- Mk1 xr2 drive shafts
- mk 4 fiesta st conversion
- 2004 Mk1 Focus tdci Random misfire
- what inlet manifold for sierra zetec turbo?
- Permanent 12v live only when the car is unlocked?
- Driveshaft / Hub Nut Size
- Cosworth distributor timing help
- CVH carb engine question
- Leak off test result
- Mk2 escort bolts size
- 05 Fiesta blower problems
- focus 1.8tdci limp mode?
- loosing brake peddle
- 2007 Focus ST3 O/S Headlight Issue
- MKII 1.8tdci - squealing noise, turbo???
- AQUA ecu eec-iv pin layouts.
- KE ECU dead ??
- 2wd cosworth no spark
- MK2 escort rear corner were to cut?
- Focus Air Con pipe
- dump valve setup fiesta RS Turbo issues
- Ford Focus RS fault codes ford techs pls help!!!!!!!!!!!!
- Rattling Blower
- transit connect 2005 model wont start
- anyone put a puma 1.7 into an early mk4 fiesta
- efi conversion help needed
- who sells red & black anodised hose fittings ?
- 07 focus 1.8 tdci none starting
- what do I need for a zetec conversion
- map and knock sensor what cable?
- S2 KE jetronic help!!!!
- mondeo tdci boost or fuel issue? really stuck no fault codes help plz
- Name that hyd centre push clutch conversion ???
- 1988 Escort 1.3 ohv. Which temp sensor?
- Overheating Problem
- 2.0 zetec turbo
- Zetec turbo inlet, fuel rail & injectors?
- Mk3 escort gas problems
- Issues with ford escort van
- Focus 2.0 tdci lots of issues (fault codes inside)
- 1.8/2.0 zetec management megasquirt. Which version?
- valvoline 20 50 in cosworth
- EFi - Tuning
- rough idle when hot
- t34 group a turbo oil feed
- No fuel at the injectors when cranking
- Mk1 RS focus misfire
- Puma conversion issue
- rs turbo efi converted hesitant
- Engine.2,5 st in S-max
- Thermostat problem - please help!
- xr2i misfire
- 1.8 silvertop exhaust manifold ,pipes coming of it?
- Pf09 tps
- turbo technics v6 head gaskets.
- Xr3i fuel pump relais
- ford p100 engine convension
- 2002 Ford Mondeo 2.0 Ghia heats up
- 2.0 zetec into diesel escort?
- track controll arms
- Best place for escos starter motor?
- do cossy engines have locating dowels for cylinder head?
- Mk6 Fiesta 1.4 running rich?!
- cossie 7.5" diff question
- turbo technics v6 starting problem
- Mk1 rs focus air leak help required please
- Weird idle issue that goes after being driven/boosted (2.0 zetec turbo
- Help with seat inca
- Hall sensor pin outs?
- What's Your Best Car Cleaning Tip?
- 1.6 Zetec-Se Rebuild
- mk7 fiesta heeečllllpppp
- zetec engine info
- Focus & Ka fuel pumps & starters
- editing a thread title?
- Recirc dv question
- Mk1 Focus TDDI ABS issue?
- Mondeo 2001 1.8td notchy power steering
- would mfi Erst tank and inline pump work for zetec n/a efi
- oil pressure ... ?
- engine oil temp 150 degrees ?????
- Mk1 frs inlet manifold question
- turbo spec info needed
- Escort mk4 Zetec conversion auto electrican Aberdeen area
- escort cosworth dim battery light
- shark tooth alloy caps
- Escort cosworth breather system
- Black stuff on the floor pan?
- Ford Fiesta 1.4 diesel starting problem???
- MK3 Escort - converting rs1800 to st170
- afr question
- Cosworth 4wd ancillaries vs 2wd ancillaries?
- Escos front seat spring support HELP
- How to modify ST EsCos inlet manifold and fit on a Saff
- forge actuator
- cossie 2wd timing belt tensioner query
- Banjo Bolt for Power Steering
- Stripping a car down to bare metal?
- Whining focus st engine
- 3 door cosworth no spark !!!
- focus tdci KKDA timing issue
- Mondeo TDCI engine swap - TDDI?
- Zvh to zetec head conversion help
- Fault Code C1288 Abs pump
- S2 RS Turbo Speedo
- Ford Puma Rocker Cover Gasket Leak
- Manifold gaskets ??
- Very strange problem!!!
- ECU temp daft question
- 3dr
- HELP! focus st170 stuck in 4th gear!
- Ford fiesta blower motor is noisy
- Total Compression Loss?
- Cosworth head repairs
- Ford 10" rear drums, which vehicle
- 2011 fiesta stereo removal
- WOT Dyno Tuning - Individual Zone Tuning.
- Cortina MK1 YB
- secs monitor wiring mines not same as manuals online
- Viscous coupling
- Any race cams for MK1 1.6 focus ?
