- 1.8 zetec head gasket and bolts
- Fiesta mk6 C.D PLAYER PROB
- 1.8 and 2.0 zetec specs
- 2.0 engine swap problems
- galaxy engine
- Cougar Airbag Problem .... can anyone help??
- Saff Cosworth cental locking fault
- RS Turbo Speedo
- Phase sensor connections. Sierra Cosworth.
- Sapph problems
- Strange water plug on my head?
- toad ai606
- Sierra XR4x4 Steering
- 8 injector help!
- Wide-band o2 meter for megasquirts, which one?
- zetec help needed peeps!!
- name that colour....anyone??
- Tappets
- castle nut torque?
- escort mk5 horn
- S1 Cooling fan & reverse lights problem??
- Help Fitting Mega Squirt Unit
- melted piston
- Broke Cossie Brakes
- Wiring up a rev counter???
- L6 ecu
- help with wire rung block?? please
- cossy brakes
- saff clutches
- Car Alarms
- Ford IB5 Gearbox.. Internals Upgrade
- romoving rs tubo radiator
- ka rattle
- Want to convert carb to efi
- whats the biggest in tank fuel pump for escos
- CVH CPS hole measurements
- about the 4x4 front diff and ratios
- wheel size and fitment
- misfire, tried everything
- whats this
- 1600 ZETEC
- map sensor which one?
- Dash Clocks
- custom made driveshafts
- uneven pad wear
- mk6 escy seats into mk5
- group a inserts on original cosworth rims?
- Central locking help plz
- Escort Cosworth rear strut brace.....
- who runs a pressure gauge on the aeromotive reg
- ZR tyres
- Fuel Pressure Regulator
- Header tank and Swirl pot question/problem?
- Magneti Marelli MR3 ECU issue - URGENT help needed
- Saff Cossie 4x4 fuel pump
- cosworth rear wheels
- Torque Settings...
- rs 1600i servo
- Wideband problems!
- EFI flywheel
- Rollcentre corrections on lowered Cossies
- bd14s
- slow transit swb 2.5 d
- Ferrule (union) for oil pressure gauges...
- Fitment of HiSpec/Wilwood brakes & Softlines alloys
- Oil retun hose
- 2wd Calipers onto 4wd car
- fuel pressure on a frst please help
- 4x4 cossie not starting very well
- Sluggish 1.6 16v escort - clutch???
- any one no this mk 2 escort body kit??? im after it help ahh
- 2.8 V6 COLOGNE MISFIRE!!
- Running Rich!
- setting the fuel pressure on a frst please help
- Focus water leak
- boost controllers
- Headgasket for Zetec 1.8 16V??
- rs bottom end , what head is best
- M3 mirrors on a Ka
- In need of advice please... Fitting Ford Racing Gauge...
- ERST Misfire
- sierra front brakes
- NEED HELP ADVICE AND INFO!!!!!!
- Fuel pump
- How do I fit a MT75 2wd gearbox to a 24v V6 Cosworth lump?
- cossy sensor
- 2.0 zetec crank
- xr3i efi misfire
- fuel pressure accuator
- To back pressure, or not to back pressure?
- cosworth engine problem
- 14 inch wheels
- xr3 alternator drain, desperately need help
- possible over boost
- brake servo problem
- Twin 40's on My Zetec Help
- rs2000 rear disc conversion question
- Converting my FRST from OFAC to OFAB
- electric windows not working
- st170 problem
- Clutch Slipping Series 2 RS Turbo (HELP REQUIRED)
- 3dr mirror
- Anyone had experience with the Demon Twekas pedal box?
- paint code
- T3 or T34
- Pinto turbo conversion
- engine rattle 4x4 yb
- escort EFI throttle cable
- black smoke
- rev counter and speedo mind of its own
- arp help
- xr3i efi engine missing every time i start it
- xr3i track day brakes
- Broken boost guage?
- MK4 Escort XR3I EFI Electronic Water Temp Gauge Fitment Help
- pace charge cooler
- rs turbo s2 no petrol throgh injectors
- Flasher relay without wing repeaters?
- ford rs-turbo non starter
- Oil Breather plumbing...
