- need help with 1990 xr3i lump convertision to rs turbo.
- ford zetec block help
- Electrical Wirring Diagram escort MK3
- AP Brakes which pads?
- mk4 efi cvh rev counter not working...
- Cosworth starting problems and grey-blue smoke
- Escort Cosworth Rear Strut Braces?
- Oil cooling on a turbo?
- dust guards
- starting probs
- Sapphire Cosworth .. and rust
- Steering/Wheels?
- RS500 owners
- Escort T25 engine wiring diagram wanted
- power steering
- gearbox mounts escort rs turbo
- I Am At A Total Loss... Still
- crank
- Zetec turbo valve springs
- Escort GTi - Sluggish
- Loosing Water
- mk6 engine into a mk 4
- Oil breathers
- N/A CVH ENGINE
- Longer 5th gear
- cosworth exhaust question
- Is it my lifter or little end??
- URGENT HELP NEEDED!!!!
- s1 turbo anti roll bar clamp
- What calipers are these off ?
- Meta Alarm problem?
- will my car make it?? help!
- N/A cam for Turbo application
- AAAAAGH.......Turbo smoke??!!!!!!!
- OK to run a Cossie with no boost??? Has fuel caused this???
- F.A.O ~ Mappers / Tuners
- Fiesta Rs Zvh
- Mk4 Diesel van
- ERST S2 Rev Limiter??
- How to make a high/low boost switch?
- excesive pressure in coolant system please help
- Need help lads
- Low compression pistons
- Can you tell what it is yet?
- HOW TO TUNE PROPERLY A COSWORTH ENGINE??
- Air bag remove
- Siemens 83 lbph partnumber request
- Mk 5/6 Clocks into a Mk 4
- focus engine questions
- Cosworth Timing Help Needed Please
- twin fans 4 grs
- Escort MFI TPS
- found xr lump!! :) what next??
- bmw advice
- 2wd tyres
- 24v Sierra Keeps cutting out when stopping
- fuel filter wrong way round.....doh
- What rims to put on my Escos Cossie
- head gasket on rs turbo
- 2.5 v6 mondie probs...
- Our Friend - Corrosion
- Focus 1600zetec
- cozzy/zetec question
- Escort XR3i Flywheel help
- wax injection
- What clutch ERST S2
- 2wd cosworth alternator help!!!!!!!!!!!!!!!!!!
- Radtec FMIC
- S2 RST Calipers
- Handbrake light
- mk4 fiesta zetec engine transplant
- 4x4 cossie knock sensor, disconnect it????
- K1 racing HT leads any good??
- cosworth smoking
- cosworth discs
- zvh fuel pump
- Galaxy door cards?
- bloody wires
- EFI Idle problem ( RS TURBO )
- Small firing problem
- S2 weird problem does anyone else have this problem
- XR3i Steering rack help
- Problems with my turbo gauge
- HELP FITTINNG 4X4 INTO 2WD
- Over heating
- CVH Head Exhaust Manifold Studs Coolant Leakage Problem
- Zetec tuning
- cossie misfire saph 4x4
- shes alive again!
- 2wd gearbox ..... T-5 .....T-56 ... ???
- Injector question
- air fuel ration meter fitting to cvh
- Mondeo V6 bell housing bolt pattern
- the misses gay brother
- Question about alloy fitment
- Mondeo Lambda wireing
- anuva 2 qtions...mk2 festa
- Central locking on the tailgate of a 3dr cossie
- Fuel tank (esc mk4 cab)
- Cossie Stage 3 Boost Settings - Greddy Profec B Spec 2
- zetec sump
- xr3i dies revs drop dead then off she goes
- starting problems
- stage 3 boost
- ECU Transducer??
- sapphire cozzy playing up
- Cossy Failed test on emissions
- MK4 ESCORT CLUTCH QUADRANT MAJOR PROBLEMS..PLEASE HELP!!
- gearbox for escort cos
- Dead Ford Orion
- Snapped Bolt !
- blue colour on bolts
- clutch questions
- Create and install own speedo faces...
- small turbo escos timing
- CVH to RS2000
- At 4000rpm engine taking air (no fuel)
- Modd grey injectors??
- charging probs
- coil trouble
- help help!! 2 probs new car!
