- Wings
- Central locking problems ...?
- Colour underneath 3 door Cosworth
- FAO people with supra diffs..
- if i turn from 2wd to 4wd do i change ABS?
- Alternatives to genuine 500 lower spolier.
- sapphire 2wd rear arb
- Digi dash and original sender
- Fuel return blowing off..
- Blanked off hole on 205 block?
- level 8 versus autronic sm4
- Digi dash install help..
- Looking side exit exhaust for 3dr
- Fuels tanks
- PAS Bracket Gasket on block?
- Cosworth/xr4i tailgate the same?
- top and bottom End knock on rebuilt yb
- Anyone know this 3 door? D22FOT
- Lower 500 rear spoiler
- Best paddle clutch for 2WD...
- value my car?
- flywheels bolts
- fordopedia.org handy for finis codes
- Cosworth 3 door interior loom WANTED
- cosworth 3 door wheels.
- Where can i get some of these fog light clips???
- Fuel tank sapphire cosworth
- Sharktooths, what they worth?
- Wasted Spark - Fitting instructions required :)
- SECS fitting instructions
- Sapphire Vibrations :(
- Quick Sapph breather question
- Roll cage on a road car
- Engjne mount help
- White 3 door D350UYJ D350 UYJ
- 3dr cosworth dash wiring diagram.
- Rear Beam Mounts Powerflex or Solid?
- Fuel tank fitting help!
- Plz recommend a garage in Yorkshire
- Brake lines - Can you still get them?
- Lack of 4 x 108 Alloys
- Removing boot spoiler
- Alloy header tank and swirl pot??
- Siemens injectors fitting querie.
- 3dr Towing eye
- Need a favour regarding cosworth steering rack length
- bushing sizes
- 4x4 gearbox bolts
- 2WD sapphire exhaust - which one to get?
- 2wd cosworth Gearbox mounts
- 3 Door grill
- inlet cam and adjustable pulleys
- Camber shim problem 3dr
- YB oil weep
- New YB loom help
- help needed !!! engine build pricing
- P8 ecu question
- Anyone clued up on a cossie YB water piping system?
- Wheel cap o-rings
- Any odd coloured cam cover pics?
- RS500 Grill Panel
- sierra 2.9 v6 24 valve breather pipes
- L8 ecu
- Block Oil Gallies & Main Bearing hole?
- Drop bracket and belts not fitting..
- What sandwich plate do I need to use on a 4x4?
- 83lb injectors
- Hubs
- Bells and rotors
- Sierra Internal Fuel Pump
- Any Bias Pedal Box for Sapphire??
- i put escort cosworth wheels on it
- Clunking noise 3dr
- Fuel line replacement part options
- Yb engine whats it worth?
- steering problems after fitting coilovers 3dr ??
- what springs ??
- Heater not working in Sapphire
- Running a T4 without a dump valve?
- Black Cosworth Rocker Cover
- coilover setup corner weighting
- what a difference some lights make....
- goodridge copper washers ??
- cosworth mapping
- 3 door cosworth fuel pump switch
- 330mm discs for 4x4 cosworth??
- Using and exhaust cam as an inlet cam...?
- Rear section saff
- Horrid noise
- What Spec battery for Cosworth
- nuts and bolts help
- 4wd - 2wd cams????
- 3dr driveshaft lenth?
- Fire extinguisher mounting, where have you put yours?
- Oil pressure switch thread
- Cosworth AFR problems
- Saph jacking points - are any replacements available ?
- 17" Wheel ET, tyre size
- Red sapphire on eBay has been relisted
- Big Brakes 16" wheels 4x4
- Headlining?
- 3 door loom
- 3dr sunroof?
- Fuel pump uprated loom
- red sapphire on ebay, current bid 8K with no tax or test!
- Coilovers catching on arch
- nylon fuel pipe on filter leaking
- Loom refitment
- Saff headlamps/upgrades?!
- 4x4 T34 to fit a 2wd?
- T34 with restrictor fitted
- hart inlet on a stage 3 cossie
- abs relay constantly clicking
- Smoky cossy
- Borg Warner spooling
- Cosworth smoking
- oil injectors bigger size can be fit in yb?
- springs from iscv valve
- who knowes about aftermaket mt75 gearkit materials????
- 4x4 crank pulley late type
- Aftermarket front ABS sensor
- How much antifreeze to put in my 4x4?
- 10MM inlet spacer for Hart inlet?
- GT3071 /76 on standard engine..?
- 044 pump and inlet fittings & pre pump filter?
