- kicking out of gear
- Engine Management ~ Cold start enricment
- map sensor
- 3 door missfire
- amal valve
- Ford escort mk4 xr3i colours
- chip & map
- escort cosworth panels
- aircon problem
- HELP MISFIRE!!!
- 16v breather
- what engines will fit in a saph?
- RS Cosworth Steering wheel woes...
- RS TURBO HOLDING BACK, SHUDDERING AND POPPING PROBLEM?? HELP
- electrical problem
- Pro Alloy intercooler and EEC IV
- 3i to rs turbo wiring loom
- xr3i to rsturbo conversion!!!
- please help
- Fuelling Problem
- Mondeo gearbox
- 202 block
- HELP for bolts to my 9 inc. rear axel.
- fueling problem
- black top = zetec turbo
- SECS Map file
- standard boost
- Escort FSE
- Cleaning product
- misfiring rst
- misfiring rst
- COSWORTH NOT STARTIN, BUT HAVE SPARK!!!!??
- Very erratic idle cosworth please read
- ARP Stud and nut 'running-in'
- arp stud and nut size??
- what size wheels and what offset for a mk4 fiesta
- mk2 escort rs clocks
- Cossie Fuel rail and regulator.....does it matter?
- hard to change gear in my saff
- slight misfiring??
- cossie webber 2wd fpr
- cosworth and co/co2
- s2 starting problems from cold
- help needed plz some 1
- Master Cylnder for escort turbo
- breathers
- Smokey
- Wet Carpet
- knocking and pulling
- ESCORT MK4 ABS ...ADVICE
- cossy coilpack
- Sapphire cos 2wd and 4x4 front anti roll bar - Compatible ?
- fuel pump residuel pressure valve....do you need it?
- 200 205 block, whats the differance?
- What connects to this?? pic added
- over fuelling prob, mk2 escort, cosworth conversion!?!
- RUNNING TEMPS ON A ESCORT COSWORTH
- P8 L8 ECU on a 4x4 saph
- cabbie electric windows
- RS1600i brake help
- injectors
- WIRING LOOM
- zetec head, solid or hydraulic?
- CVH Tall Block
- Oil - The basics
- Slow electric windows
- PiperX Cone
- VW Passat Warning light
- 3 door sierra cosworth wing are cozzie ones the same as stan
- cosworth plenum spacers
- REMOVING TURBO ON S2ERST??
- xr2i fuel pump damper
- 1.8 zetec in my 1.6 cvh efi
- rs turbo's
- Really Bad Idle - 1.8 Zetec
- Zetec running problems
- been told this shouldnt be like this???
- engine blocks
- exhaust backpressure/silencer-cat questions
- mk4 fiesta zetec help
- ERST ABS Removal?
- Zetec sump
- mk5 escort clutch ratchet conversion
- mondeo 4x4
- is this gearwheel good or bad?
- coilover fitting problem(4x4 Saff)
- Orange paint
- best way of cleaning leads
- PROBLEMS WIV MY MINT S1 !!!
- Head gasket gone................
- AVo coilovers setup advise on a escort cossie
- Cossie problem
- 2wd Saph Crank Pulley
- Boosting problems
- need help with my cossies headlining
- Cossie + mk2 escort final wiring help please..
- N/A 1600 CVH + 1300 CVH pistons = higher compression ratio?
- fiesta zetec engine swap
- Cos 4x4 Lack of power - No boost
- brakes pipe fitting
- shuddering
- front grill
- CVH Gearbox rebuild - hub puller help
- mtx75 in a s2
- mondy V6 into a focus any gen?
- S2 multi plug colours
- mondeo boot
- zetec turbo question
- Good old ford!
- RST help urgent
- help my cossie aint running right
- A little help please
- why are these different?
- fuel press gauge for WRC manifold
- Tuner in Hull area?
- does anyone know how to test if injector plugs wiring works
- Alloys need diamond cutting and straitening
- NEED HELP ON COSSIE STARTING PLEASE PLEASE PLEAS????
- erst idiling
- cosworth idle
- water pump
- Sierra XR4i + E10 Gasohall
- FRST fuel pump PLEASE HELP FITTING IT NOW
- Wheel bearings
- Lambda sensor connections ???
