View Full Version : Technical help Q & A
- low temp warning sensor 2wd cossie
- N/A ZVH build?
- escort td Diesel prob
- rs turbo sender unit
- Idling all over the place.
- Internal Heater Problem On Esc Cos...
- Washer jet questions.
- Granada cosworth hubs on 2wd
- A piller damage.
- saff 2wd cams whitch is inlet and witch is exhaust?
- Which Relay
- adjusting gear linkages
- Light Problem
- help please need adjustable lower front arms
- Zetec Turbo in a Mk4 RS Turbo shell?
- no boost in third gear ?
- vr sensor/cps on zetec
- Anti lag..... Whats the score
- rs soft 7 spokes
- WHY DO COSWORTHS MELT PISTONS?
- 90 spec rear spoiler
- Fiesta seat subframes
- Saph 2wd Cos buying guide?
- Parcel Shelf
- XR3I 1.8. SOS
- Ford KA Lexus lights
- Cosworth tappet noises?
- Escort cossie fuel pump relay???
- want torque not bhp
- cosworth wont boost past 14psi
- What size diff do I have?
- power steering conversion
- s2 will not start
- wtf is happing with my car !
- Skimming Zetec Pistons
- Escort GTi + V6 Mondeo Engine ?
- Fitting a cossie turbo onto a ERST manifold...
- twin carb minifold
- onboard fuel computer
- NON START MYSTERY???? PLEASE HELP!!!
- need help with fitting racing seats
- oil cooler for cossies
- escort xr3i 93 fuel pump realy
- fitting an cone filter to a mk4 fiesta
- 2.0 zvh
- Megasquirt use
- fitting a turbo timer HELP
- FRST Ignition??? Please help
- boost and mixture
- mk 6 escort help please!!!!
- Horn!! beep beep
- swirl pot
- help with fusebox
- Escort Cosworth Front Diff
- Roll cage type?
- 2wd gearbox options, sequential??
- oil light on on tickover
- charge cooler pump
- My runabout wont run when cold!!
- Escos front shafts
- FRS Gearbox!!!
- Bigger YB oil filter
- ahhh f*ck**g car need help on hubs
- Strange thing about rear coilovers - any ideas?
- fiesta lsd ?
- FRST starting problem
- escos dash lights
- 2.0 zetc engine to turbo, which is best? advice needed pleas
- HELP needed with OFAC wiring / Wont cold start with chip.
- boost problem
- wine?
- Difference between frst and erst engines??
- FRST Superchips.....
- changing too L8
- 4wd conversion, which transmission tunnel???
- audi injectors on OFAB management???
- Gremlin in 2 litre 130HP Focus!
- Zetec into Fiesta?
- not starting escort cosworth replica
- RS 2000 kit car rear axle
- granada cossie water hose tangle
- Fiesta heater not working
- anyone got a pectal loom diagram ?
- The curse of the smoking cosworth
- Cosworth fuel line
- zetec with bike t.bs
- killing oil seals RST
- Escort Cosworth Cams
- rs turbo in a xr2
- Unichip
- 01 mondeo wiring info needed, specifically speed pulse info
- Cossie won't start, run, i mean drive
- Ford stereo help please!!
- Air fuel ratio gauge's HELP
- FUel pressure gauge fitting????
- EFi
- xr3i spluttering
- escort cossie conversion
- Anyone know what size banjos are on cossie fuel filters/pump
- 3 door bbr stainless exhaust
- focus v6 duratec
- Will 8x17 comp mo's go straight on sapphire??
- FRST radiator! Please help!
- Removing Bushes.....
- RST Escort Sumps....
- Lamba sensor's
- 1.6 zetec-s tuning
- American 1.9 Blocks and increased capacity RS Engines
- 350+bhp and no lag?!
- RS2000 i4 engine query
- rst starting problem when hot
- BETTER BRAKES ON MK5 ESCORT 1.6
- turbo technics part numbers??
- Laser jammers
- escort rsturbo smoke????
- 2WD Saff compression pressure?
- WHITE COSSIE COMPS 17S
- actuator info please
- gaz coilovers 2wd cossy
- Flywheel?
- Trying to find an mfi engine for a Escort cabby?
- bmw cosworth-blue smoke?
- Idle control valve clicking?
- fuel pump prob
- top end rebuild
- new cvh engine, how much is it worth?
