View Full Version : Ford Sierra / Sapphire / RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. How do remove the backrest of rear seat in 3dr sierra?
  2. Bump Stops
  3. Wire ringing a must or not........?
  4. how to remove the distributor
  5. Strange thing happens with the cam belt
  6. rs 500 intercooler advice
  7. 3dr carbon door cards
  8. Is this a spoof ebay ad? RS500 engine?
  9. Failed MOT..springs
  10. Heat shield
  11. info needed on my cossie engine
  12. for fuck sake
  13. All Sapphire owners need this video in their lives!
  14. Dunno if this is the right place for pics?
  15. 2wd Diff replacement
  16. water pump question
  17. Free free free
  18. 4x4 inlet plenum on a 2wd 3dr. What are the benefits?
  19. Doubts in twinky turbo conversion
  20. Anyone got proper pictures of the rs500 touring car dashbords ?
  21. 4x4 tyre choices...
  22. silicone hoses
  23. can you fit a 4wd diff to 2wd?
  24. Centre Prop Bush
  25. Four single ignition coils
  26. 4*4 Fuel Pressure.
  27. bought myself a 2wd saff
  28. Hart Plenum fitting problems **It's on, Finally!!!**
  29. cosworth bottom pulley remover
  30. Problems fitting 2wd gearbox cradle
  31. pinto and Yb blocks the same?
  32. 3dr wont start
  33. external wastegate connection?
  34. RS 500/3dr Exhaust....
  35. ABS light on
  36. help please!!!!
  37. Super chargers on cosworths
  38. no heaters
  39. boost gauge fitting
  40. Heater Hoses
  41. rear crank seal size
  42. Strange knocking noise
  43. What pitch are propshaft retaining bolt threads?
  44. Fitting a rollcage in a sapphire
  45. cosworth breathers..?
  46. cossie cam followers
  47. T170 Gearbox for Sierra Cosworth?
  48. What wheels do you think?
  49. Cosworth sunroof help
  50. More headbolt questions !!!
  51. Central Locking
  52. 2wd lightened flywheel weight
  53. Anyone know what springs they have on their 3 door?
  54. Fitting gear stick to cossie gearbox.
  55. yb oil filt cross over part #s
  56. sapphire rear window trim
  57. Cossie T5
  58. 2wd exhaust manifold
  59. Water Leak
  60. Hart Manifold Question
  61. replacement arch
  62. Koni adjustables for DOHC sapphire
  63. rear brakes binding..
  64. 2wd sump / oil pump ?
  65. 2wd Saph issue - any ideas?
  66. help please rewiring fans
  67. iscv fault??
  68. this manifold?
  69. wiring fault on my 3dr
  70. car cover??
  71. does anyone know this car
  72. FAO Tabetha
  73. More info about (this) N/A 3dr Sierra.
  74. 45 50 and 60mm core intercoolers
  75. 3 door cosworth wheels ??
  76. cosworth front 4wd brakes fit 2wd???
  77. torque setings for 6 nut an stud kit?
  78. MSD chip with ALS ?
  79. 2wd/4x4 exhaust manifold question
  80. Cosworth gearbox oil seal
  81. How important is the length of the map sensor pipe?
  82. ggr dump valve
  83. whats needed for 380bhp saph cos
  84. amal valve wrongly fitted
  85. fuel rail question
  86. Help please!
  87. thanks enhanced performance
  88. Bootlid spoiler grommets.
  89. Frofix Racing exhaust manifold
  90. bloody misfire
  91. fuel pipe i.d
  92. RS COSWORTH 3 door t4 Turbo ???
  93. Which head gasket
  94. Cosworth Fuel Filter Thread Size?
  95. saff vs 3dr dimensions
  96. Sierra diff mount?
  97. Mongoose Exhaust Fitting - Sapphire
  98. Help! Gearbox mount bolts
  99. Diff Oil
  100. this turbo any good
  101. Really bad vibration on my 2wd saff?
  102. how much power ?
  103. YB flooding...
  104. swedish plenum
  105. what diff to go for
  106. Inlet pleunum spacers?
  107. Power steering pump pulley question ?
  108. e640jlt anyone know of this crystal saph?
  109. whats its worth
  110. engine parts ?
  111. gt35 at 15-20 psi...
  112. Group a ignition coil
  113. Help ... New Design for my Sapphire Rallyecar
  114. Sierra Saphire RS Steerin Hub
  115. Sapphire Wrap!!!!
  116. Clutch, Exhaust, Sticker questions????
  117. bigger intercooler?
  118. Isle of man tour..may 2011 final price's
  119. £dr fuel tank level sender unit
  120. dizzy cap
  121. sapphire cosworth 2wd help!
