- What tyres for 500bhp 2wd
- Coolant Temp Sensor/Fan Switch
- cossie konis
- Std Head Bolts
- Genuine Ambers Indicators ???
- Rocker covers - are they all the same?
- 4x4 cosworth not starting
- cosworth problem?
- no dash lights???
- hydraulic handbrake
- Workshop manual for sierra and escos.
- Carpet query on 3dr/4dr cosworth
- anti lag system
- Finnally Pick up my Saph today
- 2wd sapphire group a coil
- what BOV for sierra cosworth?
- Strut braces
- starter wiring
- sierra tailgate lock problem?
- Electrical power steering
- ST170 disc with Mondeo caliper on 2WD Cosworth?
- help please
- 3 Door Spoiler Caps
- cam cover marks
- Websites
- Top Gear Saph On Pistonheads.
- SECS Monitor Query
- saff pespex window kit
- Sapphire Headlight problems
- Saff Oil Pressure
- twin cam fuel pump
- abit help required
- positioning saff spoiler on new bootlid with no holes
- Sierra Cosworth Gaz coilover setting
- Max Wheel Size
- cossie and non-cossie rear 2WD axle differances
- 3 Door Bodykit
- converting from 2wd to 4x4
- Turbo talk.... should I be worried?!
- My Cossie Drives! Advise on setup/self checks please!
- Cosworth Chip for L8 where?
- Starting Issues
- Power Steering
- 4x4 cosworth brakes
- Cosworth 2WD/4WD suspension - advise needed please!
- adjuster needed sierra cosworth bumper front
- hid conversions
- Interior lights staying on
- Another Wasted Spark Question, Back fire
- 2wd and 3 door................
- Sapphire Cosworth/Escort Cosworth foglights
- Long studs
- Cosworth 4x4 head ?
- Head bolts or Stud & Nut?
- turbos
- How is standard airbox held in place? sapphire
- 4x4 track control arm.
- 2wd Sapph rear brake options.....
- trying to find a saph cossie
- bd10 info
- Changing Cambelt/Removing Crank Pulley
- Sierra central locking and mirror.
- Help again: Bleeding brakes
- Beside the normal fix...................
- Anyone got the adjustment settings needed for 4x4 saff stage 2 beam?
- Foglight & Indicators
- Electrical problems (Wipers, heater and rear screen)
- HELP! Tint, or not to tint?
- 2wd modifying plenum
- 4x4 header tank vs 2wd header tank???
- brake help?!?
- 2wd Water Pump
- Running lucas 01D142B injectors in place of siemens 83's?
- Cosworth throttle position sensor ?
- Reinstalling an Engine.
- ABS (again)!
- Spec me a 450 bhp engine please
- Sierra 2.3D - air filter box parts
- little vid of my saff. elite sequential box first run.
- gloss black/ flat black in rwd saph, many about?
- Tubular rear arms
- 3 Door Fuel Level Gauge
- BBS replica alloys on Ebay - advise
- I'd map sensor
- Sapphire rs max tyre sizes
- Gauge fitting
- 4x4 saff ferrodo rear pads fitting
- how to check part number?
- Getting used to stage 3.....
- Original ford sapphire cosworth boot spoiler
- Abs ecu query
- Selecting springs (Apex, Ahmed Bayjoo, AVO...)?
- 3dr front hubs??
- windows not working
- window switches
- 3 door door mouldings
- need some help on conversion
- Plug gap - wasted spark
- Fins codes pls
- about recaro buckram buckram
- Mechanical LSD options...
- Water pipe from stat housing when running a T4 on a 4x4
- Under engine cover
- Full hose kit for 3 door
- Cosworth Niggles - Very strange goings on
- Cosworth inlet plenum cover bolt size ?
- Cosworth Saph 2wd Breather system
- Couple of questions
- Engine mounts
- New fuel Lines
- powerflex rear bush kit help
- More Rust, Shite. Nearly Welded up yay
- skimmed pistons/squish/deck height
- 2.0 twincam RS2000 flywheel?
- Sierra 2.8 not revving
- Battery connections
- Cosworth offset ?????
- ET42 offste
- Oil pressure
- CDF Discounts!
- Discount Anyone?