- New clutch maybe ?
- cosworth 4x4 front set up
- FAO cossie loom / ecu pin out gods??
- help with escos
- ABS removal
- std cvh engine conv to turbo cvh?
- autometer voltmeter gauge
- how do you maintain a charge cooler
- escort mk5 timing problems and head gasket
- 2wd saff cossie brakes on mk5 rs2000
- What pistons are these ?
- rsturbo convertion how hard????
- Intermittent starting. ERST
- Another weird steering/suspention problem
- suspension clearance
- intercooler or charge cooler on frst?
- escort turbo convertion????
- m6 1.6 zetect alternator
- Misfire & Oily Mess Help Needed 2wd saff cossie!
- mk3 escort windcreen wipers told me where to go this morning
- mk2 xr2 xetec loom
- Buying a Chipped Ecu HELP HELP
- Lobro joints on rear wheel drive shaft! Stub axle LH or RH??
- 2wd headgasket help
- Fuel system to 550bhp
- MK5 WINDOW MOTOR
- cossie leathers into a escort rst ?
- mk5 escort van/turbo conversion
- Ecu????
- Throttle Cable????
- S2 gearbox and diff advice needed?!
- squares????
- Wanting to know a bit more about Chips?
- Escort Rs turbo ECU
- Cosworth High Idle
- jammed open ?
- Saph fuel pressure
- S1 help please . . .
- on a 36-1 flywheel what degree is the missing tooth??????
- need a t2 turbo
- Mondeo towbar
- CPS reading old spanners but not flywheel
- MK3 Escort HELP
- pictures
- mondeo forums
- turbo oil pressure
- FRST Low Power output Help!!!!
- cougar twin pipes
- What air filter ?
- cossey garaged up for winter-battery charger????
- Cossie Is CRAP!! No Boost - any advice???
- White underseal/waxoil
- S2 RS Turbo tuning
- Escort RS Turbo ECU Chips, 3 Wire Jobby?Bit Sceptical
- hydraulic handbrake
- frst cutting out when u press clutch down to change gear
- zetec fly wheel spacing is it 36-1???????????????
- help, wheel problems
- bosch 803's what cc do they at what bar?
- Cosworth 2wd tuning advice
- Newbie Ford Ka Questions
- Mk3 xr2i
- escort gti interior
- cvh turbo lost power and running lumpy
- please help- installing a hydraulic handbrake
- Parts i will need for cossy management !!!
- How to remove a turbo housing?
- rs1600i susp. settings
- Ford KA Running On 3 Cylinders
- rs turbo gearbox for mk5
- smoking on idle
- Please help,im a beginner!
- gear box differents mt 75
- Sticky Valves
- 2wd engine loom diagram
- quick dump valve question
- what would cause
- clutch
- T5 gearbox...
- Brake hoses
- cosworth Fuses
- any 1 using megasquirt or used
- ford motorsport
- wiring for ford racing voltmeter gauge
- help
- Escort GTi IDLE PROBLEM
- s1 cutting out at 4k when driving
- cossie head - back on - problems?!
- zetec on R1 carbs
- Escort Van wheel wobble
- 3dr rear side window removal
- cossie 4x4 rear springs (lowering)
- 2.1 xr3i
- mk 6 clutch
- Cossie 4x4 stereo loom
- sapphire 4x4 TCAs
- I want to replace my YBP for a YB Cosworth engine.....
- 2wd cossie rear beam.
- best oil to use in escort zvh ?
- TT F18 4i turbo conversion/help needed
- Unichip fuel
- Sport KA Blowing out cold air???
- wide band a/f gauge
- smoke under bonnet
- Cossie rocker covers - different colours - why?
- cl on a mk5 escort
- mk5 headlights
- smoke and subaru sounding engine!
- Rev Counter on P8 with Dizzyless Question
- anybody good with audi,s ????
- any 1 know ofab wiring for zetec turbo in mk5 zetec escort??
- T3 Turbo Conversion - What injectors?
- Pulling to side under acceleration
- Speed pulse?????
- 4x4 cossie help
- Group a coil fitting
- clutch cable on fiesta rs 1800
- need to turn up fuel mixture on ERST
- hazard switch
- expensiv ?
- what diesel pump on 1996 escort van?
- cosworth engine wont start HELP!!!!!!!
- Escort GTI strange noise when starting