  122. Bosch 044
  123. Oil pump testing
  124. 5th gears for T5 gearbox
  125. what colour for my wheels
  126. Let down by ford,anybody know where I can get these from?
  127. My 3 Door before goes away for winter
  128. Saff with 8" and ET32
  129. bayjoo springs,where from
  130. color nr red cam cover
  131. cosworth shell
  132. Denso iridium IK27
  133. sapphire cosworth front bumper
  134. How much BHP?
  135. Rear light gaskets?
  136. Rear beam and standard sierra floor pan
  137. T5 gearbox rear oil seal
  138. sunroof panel
  139. RWD engine Prices
  140. ecu pulses per mile??
  141. What gearbox fits Sierra Cossie?
  142. 3 Door Sound Deadening etc
  143. Where to get pistons pocketed and head mildly ported?
  144. white saph's on comps
  145. Where can I get hold of a .55 housing from, for a T34 Turbo??
  146. Opinions please guys
  147. Fuel gauge
  148. sierra cosworth rad over heating problem
  149. Anyone know what this is??
  150. Ford sapphire 2wd cosworth heat shield.
  151. Mt75 gear lever cradle bushes, solid alloy or poly?
  152. idle dropping
  153. Rocker cover gasket
  154. Whats a 4x4 beam and trailing arms worth ?
  155. sieera running bad when warmed up
  156. ABS Power supply
  157. 4x4 gear oil
  158. 24v injectors
  159. cossie coilovers
  160. Copper brake pipe size
  161. L8 Weber babyboard
  162. clutch cable
  163. Abs pump
  164. Sapph steering column flexible rubber joint?
  165. 3 door head lining
  166. 4x4 Sapphire fuel pump priming
  167. diff viscous fluid?
  168. what is a brand new 4x4 engine worth
  169. L8 ECU ?
  170. help needed rear drive shafts
  171. ISCV question? High idle.
  172. 3dr Missfire Still not solved HELP!!
  173. Solid steering rack bushes
  174. Genuine RS500 intercooler on sapphire?
  175. Standard 3 door wheel refurb
  176. adjustable bottom arms clicking - normal???
  177. 4x4 Calipers on mt FRST
  178. fuel pump rewire wire size
  179. Best Oil for diff 2wd cossie
  180. Best oil/atf for a 2wd t5 gearbox
  181. SPAX stickers
  182. New wheels now fitted
  183. Diff size
  184. Oil circulation problem?
  185. Need for readjustng the actuator for Manual boost controller?
  186. Intermittent problem
  187. 2wd Springs - what ones?
  188. steering rack leaking oil,prop uj where from?
  189. Front wing removal
  190. Battery dead
  191. Alloys
  192. 3 Door ABS ECU
  193. head parts
  194. Steady boost ?
  195. gave her a clean up
  196. 92mm 8.0:1 Wössner pistons and 136 mm rods
  197. 2wd Steering Rack
  198. Missfire On My 3dr
  199. ABS Light Staying on on a Sapphire Cosworth
  200. What Spark plug?
  201. Temp Gauge gone limp!!
  202. servo pump seized?
  203. Spring platform height
  204. Whats the best Brakes setup I can buy for my 3dr for around £500-£600 ish
  205. compression test
  206. Air condition (R12) service ports 4x4 saff
  207. IK31 iridioum denso or Qc57 champion
  208. starting problems 4x4
  209. breather return
  210. Oil pump driveshaft?
  211. cosworth 2wd inlet
  212. Sapphire Fogs/Surrounds....
  213. 2 Cossie's Same Carpark
  214. Fuel starvation problem
  215. newbie buying adv
  216. 3dr abs problem.
  217. Cosworth none start
  218. Co. up & down
  219. Where can i find chassis dynamics springs SRH???
  220. torque settings on 6 long stud block?
  221. 2wd pick up pipe
  222. cosworth rear uv joint drive flanges
  223. Enhanced performance
  224. Front drive shaft angle
  225. Where can I get this
  226. Fan cut in temp ??????????
  227. Turbo pre filter
  228. Most Expensive Cossie's I've Ever Seen!!!!!!
  229. can Valve to piston contact damage be removed by pocketing?
  230. who else uses 15w50 engine oil
  231. comp ratio question
  232. Cosworth ht leads -reistance
  233. Water injection. What kit??
  234. 2wd Header Tank
  235. Manual steering rack on 3dr? Opinions please.
  236. New greek cosworth forum !!! Check please
  237. What is this??? Late spec 4x4 Saph
  238. another addition to the ford family.
  239. Fuel pressure
  240. What do they break for?
  241. water leak cossie 4x4
  242. Setting up Cosworth cams
  243. Cosworth battery
  244. Strange distributor oil leak ?
  245. Interal block pic's request (:
  246. Oil press gauge sonection on 4x4 sierra coswarth
  247. Repairing 3dr turrets..
  248. How much power is put to each prop? MT75 4x4
  249. Saff Splitter
  250. Damn thing won't start!! **Now works as of 04/10/10**
