- 07 1.8 ford focus engine hesitating at low revs
- i need a turbo upgrade help!!!!!
- s1 lsd
- can this cvh head be repaired or is it scrap
- Zetec wiring/ loom Q
- saph 4x4 cosworth compression strut
- cvh efi mfi questions
- master cylinder
- efi erst ecu question
- cosworth manifold
- do 12 ohm fuel injectors work on standard cos ecu?
- Brakecaliper dustseals
- water temp sender
- new alarm
- s1 electrical
- steering movement inhibitor lock to lock
- Draining coolant Escort Si mk6
- T3 questions
- cossy exhaust manifold studs
- Resetting Fiesta Mk6 engine computor
- YB 200 or 205 need advise...
- mk5 lower suspension arm bushes
- length of a cosworth
- escort van / escort saloon
- rs turbo head help
- Garrett T3 problem
- erratic revving cosworth
- Galaxy 1.9 TDi (2005) Auto box dipstick+fill location?
- twin fans for grs
- s1 non custom
- electric windows
- mk2 fiesta rear brake drum assembly
- Getting a stable vacume reading on carb per cyl
- Water injection question
- engine builders help required
- how much boost
- please help...
- antifreeze
- fiesta gear box nightmare
- intercooler
- fuel guage wiring.
- IB5 SHAFT IN BC G/BOX????
- Battery Drain
- Replacing Radiator
- knackered injector
- Hot engine
- XR2I Turbo
- ZVH Experts ??
- need your help guys please
- Speedometer
- rst series2 pinking
- 1.6 cvh running problem
- Focus 1.8 zetec speedo dropping to zero
- Ford focus over-revving
- help escourt zetec
- Recovering My Cossy Dash
- immobiliser probs on mk6 escort
- RS TURBO GEAR BOX???????
- Brakes
- The weirdest problem i have ever seen. Your thoughts please
- turbo engine help.........
- cossie map sensor anyone know part number of 5 bar ?
- mk 5 rs2000 engine into mk6 escort gti help needed
- My RST eats batteries for breakfast.....
- Got a problem with the rear end of the GTi
- T34 Hybrid, where to get checked over?
- FRST Waterpump
- Ford fiesta Tunning ?
- Ohh please help before I tourch my car....CVH / blowback????
- My Escort Cosworth
- callipers the same as cossie 4x4
- injector loom
- erst Oil Feed help
- escort m4 boot builds?
- escort cosworth 1993 running problem
- frst breathing system
- does this spec sound anygood/strong?
- engine missfire
- Right camshafts for my Sierra Cosworth gr. A rally car
- boost controller
- Problems with volts from the battery
- Vin Plates
- efi conversion
- escort MK 4 1600 CVH exhaust choice? Need Help!!
- frst fuel pressure reg pipe
- 2.5 v6 duratec in a mk4 cab?
- ST170 Brakes
- best inlet manifold for big bhp 2wd or 4x4 are there any dif
- fuel pressure on cosworth
- HEEEEEEEEEEEEEELP !
- leads which way
- erst not boosting
- OFAC EFi problems - won't run with CTS connected
- Rev counter help
- compression test??
- solid lifters
- Lambda sensor
- boost controller
- Zetec ecu connector plug-(megasquirts) function of each pin?
- fitting centerlocking wheels
- boost controller
- Knocking noise from my S2
- superchip
- Header Tank
- swapping engine
- escort high temp!!!!
- a quick cossie boost question
- Wiring/relay diagrams?!?!
- Ford OBD2 protocols
- what are 'stages'
- Cosworth Plugs
- bumper trim
- help needed calling all rs1600i owners
- mk3 escort dash
- Advice on rs turbo converion?
- Mk4 Escort E Reg XR3i ... Wet Drivers Footwell ...
- Trouble Bleeding Brakes
- General Discssion area . . . .won`t open???
- all you cvh head experts i need help
- Quick-Shift for ERST S1?
- Saff Indicators
- Focus Rs Seat to be fitted to Escort Cosworth
- low comp pistons
- abs issue escort cossie
- still missing
- ERST efi mfi engines?...........
- urgent help need tonight reg mot
- brake hose
- Ford Puma 1998 1.7i ABS and SPEEDO PROBLEM HELP!!
