- Motorsport developments chip for t34.48
- Motec M800 cossie engine loom
- Safe boost for Hybrid T3
- Plenum spacers 10,14,17mm ????
- CG Motorsport 6 Paddle
- Sapphire engine tear down & rebuild
- Sierra cosworth Fiberglass panels
- 2WD Sapphire fuel pump cradle
- Heatproof/Sound Deadening
- MK2 later spec dashboard front panel dissmantle
- Oil pressure lights
- powerflex bush help
- Air box differences
- sierra cosworth front seats
- wanted sierra 3dr parcel shelf supports
- Seized 4x4 Saff NSR Caliper....
- What's a Sierra RS500 Light Pod worth
- diamond white color help
- Dash Mounted Tablet / PC on Sapphire Dashboard
- What are these wires for
- Smoked to Amber Saph Cos.
- Rear Beam Bushes
- 2wd baffle sump & big wing sump info
- 4x4 engine & GB mountings
- Spacers/Studs for Timing-Belt Cover,
- 2wd and 4wd clutch release bearings same?
- Engine loom firewall plugs
- Turbo chattering
- Full paint needed.
- Yellow injectors
- Battery
- PAS pipe
- 4x4 ex manifold on a 2wd car
- glove box clips for a 4x4
- Won't turn over
- Anybody got an rs500 fuel pressure reg for sale?
- Anyone know where to get part of a interior loom?
- 3DR hubs again
- Spec-R Turbo Heat Shield, How are they fitted?
- Rear ARB mod...
- bike rack for a sapphire!
- Polybush Kit?
- 3dr fibreglass splitters
- Re: rs500 e636 khu for sale at speed asters
- Remove door glass from 3dr cosworth
- What turbo is this and few engine questions(Sapphire Cosworth)
- Seat rails
- Temperature gauge sender
- head gasket help
- Finis code for rear suspension bolts?
- help someone must have the answer!!
- Saph Cosworth shocks same as normal Saph?
- t5 gearbox bush
- New Battery Recommendations
- clutch conversion hoses
- FORD Sierra XR4i in Russia
- Engine bay looms
- 3 door body restoration costs
- Boot lid/tailgate wire harness grommet - 3dr cosworth
- t5 gearbox tail housing bush(pic heavy)
- 3 door gearbox cross member
- DBW Throttle Installation on the 3 Door **All Fitted**
- Sierra
- sapphire windows
- Sapphire rear light problems.
- 3dr gear selection problem t5
- Dip/main steering wheel stalk
- cvh sump
- My cosworth
- Rs500 body kit attatchment
- Sierra RS500 replica
- oil pump and spacer questions
- FORD Sierra from Russia, Sochi
- Sapphire Cosworth engine oil?
- lowering 3dr drivers seat?
- which clutch is this?
- Valve collets where from??!
- actuator shaft length
- Gear selection problem T5 3dr
- Escort Cosworth wheels on a Sapphire?
- 3dr sunroof seal?
- Rebuilding T5 WC
- T34 water and oil connections
- saph cosworth
- Cosworth powered p100 will not run!
- 3 door cosworth seat belts
- Where to source genuine ford sapphire bonnet
- any info on AEM wideband AFR numbers ?
- looking for restored steering wheels pics
- Cossie actuator advice
- Tubular Exhaust Manifold
- 3DR Front Suspension Diagram
- Misfire when boosting
- RS500 Throttle Body Bolt Hole PCD
- Get your graphs out.
- AP Organic Clutch Question
- my idle valve cleaning
- Pistons and rods for engine build
- V6 power steering
- Rear light wiring
- what to or not to polybush?
- so whos using the oppiler in there 4x4 cosworth ?
- Sierra Cosworth 2WD, What to look for?
- Left Hand - Right Hand hub nut question
- Fast Ford car of the Year 2014
- Water injection?
- flywheel ring gear
- Cavity
- 3dr Sierra rear quarter glass trim clips ?
- 3dr cosworth shell
- ALS in L8?
- 4x4 hub vs xr4x4 hubs
- wasted spark driver is this ok?
- throttle cable refit
- cosworth reliability
- More wasted spark starting problems!
- 2wd 88 standard hight suspension
- idle dropping /going lean at idle
- 3dr boot decal
- never seen that in a cosworth engine like that
- My wheels since owning the car
- RS500 clips, 2 needed please help :)
- Will a t34 fit my manifold
- cosworth starting problem
- diff rebuild
- full respray advice paint
- 4x4 sierra no spark...
