PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. MK2 RS 2000 COSWORTH
  2. Mk5 EFI Escort fuel pump sucking up air when cornering....
  3. Wheels????
  4. suspension????
  5. hi, spec calipers/4 pots
  6. Ford Escort 1.8TD 1993 replacing gear knob
  7. supercharging.... would i need a new cam?
  8. 1985 XR3I
  9. Mk3 Mk4 Parcel shelves - Interchangeable??
  10. escort coswoth fuel pump location
  11. odd lambda problem..
  12. This post can be deleted
  13. This post can be deleted
  14. No reversing lights on mondeo?
  15. S1 intermittent missfire / AFR drop
  16. What is the safest stable bhp you could run an MFI setup
  17. 3 DOOR COS AND HAVE A FLAT SPOT IDLE TO 2500RPM ANY HELP?
  18. cone air filters
  19. can you have too much oil pressure?
  20. dial lights.
  21. Cossie ECU id, who chipped it
  22. Strange noise on Mk5 fiesta
  23. Cossie Driveshaft Lengths
  24. escort cosworth 1993 backfire
  25. rear beam removal
  26. main prop removal
  27. cossie misfire
  28. escort cossy f/d/s drive shaf snaped
  29. fitting RS500 3dr cossie wheels to a s1 erst
  30. Door Card Removal
  31. turbo sounds missie and lumpy <help>found out y
  32. Wobbly pedals - escort rs turbo. any help really appreciated
  33. overheating doing my head in
  34. Misfire during boost
  35. compression on a 2.0 zvh ????
  36. urgent please help
  37. 3dr rear beam - to 2wd sapph
  38. Which air filter - Series 1 RS Turbo
  39. 2.0 16v Si-Help needed
  40. Mk3 cab MFI conversion to EFI?
  41. Another mk4 / 3 question
  42. help please will this be ok???????
  43. split rims
  44. Exhaust Gas Recirculation - WRC
  45. ERST Electrical fault
  46. cossy 4x4 problem
  47. quick`e on small turbo escort cossie crank pulley ...
  48. XR2I 16V cutting out!
  49. XR2I 16V cutting out!
  50. Ford racing boost gauge and rev counter/shift light
  51. poor running focus
  52. bloody 3dr brakes
  53. low comping s2.
  54. cossie is ratlling a bit when is cold.
  55. Series 1 that will not run for long
  56. Fuel pressure HELP PLEASE!!
  57. THE START INTERESTING TOPIC EVERY DAY-HISTORY-GARTRAC TODAY!
  58. ERST boosting problems
  59. Turbo ing a Mk5 Cortina
  60. Distributor problems - S1 Esc ort RS Turbo. Sensor broke
  61. mk4 into a mk3
  62. Escort Cosworth - Diff ratios HELP!!
  63. 6 pot willwoods
  64. Mk5 fiesta brakes
  65. juddering coming from the back?
  66. 2.8efi and 2.8 mfi
  67. Clutch/ gearbox help!!
  68. Will a S2 gearbox fit a S1
  69. Saphire ignition maps
  70. ST170 Box/Clutch Questions
  71. 3 door abs not working
  72. xr3i mk4 efi
  73. lambada sensor 2wd sapphire
  74. knocks and rattles!!!!
  75. RS2000 rear hubs
  76. What alternator set-up on zetec??
  77. Remove rear wheel drum
  78. Puma 1.7 - need workshop manual and timing gear?
  79. Gearoil F.A.Q'S
  80. fezzy mk 2 brake conversion
  81. NEED SERIOUS ADVICE! PLEASE HELP!!!!
  82. rs turbo crank.......
  83. motor transplant
  84. will these calipers fit?
  85. Water temp? Escort Calypso 1997 August
  86. thanXXs
  87. Dipstick tube on my xr3i
  88. 1.6 mk6 zetec escort into a mk 4 escort
  89. How to tune a cosworth stage 3 ?
  90. my lickkle ka!
  91. xr3i rev gauge
  92. zetec mahle pistons quick question
  93. Zetec Pulse Air Pipes
  94. cooling mt75 viscous coupling
  95. Replacing RST rear wheel bearings????
  96. xr4x4 and saph cossie brakes
  97. fan relay
  98. Clifford concept 650 alarm w/Blackjax
  99. OverHeat problem!
  100. whats the difference???
  101. t3 how much is this worth???
  102. arp mainstuds is this right?
  103. wiring
  104. ecu
  105. Focus ST170 Engine Turbo or Throttle Bodies?
  106. 1.8 zetec
  107. RS2000 MK5 VAN CONVERSION
  108. t35 turbo
  109. cosworth boot light ??
  110. mk3 escort cabriolet 1.6i cutting out and running rough
  111. t34 turbo with external wastegate
  112. Greddy PRofec B-Spec II Boost Controller
  113. nitrous
  114. Rs turbo clutch
  115. new headgasket/still overheating
  116. tyres sizes and 4wd
  117. Black jaxx alarm
  118. informing dvla a bout turbo engine
  119. escort xr3i tuning and bhp improvement
  120. Wheel fitment for a Focus
  121. Ignition module wires
  122. Oil Cooler??
  123. blown fuse
  124. timing up 2wd engine
  125. converting xr3i efi cabby wit a fezzy turbo engine
  126. no fuel
  127. Sound deadening
  128. Backlash on RS2000 4x4's
  129. escort rs turbo head gaskets
  130. will an xr2 take...
