- ABS fuse - where?
- door mouldings still available from ford??
- Moonstone colour match
- Cosworth 4x4 starter motor
- is removing pedal box easy?
- escos running lean?
- diff oil
- 3 door windshield
- possible to repair 4x4 steering coupling?
- Fuel Pressure Regulator
- Anyone running a t36?
- 4wd inlet what rail?
- Warped dashboard and stuck recaros
- how many 2wd with leather interior were made?
- Powerflex Black - Upper Strut Bushings Question
- Rear trailing arm bushes, what's classes as excessive play?!
- Cosworth Quickshift Problem
- Info needed,T5 gearbox 5th gear
- Wiring a PF09 TPS and Map sensor for standalone
- Gear ratio
- gearbox diff oil service
- cossi350
- 1987 XR4Ti struggles to accelerate/start
- Cossie problem?
- Will 225 18s go on the rear of a saff ?
- New Lithium Ion battery for the 3 Door ***Final Installation It Runs***
- 2wd diff plug size ?
- How many smokestone blue saph cossies left?
- Help needed please folks!!! (2wd sapph coilovers/hub issue)
- Cosworth dashboard repair
- Help on changing a 3rd sump??
- Ab07 camshaft
- Help with setting up gaz coilovers on my Sapph
- Diff oil
- Saff rear arch liners the same as 3dr
- Engine bay decal locations?
- Cosworth Bolt sets
- 3 doore sierra bumpers WANTED
- XR4Ti Rear beam bush help
- GAZ coilovers of AVO for the Sapph?
- Stage 1 power output
- Injectors 403's Greys or Siemens 83's?
- Modifying the ISCV for Antilag
- vents in passenger side of sapphire floor
- Rocker cover tightening torque
- Can i sleeve my 4X4 front hubs to fit 2wd struts?
- problem after fitting supra diff
- 2wd sump
- sapph brakes
- Best brakes under standard wheels
- big wing sump
- Where to get Sierra upper steering column bearing?
- 225/45/17 tyres on saff ?? To wide ??
- Where to buy t5 speedo drive??
- Centre prop mount bush, options?
- Exhaust
- Are you ever finished restoring old fords
- Few issues stopping my rebuild...Please help
- Sapphire cosworth prices
- What size master cylinders for 3 Door pedal box?
- What next?
- Cossie 3 Dr. Starter relay.
- K640 AAV
- Digital ACT Gauge that can use original ACT sensor
- Injectors (blue) without clips-how to mount?
- Where to buy Conrods
- Fuel Pump Loom
- Will standard prop take 400-500Bhp???
- Cossie issues.
- loom plugs
- Sump gasket half moons...
- GGR TCA'S
- Sapphire Cosworth width...
- Cosworth fuel pump connectors
- Whats this for?
- Seals
- 4x4 rear ARB to 3dr
- Sierra Sapphire Cosworth 2wd parts
- T5 bell housing trx bolts
- cosworth electric gremlins
- panel gaps
- Mot issues, car runs like a bag of pooh!
- 2wd Cooling Fans
- Moonstone paint code 5 9
- Which is correct 2wd Cosworth badge
- Chevrolet V8 into a Sierra
- Brand new saph front & rear windscreen seals?
- Cosworth cooling system question....would this work???
- Bottom end spec for 450-500hp...
- Escort cosworth rear bias valve
- Front splitter
- Any body know this saff?
- Anybody know this chip ?
- Anybody know of this Saff? :-)
- 2wd cosworth no spark
- rs 500 bumper
- sierra 3dr bay repair ??
- Bosch 65lb/hour 650cc Low Impedance Fuel Injector
- Best Place to Get new Saph Cos engine loom
- Nitrous on a Cossie, speak to me.
- Siemens 55 and Msd chips what they worth
- AB07 vs nweman 256/350
- YB refuses to even cough.
- Downpipe flange
- Do Ford still hold any 3 door stock?
- Polly diff mount
- 100mm airtec intercooler, slimline fans needed??
- what is a set of boost hoses worth
- Is this Standard L8 baby board?
- DOHC to pinto swap
- Oil spray jets
- Clamping braided hose at fuel rail
- Distributor problem?
- Sapphire diff side gears
- T34 water cooling pipes
- Compression ratios
- WANTED: Sapphire rear outer window seals?
- Stiffer or longer?
- Sapphire headliner removal
- Brake bleeding problem....
