View Full Version : Technical help Q & A
- steering colume s1
- Can I fit
- dumpvalve delay
- puma injector flow rates?
- 2.0 Zetec in a MK3 Fiesta
- 2wd..4wd diff ??
- Zetec EFi manifold onto cvh?
- paint code help
- Escort GTI fuel pump problem
- flat spot
- bilstein damper
- lightweight
- s1 wireing
- mondeo tdci 115ps calibration numbers!!
- frst just had rebuild now smoking
- Escort Cosowrth Lighting Wiring Diagram
- changing alternator on a transit
- Correct fuel pump to use? (mk5 Escort for ZVH EFI Turbo)
- oil pressure gague
- Turbo Technics cvh turbo conversion??
- charging problem
- minimum YB head thickness????
- Sierra (etc) 1.8TD tuning
- turbo worries
- Brembo calipers
- how well would this work
- MOT question
- cosworth cam question
- idle problem
- RE-SHELL
- Does anyone know......ECU
- Attn Flux capacitor RE 0-5v sensor outputs??
- Mk5 1.25 Fiesta Airflow Meter
- Mk5 fiesta digital dash
- escort mk6 1.4 cvh efi rough idle and poor mpg
- Petrol needle not working on mk3 escort turbo conversion
- amal value and actuator
- Anglia handling!
- sick rst s2
- mk 6 escort 1.8si
- 1990 MK4 Escort XR3i EFI Radiator-Where Can I Get One?
- 17 inch diamond cut cossies fin codes for wheels
- Can i use these?
- Seat swap from 4x4 cossie into s2 RST
- Reset Engine computor
- Cylinder head flatness tolerance
- Lambda/ O2 sensors?
- saff bonnet on hatch back sierra
- Diesel MPG and remap - FAO STU if you're around?
- GT2871R on a YB??? look inside ;)
- Zetec throttle bodies
- AFR---Lambda-----Co%----...????
- 4x4 rear driveshaft nut question
- anytone got pics/links to engine mount mods for zt in mk esc
- new turbo fitted and now no usable boost till 6k+
- best 4 / 5 bar map sensor to use?
- 2.8-2.9 v6
- does anyone know of a decent upholster?
- Towbar Removal
- What boost for 400bhp??
- do rover turbo inlets need modding for a zt in mk3 escort?
- front bumper removal
- Exhaust Differance's
- Do you know anyone that rebuilds starter motors in essex?
- What is the benefit of solid bar compressionstrut??
- Recognise this map sensor?
- Exhaust diamaters? Help!
- ebay tubaler manifolds for zetec? anyone had one? opinions?
- Fiesta Heater Blowing Cold
- Central locking locking then unlocking on saph cossie
- CVH into Ka
- 2wd sapph advice
- cozzy brakes on s2 rst
- ZVH Questions
- prices to grind crank and balance with rods and pistons?
- zt inlet question
- RS steering wheel boss
- head work is there much point?
- Central locking fooking around - UPDATE: What would you do?
- Turbo Timers -HHHHHEEEELLLPPPPP!!!!!
- turbo timers
- Head work
- any vauxhall experts.....oil pump drive question
- 205 block differences
- Noobie question
- Dumpvalves
- Help!
- Cold weather Problems
- Map sensors
- S1 Cold start problems
- Removing S2 ABS quick Q
- fueling prob
- Zetec-S
- Fiesta turbo still stuttering! Help!
- drive shaft
- Air Injector Part Number
- dug kiddy ,2.2 cosy,crank
- Aeromotive Fuel Pressure Regulators.
- please delete
- Mapping in the Berkshire Area
- brake pads for the REAR
- help
- help
- can someone please help!!!
- what dia of ext wastgate do yous use when over 600bhp?
- Track Day Wheels
- efi xr3i and frst head
- spacing between cvh exhaust ports
- How to work out turbine housing sizes on HOLSET turbos?
- S1 - S2 fuel pump relay and wiring swap
- st170 help ?
- tappety s2
- Please help air filter
- Focus ST engine into XR2?
- Engine Number Location, i4/RS2000 engine?
- master cylinder (help)
- 2.0 zetec into a mk3
- Anyone understand compressor Maps?
- st170 dis lever?????
- who has an Aeromotive Fuel pressure reg?
