- 1.8 to 2L zetec conversion
- Cosworth over fueling
- water system pressure, on s2
- What CVH con-rod bolts
- S2 rst boost problems
- zetec into mk4 help
- Valve stem oil seals
- s2 rst
- is fuel pump on way out?
- What Oil (Escort Si)
- Filter thread sizes
- oil pressure t piece
- rear axle
- sapph 4x4 fuses
- S2 Turbo breather
- inner drive shaft joint
- Ford Escort Series 2 LSD
- Larger intercooler = more lag... or not
- No spark on my festa Turbo
- can some one help turbo problems
- xr3i engine tapping noise and idle probs
- Fan Rewire
- whats neede to convert FRST to P8 (Webber) management
- ignition cap
- majour over boost on an erst
- Wheels studs and spacers
- Wheel refurb?
- FIESTA ZETEC 99 PLATE COIL PACK PROBLEM
- T34 turbo with .48-.55 exhaust???
- Chassie documentation.
- Bit of a flat spot
- Immobiliser mk6 escort
- What can you say about the XS-power turbos?
- std intercooler and rad
- xs power intercoolers and radiators any good ???????????????
- Management Question
- engine block
- Diesel in petrol tank advice?
- powerless
- copy of post on cossy area - rs500 tuned up motor set up
- air con..
- RS TURBO S2 METERING UNIT
- dodgy clonky noise from front wheels
- escort suspension
- Escort springs
- ecu codes
- L8 - P8 ECU
- Engine mount
- radiator
- bad misfire help please
- Cossie 4x4 caliper overhaul???
- EFi XR2
- abs fault
- missfire on boost??
- management??
- S1 Turbo - Bent tie bar
- Cosworth ISCV partnumber
- boosts up but pops and bangs!
- ST170 hubs on a 2 ltr Focus - ABS sensor probs.
- cluch release bearing?? what grease
- cosworth t5 help
- pf09 tps
- tourqe settings??
- cosworth help 2wd
- 1.4CVH EFi Cylinder head rebuild probs :(
- m.o.t emmisions.
- Glue for trim bits?
- engine cuts out?!
- Front wheel bearings on a Ford Explorer 2000 4x4
- Cosworth 5 pin code reader??? HELP PLEASE
- WATER LEAKING INTO DRIVERS FOOTWELL / FORD PUMA????
- 2WD Saff losing water
- how do you lower a mk4 escort van ???
- over heating help needed
- Poor Starting on Ford Expedition 2003 5.4l
- Caliper slider grease?
- Speedo on xr3i doesnt work properly any ideas?
- please help me
- floorpan/mountings
- escort cosworth parts
- car feels like it has a rev limiter when it hits boost
- Help me someone
- xr3i cab wont lock? help needed please
- URGENT PLEASE HELP
- beige injectors
- Whats the Differance between rear 4x4 & 2WD calipers
- juddering when accelerating - 1.6 xr2 CVH
- Iridium vs. platinium plugs
- Tracking/Wheel Alignment
- Measuring HP at the flywheel (or estimating)
- ecu to dizzy swap?!?!? help!
- Escort Cosworth Steering Wheel Problem
- Puma Heater Problem - Please help as is quite urgent !!
- --HELP-- Cosworth --HELP--
- Strange handling on Mk2 XR2
- cruise control not working
- just cant find reley
- mondeo ST220 mods in hampshire
- rs turbo clutch
- engine swap
- Idle prob on Escos.....
- quest aboutr rs turbo sunroof
- Crank pulley
- HELP! Gearbox problems
- non starter aaaaaaaaggghhhhh
- Fiesta mk6 alternator noise
- Bleed nipples
- stereo wiring
- Will XR2i Head fit a Fiesta Rs Turbo MK3
- Focus fault code
- mk6 escort fuse box
- focus lowering
- will frst turbo fit on erst s2 (watercooled)??
- XR3I TURBO CONVERSION please help
- Cutting springs... HOW dodgy?
- Bosch/Lucas Distributors - swapping them over
- Do i need a amal valve????
- tuners? what could you get out of a Sport KA 1.6?
