- copper headgasket?
- Escort RS Turbo misfire
- how do you tell
- major missfire problem
- exhaust question
- Informations needed on a pectel board
- rst series 1 camshaft question
- Which Air/Fuel Guages?
- Need some Fiesta Parts- cheapest place to buy from??
- rs turbo problem
- Compression test results
- Running 8 Injectors. Injector sizing????
- escort cosworth oil pressure gauge
- nock on front driver side???
- ford prob probs??????
- Sierra Cosworth advice
- 2wd oil pump and crank damage
- zetec problems, HELP!
- rs500 intercooler dimensions
- fiesta 1.3 cutting out
- Are CVH 1.6 Carb & Injection Heads Identical?
- Torque wrench settings for zetec
- Collins monitor in the dashboard...
- arrangement of ht leads on rst. is this pic correct
- rs s2
- What will happen if i take and blank my dump valve of
- Rs 500 cooler
- gear ratios for 2 litre mondeo mk 2
- radio wiring
- Front Diff?
- timing
- Fitting rear pads: Saph 4x4 calipers
- Escort van turbo diesel swap
- Series 2 What to upgrade next?
- fiesta proplem
- adsusted cambelt on rst now wont start
- hole in my block ? help please
- Live Mappable tune on an EEC4 ECU (For a 5.0 V8 Twin Turbo)?
- High Pressure Oil Pump
- Electric Windows Stopped Working
- s2 spark plugs
- Cossie Brake Lights
- Heat Sink Compound
- ANOTHER 3 DOOR PROBLEM
- mapping
- RS Turbo Kit car - minor technical difficulties + Pics
- anyone know how to wire up this mirror!!!!!!
- Any Auto Electricians? Help
- FOCUS door adjar light on the dash
- Running a P8 on a sapphire Cosworth 4x4 ?
- cosworth 4x4 head
- help rs wont start off key !!
- need new brakes, can i get better???
- wider wheelbase??
- ford focus performance????????
- air flow meter
- diesel forum
- Green injector part number??
- Help guys.....
- rs drop skirt for mk4 escort estate
- how can i tell
- fiesta rs turbo engine in escort
- help cossie managment
- Zetec into Mk4 Escort
- loom removal mk4 escy/ mk2 orion
- Quick bit of advise needed on rear end poly bushes for 3dr
- cosworth dash illumination
- Possible future Fiesta MK4 problems? and bonet advice needed
- Rolling wheel arches
- D.V. FItting on 3 door
- dry sump. no need for breathers ????
- can anyone tell if this is a 105 or 130 bhp xr3i
- Series 1 Coolant Sensor
- "Ghost" noises from the strut/axle
- sierra based 7 kit car
- hello! and help please!
- RS2000 mk5 fuel problems
- How to turbocharge a 1.6L '76 Taunus engine???
- 17 inch wheel ofset
- Converting my gti to 130 bhp
- fiesta rs turbo
- Red Master Key - Ford
- stud and nut kit
- snadblasting??????????
- Puma Headlight Schematics?
- is this off the ofab loom or ofac
- Misfire Prob - can any1 help? ERST S2
- XR3i EFI ECU on a fiesta RS Turbo?
- automatic Choke on 1.1 fiesta
- raven leather
- Nitrous installations, anyone recommend a good company?
- 3dr coswoth brake servo motor
- gearbox's
- erst s2 fuel prob help ???????????????
- alloy wheel center bore help
- relay basics?????????/
- tappits or shims??
- Fitting brake discs - Norfolk
- frst brakes
- F.A.O 2.0 Zetec Escort Owners
- RADIO CODE
- rs turbo power
- comps on saff
- Efi turbo question...
- wiring modds to run zetec turbo please help
- car smoking badly
- Scorpio/granda cosworth cailpers
- running in???
- wilwood disc conversion
- rs turbo
- HELP NEEDED 4 A CALIBRA (IGNITION BARREL??????)
- help!!!!!!!!!!!!
- compression test
- How bad ? cossie engine
- siemens injectors
- escort mk5 1.8 diesel 1992, electrical gremlins
- Rear seatbelt
- s2 Gearbox
- XR3i Timing setting
- Twin Port Actuator
- PLEASE CAN ANYONE HELP ZETEC TURBO WIRING LOOM
- another tool question?
