View Full Version : Technical help Q & A
- DISTORTION ON A FRST
- Fiesta 1.6...
- sierra cosworth polybushes and air filter fitting!
- Safe Boost Levels
- dist cap
- Flow rate question, focus fuel pump?
- cossie dist cap
- converting drums to disks
- eletric window problem...
- s2 turbo sater motor
- how do i lower noise in my engine?
- peugeot v6 prob
- Marrelli/Cossie 3 Bar MAP sensor connections
- Escort fuel tank wiring connector help plz :)
- Flywheel
- door pins
- fiesta derv engine swap !
- Alarm siren swap
- temp gauge fault
- Help with electric sunroof
- engine monitoring
- boosting rs turbo
- throttle bodies for 1.8 zetecoff 2.0 mondy
- Open - or you will get a damn good thrashing!
- abs
- Fiesta Spark plugs....
- WATER PUMP ON A COSSIE ???
- brake bias valve question
- Crank position sensor for megasquirt
- BMW 318I
- arp 8740 zetec big end bolts settings
- brake pipes
- OFAB ECU in engine bay ok?
- mk 4 xr3i tappets lifters?
- rs turbo s2 inner drive shaft gaiter/boot
- Fiesta mk3 exhausts???
- Air filter
- Flat spot
- 2.0 to fit zetec 1.6
- Power steering pump
- 2wd or 4wd intercooler differences??
- piston rings
- Gearbox Swap!!!
- Fitting rear brakes on a 3door
- looking for rst s2 fuel metering unit help
- twinky to 2.9 cologne speedo question AND THE SOLUTION
- Custom brake rotors?
- mk6 escort 1.8 rs2k engine swap
- Mk2 Fiesta Zetec Exhaust Manifolds
- Info injectors...
- Throttle Body Fail
- URGENT need diagram for citroen
- Map Sensor Problem???
- how put standar wires in a gr A coil ? (cosworth)
- pictures of wrc top mounts
- escort mk7. leaks, and brakes.
- fuel gauge question...
- HELP PLEASE...3 Door Under Bonnet Transfers
- PROBLEM
- CO of 0.31% ERST S2
- Brake upgrade
- MK6 ESCORT ESTATE LOWERING SPRINGS
- Stuck sump plug
- Running Problem 4x4 Cossie
- Reuse wrc headgasket?
- bottem end on zvh
- EFI CVH xr3i to FRST Engine swap questions
- rover key fob
- Boost for RST
- cosworth reshell
- EFI throttle body bottom small pipe (RST Fezzy engine)
- S2 RST Cutting Out
- escort cos t25 checking boost pressure
- Exploded pic of 2wd cossie caliper.
- 1.8 - 2.0 litre, do i need?!?!
- Battery question/light
- mk5 escort rs 2000 engine sensors
- Phase Sensor
- MK5 Escort RS 2000 tapping noise.
- ECU
- 4x4 cossie convert to 2wd?
- Priming S2 oil pump
- Mulitplugs
- Mk 5 fiesta heater motor
- wrc bottom end
- Fiesta RS injectors
- Timing
- FRST Re-Build Probs
- Locking wheel nut issue...
- Ford Mondeo - Fuel Pump & Cooling Fan always on
- rst s2 help
- ERST problems...where to start :(
- what is 6.5mm converted to inches/imperial size etc
- standard sapphire cosworth,want 400 bhp ish,help!
- Fuelpump won't prime
- Misfire on startup
- RS Turbo 1.6 CVH Head
- zetec gear box,s
- Will brake shoes off a sierra the same as a capri
- Fitting a turbo to 1600 CVH
- zetec timing
- fiesta gearbox
- Will a Fiesta turbo,turbo manifold fit a 2000 fiesta zetec s
- 18 zetec turbo whats required ?
- green connector?
- Cossie Speedo problems??
- 4 plugs under injection on s1rs turbo
- Info on Secs S8 ECU anyone?
- cossi 4x4 won't start.
- Fiesta Zetec-S Turbo Manifold
- intercooler quickie
- What is best CVH crank front oil seal fitment method?
- what alternator is this?
- lean running when boosting
- Cosworth...044 fuel pump problem...
- HELP: engine stalling
- zetec turbo engine
- roll cage
- fuel pump trouble now...
- do rs turbo caliper slider brackets fit 4x4 cossie calipers
- YB Cosworth PIPER Vernier pulleys and Cambelt Change
- zetec. cable or rod change???
