- 1.8 sierra fuel pump
- Powder coating inlet
- Frs mk1 replacement cylinder head
- Immobiliser problem
- Air filter
- Sierra Mk2 2.0 DOHC (Tuning Parts?)
- Zetec turbo problems
- Zetec
- Zetec turbo questions
- Cologne 2.9i in Sierra swap
- Help!! - Ford Fiesta diesel not starting!
- Tensile strength of prop shaft bolts
- fiesta 1.25 zetec swap
- Mondeo 2011 - Sat Nav and Convers+
- Bonnet catch issue
- help needed to identify a westfield turbo based zetec engine throttle body
- FRST boost problem
- Focus mk1 aircon problem
- Adding a vacuum for brake servo
- Diesel Fuel Filter - Installing precautions
- 2wd track suspension questions
- key problem
- MK1 Focus RS running hot (i think)
- Focus ST is not giving full boost
- 2.9 12v into 2.8 xr4i
- Motorsport brake upgrade on fiesta
- cosworth MSD wasted spark not working
- escort mk3 headlight issues????????????
- Car acceleration problem
- Diff output cup removal technique
- Rear door on focus locked will not unlock
- EMU unit 'little black box' - Ford Fiesta
- rpm very slow to fall on over run after cleaning throttle body
- Wiring cvh fiesta rs turbo
- 2008 fiesta 1.6 tdci engine /transmission light keeps coming on.
- st225 clutch replacement
- Brake master cylinder
- Rev counter HELP!
- Cosworth gearbox tunnel
- 1.6tdci turbo change
- Help with ECU
- Zetec engine weight
- Escort Cosworth aftermarket temp gauge
- Standerd sierra cosworth 2wd wheel bhp ???
- Focus ST 225 Turbo removal question ?
- Leaking fuel pump connection on mk1 focus
- ST170 Idle issues
- sierra 3 door bulbs
- 2.8 mfi wiring hel please
- rwd zetec HELP NEED
- 1.6 TDCI 07 intermittent 'engine system fault'
- New focus 1.8 cam belt not running true
- building a zvh
- Cosworth Fan Problems
- Turbo identification help please
- Bottom ball joint bolt/nut
- Help finishing my XR3i to RS Turbo...
- Z20let pisons on zetec rods
- mondeo breaking and boot warning lights
- Focus rs mk1 map sensor
- T5 box help.
- Escort Cosworth Group a roll cage
- Focus RS ECU and loom into zetec turbo'd focus help!
- 03 Fiesta Zetec - help please!
- mondeo 1.8 duratec smoky
- Inlet air temp sensor - removal help (cvh/zetec)
- fiesta mk3 1.8 diesel
- Cozzy Rear Diff Whine Fix?
- best and quickest way to get rid of brake booster mk2 escort
- zetec turbo or zvh?????
- zetec into type 3 box
- MK2 Orion MFI to EFI RST
- MK2 Escort LHD to RHD
- Focus RS management help
- 2009 1.8 TDCi - BCM needs coding???
- Zetec turbo wastgate problems
- Please help .. About given up :(
- Cossie YB engine
- Cosworth conversion garage.
- Ford Fiesta 1.6 TDCI Turbo Problems
- Self levelling suspension
- 01 mondeo camshaft position sensor
- fiesta rs turbo problems
- ECU Power feed
- zetec silvertop turbo problems
- Mk 6 fiesta 60mm springs
- 4.0 sohc gearbox
- Transit 2.4tdci warm starting problem
- Focus - How to disconnect coolant hose?
- 2008 1.8 Diesel Focus Estate - Coolant leak found - what's this called?
- mondeo mk3 no injection signal
- MK3 Escort outer lower door rubbers alternative replacement
- What gearbox diff etc? Dog box 4x4 cosworth
- I have a problem....
- No Main Beam!!!!
- 6000cd fm reception issues
- converting BT to aircon
- ST170 knocking sound when I press or depress the accelerator pedal
- Focus Mk1.5 2.0 Zetec hesitating under light load
- Hi help needed identifying ignition wiring xr3i
- Help fitting powerflex top mount bushes
- Xr4x4 2.9
- Misfire?
- mondeo mk3 2.0 engine difference to fiesta st 2.0
- weird escort mk6 electrical problems
- This doesnt look right
- mondeo mk3 tdci wont start after running
- Ford CVH 1.4 --> 1.6 Conversion
- what are the symptoms?
- Ford Fiesta passenger side speaker
- Skyline cossie clutch release
- Radio fader option
- 2004 Ford Focus C Max 1.8
- T34-t35-t36 for 400/400 quick q help
- what boost with 803s and chip
- 205 GTI Rally car wiper setup - XR2I project update
- lightend flywheel
- 2000 Fiesta Zetec - Burnt out Instrument Cluster
- help
- 2001 ford fiesta rear light wont work
- who encountered such a unit?