- Boost
- judder
- erst s2 clutch cable probs
- master cylinder rst
- cossie now sparks but fuel leaking through breather pipe ??
- New brakes for my sapphire
- Recomended Oil
- rs turbo brakes
- t5 zetec
- Amal Valve
- Garrett GT32 Turbo
- IDLE SPEED ON FRST
- Oil filter for zetec turbo?
- Need help with cossie missfire an black smoke !PLEASE PEEPS!
- wheres my iat sensor
- ???confused
- RS Turbo Decal
- fiesta turbo* HELP!
- sierra cossie leaded ?
- sierra ENGINE CONVERSION !
- cossie wont spark ??????????????
- Cosworth 4x4 Driveshaft Problem
- WANTED - STAGE 3 MAP for SECS S8 on 2WD SAPH
- s2 cutting out
- saph cossie wont start sparks and fuels but no go????
- I want lock, YOU got lock?
- TURBO TROUBLE
- t3/t4 hybrid turbo
- Anyone know a good rolling road near newcastle??
- Cosworth Pistons / Block
- URGENT HELP !!!
- turbo
- AMEL VALVE PIPING
- does this piston look like a c20let calibra turbo piston?
- oil out of exhaust?
- alright any ideas what this is on my sump
- STAR tester
- Stu at MSD - Help required now very urgent
- flames
- High idle speed on series 1
- BMW 535 Throttle Body On YB Cos?
- underbody sealing and painting
- Radio Code
- I cant find my cossie looms coil +ve wire..
- RS 2000 escort - 1995 N plate
- Zetec Head Gasket thickness
- some help please
- How do u tell a ERST CVH from any other CVH
- alarm advice?
- Washing Mashines live longer with....
- Wheel Bearings
- trouble mating with my exhaust!
- escort kangaroo
- could it be?
- s2 fires up then cuts out
- Out with the French and in with the ford
- escort coz air bag info
- need some help Q&A
- maf sensor
- Will it fit?!!
- koni adjustable removal
- Fiesta gearbox Mount Issues
- setting standerd boost
- Oil and filter change, please help,
- rs2000 or rs turbo
- compression ratios
- psi-bar
- ST170 Fous Manifold on Mk3 Fiesta
- Standard Yellows capacity?
- S2 WONT IDLE
- head gasket
- swaping a 1.8 zetec for a 2.0
- Fule pump relay
- Chain tensioner on Mk 5 RS2000
- S2 gearbox
- fiesta st juddering
- activating new remote on a 1995 mondeo Help
- Can a S1 ECU be used in an S2?
- Can anyone recomend....??
- turning down the boost??
- Swapping gearboxes on sierra 4x4 dohc
- RS 2000 K REG STARTING PROBLEM PLZ HELP!
- ***urgent help again*** key and ignition problem
- my cossy rep
- s***ey cvh rattles - HELP
- ERST Starting Probs :(
- 1.8 zetec inlet manifold on 2.0ltr engine?
- Doubling up rear anti roll bars... will it work on a sierra?
- poo in pipes on breather system - Engine breathing heavily
- no boost?
- DUMP VALVE ON TRANSIT DIESEL?
- rs turbo rad and gearbox
- Fiat Punto
- electronic boost controllers
- how difficult to remove the head
- acclerating
- saph aircon into 3dr
- oil pump fitting
- S2 gearbox in MK3 Escort???
- ***urgent help*** battery siza for escort cosworth
- Ka brakes?
- Mk3 Fiesta springs fit Ka?
- torque settings on cossie head
- gearbox or clutch ?????????
- Tacho feed signal
- battery wires
- Distributor On my Series2
- ESCORT COS COVER
- Xr2i Wiring loom
- xr2i steering
- Whats needed to convert to 2wd form 4wd..........
- Piston deck height on a 2wd saph?????????
- cossie fuel pump and sparking problems can anyone help????
- asked befor ??
- fitting an rst exhaust
- 6 days on and its broke down......S2 Turbo
- Help ! Zetec Drinking lots of fuel (read my story)
- front wheel bearings
- Which gearbox???
- Rust under windscreen
- chip/ecu experts
- CROSSMEMBER DIFFERENCES
- starting probs
- abs probs