- ARP Flywheel bolts
- T34 actuator bracket
- HELP....Turbo water pipe union washers
- 4x4 Gearbox and clutch options
- Wheel nuts
- misfire
- 3 door wheel cap locking
- Strange potentiometer
- Sapphire and hatchback rear bumpers - are they the same?
- Sapphire door trims
- Best offset for 8"x17" wheels on a 4x4 saph?
- Sapphire rear light gaskets
- Mallard green 4x4 Sapphire
- T34 0.48 or 0.63
- Cosworth
- 4x4 saph floor pan
- GT30 turbo on standard engine??
- Any pics of fuel an brake line clips in place so I no were to put them plz???
- Any rubbing issues
- How to modify a 4x4 downpipe to fit a 2wd manifold?
- Roof rails
- wheel locks 3 door sierra cosworth
- I4 2.0l 8 valve
- wrong offset?
- amal valve jet sizes for msd 380bhp chip
- 3DR 17" Alloys Offset & Tyre Size - Help!!!
- Which injectors
- Removing ignition barrel without keys?
- No cup holders!!!
- cosworth outer trailing arm bush on 6 degree beam
- 2.4 stroker kit, sierra cosworth.
- RS500 splitter with ARB question
- 4x4 turbo damper
- 17 x 7" wheels on a saph? Widest tyres I can fit?
- Rear beam bushes
- Abs alternatives on a 2wd??
- rs 500 oil filter blew almost up
- Saph 4x4 turbo
- 3 door with a full chassis ? anybody ever seen one?
- 3 door front bumper mount repair?
- 3 door Cosworth clutch cable.
- engine
- Mk4 Escort sunroof
- 2wd power sterring pipe
- Sapphire box clunking
- 4x4 saph 1991
- Cosworth wiring
- What is my engine?
- Lift pump wiring
- Recomended body & paint place (Teesside Area)
- tramlining-handling
- be carefull with E bay turbo damper
- EFR7064 on a Cossie
- Play in Saph 4x4 steering rack
- 18s on a sapphire
- Sierra breaking
- help needed compomotive mo6 wheel nuts?
- Raven leather & TPS
- Removing center vents
- 4x4 viscous coupling
- Who can supply me a brand new turbo?
- door and wing mouldings
- Headlight Help Please
- oil presure problems! any one help??
- Carbon delight???
- new cranj
- Sapphire cosworth standard ride height.
- cosworth recaro leather seats ?????
- Reducing YB capacity down to 1400cc
- RS500 Turbo damper help
- Can you identify this?
- Washed and looking good again
- Air to Air injectors
- Stage 1 2WD sapphire fuel pressure and boost pressure
- central locking 92 sierra sapphire
- Anyone with a bailey power steering tank ??
- distributor gear and auxiliary shaft gear broken also oil pump shafted twisted
- Sierra Cosworth Group A Manual
- offset help
- Cosworth not starting :(
- sapphire with team dynamics 1.2 17" wheel pics anyone?
- Sapphire 4x4 headlight upgrade
- value of a brand new lattice wheel
- crank
- Turbo choice to transit cosworth
- Saff with kahns
- front arch liners
- Saphs on 16's
- any help on cooling system change sapph 4x4
- 3dr owners help
- 2wd sapphire cosworth valuation?
- Propshaft Donut/Coupling in an MKII 1.6 Sierra
- Best cosworth stage 1 clutch kit
- what to check on a dodgy cosworth
- heater blower
- Watford PF owners where to g]et wideband sensor bung welded in Watford area?
- map sensor help ?
- 2WD Engine loom
- Saph 4x4 bushes
- engine stuttering under acceleration?
- Chassis leg
- j85 htu
- rs500 intercooler hoses ??
- Wrapped sapphs
- sapphire cosworth a real daily?
- Anyone from birmingham?
- Modeen oil cooler
- Saph 4x4 tyre sizes for 17s
- Cosworth TPS help please
- Distributor shaft play
- Torque settings
- Sapph 4x4 heater not working
- rs 500 anyone :)
- Looking for help / info on remote servos
- Removal of complete running gear question?
- Machining rocker cover
- Differet dash on RS500 vs regular 3door?
- Rs 500
- My Pride and Joy
- Off set. wheels 3 dors sierra cosworth - help please
- White Cossies Wanted For Wedding Scotland
- WRC Style Mirros Sapphire
- Saph Body Panels
- toyo 888,s+ rl7 +saff = what et and widths
- 3 door cosworth genuine?