- Bonnet gas struts
- My new work horse, sierra p100
- Indicator question
- RS 500 style pin stripe
- fender guard / lining 3dr standard ?
- Throttle position signal = where from
- splutters under load
- bad day
- This Sierra?
- Bonnet Swap...
- cosworth na minor problem
- What remote iscv for Antilag?
- tsw hockenheim
- Sierra lowering
- Strut braces, worth it?
- 2wd spark plug problem
- Carbon sidedoor mouldings ?
- 3dr wheel center cap lock ?
- Sierra & Sapphire Cosworth Still in Demand By Thieves?
- Alternator - is this right?
- Sourcing genuine parts, wings
- 3 Door Cosworth wanted
- doh! (twin 45's)
- Sierra Mk2 rear lights, Saph and Hatch different?
- Sapphire Door Strips
- 3Dr side exit exhaust fabrication
- Wiring questions
- sierra sapp cosworth
- Head rest removal
- Cosworth 4x4 rainbow cloth?
- 2wd saph running issues
- Boost and idle promlem one for a cossie god
- Bonnet pins / Aerocatches
- t5 4th gear problem
- Dimensions of a Saph cossie front foglight?
- My p100 tell me what you think
- Pics upload small
- swirl pot mounting 3dr
- Lambda sensor thread on cossie?
- 4wd plenum
- saff bumper brackets
- gaz gold set up ??
- ABS wiring loom grommit
- doors on 3door help
- New Fuel System Goodies
- brake upgrade
- Sierra 2.8 metering head and injectors
- Wasted spark
- Bleeding brake valve on sapphire 2wd
- What clutch for 400bhp?
- 4x4 side repeaters?
- Sun roof on a 3 dr
- Mountune YB-cams
- cosworth tie rod ends
- saph heater matrix
- On a saph, what do you call the black metal part nearest the bulkhead?
- Sapphire Cosworth idle problems, tickover lumpy. HELP!!!
- valve spring qestion?
- Sierra estate suspension
- billit fuel rails with retaining clips
- What actuator for gt30?
- Air In The Cooling System
- 2WD vs 4WD Front Wheel Hubs
- Recaro seats swop
- Fiberglass 3 door kit suppliers?
- T5 shifter
- AGPR 902P or denso irridium IK27
- P100 2.9 v6
- Cylinder head testing
- Bara gearbox rebuilds
- Aux water hose kit - oil modine
- lowering compression
- Pro alloy breather/mirror image
- Granada front hubs same as 3dr cossie ones
- Rocker cover gasket, whats best?
- ABS sensor/Brake wear sensor front suspension strut clip?
- Searching piston & longer rod packet (YB)
- 2wd petrol flap gasket
- Cosworth YB 2WD – Coolant system
- Front hubs
- general engine loom questions
- 3dr ignition switch cable
- 4x4 saph front springs
- ECU indentification
- Gearbox mount thread
- can a cosworth water pump be rebuilt
- GT30 water feed piping advice
- cosworth v's xr4i front shocks
- Standard Rev counter in 2WD Saph
- 2.0 dhoc turbo???
- saff cossie 4x4.T3 turbo
- Alternator Issue ?? I'm puzzled
- Flushing the full system on a 4x4
- Airtec intercooler
- Fuel Pipe leakage
- skirt rivets
- differential
- 2wd ecu on 4wd car
- Waterhose size
- Dead Turbo...
- Cosworth exhaust manifold to elbow gasket
- saff cossie door mirrors
- prefrences on cone or performane panel filter??
- Sapphire battery clamp
- Hex prop donut
- A17 AHF white saff, upto2001???
- air filter housing diffrence
- 2wd rear caliper thread size
- Saff Cossy ?? Dead or alive
- Sticky caliper
- struggling to start??
- Coilpack location ideas?
- help! need wiring loom grommet...
- Which fuse for central locking??
- What disks and pads????
- 2wd saph diff
- difficult gear change 4x4
- rev counter and fuel guage problem
- sapphire indicator lense
- 4x4 Suspension
- Turbo Damber - Fitting Problem
- Can someone that actually knows clear this up for me?(front diff removal)
- 4 pot calipers
- Rebuilding rear calipers
- 3 Dr bumper question
- saff headlight wash wipe
- Gear gaiter
- What's the deal with Cosworth ABS Sensors?
- diff mount ?
