View Full Version : Technical help Q & A
- Carbs better than fuel injection - Why ???
- wing mirrors
- 205 block id
- cosworth head bolts
- Cossie dash clocks, all one unit???
- help me,, ive got no spark!!!!!
- series 1 running problem
- fuel lines.
- Mk4 escort rear springs
- anyone had this problem b4?????
- help me fit my turbo please!
- No oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- polished rocker cover
- StreetKA mirror assembly help request
- Supercharging sierra 2.9 v6 12v
- aMAL VALVE
- Duratec Q....read on.....
- fiesta turbo wiring diagram
- XR3 No3 Cylinder Spark Jumping from lead to head..
- vibrating noise
- zetec turbo conversion, turbo question??????
- How can I check Crank Position Sensor for a signal
- Cozzy 200 block oil return
- which size tyre do i use
- Power Steering Pipes
- Mk6 Escort ,Steetring Wheel Movement
- misfiring 2.8 capri
- 4x4 transmission and diffs
- boost prob on escort s2
- 2.o efi pinto into mk 2 escort
- 4x4 ESCORT COSWORTH WATER PUMP
- bilstein suspension
- S1 turbo running probs
- 1.4 EFI Escort R reg leaking oil, common places please?
- ATB rear diff
- What is the purple and black wire on xr2i fusebox pls
- what turbo to make 400 450 bhp
- 98 escort air con switch
- Missfiring problem
- S1 passenger side rear wheel locked
- Poor running FRST.
- Noisey 4x4 Engine - Poss rebuild help
- Plug gap question
- Brake problems not getting solved :cry:
- quater light black caps replacement
- 350 brake
- loosing coolant from yb
- rs turbo with creaky rear suspension?
- 2wd turbo damper parts diagram
- Fuse box help
- zetec S rear beam (axel) on mk3 xr2i
- Help needed!!!!
- cosworth crank..
- Brakes and bleeding
- xr4x4 gearbox?will it fit my cossie?
- Mk4 eclipse strut brace problems
- Escort 1.6 4x4 1996, Links/Addresses/Tech info on 4x4 system
- Escort Cosworth Smoking!
- rocker cover colour
- YB valve seal renewal without removing head?
- oil return on zt
- transit van brakes on erst
- rebuilding zetec
- BOOST GAUGE FITTING?????????????????
- Problem with ´95 scorpio
- Will an chipped RST ECU fit on a RS1800 Engine
- Siezed Caliper - Is there a temporary measure???
- Sapphire 4x4 not boosting
- Zetec Turbo???How the Fook!!!!!!!!!!!!!!!
- urgent help needed asap
- Mondeo 1.8zetec 51reg engine management/warning light on?
- 3 door cosworth arch fitting - Help needed pls
- Noisey Cosworth Head
- grounding out at bumps
- brake flaring best way to do a good job?
- what type of wire from ecu to injector in the loom?
- American Steel Internals for 2.1 Turbo.
- Escort Problems
- ford cosworth adaptor plate
- Is it okay to mix and match....
- URGENT HELP No boost !!!!!!!
- loosing coolant
- compreshion test
- engine tests
- How low can Coilovers Go?
- saph cossie brake problems
- Focus alloys
- Group A Fitment Rally Wheels for a Escort Cosworth
- 300bhp small turbo ecossie wot plugs?????
- How do i adjust my Kent cam CVH solid cam followers?? HELP!
- WINTER STORAGE FOR 4X4
- plug gap size on champion qc57c plugs
- zetec fuel rail
- Series 2 lowering springs, help needed please!!
- electric fuel problem with mk4 escort efi turbo
- ERST Suspension Spinning!!!!
- ignition coil
- non startin s2 rst
- gearbox advice??????
- Sierra XR4x4 running on 3 help
- zetec turbo stud fitting
- S1 Conversion- Need advice
- rear heated screen and ariel amplifier
- Newbie needs help
- cosworth turbo's???
- Alternator question
- wheel sitting too far back?????
- group a pump/relay???
- Cossie Front wheel bearing change - how hard
- t3 turbo wastegate
- Piston ring question!
- fiesta rst engine into a mk2 efi orion ghia wiring help
- Spring rates (once more)
- Cossie probs......again!!
- Escort SI central locking
- 4x4 cossie blue injector p/n
- How do I plumb in an AMAL valve?