- Swap 16 zetec for 20 zetec
- box and plugs
- 57I K&N INDUCTION AND REV COUNTER
- fiesta mk3 problem
- roof on escort cab (mk4) and el windows
- throttle position sensor
- Noisy suspension
- saff cossie temp gauge problem
- iscv valve
- cossie misfire
- disc conversion
- De-Locking
- Fuel Gauge/Computer
- pinto cambelt
- Dump Valve
- Aircon on Escort GTi
- cometic sump gasket
- turbo exhaust houseing
- engine transplant
- 03 Plate Focus 2.0 Water Pump?
- secs monitor
- Help with how to use engine stand
- arp con rod bolts???
- Home Safe Lights
- Rs turbo ecus
- Cossie Crank Spigot Bearing
- Uprated rear bump stops
- FAO - people with secs monitors
- steering rack q
- smoking t25 escort cos
- Series 2 rear brakes
- engine swap
- 1.8 si escort tuning
- MK6 FIESTA 1.3LX yr 2002...help!
- Fiesta bloody turbo problems
- Good Mega Squirt Mapper In The North
- bleeding brakes
- RS1800 ecu help please
- Do the later type screw oil filler caps on cossies leak oil
- saph 4x4 cossie. high idle and poor coldstart
- hoses for xr2 hep neeeded asap
- window tinting
- Water Injection (4x4) Cossy
- Cosworth Expert Required... Apply within!!!! ;)
- help requird
- bailey oil separators
- Electronic boost controllers
- S2 LOOM/XR3I PLEASE HELP
- 1.6 zetec problems suprise suprise lol
- 1.1-xr2 fuel pump??
- anybody know these answers???
- Series 2 over fueling
- 4x4 cossie boost/vacum
- Frog's 4x4 cossie goes clink clink clink - sorted
- MK6 door trims
- Rattleing boot doin my head in
- MK4 RST engine to MK3 Cabriolet ASAP
- Is it leagal in UK?
- Non Ford Question - Pug 406 Brembos Onto A VR6?
- miss fire cosworth
- car goes dead when try to start
- Cosworth Broken Cam
- xr fuel pump??
- vibra-technics geaarbox mount query?
- Fitting Cossie brakes to the front of my S2!!
- KAM KIT
- mk2 clio sidelight's
- mk6 escort engine converstion
- Fitting coilovers to a sierra? Question!!
- Advice on engine/megasquirt/manifold
- Escos handling "In Your Opinion"
- escort LX problems
- where is the CTS (coolant temperature sensor) on a Fiesta
- 1.6cvh vs 1.8 zvh power
- help with chip
- Escort electric mirrors
- 1.6 efi to 2.0 zetec
- new shape focus..........locking help
- No brakes
- S2 A.B.S removal?
- mk6 escort 1.6 zetec problem
- starting problems when warm mk5 escort
- faulty sensor
- help needed rear wheels problem
- Zetec problems
- Big Valves
- "Quaife" T-5 gearbox...anyone tried it ???
- mk6 escort zetec problems please help
- Throttle body for XR2I
- Astra td broken follower
- cleaning a header tank ?
- Hydraulic release bearing question
- compression ratio (c/r)
- any r&d gearbox builders here?
- Battery capacity/size????
- second boost gauge ?
- how to fit springs any help
- m.s.d. wasted spark driver on 4x4 pectel ecu
- Fiesta Turbo not well
- series 2 Fuel relay
- Escort RS Turbo Head Gasket
- FUEL HELP PLEEASE
- Lights stay on
- Alternator Q ?
- my smoking problem... who can help?!
- Chugging Along
- Zodiac Mk4 Suspension update?
- Twin webers
- fiesta alloys
- clutch release bearing question.....
- Anyone know anything about foxguard alarms?
- my mk1 fiesta conversion
- MOT failed CO problem
- Boost without a map sensor
- turbo chatter
- Vacum Line Connections on series 2 rs turbo
- xr dizzy assembly?? help!
- running probs rs1800
- wheel arches cosworth
- zetec alternator bracket
- Caliper question
- advice please
- S2 ENGINE TRANSPLANT
- Mustang injector spec?
- New GearBob/no reverse lights?
- Pipes on steering rack on 2wd saff cos
- Secs Monitor - Water Injection question.....
- swapping xr engine
- last qtios, 1.1 - xr swap