- messing with dervs! ha
- Speedo wobble?
- Exhaust Gas pipe? Where the hell has it gone?
- Flurosilicone Lined Silicone Hoses
- would 18" escort cosworth wheels fit on my 3 door coswo
- RST Idle
- Zetec Heads
- RS 500 BUILD NUMBERS
- YB runs for 10sec then cuts out- fuel reg problem SORTED!
- whats the max boost for small turbo engine????
- Mondeo not starting
- wheelnut question
- ford capri, a worthwhile restoration??
- Bushes
- Ford sierra cosworth jack, 4x4
- Fuel pressure regulator
- fuel piping ?
- Saf Cos- ABS light on, will it fail MOT if ABS bulb removed?
- pressure reg
- Is it necessary to have an uprated fuel pump over 400bhp?
- question about a 4x4 sierra conversion
- disc carriers
- S2 EFI convertion. Tech Discussion?
- Cosworth 2wd Coilovers
- turbo
- petrol gauge
- fit mtx75 s2 turbo
- 4 wheel drive problems
- Escort mark 5 charging cable
- Custom made glass?
- noisy lifter ?
- My First Car - Battery Problems
- Escos Dash
- Fiesta efi & Escort efi
- Cossie Managment Question
- Custom perspex windows
- 85 xr3i
- noisey cam and tappets
- tyres- which do you use/reccomend
- I want a ZVH Built for me.....
- Street Ka Tuning
- Zetec / Zvh turbo info required please
- cosworth cams
- escort cos banana pod wiring
- escort cosworth leather seats into a mk5 escort
- puting a cossie t3 on a s2 turbo any ideas
- Mapping with a Wideband..
- cossie idling issues
- best camshafs for cosworth on 34mm restrictor?
- ignition timing
- 24v starting problems, please help
- rose joint dust cover
- Normal sapphire hubs will cosworth shocks fit ?
- innovate xd16
- Road wheel sits further back on one side!
- rsi turbo conversion
- zetec turbo help
- bar to psi?
- Ka engine swap to something bigger
- new 2.0 zetec blocks ??
- What type of clutches for over 500bhp 2wd and 4wd?
- Ford Explorer..............
- Procedure for bleeding cossie brakes?
- Tyres sizes on 17" alloys
- My daily Hack- Tech Q??
- cosworth conrod weights
- FRST not starting!
- FRST STOLEN, NOW I HAVE TO FIX IT
- seats swop mk6 into mk5
- Fiesta RS- do these sills need welding????
- Somebody use KnockLite for knock monitoring?
- S1 RS Turbo AFR Results
- diesel leak
- cosworth conrod weights?
- rev counter for coil pack UP DATE ITS SORTED
- what do i need
- torn between two cars?!?! help!
- Zetec Heads, Are they interchangeable?
- service light
- turbo help
- oil pressure
- Newbie here
- Strong Fuel Smell???
- how to adjust the cosworth TPS?
- Bloody car 3 door)
- zetec in a sierra...wont start?????
- please please help frs wont start!!!
- 3 door rs cosworth head lining
- REV COUNTER
- hydraulic handbrake help!!!!
- top left engine mount - mk3 1.1 fiesta
- Fiesta RS turbo missing, changed plugs, what next?
- problem injectors help plz
- water thirsty transit
- Confused about spark plugs
- RS COSWORTH REBUILD
- no spark S1
- hd enough rebuild due
- erst boost problem
- Inovate motorsport gauges
- big end bearing codes?????????
- oil rings
- what grade of oil
- big turbo escos pistons
- engine rebuild
- TPS sensor
- Colour Code
- cut at 20 psi , heellppppp !!!!
- T3 TURBOUPGRADE S2
- removed egr now a problem.
- VNR 9000
- gt35 turbo need help
- Engine Transplant
- cossie cutting out
- mk6 clocks.
- running problems on my fiesta turbo efi engine
- AFR levels
- Street KA uprated Brakes Need Help
- clutch problem
- max boost on ofac map sensor
- mk6 si e/w motor
- High impedance injectors
- SERIES 1 RST Full load enrichment fault.
- Cossie ECU, Which one??
- focus rs brakes under 15's?
- standing rst
- what kind offuel pump do i need?
- Dashboard cracks
- smoothing bumper strip lines