- Worn Turbo
- 1.8 cvh bottom end
- S2 having problems getting started
- zvh problem
- Oil light on whilst idling!! ERST S2
- S1 problem
- BEST POWER UPGRADES FOR FIESTA ST ?
- Problems running a floating bearing turbo with no DV?
- Advice on spark plugs!!
- ecu wires??? help plz
- misfire but its not the fuel
- midlocksystem
- Speed Sensor on EFI RST.....is it needed?
- advice on induction kits
- Where to get Chrome engine parts
- mtx75
- camshafts for cosworth
- Smokey S2
- zetec engine whats the difference ???? help needed please
- cosworth piston rings/con rods
- s1 brakes
- Air Injectors - Pros and Cons - Are They worth Having???????
- Flat spot on the rollers in My escort Cossie
- What oil to use
- University Gearbox project.
- 5th injector
- not firing properly when cold?
- need help buying my first saph cosworth
- another 1300 - 1600 question
- head skimimg
- xr3i cvh cam timing question?
- No Gears!!!
- BIG 3?????
- l8 cos ecu question...
- FSE Query
- Fitting remote central locking to P reg Fiesta.
- Can anyone help?? (Lancia Delta)
- escort rs turbo prob
- 1300 - 1600 swap
- Wheel well like a swimming pool
- is this chipped
- S1 turbo not running
- Exhaust smell in Header Tank (Escort Mk4 RS)
- 4x4 saff probs
- TURBO`D ST200
- Cossie timing belt tension
- ZVH 1.8 Piston CR Help
- Roof lining & board on a 3dr
- Can't select 5th gear (Focus)
- tick tick tick tick......
- Annoying locking problem
- Crankshaft for sale, looks to be virginal & more LOL
- Technical information for cosworth 2wd original camshafts
- coolant problems on my 2wd saf
- help plz
- s2 rst brake trouble
- WRC Head gasket: 3 or 4 Layers ?
- Cossie tappets
- 2.5 V6 Engine - What Box ?
- Differents plenum
- changing alternator belt
- which fwd gear will fit the cossie yb engine?
- mt75 help plz
- will these fit please help asap!!!
- Rear seat belt jammed
- ALL ELECTRICS GONE ON SAFF 4X4
- misfire on startup?
- relocating battery
- Peugeot wheels fit on a Ford
- Controlling Large Injectors
- Any1 know their driveshafts?
- esc cos wheelnut question
- CVH Fuel Pump Push Rod?
- reverse gear ERST
- Hydraulic Clutches???
- radiator
- fuel fault can anyone help its driving me mad
- YB Spigot Bearing.
- YB Crank Pulley Bolt Torque
- YB Flywheel Bolt Torque
- boost problem with fiesta turbo
- RS 7 spoke refurb
- plug gaps for coil pack con
- phase sensor question?
- can i bluefin my escort with an EEC V?
- Lowering on 15's
- rs cab loom questions
- weird squeaking sound from front EsCos
- Gearbox/clutch problem, please help
- best front brake combi for a series 1 with standard wheels
- 100k service on escort mk6!
- zetec inlet manifold
- Ka engine juddering
- electric probs help!!
- Can anybody identify what turbo this is for please?
- rough running escort cosworth
- Bettery keeps dying
- s1 rs turbo cuts out and won't start
- timing on a 92' escort 18 16v zetec
- twin port shroud on a turbo, what is it?
- type 9 gearbox on cosworth lump help plz?
- Rust spots !!!
- peugeot 205 XR 1.4l
- throttle body???
- Brake Line diagram
- Focus - Anybody ever come across this problem?
- oil Recommendation please
- oil pressure on 2.1 zvh??
- sick of electrics, can any1 help me please
- these in car boost adjusters what they all about
- Brake Line Diagram
- shuting of the turbo
- Escort Cosworth SuspensionTopmount(strut)
- roof relays
- fuse board diagram for mk5a XR3i cabbie
- HELP XR2i rear shocks
- Escort S2 Starting Problem
- Supercharger + Turbo ~ How To?
- Where can I get a S1 engine mount?
- M reg RS1800 Help wiln't start o turn over
- offset with 17s
- bar to psi converted
- escort turbo running problems
- Very Quick question
- mk5 fiesta turbo no boost??
- clutch adjustment
- altonator