- mk4 escort care
- Ford Focus mk 2 2.0 tdci
- seq mt75 convertion
- brake fluid resevoir wiring on s2 turbo
- Idle problem Focus RS mk1
- problem fitting mocal oil cooler to sapphire cosworth
- Mk2 Focus Duratech HE starting problem.
- Smart Charge alternator wiring
- 1.8 turbo not boosting
- Any harm in having a fuel return on Twin 40 DCOM carbs?
- ABS Problem but no warning lights
- Cosworth won't start. HELP PLEASE!
- help needed with my transit!
- Escort rs turbo cosworth management won't start
- S2 6 speed converson driveshaft lengh
- 2004 Fiesta 1.6
- mk4 fiesta duratec conversion
- Transit Connect 5 Stud Conversion
- Please help Engine cooling fan not clicking on.
- using 1.8 parts with a 2.0 blacktop
- Zetec piston sizes
- electric mirror problems (saph cos)
- 1.4 pte inlet manifold onto rs turbo
- 02 Fiesta LX Misfire
- remote key for mk6 fiesta
- best cozy engine mounts
- 1AFA to OFAB ECU
- Kuga 2.0 tdci hesitation when cold - help.
- Focus blower issues
- Focus mk1.5 1.6 Help needed battery issues potentially.
- Rev Counter
- I want to turbo my puma
- engine light focus st
- L8 loom connectors
- mk2 orion zetec conversion help needed
- OFAB Wiring Help - I Know I know
- Gearbox identification
- Another cutting out TDCi 2.2!
- Radiator flush
- Fiesta St Cutting Out
- ECU wiring
- '54 Plate Ford KA - Cylinder 2 Misfire
- Mk4 escort fwd,rwd or 4wd ???
- Power chip help
- Bladed roll bar ends
- identifying cvh gearboxes
- weather strips
- Mk3 escort 3 pin relay help
- sierra problem
- Head gasket thickness
- 2010 st focus headlight issue
- Tuning guide for mk2 ST
- mfi engine bay loom problem..
- RS Turbo MFI Wiring Help
- Zetec leaking oil...breather ?
- Losing power
- ST170 Engine into a mk4 escort estate
- Rs turbo front bearing cups
- Headlight Bulb replacement Mk2 escort
- Brake pipe flare type SAE or DIN
- Starter motor grinding on front of fly wheel not engaging s2 turbo
- Mondeo Mk3 115 TDCI (53) ABS Fault
- 1.8td overheating and throwing oil all over the place
- Which Bellhousings/Gearboxes Will Fit an Endura DE 1.8td
- Turbo
- Mondeo MK3 Handbrake Hell!!
- ford style wiring connectors?
- focus st170 clunk / thud possible steering rack
- xr3i efi running problems
- MK4 Escort clutch pedal problem
- Oil pressure on 1.8 TDdi
- Puma queries
- New Clutch Required
- Escos NO Spark
- Camber Issue Continues.
- Ford B-Max battery known fault
- Cosworth yb main cap bolts
- Battery problem
- r1 crabs
- Geometry and coilovers
- type 9 gearbox mount which one?
- fiesta st airbag module removal !!!!!
- rear caliper bleed nipple thread size
- duratec 2.0 into a ka??
- RS turbo sump gasket issue
- st170
- S2 rst cutting out when warm
- the best for you is the best,speed up!!!!!
- Fiesta 2004 - durashift & TCM problems
- 200 bhp+ for sierra. advice / suggestions
- 1.6tdci turbo pumping
- Sierra 90 remote control for central lock installation
- t3 turbo wont accept .48 housing
- Mk4 escort efi problems
- Any Ford Techs in, can you help-Battery drain problem
- Locked out.
- ib5 xs4r codes
- 4x4 Cossie - slackening turbo to manifold bolts
- Focus gear cables
- Cosworth front ARB identification???
- Fiesta mk5 1.25 squeaking noise
- Cosworth yb best turbo 450bhp?
- Leaky sunroof
- escort mk3 xr3i coolant hose order ??
- base setting distributor
- Cosworth ticking under load after oil change?
- Revs when starting
- plz help
- Crankshaft sensor focus 1.8tdci (Not camshaft sensor}
- Problem after brake change on 2011 Focus
- Ford Focus 1.8 tdci 04 reg
- No oil pressure on xr2
- Air bag and abs lights have come on ....
- fuel lines cosworth
- Ford KA 2001 - Battery dies overnight
- Problem with lean condition and p1131
- Oil leak and wheel noise
- Mk4 Escort engine fan not working.
- Rs1600i Now not starting
- galaxy engine swap advise plz
- Fiesta Mk6 & Mk7 - wheels interchangeable?
- saphire cosworth fuel filter leaking
- what to use to bodge a sump up........
- Transponder issue
- Brake problem rs1600i
- Timing belt alignment
- BMW 330 MSport problem
- Can I mount catch tank behined wing?