- cosworth mising can you help???????
- toad ai606 alarm
- beige injectors
- my saph
- help needed brakes?
- Mobile auto electrican needed
- plz help ma car running like shit!!!!!!!
- feeler gauge conversion
- help needed or advice oil and petrol mixing together (cossie
- Best place to go for uprated injectors ??
- Are S1 and S2 Manifolds the same?
- drain tube ??
- Stereo Question....
- Would These Fit A 1600CVH?.....
- Focus Gearbox
- smoking
- Need new clutch
- Tapping noise
- can't get a speedo cable
- Tyre wear
- Filling little hole in bumpers & arches???
- oil light flickering when idling
- missfire problem
- Cheapest superchip dealer to flash/re-set chip?
- Having trouble selecting gear.
- zetec no spark
- front bumper removal
- Brake line size ?
- tuning a yb
- n/a 2.0 ZVH ?
- help with immobilser
- What gearbox oil for 4x4 saff
- Streetka alarm problem
- What flange? And where from?
- metering unit
- escort mk4 1.4 auto auto - manual?????
- Fiesta Turbo julting and being a pain in the ass
- 1999. Fiesta Zetec 1.25 - Big-end bearings question.
- SQUEEKY BRAKES
- Anybody Good With Wiring?
- Which intercooler?
- idleing problem
- alarm problem
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- turbo fitment
- cts
- Omex Management
- rs focus wheels on 1.8 focus
- Help With A Part Number Please
- What 2.0 blocks fits the MK1 Zetec-E?
- Cossie Engine Oil
- mk6 dials, conversion to the GIT dials. please help.
- Power Steering
- Turbosmart E-boost control problem
- How do you remove a viscous fan?
- stainless flexi hose fitment????
- Turbo smoke
- efi co pot question
- White/blue smoke
- frst engine sensor testing
- frst custom intercooler help
- 3door wheel wobble
- ignition problem - tempremental
- Rad
- Mk 3 escort stud pattern
- S2 holds back ???
- 3 door , wet carpet ? help
- Were T3's on 1989 Sierra Cosworths water-cooled?
- Gearbox to suit 460 in F100
- Head gasket??
- S2 misfire
- Brake servo escort mk4
- escort mk6 stub axles.
- boost gauge connection
- COULD BE A SILLY QUESTION BUT.....
- Tuning a 2wd
- Cossie front crankshaft seal/crankshaft dimensions
- series 1 van not boosting well
- gearbox oil
- Fuel gauge
- heating up
- Pectel monitor connectoin
- cosworth oil grade
- XR4x4 front brake upgrade?
- Cutting out-1800 zetec xr2i
- Spray pattern KE injectors
- 4x4 cossie front wheel bearing dust seals...
- boost controller
- xr2 t3 upgrade
- what size thread on egt bung on turbo housing
- st brake hubs
- S2 RS TURBO LOOM PLEASE HELP
- ERST oil return pipe to block??
- Escort rear bumber dimensions MK7
- Rear Arms
- rear poly bushes saff cosworth
- s2 header tank leaking, advice please
- wire rung block
- Coil Springs
- RST judders under braking
- ARP stud nut kit
- Quick help please, Escort 1.3
- Want a new engine...
- Sapphire Cosworth rev.counter
- S1
- air tec intercooler
- 1.0l OHV Fezzie engine
- Rev counter
- Mk5 escort wont start
- Cosworth ABS
- non starting s2..
- Cossie Rear Wheel Allignment
- zvh psiton identification??????????????help
- poor idle on zetec
- changing from mfi to efi
- Rotating the Zetec Head
- ignition lights staying on even when key removed
- Sintered clutch - slipping?
- strenghting a bodyshell
- Pictures
- Clutch
- zvh headgasket??????????? conversion questions???? help plz
- frst servo and master cylinder
- Escort Cosworth brakes fitment to a S2 RsTurbo
- Amal Valve switched live feed is faulty/no juice help please
- Injector flow rates
- What colour is my old car?
- non starting rst
- zetec s conversion
- CPS - Cos...
- erst corse plug .HELP
- frst running problems