  131. 2wd cossie won't start or charge unless on jump leads
  132. rs turbo loom plz help
  133. possible mt75 gearbox trouble
  134. wireing diagrams for a focus rs please!!!!
  135. removing wheel studs?
  136. s1 turbo brakes
  137. starting problem please help im unsure.
  138. knocking noises from rear of mondeo tdci
  139. tacho
  140. 4x4 Sapphire cosworth - power steering pump leak
  141. rs turbo earth
  142. Benifits of a 2.0 zetec bottom end compared to 1.8
  143. wiring diagram's
  144. decat on st170
  145. still need help on cossie running on 3 cylinders
  146. quick simple question
  147. Car wont start :-( ignition question
  148. xr3i rev counter
  149. cossie 4x4 running on 3 cylinders
  150. st 170 erst brackets???
  151. Electronic boost controllers
  152. Servo pipe
  153. Puma with idling probs
  154. auto electrition
  155. Timing belt
  156. mk4 3i/rs sunroof stuck
  157. Change CO emission S2
  158. s1 rs turbo brakes
  159. change escort wheel baring
  160. 4x4 saff cossie abs
  161. pinto conversion mk1 fiesta
  162. new fault
  163. rpm-counter on aftermarket management???
  164. Fan never stops on 3door ..ANY OTHER IDEAS????
  165. 285t2 cam/xr2
  166. manifolds
  167. Specialists, where?? Surrey, berkshire,
  168. Crank sensor gap
  169. what would happen if....
  170. s2 water hose
  171. Mk4 Escort front suspension
  172. Front drive shaft inner CV Joints 4x4 cossie
  173. Engine mounts, 4x4 - Saff best way to fit?
  174. Lambda sensor question
  175. zvh cossie managed air filter
  176. inter cooler
  177. removing power steering pump help please
  178. bosch 403 grey fitting help
  179. What are these ?
  180. Any opinions on running in an engine
  181. mk3 escort brake upgrade
  182. throttle bodys 4 1.6 zetec s
  183. s2 rear brake discs
  184. Head Gasket?
  185. whats wrong with my brakes??
  186. Long Stuuded Cosworth Block
  187. gearbox change or not???? need help
  188. ok
  189. power boost valve
  190. Motec ecu into a saph cosworth
  191. Anyone with early ford without wing repeaters!
  192. help pics needed
  193. mk 3 escort engine swap..
  194. Paint
  195. What flywheel??
  196. cossie rs 500 cooler
  197. funny noise on 1.6 zetec
  198. 1.8 zetec 16v
  199. big disc convertion/escort cosworth
  200. Oil Burner S1 RS Turbo. Not a diesel!!!
  201. uneven tickover when cold
  202. escort gti temp guage
  203. escort mk6, 1.6 16v to 2.0 16v
  204. 4x4 power steering problem
  205. Oil Leaking from Rear Seal on Cosworth T5 Gearbox
  206. Cosworth Flywheel
  207. Escort Turbo Diesel Power.
  208. Running Issue S2
  209. fiesta brakes
  210. Distributor on a 3dr
  211. xr2 brakes
  212. Series 1 & 2 Cylinder Heads,Is there any difference
  213. Help on NEW project
  214. fuel problem Escort RS-Turbo S2
  215. capri 2.8 wont start!!
  216. GOT SMOKE? part 2
  217. Clifford Concept 100 G4 Wiring Diagram
  218. S2 Turbo Charge Cooler or Frontmount?
  219. s2
  220. Fitted Koni's to S2, Need a definitive answer!!!
  221. FORD ORION TURBO???
  222. water pipes and breaathing pipes
  223. S2 Dash Lights
  224. Power steering pump
  225. DOOR POPPERS. CONFUSED!!!!!!!!!!
  226. Over heating
  227. help on turbo conversion
  228. How to change a Wishbone ? Mk 4 Escort
  229. No fuel at the injectors
  230. boot vents
  231. modaeo tdci- glow plug warning light flashing--help
  232. Cossie crank pulley bolt question?
  233. How much power from a Zetec?
  234. s1 lower track control arm question ??
  235. NO BRAKES
  236. problems
  237. what stage turbo?
  238. no spark on my s1
  239. my p reg mk6 escort efi
  240. 2wd Cosworth rear diff question...!
  241. wheel bolt problem
  242. Clutch and flywheel removal
  243. presure in the cooling system?
  244. no ignition erst
  245. Rs Turbo conversion problem
  246. Who Knows Their Escort Gearboxes?!
  247. rover
  248. Hydraulic lifters...Bulging???...Anyone know why..
  249. fuel filter change....
  250. Gearing for 1/4 miles