- Help with electric aerial
- cambelt change. Where? Essex/East London.
- Best place to get 2wd sump big winged?!!
- Cosworth values
- Pace intercooler and charge cooler
- pinto and clutch queries
- Yb ECU's
- Removal 5th gear
- Fuel pump wiring
- need: pinto turbo manifold
- 4x4 Cossie oil leak locations
- FL 205 / FS Steering Bearing mod
- Uprating rear calipers to 4 pots.......
- Vehicle speed signal needed for L8 ECU?
- Paint code for smokestone
- Need help identifying ECU
- New Sapphire Cosworth Front Bumper.
- Rs500 splitters for saphs?
- Quickshift & reverse lockout
- Cosworth heater blower not working
- Centre dash vent removal.
- yb mods whats best way to go
- Diff Play
- 3door head lights
- Idle valve vae01
- A sierra girl for sure
- XR4Ti > Cosworth fuel tank
- Fuel pump cradle mounts Help 😥
- What kind of rear beam/arms are these?
- What is the best dry sump system for YB 2WD?
- 3 door wheel offset
- Do you have to remove the gearbox for hydraulic clutch conversion
- Help with ecu
- Head assembly problem????
- clutch cable for ap 6paddle
- dry sump size for YB
- Engine machine work
- Ignition timing
- 4x4 camshaft O'rings
- AP organic clutch is it ok at say 420bhp??
- cossie fuel pipe leaking
- T5 Shift knob
- YB compression height
- Cosworths - Real & models
- Removing 4x4 rear discs
- 4x4 Cos Clutch fork question
- 3dr steering wheel diamater
- Sierra 2WD rear beam and suspension arms
- l8 ecu
- Green & White engine bay clips.
- changing engine shaft oil seals
- Braided Wiring Harness Inquisition
- Fuel pump fuse and relay
- Sapphire cosworth door mouldings??
- 3dr Cosworth grill mesh were from??
- Rear braided line advice needed
- Turbo water/oil lines
- 3 door cossie died
- XR4i Central cocking and electronic boot release??
- Sierra Tapered wheel bearings Help
- Headlining material WANTED
- Sierra Cosworth Standard Gear Knob Refurb.
- BD15+ Cams
- 4WD Loom on 2WD car
- fan comong on but not cooling
- Fuel pump wiring ( no 12v to pump )
- Rear lights
- T5 gearbox repair kit
- 3 door sierra boot lock
- Gear stick removal
- how heavy cossie head with manifolds and turbo
- Sierra Dashboard
- 2wd Cosworth pivot
- Difference 2wd sapph hubs and 3dr hubs
- Oil filter relocation
- aftermarket brake bias pedal box
- 4x4 starter
- Anal valve
- Sierra roof skin swap! any threads on it ?
- 4x4 crank pulley on 2wd...
- 3 door cosworth headlights
- spark plugs ngk or denso?????
- What head on sierra 4x4 front propshaft flange bolts
- In tank fuel pump upgrade needed for 24v v6
- turbosport experience ???
- Cylinder Head Bolts
- Thoughts!!!
- Cosworth cross members difference?
- Saff sideskirt clip position.
- Help needed for poor running sapphire 1.6 pinto
- Best place for leads, dizzy cap ect guys??
- what hp can handle a sigle clutch plate ?
- Mt75 Transferbox 4.1
- Sapph 4x4 front hub nuts
- Cosworth Restoration Help
- Aldusting camber
- Gas gold spring rates
- sapphire front wheel
- Msd coilpack on yb, same fireing order as ford one?
- spotted in suffolk
- sapphire adjustable tca
- Anybody got any info on H18 CJB moonstone saff
- ARB Shimming
- Next step advice please. Currently t35.55 and 55 injectors
- Sierra 2.0 DOHC brake upgrade
- Cosworth engine issue!
- replacing sump gasket advise
- Please help, Whats the story behind D40 NTA
- What's the story with this eBay RS500?
- Cosworth bumper brackets
- Car won't start plugs not wet but have spark?
- weld cosworth yb cyl. head or only skim to remove dent
- Engine cold idle problem
- New fuel pump loom which wires for the relay
- fluctuating fuel pressure!
- viscous fan
- 3 door standard exhaust housing
- Cosworth 2wd gearbox
- What was so special about the Sierra GT?
- Rs500 grill mesh
- '91 OHC 2.0 wiring/loom
- T-5 parts and motor mounts
- has anyone used or bought a head fromwww.cncheads.co.uk