- MK6 Fiesta - How do I remove this hose...
- Focus 2008 1.6 tdci
- 1.8 TDCI Engine code location
- saff 4x4 o/s/f drive shaft popd out
- Focus mk1 Rs charge cooler help.
- SportKa Engine Transplants
- mk6 fiesta speedo problems
- CVH 1.8 zetec bottom end conversion
- removeing underseal
- escort mk6/7 cosworth throttle body
- keyless entry
- Cosworth YB engine build discussion, 400 bhp goal.. talk to me..
- Sierra cosworth oil pipe ??
- Escos High Revs Problem
- cosworth fuel pump problem
- Disarm passenger airbag? (Focus mk2)
- Stereo won't turn on (3dr)
- fiesta rs turbo injectors
- Mk1 Focus RS smoking after engine re-build
- megajolt tacho feed
- RS turbo.. Desperate Help required..CUTTING OUT
- Mk2 Escort Brake Problem after upgrade Calipers
- Restoring a car and sound deading
- Cvh ticking, sounding like a scooby
- Help Needed 1.6 zetec ignition problem! missed ford fair :(
- Odd knock/clunk
- Sierra fuel injector cleaning
- Focus ST2 Oil seprator
- Newbie after timing help
- strange noise from car on idle
- Roelof Smith
- What cams to use in my stage 3 saph?
- Lotus twincam, Cam bearings worn?
- Sapphire/Sierra 2WD ABS
- MK1 FRS Piston rings
- Saph Cosworth 4x4 alarmmodule fault
- Fuel pressure problem
- cosworth 4wd fiesta 06??
- help needed! stu@motorsportdevelopments?
- Bosch 044 help
- p100 rear axle options
- mk3 escort rwd using sierra rear floor. In need messurments
- pectel t2 / apexi boostcontrol
- tyres
- Focus RS management/loom, standard throttle sensor?
- best oil to put in g/box & diffs ?
- urgent help required asap
- 1.8 petrol 2003 mondeo
- series 2 rst
- Rolling arches
- Mega squirt
- ecu chip
- Flooding
- Nylon Fuel Line and Barb Fittings - How to connect?
- Which oil level dipstick can I use? 2.0 zetec E
- ST170 - MPG Computer
- Under bonnet chrome plates
- St mk2 boost issues
- USB OBD11 ELM327 any good.
- Rst into bonus shell- cutting holes
- 02 KA Headlights go out when braking
- need advice on ignition setup
- Escort mk2 zetec efi very high idle
- missfire
- missfire
- Electric window switch plugs..
- Xr3i missing problems
- mk 4 rst mfi over fueling
- 02' Mk 6 fiesta gem unit help!
- Wheel Speed Sensor - Position
- Focus Sump Plug Right Or Left Hand Thread
- 56 plate focus 1.8 tdci estate dead on key
- Pulling my hair out
- Renault lads. Clio 172 cup help with dash.
- Alarm problem
- 1.6 Focus Air Con What Pipe Do I Need?
- transfer box chain
- Saph cos running problems
- standard ET for an S reg escort van?
- gt3076.82 has become verry laggy??
- strange one
- Fuel pump
- Electronic boost controller
- St2 wet handling issue.
- Mk2 xr2 rad fitment?
- mondeo tdci expansion valve location ???
- I have a wobble!
- Revs hanging and misfire!!! Help
- SportKa overheating and EML
- Another Transit Cut Out Problem
- Mk1 escort panels
- Differences between Mondeo and Focus black tops
- I.d. this turbo please
- Fezza z s tdci
- fuel filling into manifold and cylinders rs turbo zetec
- Mtx-75 conversion into mk5zsT speedo help
- Mk2 Focus RS gearbox to Zetec engine?
- whaletail fixing-3 door
- ANOTHER KA engine swap. KA 1.3 to 1.6!!!!
- Please help mk5 zetec s
- 2004 fiesta 1.4 tdci - eac fail - fault p0193. Help!!!
- Webcon fuel pressure regulator fitting
- yb pistons--best option?
- 2.0 icv on rs1800 inlet?
- ecu datascan wiring
- Water Leaking Bad
- Power steering rack
- Escort RS turbo fueling
- how to tell if level 8 is running c/loop?
- Zetec blow up
- Overheating Help
- Zetec turbo idle is all over the place
- Gearbox whoes
- Rolling road recommendations please.
- Mk3 XR3i gearbox on Zetec 1.8
- montune long stud
- Brake disc size
- yb oil
- Best box for 500hp escos (Fast Road use) ??
- Zetec turbo misfire! please help ! under load.
- oil change question
- sabtvr vin number
- 2WD YB Cometic gasket low compression
- stage 3 boost psi
- Escort cosworth wheel fitment
- Fiesta 1.25 clutch problem
- S2 refusing to start
- Studs or bolts