- will my 4x4 cluth fit a t5 box?
- cold start!
- oil turbo feed pipe problem
- idle adjustment on a cossie
- smokey exhaust
- Benefits of a tubular manifold - Escort cosworth
- Cosworth boost help
- How does a rev counter work? what input?
- M I S S F I R E !!!!!!!!!!!!!!
- Motorsport tyres, for sprint XR2.
- Cosworth radiator fan switch **FAULT FIXED**
- fiesta rs turbo gearbox
- Garrett turbo identification
- ERST wont idle
- xr3i burning oil - update
- Fuel settings on rs turbo efi
- coilovers HELP!
- fault code clearing
- My EscCos "jumps"/studders
- Mk6 Escort
- rs turbo fuel wiring
- 2wd saff electrical problem fuses blowing
- coolant sensor
- a quick question for all hard driving 2wd saph owners
- can someone help?
- Can anyone tell me what the secs ecu monitor does
- Electric Sunroof Conversion for Escort Cosworth
- Throttle bodies on a zetec, lengths????
- sierra cosworth boost hoses
- Oil blowing out of the breather
- 2 wd saff no spark
- does anybody no a good tech in the wakefiled area
- Electrical problems on mk4 escort rs turbo
- Brake master Cylinder repair kits?
- misfire is back please help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- suspension query
- good tunner needed
- Group A...?
- bc gearbox
- Racetech oil press/temp gauge fitment on sierra cosworth
- fuel tank removal on a sierra sapphire 4 x 4 cosworth
- is this turbo no good(pic)
- 4x4 backfire/misfire/revcounter
- fuel pump??
- 1.8 zetec Turbo Conversion
- S2 RST Master cylinder to servo seal???
- Zetec blowing oil out of breather
- t5 to v6
- Sierra hub options
- my mate s2 rs turbo is boosting early ?
- turbod st170 kit car
- 4X4 COSWORTH SAPHY BLOODY FANS
- zvh gearbox...help
- coilpack
- Burning oil :( Out of ideas...
- Focus RS air intake temp sensor
- Smokey sierra
- 3 door cosworth buying
- inter cooler
- COSSIE TAPPETS PROBLEM
- P8 ECU dizzless????
- XR3 headlamp washers!
- yet more problems with car!
- Zetec starter on CVH
- Cosworth Starting problem...
- running in a new engine
- anti-lag
- 3 point seatbelt for Mk4 Cabriolet
- fiesta stereo
- as crude a way as it is
- Timing adjustment
- fiesta turbo cuts out under boost
- Leaking focus!
- Diff Problam
- UPDATE Sierra Cos4X4 won't run after install Pectelboard+330
- New member - Problem with Mazda 121 (Ford Fiesta) heater
- 3 dr rear wheel sizes
- COSSIE BOOT SPOILER
- cam shaft removal on erst
- Anyone heard of a supercharger for a mondeo st200??
- st170 inlet question
- starter motor wont fit?
- bonding on a widearch cossie kit
- wiring in ERST in place of CVH (mk5)
- EFI conversion on S1? pin2 edis?
- missfire problem
- Mk1 XR2 problems
- Help ka has sprung aleak!!!
- Brakes Upgrade for RST
- Cossie Prop Shaft Bolts
- more aesthetic than technical !!!
- 2wd saff temp guage not working
- Are 5w and 0w oils too thin?
- S2 RS Turbo Speedo Clocks
- SAFF COS CRANK PULLY.
- help mk6 escort steering probs
- help with kw and ps horse power ratings
- wheels
- Car wont fire up, camshaft problem? help!!
- Focus ST / RS 5cyl Engine - 300bhp Atmo Build
- where are the zetec timing marks?
- S2 turbo oil return pipe
- New standard clutch will it be ok with
- ZVH conversion....whats best way to go about it ??
- turbo damper?????
- My Pumas lost its power and revs keep down too low
- 1987 Mk4 (MFi) XR3i Starting issue ... strange ...
- blue smoke
- oil seperator
- Dragging brakes?
- engine problems!
- engine missfire
- DTC error code P0170 - What does it mean?
- non running series 2
- 3-dr smoke only when pulling away
- Stutter on acceleration
- broken connector.
- escort rs turbo over fuelling
- data logging
- 1.8 to 2L zetec conversion