- Escort Wishbones
- best kind of metal
- flammer kit
- Running in rings
- Loom/Electrics problems
- Carb to MFI
- XR3I Help!!!
- Strange clunking noise from o/s front on saff???
- RUNNING ON 3 HOLDING BACK
- cosworth turbo flutter
- Carbon composite effect
- Mk4 Heater Control Knobs
- focus rs lump into mk6 escort
- help??
- Alternator advice???
- RS Focus Dump Valve
- where and how much?
- cat on or off
- zetec question...
- HELP NEEDED WITH AMAL VALVE ON A SAPPH COSWORTH
- st24 help plse
- sapphy spluttering!
- ERST S2 Havings Problems
- noisy box!!!
- escos injectors
- 2wd cossie rear diff in to a 4x4
- Rs Turbo cutout
- escort cossie kangrooing.....??
- Dash/loom connector
- plugs and gaps running 2 bar
- Zenon Headlight Conversion
- PACE CHARGECOOLER
- cossie gone BANG with flames :(
- Help Please. Towbar fitting instructions needed??
- engine...
- bayjoo 330 chip + T34 turbo
- 2wd EXHAUST MANIFOLD/TURBO
- I am a dipstick.
- quick help needed with rs turbo zetec conversion
- Can anyone PLEASE HELP me out????
- Mk3 Fiesta ECU
- engine rebuild
- HELP. Fuel pump problem in sierra cosworth
- Are the 3dr and Saph T5 crossmember interchangable?
- FRST management realy pissing me off , any ideas????
- Piston Rings
- Gaz coilover spring rate advice??
- Exhaust
- st24 to st200 engine conversion
- escort si alarm wiring diagram
- Part number for RS500 fog light grills
- 2wd cossie going lean above 1bar
- Weak Actuator ?
- Removing a loom
- how do i fit a -31 actuator
- Gearbox problems
- Is my ecu chipped or not ?
- cossie overfuelling, what could cause this??with readings***
- s2 noisy tappets. due to low oil pressure?
- Fitting new KONI shocks and springs to 4x4 cos.
- Escort RST Swirl Pot
- cosworth running problems
- temperature gauge
- saff 2wd cosworth problem
- water hose
- Extra Low Lowering springs!
- ECU problem? XR2i
- s2 front mount intercooler query
- clutch prob on s2..help!!!!!
- lack of power when cold
- low charge battery light???????????
- Towbar on escort
- zvh problems
- Got a weird grinding noise...
- Gearbox's Short Ratio
- Escort Cosworth giving me the Hump
- ford orion rs turbo conversion
- NEEDED, Auto Electrician
- ford cvh gearbox differences?
- anti lag
- fuel pressure regulator
- est mrk 5 bad camber
- escort s2 oil out of dump valve
- Suspension problem Mk3 3i
- s2 rs turbo gearbox swap
- saph cos - -25mm / konis undrivable garbage. help? :(
- Fitting KONI Suspension
- GTi side skirts
- Help!!!! My cossies misbehaving
- cossie engine rebuild best place to for parts????`
- cossie 2wd annoying squeaking
- Mk4 Escort Carbon Fibre Bonnets
- What quantities do you use when mixing paint?
- Possible bad earthing for headlight???
- no amal valve
- mk4 escort headlights
- erst mfi c/o
- fiesta lsd swap?
- 5th gear puller needed
- Cossie workshop manuals
- EFI HELP
- valve timing on bd 14s
- anyone know what type of boss on mk.6 escort?
- Rs gearbox
- Turbo-ing a xr3i
- cosworth cooling fans
- Zetec 2.0 Problems
- How much oil do you need to put in? saph 4x4
- My car has a wobble !!
- 4x4 head
- pre filter
- Exhausts
- BIG POWER COSSIE
- Q plate - Any info e.g cost etc...
- 2.0 Si problems
- erst wheel studs ?
- why is my cossie whirring????
- T3 turbo not boosting
- Fiesta Reverse Light
- Zetec engine running problems
- 1997 escort SI Alarm
- **Cossie sump plug, what size of allen key???***
- smoke on start up ?????
- grp a fuel pump wiring?
- Sapphire 4x4 Cos will not run! Now she does with stutter!!
- Boiling Header tank! Help needed
- longstuded cos block
- XR2i Carb conversion
- AP brake pads catching bells!!! help
- FORD FIESTA MK4: wiring diagram
- ERST Breather System
- XR4x4 running badly.....
- bd10s