- Fitting size - Compressor housing
- mt75 4x4 gearbox diy building?
- 909 Top mounts fitting problems
- Monitor
- Std rebuild
- Wheels Thread
- King pin inclination
- 2wd Saph underbonnet carpet
- Tremec
- Centra wheels?
- MT75 4x4 Gearbox - how much torque causes problems?
- Sapphire clocks
- sierra sapphire seat mounts
- 3dr headwork
- Sapphire Cosworth value
- Standard ride hieght springs?
- cossie sounds like bag of nails and no boost
- best company for sills 3 door
- Secs wiring instructions
- T34 turbo rebuild prices?
- 2wd cosworth clutch recomendations pls?
- Quick bit of help please.. Crank oil seal (yb)
- 4x4 saph cosworth vibrations from the front update : os sharft shit its self
- power steering issues please help
- Steering column issue
- Where tyres for my 8x17's??
- Power Brakes
- Sierra dohc runing problems
- Ahmed Bayjoo Springs
- Anyone managed to stop the front bumper from smiling ?
- What is this worth?
- Delete
- Sunroof blind removal
- Knock sensor for 4x4 cosworth
- How to remove
- Sapp cos bumper outer brackets
- RS500 Front lower splitter part numbers req
- Exhaust Housing T34
- Timing cover fitting
- 2wd diff cooler options?
- 4x4 sump gasket
- msd distributor blank help
- Sapphire 2wd speedo binnacle
- Failed trailing arm bushes?
- Which ECU do I have
- Exhaust manifold studs and nuts
- Cossy 2.0 16 '91 - Gasoline pression regulator
- RS 3 and 4 spoke wheels
- Sapphire Cossie door - bottom weather Rubber/Clips
- cossie rear stub axle
- T-35 Turbo For sale on Ebay
- I'm looking for photos sierra mk2 with arch kit from mk1 cosworth
- Serviceable bottom balljoints?
- Steering self centering
- Quaife ATB
- Locks 4x4 sapph
- GGR oil separator
- 3 Door Wheel Refurb
- Cosworth fuel pump cradle
- 3 Door 1/4 window from clips
- Sierra sapphire roof bars
- sierra wheel earing size difference help?
- Std Fuel Lines vs Braided
- Oil pressure and running temp in general. Info please.
- Who runs a T4
- Sapphire tailpipe size
- help / information remote servos
- rear hub torque?
- Window seals
- alternative bulkhead padding??
- Is it stage 1 L8 eeprom?
- Alternators
- Alloy Vernier Camshaft Pulleys
- Flange on boost hoses?
- Fuses
- Bearings
- Gearbox and diff oils 2wd
- 3dr rear pads
- how do you remove a sunroof from a sierra
- ABS sensors... 2wd & 4x4 the same?
- sapphire standard front brake hoses
- Castor
- Stock cam timing suggestion on modified YB engine
- Cosworth not starting
- ET25 235's Rubbing 3dr
- Anyone know where I can get cosworth diff mount countersunk plate
- K919 YRJ
- does anybody know this car f77 knd
- newbie
- When were 3 door Cossies built??
- anyone now bayjoo spring length on rear of 4x4 staph?
- Sapphire 2wd water pump
- SOLVED!!! Chatter and no dump valve after fitting boost gauge....?
- hiss when remove petrol cap?
- Fuel pipe to rail
- Starting issues with wasted spark
- Help!
- Powder coat help on me saph
- strange rollcage xr4i
- cosworth looms
- External wastegates....
- Oil leak
- 2WD sapphire gearbox
- Cosworth gaz gold spring
- Standard cosworth breather system?
- T5 box sitting too high after Vibra technics
- oil pump priming
- fuel sender ohms
- Identifying Standard Fuel Lines
- Knock sensor cossie
- are 2wd and 4wd backboxes the same
- Sapph carcoon anyone used one ??
- sierra fuel line clips
- anyone using a data stream? info please
- Standard Cosworth engine bay pics
- T3 turbo , 3inch down pipe for ???
- LHD 3dr headlamps finis code?
- YB sump gasket which is best
- Abs loom Cossy
- D 66 NKN
- Rs500 first day clean
- Rear brake caliper cossie 3dr
- What engine mounts do you recommend for 3dr?
- Cosworth Coilover options
- RS Spoilers
- reverse switch
- Kidney filter
- New intercooler help needed
- Wings
- Central locking problems ...?
