Sierra Cosworth for use as a daily driver
- Part of TCA Sapphire
- Sierra 4x4 front wheel bearings
- starter motor
- Saph 4x4 suspension?
- cdz 982 is playin up
- AN fitting for FPR
- Anyone's on here?…
- Need to measure a T5 Gearbox... can you help?
- need help t34 actuator
- some help? sierra sapp
- Camber problem on 2wd sapphire
- Sierra 2.0 dohc 4x4 vs cosworth 4x4
- 2wd saff cossie track control arms
- Pics of Magenta / Neuvau red Saffs on white rims?
- sierra hubs
- holset h1c turbo for cosworth
- L8 ECU
- Removing boost controller
- Sierra MK1
- spoiler lip saphire same as 3 dr ?
- turbo heat shield refurb
- Cosworth head studs
- 2wd saff rear wheel bearings ?
- Misfire / splutter on boost in 2nd gear not others ??
- saff cossie 4x4 track control arm bushes
- Sapphire Cosworth Factory Options
- Crank help !!!!
- Aero Catch bumper fitments
- Sierra 2 door sapphire with Minker engine
- grooved, drilled, dimpled or just plain brake discs
- Fancy Billet anodised blue fuel rail/aeroquip fittings & hosing
- Sierra 2.0i EFI wont start
- saff cossie T3 turbos
- Poor running 24v cosworth urgent help needed
- anyone got any info on this cossy cdz 982?
- replacing brake pads - Saff 2wd - how to ?
- daft one, burning hot Grp A coil + no spark = dead coil?
- Cosworth temp gauge
- indicator switch ford sierra mk2
- 4x4 sapphire running very hot / overheating
- Passenger wheel sits in further on saff
- buying a saph
- where would i get
- Simple question regarding msd evo chip
- Headlight help needed
- water pump help
- Indicator relay
- Hole in cam cover
- Set Up 3 Door Cosworth
- diff rebuild
- 3-door windscreen
- wiring diagram wanted please guys
- what turbo after a T4 ?
- ** F831 MFP ** Flint Grey Sapphire Cosworth WANTED
- now then mr rs500 reg
- rich running cosworth
- What Oil pump
- P100 almost finished
- Valuation
- Fuel rail adapter
- idle speed problem
- Places to buy YB sengine sensors and thermostat
- best place to buy heater cores
- spark plug grade on DOHC Turbo
- 3 door sierra cosworth whells
- saff cos petrol tank
- Anyone have the old ''Fast Ford Magazine'' which featured one Norwegian Cossie?
- setting up tps yb(2wd l8)
- Dog Box for RWD Cosworth Rallycar
- Spax Springs
- Rebuilding distributor
- Where do i find styling? Ford Sierra 1986
- any interest?
- camshaft choice
- rocker breather
- Oil Pressure Light
- Secs monitor wiring
- what clutch??
- water pump question
- question about imperial blue
- 2wd rear beam help!!!
- exhaust query
- Engine Problem! Need Help!!
- saph cossie 4x4
- Vac elbows where from
- please help with boost! UPDATE
- T5 Tailshaft housing Part number
- sierra sapphire to rwd cosworth
- saff cossie radiator temp switch plug
- Photoshop request please
- 16th September 2004 - now a distant memory
- Can i run without a dump valve safely
- High reving when iscv is plugged in
- Can you swap seat backs on recaro's
- Straight cut gearbox on the road (whats it like)
- recaro seat help
- ford p100 tuning
- 4x4 to 2wd pistons
- Wasted Spark with Coil on Plug possible?
- T5 Gearboxparts
- Very cheap new door window rubbers Doncaster
- wich oil after rebuild
- Partnumber of the pinion bearings? 7" 4x4 rear diff
- question about fiberglass rs 500 bumper
- GGR inner/outer replacement bushes/bearings..
- Best place for this
- ARP stud and nut kit
- 4x4 cossie
- 3dr rear hatch central locking help required
- cosworth zputter probs
- What front spoiler lip is this ??
- bore wash cossie ????
- ABS warning
- 3dr cosworth door trim, where to get them?
- Removing ABS
- Cosworth engine management light
- Anyone here tried using an apexi avc-r or safc?
- 7 inch 3.92 LSD - track day Cossie 4x4 ?
- saph 4x4 wiring help..
- 2wd co2 setting
- Kevlar cam belt
- cossie wont fire up??? help
- can you....
- 3 bar map sensor
- pas doesnt work on idle???
- juddering on low revs???
- how to place bucket seats in a sapp
- Are these cheap fans better than the std. ones?
- photoshop please
- crank seal renewal
- L8 ECU
- Best RPMs to launch 4x4 Cosworth?
- Front splitter for saph
- 3dr RS500 carbon front splitter
- Lightweight 3dr
- tachometer problem.
- 18" speedline corsr
- Rear Bearing 3 door
- Too hot?
- PAS tanks/caps
- Southwest RS get together!
- ecu bracket help please
- Hydraulic Cam Followers
- saff sunroof
- 4x4 head to 2wd head
- MSD Wasted Spark Kit - Fitting
- brakes
- focus brakes
- who uses their saph cossie everyday?
- Collins / Vibratechnics etc e/mts.
- Brake pedal to the floor
- Had some professional piccys done!
- High lift cam question
- cossy 4x4 front diff vs xr 4x4 front diff?
- Can someone explain diffs to me please
- 9" rear diff
- Head & Block questions
- Type 9 gear box question.....
- Head question??
- help needed
- saff cossie 4x4 shockers
- FUSE BOX
- who's good for doing cosworth heads
- getting hot on boost? if it has happened to u pleasepost advise
- Head bolts from Burtons
- how much
- Bosch 979 Fuel Pump
- sapphire cossie rear spoiler fixings.....
- 4x4 road set up, but not t34....
- wanted leather bottom part of recaro
- 3 Door dashboard screws/bolts
- how much has joining a forum cost you
- standard rad, opinions please.....
- T5 gearbox problem??
- Overfueling Saph Cos???
- 330mm brakes / 3dr hubs
- Machine shop?
- cv joint tight
- anybody fitted scorpio seat's to a saph??
- boxing in a cone air filter
