- Staph Cos brake problem
- Sapphire Cosworth body colours...
- Fuel lines on sapphire.
- Ryan loom wiring plug diagram needed please
- RS500 Intercooler and relay question
- Correct boost hose size
- Took the old girl for her mot this morning
- 3 door spoiler caps
- sapp cage
- Ab07 cam question
- Spins well ( vid )
- Steel lined gasket set?
- Sequential box for my old 3 door
- Sapphire sunroof blind removal
- AP help
- crankshaft endfloat
- 2wd oil turbo oil feed bolt locations.
- Help needed after rebuild
- Last drive of the year for the Cossie
- pad wear sensor plugs on car loom?
- Dutch Trackday Cossie
- Gearbox oil & diff oil
- Body panels for 3dr
- What power can i expect from this setup? (stage 3)
- what do you guys think of this cossie?
- Sierra ABS guru needed!
- got my aps now whey
- 4x4 throttle body same as 2wd
- would a 4x4 saph cos owner be kind enough to
- Does anyone recon 2WD PAS Pumps?
- Disaster fitting turbo oil feed pipe
- Helix fast road clutch kit
- Saph 4x4 tuning advice needed
- Cosworth engine build help please
- coss 2wd non assksted ps rack?????
- Crank timing gear
- crank seal / aux seal
- Leather now fitted and treated
- Fitting new exhaust studs
- Cosworth misfire problem
- sapphire bumper brackets
- Saph prices
- Saph wheel choice
- inner guard (arch liners) station wagon (estate)
- solid lifters cosworth yb
- Rear arch liners still available ?
- will 18 X 8 ET25 FIT A 4X4 SAPH ??????
- Turbo heat sheild options?
- 3door and 2wd sapp question
- Relay prob
- et 25
- ET 25
- SECS monitor new from Matt Lewis
- Sapphire boot spoiler
- Blowing Cossie inlet manifold gasket(s)- Symptoms?
- AFR problem
- D741 WFE- now with a pic;)
- sierra 4x4
- any experience with these MTEC discs?
- Chip Specs
- Breather return to sump?
- Amal valve wiring
- 909 map sensor
- intercooler outlet sizes
- ACT Sensor Thread Size
- Leather recaros in to lounge furnature
- Anybody running a 6 paddle Alcon with standard cover?
- Free - Drivers seat and steering wheel for Mk1 Sierra 4x4
- diff problem
- Sierra ABS brake master cylinder differences
- adjustable rear beam
- setting up idle with new idle valve
- Primary to secondary exhaust manifold
- YB Fuel rail
- Fuelpump bracket
- Jacking point covers
- correct rear boot badge sises
- anyone used or using k sport brakes?
- Anybody done the focus rs conversion on front brakes
- front splitter??
- Underside help plz??
- Cosworth BOA's and BOB's
- What's a clean saff cos shell worth?
- Valuation for insurance
- Wheeler Dealers Cosworth on ebay
- Exhaust manifold stud question
- RS7 diamond cut alloys
- Look what came Tuesday yay!!!
- 60/70mm airtec intercooler
- YB Water pump difference?
- Ceramic heat coatings on manifolds and turbo back housings
- Anyone used one of these ?
- Brake lamp warning illumination
- What's the widest 18 inch tyre can get on back of saff ?
- Identification please
- What's the best remote oil filter kit for yb?
- Best headgasket stage 3??
- Cosworth 4x4 Brembo Brake Conversion
- Sourcing parts for stage 3 set up
- Rear brake imbalance
- Cosworth arb question
- slow to rev at standstill????? idears?
- Blanking plugs on offside of block (suitable for oil temp sender?)
- cosworth not starting (with results)
- PF09 TPS Details
- Sapphire 4x4 door adjustment
- Is this the same headlight as a Saph Cossie ?
- Fuel Tank Strap Bracket?
- Have the 7 spokes had there day?
- 3dr coilover issue, HELP!
- Engine wiring loom
- Valve Guides?..
- Cosworth caliper bleed nipple size? seized!
- avo suspension 3 door
- pos braking 2wd sierra cosworth
- valve on rear circuit ABS MC Sierra/Granada
- Stage 1 cosworth issues
- 3dr brakes onto 2wd saph
- What spec for 450 bhp
- Coilovers with compression struts, what springs?