- 3DR ABS PLAYING UP
- Escort Brakes
- 5k miss-fire
- Escort cosworth engine mounts
- light blue of greys?
- 4x4 Box (Cossy) vs BHP
- Saff Boosting probs
- Dry CVH
- headache
- battery dead
- cossy brake pipes
- series two clutch adjustment
- no spark (cossie)
- Cossie 4x4 gear stick
- throttle cable adjustment on zetec
- Rear Calipers
- Efi lumping running...
- Changeing from T5 to a T56
- FRST and Zetec accelerator cables
- EFI Valves smacked by a piston :(
- Engine Change Fiesta 1.1?????
- sapphire cosworth wheels rubbing on the front
- Copper core rad or alloy??
- cvh vernier pulley
- help me please my cossy is smoking
- Mk2 Xr2 turbo transplant project help needed!!
- sparking
- turbo cooling/lubrication
- Apexi AVC-R
- MOndeo MKI Diagnostic
- Bigger Engine For Mk3 1.1 Fiesta Classic!!!
- ford galaxy?
- RS2K brake
- Electric sunroof conversion.
- BOSCH KJETRONIC fuel metering head
- No spark!!!
- sierra brakes
- ZETEC HEAD
- flamer kit
- Wat brakes!!
- Head questions
- Wheel bearing prob!!
- Car still dead
- braking problem
- Wheel Nuts
- zvh exhaust
- Coil pack / carb turbo engine
- rev`s staying high
- hcs - cvh mk2 fiesta conversion??
- cosworth abs light
- zetec injectors please help
- clutch release arm help
- erst cossie brakes?
- rs chargeing problem
- cam caps aarrrggghhh
- zetec timing! help plz
- cvh efi inlet manifold?
- Coil pack on efi cvh
- recommended turbo rebuild
- power output?? xr2
- other starter motors to use on a zetec in a mk2 orion??
- Code reader/diagnostics ???
- what compresion ratio
- Ashley four branch manifold fitment to Mk4 Escort XR3i EFI?
- Escort 1.6 or 1.8 Diesel?
- Cleaning hego sensor and fuel injectors
- Blue injectors questions for all of you out there.
- ABS LIGHT FLASHING ON AND OFF
- Tyres
- Stage 2 ERST And FRST
- Orion / Escort Rear Arm Assembly
- boosting
- Steering wheel
- Exhaust heat shield Q???
- Stuttering after start up
- s2 rs turbo running?????????
- problem with s1
- Cosworth 24v and mtx75 gearbox
- Locating and testing relays please help....
- rs turbo pistons
- XR2 brakes
- injectors
- Galaxy wheels?
- wheel spacer / offsets escos
- Puma engine conversion help please!!driveshafts??
- mondeo's
- Escort Cosworth Lambda Sensor Part Number
- MK3 Escort stereo loom
- K-jet xr3i mk3 to Efi EDIS need help
- knocking coming from engine as revs are increased. backfired
- engine swap from cvh to a mk5 rs2000
- pinto carb
- Anyone know the size of the strut upper nut on a . . .
- cossie not sparking
- 1.6 16v head...
- 1.8 16v escort efi engine problem need help asap
- escort cabriolet mk5 window
- 4x4 cos rev counter & Pe converstion
- 4x4 cos, brake problems...
- Throttle Position Sensor on CFI Unit
- Danny B's new rear beams...
- S1 with no spark!
- Efi 1.6 to EFI Rs turbo conversion, Help
- 2.0 Zetec - Starting then cutting out - Help!!
- Air to Air Problem!!!
- boost guage help!!!!
- 1.8cvh crankshaft to 1.6cvh
- abs sensor
- Mondeo 2.5 4x4 conversion (advice needed)
- metering head
- Non Ford question!
- rs turbo again lol
- Orion Turbo - Pics added
- 1.8td thermostat
- rst gearbox
- battery light
- Are turbo bearings supposed to be a tight fit
- 1990 xr3i
- 1.6 16v big turbo Camshaft specification
- problem
- mondeo electrics help please
- Still got battery trouble !! I think
- efi help
- Could it be my coilpack?? HELP!!
- How to test a factory fitted alarm
- clutch for s2
- cvh stem seals
- Cosworth Cam Caps
- DISTORTION ON A FRST