- 4x4 head turbo oil feed blanking plug
- radio code
- Compression Ratio
- s2 rst need help
- Cleaning silicone hoses
- Coont of a oil leak ! 3 door
- where do you get the decopresion plates from for a zetec
- PAS fluid (cosworth) and auto trans fluid Q
- tuning escort gti
- oil change ??????
- cam belt diagram
- i need a new paint code tag making!!!
- Help with *^^&%( fog lights
- fabrication tool???need help asap
- rs turbo engine in a sierra will it fit ? 1800 cvh bottomend
- lapping valves
- Plugs on a s2 (again)
- BROWN OILLY SLUDGE IN TURBO AND CHARGE PIPES
- Porting and polishing EFI CVH head.
- Replacement Key
- Racing Puma Seats in a Focus
- Any1 know how to change the oil seals on a t3 garret turbo
- escort building?
- Mondeo ECU
- arp stud kit
- any got a t3 down pipe for sale
- efi fuel question
- Maf's
- Q : uprated oil pump problem....maybe.
- reverse lights
- supe charging and turbo charging
- 2.0 conversion, gearbox fucked? urgent help!!!!
- Rs turbo S2 release bearing
- help needed
- TEMP GAUGE DOESNT WORK................NEED SOME HELP
- erst efi question
- escort van rear suspension
- NMS, Stage 2, Head "low lag 400"
- ESCORT RIMS ON SAFF COSSIE
- Is my turbo fooked?
- whats the best way to turbo my mk4 xr3i efi?
- Map sensor FRST
- Management for a low pressure turbo
- suspension help!
- ST24 turbo
- POWER STEERING , 3 DOOR ! help
- green wires going to coil.
- sierra power steering pump
- rear disc conv problem help!!!!
- 2 part numbers for a Bosch 044 fuel pump?
- Series 1 Starting/running problem
- photos
- moving an exhaust 1/4 inch
- HAVING TROUBLE WITH DOWNPIPE BOLTS
- Dash Swaps
- Please can people measure something for me?
- Low speed missfire/cutting out 4x4 saff
- puttin collets on valves
- S2 misfire and popping and banging when under load on boost
- EFI CVH ECU's
- 4wd engine with 2wd sump....question
- dash coming to life
- 8 Injector Escort Cossie
- would a
- will 4x4 cossy head fit 2wd block
- 2.0l zetec strange engine prob with pics
- Coil pack
- ford escort turbo diesel luke warm heater
- what is the stroke of 2.0 moneo block?
- Solenoid Control Valve ERST
- none runner
- What gaskets to change in a rebuild?
- saff coz spulttering at high revs????
- Oil pump question ....
- FUEL CELL
- green injectors
- frst lump into mk6 esc 1.4
- Please clue me up
- cozzy wont start
- MBE 956 Map - Ford Pinto on TB's ??
- Turbo help needed
- Brake Discs
- 1.8 zetec turbo into mk3 fiesta
- fuel problem on turbo conversion
- BD10 and BD14 Camshaft
- Cosworth TPS
- audio
- How do u set the fuel pressure
- 3 door steering rack . help .
- Urgent information required (fitted an MSD chip)
- Plenum chamber
- How do you fit ST170 front brakes to mk3.5 Rs1800 Fiesta?
- Converting a Sierra from LHD to RHD?
- interior problems
- lag
- escort mk3 diagrams>
- BRAKES
- intermittant misfire
- Need help battery drain with clifford alarm and boot light.
- Cosworth idle
- 18s on a saff
- mk 2 escort brakes
- help with my 2wd saff please
- help with s2 rs turbo please
- alloy wheels and tyres
- Piston tops
- wrong chip fitted and now got problems
- F*cked up my S2 again...help needed
- running lean
- 1.25 zetec fiesta running issues
- Cossie heads .... ???
- Lambde sensor
- VW Head Units
- mk3 xr3i rear brake lights not working all the time and bat?
- TPS question
- Heated Rear Screen not working
- ESCORT LX 1.6 problems
- what Gearboxs can i use?
- oiltemp. and consumption
- does any one have a ofab map sensor for sale
- fuel gauge and temp?
- Mondeo rims onto a mk4 escort
- Battery light staying on,mk3 fiesta 1.3
- heater matrix
- Turbo Charging EFI XR3i
- Cam Belt Change
- Removing Dump valve
- Can you still get these ?