- Handbrake problems
- 3dr loom
- solid lifters
- 2wd Sapphire Cosworth gearbox and Diff Oil?
- Did some 402 today..
- Gearbox Fluid
- turbo rad
- cosworth breakers in the midlands
- starter motor 2wd
- 2wd cosworth big brake conversion help
- Injector colours
- Fuel tank
- Air vents to front bumper
- Paint code
- Continuing Problem
- Sunroof question
- Sierra spring types ?
- Where to buy Axle shafts?
- rad/intercooler set ebay opinions
- Saff dash in a 3 door??
- ABS wiring plan 2WD
- Bilstein dampers
- t34 turbo
- Sapphire info
- What options do we have if dont want to go poly bush??
- Fuelling Mystery
- 24V Cosworth XR4i Conversion
- Rear beam
- Wanted
- Best T5 quick shift
- Just bought a Sierra Cosworth project
- Sapphire Cosworth Fibreglass bumpers.
- ariel amplifier
- wheel offset 3 door
- finally found one 3 door cos pics
- replacing my rear bumper
- anyone know where to get a new one?
- Oil leak on my Sapphire Cossie.
- What colour?
- Cossie 4x4
- Boost leak testing (how to)
- Those running AVO coilovers favour needed
- Dash and fuse issue
- Oil leaking from exhaust manifold
- Replacing exhaust manifold gaskets
- 2wd gearbox mount part number...
- Anybody breaking a sierra?
- Had to wave bye bye today to the cosworth BACK HOME NOW
- info/help on servo ?
- Ford amplifier question
- Sierra 2.9 4x4 imobiliser
- Recon gearbox and new quaife diff on 2wd, what else??
- To rebadge or keep de-badge
- Ford sierra 2.0 CO screw
- Typical. Faulty cossie the day before Ford Fair weekend.
- any one using cdf racing pulleys? help please
- 3dr Ford boot badge size
- How to refit Sierra radio?
- 4x4 cossie not firing :-(
- cossy parts how much and where from
- Standard or modified
- Ford Fair preperation
- Expected power On MSD Chip
- which oil for stage 3 cossie
- A shocking problem..... ;-p
- quick question 4x4 drive shafts (front)
- T3/T34/T35/T38 specifications
- Essex engine with type3
- Does anyone know this car G775LWX?
- iscv & idle niggle
- With one week to go before ford fair just lots of cleaning left to do
- 2wd shocks and springs ?
- 2wd rear diff
- E38 brembos
- Which front springs for my 4x4 3 door?
- RS500 splitter for my saph, where/who?
- Help re -rear axle pick up points
- Pops and cuts out at 4k
- Weber L8 mapping
- good old 2wd diff lol
- ecu
- Engine coughed a big end.
- Negtive camber saph :(
- Fitting 2wd exhaust manifold onto 4wd?
- 3dr & 500 Petrol Tank Original Colour
- Wheels on a 3 door
- Brake compensator valve?
- sapphire cosworth door cards
- Por 15 link???
- 044 fuel pump rewire problem
- rs500 centrelocks arch rub
- Saph fuel tank removal
- How to release clutch pedal ratchet?
- siemens 55lbs Lucas replacement
- 4x4 Saph quik shift?
- any pics of RSMAT's car with the centrelocks?
- Relays saph 4x4
- Discs and pads for 400bhp?
- Can I tow a 4x4 sapphire
- 2.8 cologne engine flooding>?
- i need cologne 2.8 answers before i take a hammer to it!
- Sierra Wing mirrors
- sell it or re-shell it ????
- oil pan on sierra dohc 2.0 1991
- H170gbd anyone know it?
- 4x4 cossie abs !?
- Sierra 2.0 DOHC Coolant Leak
- How much is a saff worth
- Sierra rubber boots
- bringing a cosworth back to life!
- Twitchy sierra?
- Dv replacement diaphragm
- 2.8 cologne problems :(
- petrol tank strap ,fitting advice please
- Dump valve
- sapphire cosworth electric mirrors
- Who knows L8s and chips?
- Konis for a base model
- Dash clocks not working
- Tuning Options on a 2wd saph? 3k
- Supercharging a NA Cosworth YB
- 4x4 engine into 2wd shell
- Granada cosworth none runner
- Anyone know this car C197GVM
- sapphire cosworth head light protectors.
- replica front bumper spliter, painting
- what pistons
- 3dr Speakers
- Vibration under load
